0013757 | ParaView | (No Category) | public | 2012-12-24 15:20 | 2015-01-11 08:28 | ||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013757: String arrays with whitespace endup showing up with weird separation in SpreadSheet view | ||||||||
Description | Load attached file and look at the point data in SpreadSheetView. You'll see that the "Strings" array has extra spacing between "Hello" and "World". There should just be 1 space. | ||||||||
Project | Kitware | ||||||||
Topic Name | 13757_string_arrays_in_spreadsheet | ||||||||
Attached Files | sample_data.vtk [^] (169 bytes) 2012-12-24 15:20 | ||||||||
(0029945) Utkarsh Ayachit (administrator) 2012-12-24 15:22 |
commit 49d1d0e5a0e23878f7307ee9ece2ffcd3ce1e550 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Dec 24 15:20:52 2012 -0500 BUG 0013757. Fix spacing in string arrays in spreadsheet view. Ensuring that we don't replace all " " with "\t" in spreadsheet view when dealing with vtkStringArray values. Change-Id: I3e9cd7be87d3bf0428197edc547a063f7ebea865 |
(0029946) Utkarsh Ayachit (administrator) 2012-12-24 15:37 |
User Request: Also, when embedding a variant array (when the variant itself is a vtkObject) as field data it displays many errors "Cannot convert to string". Would it possible to just display the vtk object type? |
(0029947) Utkarsh Ayachit (administrator) 2012-12-24 15:41 |
commit 2cd8567db0aff2d001411b4eaf5f860e0b03eee6 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Dec 24 15:40:15 2012 -0500 BUG 0013757. Added logic to show Variant arrays with object ptrs. Added logic to show vtkVariantArray with vtkObject* correctly in spreadsheet view. Change-Id: Ia56244165970c9c435a75ae90852dee10f38f350 |
(0029948) Utkarsh Ayachit (administrator) 2012-12-24 15:42 |
To test variant arrays with object pointers, create a point source with a single point and then apply the Programmable filter with the following code and look at the result in the spreadsheet view. output = self.GetOutput() val = vtk.vtkObject() v = vtk.vtkVariant(val) a = vtk.vtkVariantArray() a.SetName("Variants") a.SetNumberOfTuples(1) a.SetValue(0, v) output.GetPointData().AddArray(a) |
(0029954) Utkarsh Ayachit (administrator) 2012-12-25 08:44 |
merged into master. |
(0030054) Alan Scott (manager) 2013-01-10 19:29 |
Tested windows, master, local server. |
2012-12-24 15:20 | Utkarsh Ayachit | New Issue | |
2012-12-24 15:20 | Utkarsh Ayachit | File Added: sample_data.vtk | |
2012-12-24 15:22 | Utkarsh Ayachit | Topic Name | => 13757_string_arrays_in_spreadsheet |
2012-12-24 15:22 | Utkarsh Ayachit | Note Added: 0029945 | |
2012-12-24 15:22 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-12-24 15:22 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-12-24 15:22 | Utkarsh Ayachit | Resolution | open => fixed |
2012-12-24 15:22 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-12-24 15:37 | Utkarsh Ayachit | Note Added: 0029946 | |
2012-12-24 15:41 | Utkarsh Ayachit | Note Added: 0029947 | |
2012-12-24 15:41 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-24 15:42 | Utkarsh Ayachit | Note Added: 0029948 | |
2012-12-24 15:45 | Utkarsh Ayachit | Status | customer review => gatekeeper review |
2012-12-25 08:44 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-12-25 08:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-25 08:44 | Utkarsh Ayachit | Note Added: 0029954 | |
2013-01-10 19:29 | Alan Scott | Note Added: 0030054 | |
2013-01-10 19:29 | Alan Scott | Status | customer review => closed |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 37c17453 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 2cd8567d |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 49d1d0e5 |
