0013774 | ParaView | (No Category) | public | 2013-01-08 16:55 | 2016-08-12 09:59 | ||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0013774: Plot global variables over time not initialized correctly | ||||||||
Description | The plot global variables over time filter is not initialized correctly. To see this, do the following: * Master, Linux, remote server (I am sure local server shows it). * Can.exo, all variables on, apply. * Plot global variables over time filter. (Nothing will show up.) Apply. >> Bug - nothing shows up in the 2d window. Something should be initialized here. * Select Unnamed block ID: 1 Type: HEX. Stuff now shows up. * Unselect everything in the Element Blocks that you selected above. >> Bug - Stuff still shows up in the 2d window. But we should be displaying nothing! | ||||||||
Project | Sandia | ||||||||
Relationships | |||||||||||
(0033959) Utkarsh Ayachit (administrator) 2014-12-14 12:34 |
The problem is oddly related to incorrect marking on "partial arrays". If you look at the "Information Tab" for the "PlotGlobarVariableOverTime" filter, you'll see that all/most variables are marked as partial. |
(0036090) T.J. Corona (developer) 2016-06-21 09:33 |
I cannot replicate this issue on OS X, local server |
(0036093) Utkarsh Ayachit (administrator) 2016-06-21 11:06 edited on: 2016-06-21 11:06 |
Further debugging, I doubt it's related to the partial array issue (as I mentioned in my earlier comment). That's a symptom of the bug, not the cause. |
(0038311) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-01-08 16:55 | Alan Scott | New Issue | |
2013-02-06 18:12 | Utkarsh Ayachit | Assigned To | => Nikhil Shetty |
2013-06-05 16:29 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2014-12-14 12:34 | Utkarsh Ayachit | Note Added: 0033959 | |
2014-12-14 12:35 | Utkarsh Ayachit | Relationship added | related to 0015102 |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | => 4.3 |
2015-07-08 14:53 | Alan Scott | Target Version | => 4.5 |
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
2016-06-21 09:33 | T.J. Corona | Note Added: 0036090 | |
2016-06-21 11:05 | Utkarsh Ayachit | Relationship added | related to 0016099 |
2016-06-21 11:06 | Utkarsh Ayachit | Note Added: 0036093 | |
2016-06-21 11:06 | Utkarsh Ayachit | Note Edited: 0036093 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038311 | |
2016-08-12 09:59 | Kitware Robot | Fixed in Version | 4.3 => |
