0013849 | ParaView | (No Category) | public | 2013-02-01 10:00 | 2016-08-12 09:59 | ||||
Reporter | David C. Lonie | ||||||||
Assigned To | David Thompson (old) | ||||||||
Summary | 0013849: Rendering mathtext into the ScalarBar title broken. | ||||||||
Description | Text here is always rendered via freetype. | ||||||||
Project | TBD | ||||||||
(0030294) David C. Lonie (developer) 2013-02-01 11:20 edited on: 2013-02-01 11:22 |
This is because vtkScalarBarActor uses vtkTextMappers to display text. The scalar bar class will need to be ported to vtkTextActor, since the vtkTextMapper code cannot be easily ported to use vtkTextRenderer. vtkTextMapper uses ftgl to directly render the text into the opengl context, so the vtkTextRenderer approach of text-->image-->texture doesn't apply. |
(0038332) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-02-01 10:00 | David C. Lonie | New Issue | |
2013-02-01 10:00 | David C. Lonie | Assigned To | => David C. Lonie |
2013-02-01 11:20 | David C. Lonie | Note Added: 0030294 | |
2013-02-01 11:22 | David C. Lonie | Note Edited: 0030294 | |
2013-02-01 13:26 | David C. Lonie | Assigned To | David C. Lonie => David Thompson (old) |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038332 | |
