0013857 | ParaView | (No Category) | public | 2013-02-02 07:26 | 2016-08-12 09:59 | ||||
Reporter | Takuya OSHIMA | ||||||||
Summary | 0013857: Sources - Hyper Tree Grid. Crash. | ||||||||
Description | PV 3.98.1-RC1, OS X 10.6.8, CMake 2.8.10, Qt 4.8.4. Start ParaView. Sources - Hyper Tree Grid. ParaView crashes with: ERROR: In /opt/src/paraview/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 389 vtkPVSessionCore (0x10b1355e0): Object type: vtkHyperTreeGridSource, could not find requested method: "SetAxisBranchFactor" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = vtk_object_pointer {vtkHyperTreeGridSource (0x10b5c7570)} Argument 1 = string_value {SetAxisBranchFactor} Argument 2 = int32_value {2} ERROR: In /opt/src/paraview/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx, line 390 vtkPVSessionCore (0x10b1355e0): Aborting execution for debugging purposes. ############ ABORT ############# ERROR: In /opt/src/paraview/ParaView/ParaViewCore/ServerImplementation/Core/vtkSIProxy.cxx, line 486 vtkSISourceProxy (0x10b5a3e40): Could not parse property: AxisBranchFactor ERROR: In /opt/src/paraview/ParaView/ParaViewCore/ClientServerCore/Core/vtkPVAlgorithmPortsInformation.cxx, line 56 vtkPVAlgorithmPortsInformation (0x118419280): Could not downcast vtkAlgorithm. Invalid output port : pqPipelineSource::getOutputPort( 0 ). Available number of output ports: 0 Abort trap | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0038336) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-02-02 07:26 | Takuya OSHIMA | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038336 | |
