0013881ParaView(No Category)public2013-02-15 13:252016-08-12 09:59
ReporterJames Thunes
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version3.98.0
Summary0013881: Orientation axis color defaults to cyan (in OSX)
DescriptionOrientation axis label color defaults to cyan.
Changing color via Edit->View Settings->Annotation->Axis Label Color works for current session, but changes when reopened.
Operating system is OS X 10.7.5
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0030350)
James Thunes (reporter)
2013-02-18 21:31
Some additional information:
I'm using a white background.
I deleted the configuration files and reopened the program. After changing the background color to white, I set the axis label color using Edit->View Settings->Annotation. Reopening the program gave the erroneous result - the axis label color was cyan.
Changing the axis label color through Paraview->Preferences->Colors->Text Color, worked. Axis label color was black even when program was restarted.
Axis label color does not respect Edit->View Settings->Annotation but *does* respect Paraview->Preferences->Colors->Text Color. Perhaps one settings is overwriting the other in the Paraview*.ini file.
(0038343)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2013-02-15 13:25 James Thunes New Issue
2013-02-18 21:31 James Thunes Note Added: 0030350
2016-08-12 09:59 Kitware Robot Note Added: 0038343
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
