| 0013931 | VTK | (No Category) | public | 2013-03-07 23:36 | 2013-03-08 11:12 | ||||
| Reporter | Orion Poplawski | ||||||||
| Assigned To | Marcus D. Hanwell | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Status | closed | Resolution | no change required | ||||||
| Product Version | |||||||||
| Summary | 0013931: VTKConfig.cmake contains build directory path | ||||||||
| Description | VTKConfig.cmake ends up with A path that refer to the build directory that causes problems when building packages: # Load testing interface macros. -include("@VTK_CONFIG_TESTING_MACROS_FILE@") +include("/builddir/build/BUILD/ParaView-3.98.1-source/VTK/CMake/vtkTestingMacros.cmake") Perhaps need to handle more like VTK_CONFIG_CODE? | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0030418) Utkarsh Ayachit (administrator) 2013-03-08 00:11 |
I don't think this is a problem since the <VTKBinDir>/VTKConfig.cmake is meant for building projects against the build dir. We don't install this file. The file installed is <VTKBinDir>/CMakeFiles/VTKConfig.cmake which is used when building against an installed version of VTK. |
(0030419) Orion Poplawski (reporter) 2013-03-08 00:24 |
This *is* the installed version of the file: /usr/share/cmake/paraview/VTKConfig.cmake |
(0030420) Brad King (developer) 2013-03-08 07:37 |
This was resolved in VTK master here: http://vtk.org/gitweb?p=VTK.git;a=commitdiff;h=bf3c1599 [^] |
(0030421) Marcus D. Hanwell (developer) 2013-03-08 11:12 |
As Brad pointed out, this was already fixed in VTK master. |
(0030422) Marcus D. Hanwell (developer) 2013-03-08 11:12 |
Closing, resolved in master already. |
| Notes |
| Issue History | |||
| 2013-03-07 23:36 | Orion Poplawski | New Issue | |
| 2013-03-08 00:11 | Utkarsh Ayachit | Note Added: 0030418 | |
| 2013-03-08 00:24 | Orion Poplawski | Note Added: 0030419 | |
| 2013-03-08 07:37 | Brad King | Note Added: 0030420 | |
| 2013-03-08 11:12 | Marcus D. Hanwell | Note Added: 0030421 | |
| 2013-03-08 11:12 | Marcus D. Hanwell | Status | backlog => tabled |
| 2013-03-08 11:12 | Marcus D. Hanwell | Resolution | open => no change required |
| 2013-03-08 11:12 | Marcus D. Hanwell | Note Added: 0030422 | |
| 2013-03-08 11:12 | Marcus D. Hanwell | Status | tabled => closed |
| 2013-03-08 11:12 | Marcus D. Hanwell | Assigned To | => Marcus D. Hanwell |
| Issue History |
