0013946 | ParaView | (No Category) | public | 2013-03-15 04:47 | 2016-08-12 09:59 | ||||
Reporter | Joni-Pekka Kurronen | ||||||||
Product Version | 3.98.1 | ||||||||
Summary | 0013946: when VR start button pressed then crash, libVRPlugin.so: undefined symbol | ||||||||
Description | /mpi3/C2/ParaView2/lib/paraview-3.98/paraview: symbol lookup error: /mpi3/C2/ParaView2/lib/paraview-3.98/libVRPlugin.so: undefined symbol: _ZN19vrpn_Tracker_RemoteC1EPKcP15vrpn_Connection === paraview # This is the CMakeCache file. # For build in directory: /mpi3/S2/ParaGit-BBUILD2 # It was generated by CMake: /usr/local/bin/cmake # You can edit this file to change values found and used by cmake. # If you do not want to change any of the values, simply exit the editor. # If you do want to change a value, simply edit, save, and exit the editor. # The syntax for the file is as follows: # KEY:TYPE=VALUE # KEY is the name of a variable in the cache. # TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!. # VALUE is the current value for the KEY. ######################## # EXTERNAL cache entries ######################## //Dependencies for the target AnalyzeNIfTIIO_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Dependencies for the target ArrowGlyph_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Build the VTK documentation BUILD_DOCUMENTATION:BOOL=OFF BUILD_EXAMPLES:BOOL=FALSE //Build a coprocessing adaptor that can be called from Fortran // or C BUILD_FORTRAN_COPROCESSING_ADAPTORS:BOOL=OFF //Build a coprocessing adaptor that renders particle systems BUILD_PARTICLE_COPROCESSING_ADAPTORS:BOOL=OFF //Build IceT with shared libraries. BUILD_SHARED_LIBS:BOOL=ON //Build the testing tree. BUILD_TESTING:BOOL=ON //Path to a program. BZRCOMMAND:FILEPATH=/usr/bin/bzr //Path to a program. CMAKE_AR:FILEPATH=/usr/bin/ar //For backwards compatibility, what version of CMake commands and // syntax should this version of CMake try to support. CMAKE_BACKWARDS_COMPATIBILITY:STRING=2.4 //Choose the type of build. CMAKE_BUILD_TYPE:STRING=Debug //Enable/Disable color output during build. CMAKE_COLOR_MAKEFILE:BOOL=ON //CXX compiler. CMAKE_CXX_COMPILER:FILEPATH=/mpi3/C2/mpich-3.0.1/bin/mpic++ //Flags used by the compiler during all build types. CMAKE_CXX_FLAGS:STRING=-Wl,--no-as-needed -fPIC -DAdd_ -m64 -pthread -O3 -fopenmp -lgomp -march=barcelona -ftree-vectorize -funroll-loops -ffast-math //Flags used by the compiler during debug builds. CMAKE_CXX_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //C compiler. CMAKE_C_COMPILER:FILEPATH=/mpi3/C2/mpich-3.0.1/bin/mpicc //Flags used by the compiler during all build types. CMAKE_C_FLAGS:STRING=-Wl,--no-as-needed -fPIC -DAdd_ -m64 -pthread -O3 -fopenmp -lgomp -march=barcelona -ftree-vectorize -funroll-loops -ffast-math //Flags used by the compiler during debug builds. CMAKE_C_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //Flags used by the linker. CMAKE_EXE_LINKER_FLAGS:STRING=' ' //Flags used by the linker during debug builds. CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Enable/Disable output of compile commands during generation. CMAKE_EXPORT_COMPILE_COMMANDS:BOOL=OFF //Install path prefix, prepended onto install directories. CMAKE_INSTALL_PREFIX:PATH=/mpi3/C2/ParaView2 //Path to a program. CMAKE_LINKER:FILEPATH=/usr/bin/ld //Path to a program. CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make //Flags used by the linker during the creation of modules. CMAKE_MODULE_LINKER_FLAGS:STRING=' ' //Flags used by the linker during debug builds. CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_NM:FILEPATH=/usr/bin/nm //Path to a program. CMAKE_OBJCOPY:FILEPATH=/usr/bin/objcopy //Path to a program. CMAKE_OBJDUMP:FILEPATH=/usr/bin/objdump //Value Computed by CMake CMAKE_PROJECT_NAME:STATIC=ParaView //Path to a program. CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib //Flags used by the linker during the creation of dll's. CMAKE_SHARED_LINKER_FLAGS:STRING=' ' //Flags used by the linker during debug builds. CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING= //If set, runtime paths are not added when installing shared libraries, // but are added when building. CMAKE_SKIP_INSTALL_RPATH:BOOL=NO //If set, runtime paths are not added when using shared libraries. CMAKE_SKIP_RPATH:BOOL=NO //Path to a program. CMAKE_STRIP:FILEPATH=/usr/bin/strip //Thread library used. CMAKE_THREAD_LIBS:STRING= //If true, cmake will use relative paths in makefiles and projects. CMAKE_USE_RELATIVE_PATHS:BOOL=OFF //If this value is on, makefiles will be generated without the // .SILENT directive, and all commands will be echoed to the console // during the make. This is useful for debugging only. With Visual // Studio IDE projects all commands are done without /nologo. CMAKE_VERBOSE_MAKEFILE:BOOL=FALSE //Path to program used to compress files for transfer to the dart // server COMPRESSIONCOMMAND:FILEPATH=/bin/gzip //Path to the coverage program that CTest uses for performing coverage // inspection COVERAGE_COMMAND:FILEPATH=/usr/bin/gcov //Extra command line flags to pass to the coverage tool COVERAGE_EXTRA_FLAGS:STRING=-l //Enable to build Debian packages CPACK_BINARY_DEB:BOOL=OFF //Enable to build NSIS packages CPACK_BINARY_NSIS:BOOL=OFF //Enable to build RPM packages CPACK_BINARY_RPM:BOOL=OFF //Enable to build STGZ packages CPACK_BINARY_STGZ:BOOL=ON //Enable to build TBZ2 packages CPACK_BINARY_TBZ2:BOOL=OFF //Enable to build TGZ packages CPACK_BINARY_TGZ:BOOL=ON //Enable to build TZ packages CPACK_BINARY_TZ:BOOL=ON //Enable to build TBZ2 source packages CPACK_SOURCE_TBZ2:BOOL=ON //Enable to build TGZ source packages CPACK_SOURCE_TGZ:BOOL=ON //Enable to build TZ source packages CPACK_SOURCE_TZ:BOOL=ON //Enable to build ZIP source packages CPACK_SOURCE_ZIP:BOOL=OFF //How many times to retry timed-out CTest submissions. CTEST_SUBMIT_RETRY_COUNT:STRING=3 //How long to wait between timed-out CTest submissions. CTEST_SUBMIT_RETRY_DELAY:STRING=5 //Path to a program. CVSCOMMAND:FILEPATH=CVSCOMMAND-NOTFOUND //Options passed to the cvs update command. CVS_UPDATE_OPTIONS:STRING=-d -A -P //Value Computed by CMake Cosmo_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/Cosmo //Dependencies for the target Cosmo_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtksys;general;/usr/lib/openmpi/lib/libmpi.so;general;/usr/lib/openmpi/lib/libopen-rte.so;general;/usr/lib/openmpi/lib/libopen-pal.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/x86_64-linux-gnu/libnsl.so;general;/usr/lib/x86_64-linux-gnu/libutil.so;general;/usr/lib/x86_64-linux-gnu/libm.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/openmpi/lib/libmpi_cxx.so;general;/usr/lib/openmpi/lib/libmpi.so;general;/usr/lib/openmpi/lib/libopen-rte.so;general;/usr/lib/openmpi/lib/libopen-pal.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/x86_64-linux-gnu/libnsl.so;general;/usr/lib/x86_64-linux-gnu/libutil.so;general;/usr/lib/x86_64-linux-gnu/libm.so;general;/usr/lib/x86_64-linux-gnu/libdl.so; //Value Computed by CMake Cosmo_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/Cosmo //Limit of reported errors, -1 reports all. DART_BUILD_ERROR_REPORT_LIMIT:BOOL=OFF //Limit of reported warnings, -1 reports all. DART_BUILD_WARNING_REPORT_LIMIT:BOOL=OFF //If you have Dart installed, where is it located? DART_ROOT:PATH=DART_ROOT-NOTFOUND //Maximum time allowed before CTest will kill the test. DART_TESTING_TIMEOUT:STRING=1500 //Show the actual output of the build, or if off show a . for each // 1024 bytes. DART_VERBOSE_BUILD:BOOL=OFF //Should Dart server send email when build errors are found in // Continuous builds? DELIVER_CONTINUOUS_EMAIL:BOOL=Off //Value Computed by CMake DICOMParser_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/DICOMParser //Value Computed by CMake DICOMParser_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/Utilities/DICOMParser //Disable compiler warnings EXODUSII_DISABLE_COMPILER_WARNINGS:BOOL=ON //Path to Eigen install. Eigen_DIR:FILEPATH=/mpi3/S2/ParaView/Plugins/SciberQuestToolKit/eigen-3.0.3/eigen-eigen-3.0.3 //Dependencies for the target EyeDomeLightingView_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS;general;vtkEyeDomeLighting; //Value Computed by CMake EyeDomeLighting_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/Plugins/EyeDomeLighting //Value Computed by CMake EyeDomeLighting_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/Plugins/EyeDomeLighting //Path to a program. GITCOMMAND:FILEPATH=/usr/bin/git //git command line client GIT_EXECUTABLE:FILEPATH=/usr/bin/git //Path to a file. GLUT_INCLUDE_DIR:PATH=GLUT_INCLUDE_DIR-NOTFOUND //Path to a library. GLUT_Xi_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libXi.so //Path to a library. GLUT_Xmu_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libXmu.so //Path to a library. GLUT_glut_LIBRARY:FILEPATH=GLUT_glut_LIBRARY-NOTFOUND //The directory containing gmvread.c, gmvread.h and gmvrayread.h GMVReader_GMVREAD_LIB_DIR:PATH=/mpi3/S2/ParaView/Utilities/VisItBridge/databases/GMV //Dependencies for the target GMVReader_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Calculate minimum and maximum of data arrays in RequestInformation // calls. //\n A feature inherited from AVSucdReader, but it seems this // information is //\n never queried by ParaView. GMVReader_SKIP_DATARANGE_CALCULATIONS_IN_REQUEST_INFORMATION_CALLS:BOOL=OFF //Path to gunzip executable GUNZIPCOMMAND:FILEPATH=/bin/gunzip //Dependencies for the target H5PartReader_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Value Computed by CMake HDF5_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/hdf5/vtkhdf5 //Value Computed by CMake HDF5_HL_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/hdf5/vtkhdf5/hl //Value Computed by CMake HDF5_HL_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/hl //Value Computed by CMake HDF5_HL_SRC_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/hdf5/vtkhdf5/hl/src //Value Computed by CMake HDF5_HL_SRC_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/hl/src //Value Computed by CMake HDF5_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/hdf5/vtkhdf5 //Value Computed by CMake HDF5_SRC_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/hdf5/vtkhdf5/src //Value Computed by CMake HDF5_SRC_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/src //Path to a program. HGCOMMAND:FILEPATH=/usr/bin/hg //Value Computed by CMake ICET_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/ThirdParty/IceT/vtkicet //Build and run the IceT tests. ICET_BUILD_TESTING:BOOL=ON //Sets the preferred `k' value for the radix-k algorithm. This // is the amount of simultaneous messages each process receives. // A value of 8 is generally good on most architectures, but in // others that have slower computation with respect to network // (such as BlueGene), a larger value may give better performance. ICET_MAGIC_K:STRING=8 //Sets the preferred number of times an image may be split. Some // image compositing algorithms prefer to partition the images // such that each process gets a piece. Too many partitions, though, // and you end up spending more time collecting them than you save // balancing the compositing. ICET_MAX_IMAGE_SPLIT:STRING=512 //Value Computed by CMake ICET_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/ThirdParty/IceT/vtkicet //Arguments given to the test program. These are given between // the test executable and the name of the test. Run the test // executable with the -h flag to see what is available. ICET_TEST_FLAGS:STRING= //Use MPE to trace MPI communications. This is helpful for developers // trying to measure the performance of parallel compositing algorithms. ICET_USE_MPE:BOOL=OFF //Build MPI communication layer for IceT. ICET_USE_MPI:BOOL=ON //Build OpenGL support layer for IceT. ICET_USE_OPENGL:BOOL=ON //Dependencies for the target IceTCore_LIB_DEPENDS:STATIC=general;m;general;m; //Dependencies for the target IceTGL_LIB_DEPENDS:STATIC=general;m;general;IceTCore;general;/usr/lib/x86_64-linux-gnu/libGLU.so;general;/usr/lib/libGL.so;general;/usr/lib/x86_64-linux-gnu/libSM.so;general;/usr/lib/x86_64-linux-gnu/libICE.so;general;/usr/lib/x86_64-linux-gnu/libX11.so;general;/usr/lib/x86_64-linux-gnu/libXext.so; //Dependencies for the target IceTMPI_LIB_DEPENDS:STATIC=general;m;general;IceTCore;general;/usr/lib/openmpi/lib/libmpi.so;general;/usr/lib/openmpi/lib/libopen-rte.so;general;/usr/lib/openmpi/lib/libopen-pal.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/x86_64-linux-gnu/libnsl.so;general;/usr/lib/x86_64-linux-gnu/libutil.so;general;/usr/lib/x86_64-linux-gnu/libm.so;general;/usr/lib/x86_64-linux-gnu/libdl.so; //Path to java command, used by the Dart server to create html. JAVACOMMAND:FILEPATH=/usr/bin/java //Command to build the project MAKECOMMAND:STRING=/usr/bin/make -i //Path to the memory checking command, used for memory error detection. MEMORYCHECK_COMMAND:FILEPATH=/usr/bin/valgrind //File that contains suppressions for the memory checker MEMORYCHECK_SUPPRESSIONS_FILE:FILEPATH= //Executable for running MPI programs. MPIEXEC:FILEPATH=/mpi3/C2/mpich-3.0.1/bin/mpiexec //Maximum number of processors available to run MPI applications. MPIEXEC_MAX_NUMPROCS:STRING=2 //Flag used by MPI to specify the number of processes for MPIEXEC; // the next option will be the number of processes. MPIEXEC_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIEXEC. MPIEXEC_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by MPIEXEC. MPIEXEC_PREFLAGS:STRING= //Cleared MPI_CXX_COMPILER:FILEPATH=/usr/bin/mpicxx //MPI CXX compilation flags MPI_CXX_COMPILE_FLAGS:STRING= //MPI CXX include path MPI_CXX_INCLUDE_PATH:STRING=/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi //MPI CXX libraries to link against MPI_CXX_LIBRARIES:STRING=/usr/lib/openmpi/lib/libmpi_cxx.so;/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so //MPI CXX linking flags MPI_CXX_LINK_FLAGS:STRING= -Wl,--export-dynamic //Cleared MPI_C_COMPILER:FILEPATH=/usr/bin/mpicc //MPI C compilation flags MPI_C_COMPILE_FLAGS:STRING= //MPI C include path MPI_C_INCLUDE_PATH:STRING=/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi //MPI C libraries to link against MPI_C_LIBRARIES:STRING=/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so //MPI C linking flags MPI_C_LINK_FLAGS:STRING= -Wl,--export-dynamic //Extra MPI libraries to link against MPI_EXTRA_LIBRARY:STRING=/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so //MPI library to link against MPI_LIBRARY:FILEPATH=/usr/lib/openmpi/lib/libmpi_cxx.so //Value Computed by CMake MaterialLibrary_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/MaterialLibrary //Value Computed by CMake MaterialLibrary_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/Utilities/MaterialLibrary //Dependencies for the target MobileRemoteControl_LIB_DEPENDS:STATIC=general;pqComponents;general;pqApplicationComponents; //Request building AutobahnPython Module_AutobahnPython:BOOL=OFF //Request building Twisted Module_Twisted:BOOL=OFF //Request building VisItLib Module_VisItLib:BOOL=OFF //Request building ZopeInterface Module_ZopeInterface:BOOL=OFF //Request building pqPython Module_pqPython:BOOL=OFF //Request building vtkAcceleratorsPiston Module_vtkAcceleratorsPiston:BOOL=OFF //Request building vtkFiltersParallelGeometry Module_vtkFiltersParallelGeometry:BOOL=OFF //Request building vtkFiltersReebGraph Module_vtkFiltersReebGraph:BOOL=OFF //Request building vtkFiltersSelection Module_vtkFiltersSelection:BOOL=OFF //Request building vtkFiltersStatisticsGnuR Module_vtkFiltersStatisticsGnuR:BOOL=OFF //Request building vtkGUISupportQtOpenGL Module_vtkGUISupportQtOpenGL:BOOL=OFF //Request building vtkGUISupportQtSQL Module_vtkGUISupportQtSQL:BOOL=OFF //Request building vtkGUISupportQtWebkit Module_vtkGUISupportQtWebkit:BOOL=OFF //Request building vtkGeovisCore Module_vtkGeovisCore:BOOL=OFF //Request building vtkIOFFMPEG Module_vtkIOFFMPEG:BOOL=OFF //Request building vtkIOGDAL Module_vtkIOGDAL:BOOL=OFF //Request building vtkIOMINC Module_vtkIOMINC:BOOL=OFF //Request building vtkIOMPIParallel Module_vtkIOMPIParallel:BOOL=OFF //Request building vtkIOMySQL Module_vtkIOMySQL:BOOL=OFF //Request building vtkIOODBC Module_vtkIOODBC:BOOL=OFF //Request building vtkIOPostgreSQL Module_vtkIOPostgreSQL:BOOL=OFF //Request building vtkIOSQL Module_vtkIOSQL:BOOL=OFF //Request building vtkIOVideo Module_vtkIOVideo:BOOL=OFF //Request building vtkIOVisItBridge Module_vtkIOVisItBridge:BOOL=OFF //Request building vtkImagingMath Module_vtkImagingMath:BOOL=OFF //Request building vtkImagingStatistics Module_vtkImagingStatistics:BOOL=OFF //Request building vtkImagingStencil Module_vtkImagingStencil:BOOL=OFF //Request building vtkInfovisBoost Module_vtkInfovisBoost:BOOL=OFF //Request building vtkInfovisBoostGraphAlgorithms Module_vtkInfovisBoostGraphAlgorithms:BOOL=OFF //Request building vtkInfovisLayout Module_vtkInfovisLayout:BOOL=OFF //Request building vtkInfovisParallel Module_vtkInfovisParallel:BOOL=OFF //Request building vtkPVPythonSupport Module_vtkPVPythonSupport:BOOL=OFF Module_vtkParaViewWeb:BOOL=OFF Module_vtkParaViewWebDocumentation:BOOL=OFF //Request building vtkRenderingFreeTypeFontConfig Module_vtkRenderingFreeTypeFontConfig:BOOL=OFF //Request building vtkRenderingImage Module_vtkRenderingImage:BOOL=OFF //Request building vtkRenderingMatplotlib Module_vtkRenderingMatplotlib:BOOL=OFF //Request building vtkRenderingQt Module_vtkRenderingQt:BOOL=OFF //Request building vtkRenderingTk Module_vtkRenderingTk:BOOL=OFF //Request building vtkTclTk Module_vtkTclTk:BOOL=OFF //Request building vtkTestingIOSQL Module_vtkTestingIOSQL:BOOL=OFF //Request building vtkUtilitiesColorSeriesToXML Module_vtkUtilitiesColorSeriesToXML:BOOL=OFF //Request building vtkViewsGeovis Module_vtkViewsGeovis:BOOL=OFF //Request building vtkViewsInfovis Module_vtkViewsInfovis:BOOL=OFF //Request building vtkViewsQt Module_vtkViewsQt:BOOL=OFF //Request building vtkWrappingJava Module_vtkWrappingJava:BOOL=OFF //Request building vtkWrappingPython Module_vtkWrappingPython:BOOL=OFF //Request building vtkWrappingTcl Module_vtkWrappingTcl:BOOL=OFF //Request building vtklibproj4 Module_vtklibproj4:BOOL=OFF //Request building vtkmrmpi Module_vtkmrmpi:BOOL=OFF //Request building vtksqlite Module_vtksqlite:BOOL=OFF //Dependencies for the target Moments_LIB_DEPENDS:STATIC=general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Specify default maximum number of elements in the file chunk // cache chunk for HDF5 files (should be prime number). NETCDF4_CHUNK_CACHE_NELEMS:STRING=1009 //Specify default file chunk cache preemption policy for HDF5 files // (a number between 0 and 1, inclusive). NETCDF4_CHUNK_CACHE_PREEMPTION:STRING=0.75 //Specify default file cache chunk size for HDF5 files in bytes. NETCDF4_CHUNK_CACHE_SIZE:STRING=4194304 //Specify the number of chunks to store in default per-variable // cache. NETCDF4_DEFAULT_CHUNKS_IN_CACHE:STRING=10 //Specify default size of chunks in bytes. NETCDF4_DEFAULT_CHUNK_SIZE:STRING=4194304 //Specify maximum size (in bytes) for the default per-var chunk // cache. NETCDF4_MAX_DEFAULT_CACHE_SIZE:STRING=67108864 //Disable compiler warnings NETCDF_DISABLE_COMPILER_WARNINGS:BOOL=ON //Build netcdf C++ API NETCDF_ENABLE_CXX:BOOL=ON //Path to NVCONTROL headers (NVCtrlLib.h and NVCtrl.h) NVCtrlLib_INCLUDE_DIR:PATH=/usr/include/NVCtrl //Path to NVCONTROL static library (libXNVCtrl.a) NVCtrlLib_LIBRARY:FILEPATH=/usr/lib/libXNVCtrl.a //Dependencies for the target NonOrthogonalSource_LIB_DEPENDS:STATIC=general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Path to a file. OPENGL_INCLUDE_DIR:PATH=/usr/include //Path to a library. OPENGL_gl_LIBRARY:FILEPATH=/usr/lib/libGL.so //Path to a library. OPENGL_glu_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libGLU.so //Path to a file. OPENGL_xmesa_INCLUDE_DIR:PATH=OPENGL_xmesa_INCLUDE_DIR-NOTFOUND //Build AdiosReader Plugin PARAVIEW_BUILD_PLUGIN_AdiosReader:BOOL=FALSE //Build AnalyzeNIfTIIO Plugin PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIIO:BOOL=TRUE //Build ArrowGlyph Plugin PARAVIEW_BUILD_PLUGIN_ArrowGlyph:BOOL=TRUE //Build EyeDomeLighting Plugin PARAVIEW_BUILD_PLUGIN_EyeDomeLighting:BOOL=TRUE //Build ForceTime Plugin PARAVIEW_BUILD_PLUGIN_ForceTime:BOOL=FALSE //Build GMVReader Plugin PARAVIEW_BUILD_PLUGIN_GMVReader:BOOL=TRUE //Build H5PartReader Plugin PARAVIEW_BUILD_PLUGIN_H5PartReader:BOOL=TRUE //Build MantaView Plugin PARAVIEW_BUILD_PLUGIN_MantaView:BOOL=FALSE //Build MobileRemoteControl Plugin PARAVIEW_BUILD_PLUGIN_MobileRemoteControl:BOOL=TRUE //Build Moments Plugin PARAVIEW_BUILD_PLUGIN_Moments:BOOL=TRUE //Build Nektar Plugin PARAVIEW_BUILD_PLUGIN_Nektar:BOOL=FALSE //Build NonOrthogonalSource Plugin PARAVIEW_BUILD_PLUGIN_NonOrthogonalSource:BOOL=TRUE //Build PacMan Plugin PARAVIEW_BUILD_PLUGIN_PacMan:BOOL=TRUE //Build PointSprite Plugin PARAVIEW_BUILD_PLUGIN_PointSprite:BOOL=TRUE //Build PrismPlugin Plugin PARAVIEW_BUILD_PLUGIN_PrismPlugin:BOOL=TRUE //Build QuadView Plugin PARAVIEW_BUILD_PLUGIN_QuadView:BOOL=TRUE //Build SLACTools Plugin PARAVIEW_BUILD_PLUGIN_SLACTools:BOOL=TRUE //Build SciberQuestToolKit Plugin PARAVIEW_BUILD_PLUGIN_SciberQuestToolKit:BOOL=TRUE //Build SierraPlotTools Plugin PARAVIEW_BUILD_PLUGIN_SierraPlotTools:BOOL=TRUE //Build SurfaceLIC Plugin PARAVIEW_BUILD_PLUGIN_SurfaceLIC:BOOL=TRUE //Build UncertaintyRendering Plugin PARAVIEW_BUILD_PLUGIN_UncertaintyRendering:BOOL=TRUE //Build VRPlugin Plugin PARAVIEW_BUILD_PLUGIN_VRPlugin:BOOL=TRUE //Build VaporPlugin Plugin PARAVIEW_BUILD_PLUGIN_VaporPlugin:BOOL=FALSE //Enable ParaView Qt-based client PARAVIEW_BUILD_QT_GUI:BOOL=ON //Enable/Disable web documentation PARAVIEW_BUILD_WEB_DOCUMENTATION:BOOL=OFF //Turn on/off client tests that involve separate data and render // servers. PARAVIEW_CLIENT_RENDER_SERVER_TESTS:BOOL=ON //Add Collaboration testing PARAVIEW_COLLABORATION_TESTING:BOOL=ON //Path to a file. PARAVIEW_DATA_ROOT:PATH=PARAVIEW_DATA_ROOT-NOTFOUND //Enable/Disable the CoProcessing library. PARAVIEW_ENABLE_COPROCESSING:BOOL=ON //Enable FFMPEG Support. PARAVIEW_ENABLE_FFMPEG:BOOL=OFF //Enable/Disable Python scripting support PARAVIEW_ENABLE_PYTHON:BOOL=OFF //Enables markers in the spyplot reader PARAVIEW_ENABLE_SPYPLOT_MARKERS:BOOL=OFF //Turn off to avoid ParaView depending on all used VTK modules. PARAVIEW_ENABLE_VTK_MODULES_AS_NEEDED:BOOL=TRUE //Enable/Disable web support PARAVIEW_ENABLE_WEB:BOOL=OFF //Semi-colon seperated paths to extrenal plugin directories. PARAVIEW_EXTERNAL_PLUGIN_DIRS:STRING= //When enabled, "make install" will install development files PARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=OFF //Enable IceT (needed for parallel rendering) PARAVIEW_USE_ICE_T:BOOL=ON //Enable MPI support for parallel computing PARAVIEW_USE_MPI:BOOL=ON //Use MPI synchronous-send commands for communication PARAVIEW_USE_MPI_SSEND:BOOL=OFF //Build ParaView with Piston GPGPU filters PARAVIEW_USE_PISTON:BOOL=OFF //Build ParaView with VisIt readers. PARAVIEW_USE_VISITBRIDGE:BOOL=OFF //Build ParaView with VRPN support PARAVIEW_USE_VRPN:BOOL=ON //Build ParaView with VRUI support PARAVIEW_USE_VRUI:BOOL=OFF //Disable compiler warnings PROTOBUF_DISABLE_COMPILER_WARNINGS:BOOL=ON //Command to run after a failed test to cleanup processes. Example: // "killall -9 rsh paraview" PV_TEST_CLEAN_COMMAND:STRING= //Node which serves as the client node, used to connect from the // server side in reverse connection mode. PV_TEST_CLIENT:STRING=localhost //Command to run before a test begins. Multiple commands are separated // by ';'. PV_TEST_INIT_COMMAND:STRING= //Use random port numbers when testing client-server configurations. PV_TEST_USE_RANDOM_PORTS:BOOL=ON //Path to a program. PYTHON_EXECUTABLE:FILEPATH=/usr/bin/python //Dependencies for the target PacMan_LIB_DEPENDS:STATIC=general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Value Computed by CMake ParaView_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2 //Value Computed by CMake ParaView_SOURCE_DIR:STATIC=/mpi3/S2/ParaView //Value Computed by CMake PointSpritePlugin_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/Plugins/PointSprite //Value Computed by CMake PointSpritePlugin_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/Plugins/PointSprite //Dependencies for the target PointSprite_Plugin_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS;general;vtkQvis;general;vtkPointSpriteGraphics;general;vtkPointSpriteRendering; //Dependencies for the target PrismPlugin_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Path to a library. QT_ARTHURPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_ARTHURPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_CONTAINEREXTENSION_PLUGIN_DEBUG:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_CONTAINEREXTENSION_PLUGIN_RELEASE:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-NOTFOUND //Path to a program. QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=/usr/bin/qdbuscpp2xml //Path to a program. QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=/usr/bin/qdbusxml2cpp //Path to a program. QT_DESIGNER_EXECUTABLE:FILEPATH=/usr/bin/designer-qt4 //The location of the Qt docs QT_DOC_DIR:PATH=/usr/share/qt4/doc //qhelpgenerator used to compile Qt help project files QT_HELP_GENERATOR:FILEPATH=/usr/bin/qhelpgenerator //The location of the Qt imports QT_IMPORTS_DIR:PATH=QT_IMPORTS_DIR-NOTFOUND //Path to a program. QT_LINGUIST_EXECUTABLE:FILEPATH=/usr/bin/linguist-qt4 //Path to a program. QT_LRELEASE_EXECUTABLE:FILEPATH=/usr/bin/lrelease-qt4 //Path to a program. QT_LUPDATE_EXECUTABLE:FILEPATH=/usr/bin/lupdate-qt4 //The location of the Qt mkspecs containing qconfig.pri QT_MKSPECS_DIR:PATH=/usr/share/qt4/mkspecs //Path to a program. QT_MOC_EXECUTABLE:FILEPATH=/usr/bin/moc-qt4 //Path to a library. QT_PHONONWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_PHONONWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_PHONONWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libphononwidgets.so //Path to a file. QT_PHONON_INCLUDE_DIR:PATH=/usr/include/qt4/phonon //The Qt PHONON library QT_PHONON_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libphonon.so;debug;/usr/lib/x86_64-linux-gnu/libphonon.so //Path to a library. QT_PHONON_LIBRARY_DEBUG:FILEPATH=QT_PHONON_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_PHONON_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libphonon.so //The location of the Qt plugins QT_PLUGINS_DIR:PATH=/usr/lib/x86_64-linux-gnu/qt4/plugins //Path to a library. QT_QCNCODECS_PLUGIN_DEBUG:FILEPATH=QT_QCNCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QCNCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqcncodecs.so //Path to a program. QT_QCOLLECTIONGENERATOR_EXECUTABLE:FILEPATH=/usr/bin/qcollectiongenerator //Path to a library. QT_QCOREWLANBEARER_PLUGIN_DEBUG:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QCOREWLANBEARER_PLUGIN_RELEASE:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QDECLARATIVEVIEW_PLUGIN_DEBUG:FILEPATH=QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QDECLARATIVEVIEW_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqdeclarativeview.so //Path to a library. QT_QDECORATIONDEFAULT_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QDECORATIONDEFAULT_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QDECORATIONWINDOWS_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QDECORATIONWINDOWS_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QGENERICBEARER_PLUGIN_DEBUG:FILEPATH=QT_QGENERICBEARER_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QGENERICBEARER_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so //Path to a library. QT_QGIF_PLUGIN_DEBUG:FILEPATH=QT_QGIF_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QGIF_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqgif.so //Path to a library. QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/graphicssystems/libqglgraphicssystem.so //Path to a library. QT_QICO_PLUGIN_DEBUG:FILEPATH=QT_QICO_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QICO_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so //Path to a library. QT_QIMSW_MULTI_PLUGIN_DEBUG:FILEPATH=QT_QIMSW_MULTI_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QIMSW_MULTI_PLUGIN_RELEASE:FILEPATH=QT_QIMSW_MULTI_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QJPCODECS_PLUGIN_DEBUG:FILEPATH=QT_QJPCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QJPCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqjpcodecs.so //Path to a library. QT_QJPEG_PLUGIN_DEBUG:FILEPATH=QT_QJPEG_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QJPEG_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so //Path to a library. QT_QKRCODECS_PLUGIN_DEBUG:FILEPATH=QT_QKRCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QKRCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqkrcodecs.so //The qmake executable for the Qt installation to use QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake //Path to a library. QT_QMNG_PLUGIN_DEBUG:FILEPATH=QT_QMNG_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QMNG_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so //Path to a library. QT_QSQLDB2_PLUGIN_DEBUG:FILEPATH=QT_QSQLDB2_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLDB2_PLUGIN_RELEASE:FILEPATH=QT_QSQLDB2_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLIBASE_PLUGIN_DEBUG:FILEPATH=QT_QSQLIBASE_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLIBASE_PLUGIN_RELEASE:FILEPATH=QT_QSQLIBASE_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLITE2_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE2_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLITE2_PLUGIN_RELEASE:FILEPATH=QT_QSQLITE2_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLITE_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLITE_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/sqldrivers/libqsqlite.so //Path to a library. QT_QSQLMYSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLMYSQL_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLMYSQL_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/sqldrivers/libqsqlmysql.so //Path to a library. QT_QSQLOCI_PLUGIN_DEBUG:FILEPATH=QT_QSQLOCI_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLOCI_PLUGIN_RELEASE:FILEPATH=QT_QSQLOCI_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLODBC_PLUGIN_DEBUG:FILEPATH=QT_QSQLODBC_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLODBC_PLUGIN_RELEASE:FILEPATH=QT_QSQLODBC_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLPSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLPSQL_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLPSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLPSQL_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLTDS_PLUGIN_DEBUG:FILEPATH=QT_QSQLTDS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLTDS_PLUGIN_RELEASE:FILEPATH=QT_QSQLTDS_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSVGICON_PLUGIN_DEBUG:FILEPATH=QT_QSVGICON_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSVGICON_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so //Path to a library. QT_QSVG_PLUGIN_DEBUG:FILEPATH=QT_QSVG_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSVG_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so //Path to a library. QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqt3supportwidgets.so //Path to a file. QT_QT3SUPPORT_INCLUDE_DIR:PATH=/usr/include/qt4/Qt3Support //The Qt QT3SUPPORT library QT_QT3SUPPORT_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQt3Support.so;debug;/usr/lib/x86_64-linux-gnu/libQt3Support.so //Path to a library. QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQt3Support.so //Path to a library. QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblecompatwidgets.so //Path to a library. QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so //Path to a file. QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=QT_QTASSISTANTCLIENT_INCLUDE_DIR-NOTFOUND //The Qt QTASSISTANTCLIENT library QT_QTASSISTANTCLIENT_LIBRARY:STRING= //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTASSISTANT_INCLUDE_DIR:PATH=QT_QTASSISTANT_INCLUDE_DIR-NOTFOUND //The Qt QTASSISTANT library QT_QTASSISTANT_LIBRARY:STRING= //Path to a library. QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANT_LIBRARY_RELEASE-NOTFOUND //The Qt QTCLUCENE library QT_QTCLUCENE_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtCLucene.so;debug;/usr/lib/x86_64-linux-gnu/libQtCLucene.so //Path to a library. QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=QT_QTCLUCENE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtCLucene.so //Path to a file. QT_QTCORE_INCLUDE_DIR:PATH=/usr/include/qt4/QtCore //The Qt QTCORE library QT_QTCORE_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so //Path to a library. QT_QTCORE_LIBRARY_DEBUG:FILEPATH=QT_QTCORE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCORE_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtCore.so //Path to a file. QT_QTDBUS_INCLUDE_DIR:PATH=/usr/include/qt4/QtDBus //The Qt QTDBUS library QT_QTDBUS_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtDBus.so;debug;/usr/lib/x86_64-linux-gnu/libQtDBus.so //Path to a library. QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDBus.so //Path to a file. QT_QTDECLARATIVE_INCLUDE_DIR:PATH=/usr/include/qt4/QtDeclarative //The Qt QTDECLARATIVE library QT_QTDECLARATIVE_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtDeclarative.so;debug;/usr/lib/x86_64-linux-gnu/libQtDeclarative.so //Path to a library. QT_QTDECLARATIVE_LIBRARY_DEBUG:FILEPATH=QT_QTDECLARATIVE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDECLARATIVE_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDeclarative.so //Path to a file. QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=/usr/include/qt4/QtDesigner //The Qt QTDESIGNERCOMPONENTS library QT_QTDESIGNERCOMPONENTS_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtDesignerComponents.so;debug;/usr/lib/x86_64-linux-gnu/libQtDesignerComponents.so //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDesignerComponents.so //Path to a file. QT_QTDESIGNER_INCLUDE_DIR:PATH=/usr/include/qt4/QtDesigner //The Qt QTDESIGNER library QT_QTDESIGNER_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtDesigner.so;debug;/usr/lib/x86_64-linux-gnu/libQtDesigner.so //Path to a library. QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDesigner.so //Path to a file. QT_QTGUI_INCLUDE_DIR:PATH=/usr/include/qt4/QtGui //The Qt QTGUI library QT_QTGUI_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so //Path to a library. QT_QTGUI_LIBRARY_DEBUG:FILEPATH=QT_QTGUI_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTGUI_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtGui.so //Path to a file. QT_QTHELP_INCLUDE_DIR:PATH=/usr/include/qt4/QtHelp //The Qt QTHELP library QT_QTHELP_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtHelp.so;debug;/usr/lib/x86_64-linux-gnu/libQtHelp.so //Path to a library. QT_QTHELP_LIBRARY_DEBUG:FILEPATH=QT_QTHELP_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTHELP_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtHelp.so //Path to a library. QT_QTIFF_PLUGIN_DEBUG:FILEPATH=QT_QTIFF_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTIFF_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so //Path to a file. QT_QTMOTIF_INCLUDE_DIR:PATH=QT_QTMOTIF_INCLUDE_DIR-NOTFOUND //The Qt QTMOTIF library QT_QTMOTIF_LIBRARY:STRING= //Path to a library. QT_QTMOTIF_LIBRARY_DEBUG:FILEPATH=QT_QTMOTIF_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTMOTIF_LIBRARY_RELEASE:FILEPATH=QT_QTMOTIF_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTMULTIMEDIA_INCLUDE_DIR:PATH=QT_QTMULTIMEDIA_INCLUDE_DIR-NOTFOUND //The Qt QTMULTIMEDIA library QT_QTMULTIMEDIA_LIBRARY:STRING= //Path to a library. QT_QTMULTIMEDIA_LIBRARY_DEBUG:FILEPATH=QT_QTMULTIMEDIA_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTMULTIMEDIA_LIBRARY_RELEASE:FILEPATH=QT_QTMULTIMEDIA_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTNETWORK_INCLUDE_DIR:PATH=/usr/include/qt4/QtNetwork //The Qt QTNETWORK library QT_QTNETWORK_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtNetwork.so;debug;/usr/lib/x86_64-linux-gnu/libQtNetwork.so //Path to a library. QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtNetwork.so //Path to a file. QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND //The Qt QTNSPLUGIN library QT_QTNSPLUGIN_LIBRARY:STRING= //Path to a library. QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTOPENGL_INCLUDE_DIR:PATH=/usr/include/qt4/QtOpenGL //The Qt QTOPENGL library QT_QTOPENGL_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtOpenGL.so;debug;/usr/lib/x86_64-linux-gnu/libQtOpenGL.so //Path to a library. QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtOpenGL.so //Path to a library. QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/graphicssystems/libqtracegraphicssystem.so //Path to a library. QT_QTSCRIPTDBUS_PLUGIN_DEBUG:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPTDBUS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/script/libqtscriptdbus.so //Path to a file. QT_QTSCRIPTTOOLS_INCLUDE_DIR:PATH=/usr/include/qt4/QtScriptTools //The Qt QTSCRIPTTOOLS library QT_QTSCRIPTTOOLS_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtScriptTools.so;debug;/usr/lib/x86_64-linux-gnu/libQtScriptTools.so //Path to a library. QT_QTSCRIPTTOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPTTOOLS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtScriptTools.so //Path to a file. QT_QTSCRIPT_INCLUDE_DIR:PATH=/usr/include/qt4/QtScript //The Qt QTSCRIPT library QT_QTSCRIPT_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtScript.so;debug;/usr/lib/x86_64-linux-gnu/libQtScript.so //Path to a library. QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtScript.so //Path to a file. QT_QTSQL_INCLUDE_DIR:PATH=/usr/include/qt4/QtSql //The Qt QTSQL library QT_QTSQL_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtSql.so;debug;/usr/lib/x86_64-linux-gnu/libQtSql.so //Path to a library. QT_QTSQL_LIBRARY_DEBUG:FILEPATH=QT_QTSQL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSQL_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtSql.so //Path to a file. QT_QTSVG_INCLUDE_DIR:PATH=/usr/include/qt4/QtSvg //The Qt QTSVG library QT_QTSVG_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtSvg.so;debug;/usr/lib/x86_64-linux-gnu/libQtSvg.so //Path to a library. QT_QTSVG_LIBRARY_DEBUG:FILEPATH=QT_QTSVG_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSVG_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtSvg.so //Path to a file. QT_QTTEST_INCLUDE_DIR:PATH=/usr/include/qt4/QtTest //The Qt QTTEST library QT_QTTEST_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtTest.so;debug;/usr/lib/x86_64-linux-gnu/libQtTest.so //Path to a library. QT_QTTEST_LIBRARY_DEBUG:FILEPATH=QT_QTTEST_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTTEST_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtTest.so //Path to a file. QT_QTUITOOLS_INCLUDE_DIR:PATH=/usr/include/qt4/QtUiTools //The Qt QTUITOOLS library QT_QTUITOOLS_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtUiTools.a;debug;/usr/lib/x86_64-linux-gnu/libQtUiTools.a //Path to a library. QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTUITOOLS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtUiTools.a //Path to a library. QT_QTWCODECS_PLUGIN_DEBUG:FILEPATH=QT_QTWCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTWCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqtwcodecs.so //Path to a file. QT_QTWEBKIT_INCLUDE_DIR:PATH=/usr/include/qt4/QtWebKit //The Qt QTWEBKIT library QT_QTWEBKIT_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtWebKit.so;debug;/usr/lib/x86_64-linux-gnu/libQtWebKit.so //Path to a library. QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=QT_QTWEBKIT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtWebKit.so //Path to a file. QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=/usr/include/qt4/QtXmlPatterns //The Qt QTXMLPATTERNS library QT_QTXMLPATTERNS_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so;debug;/usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so //Path to a library. QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=QT_QTXMLPATTERNS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so //Path to a file. QT_QTXML_INCLUDE_DIR:PATH=/usr/include/qt4/QtXml //The Qt QTXML library QT_QTXML_LIBRARY:STRING=optimized;/usr/lib/x86_64-linux-gnu/libQtXml.so;debug;/usr/lib/x86_64-linux-gnu/libQtXml.so //Path to a library. QT_QTXML_LIBRARY_DEBUG:FILEPATH=QT_QTXML_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXML_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtXml.so //Path to a library. QT_QWEBVIEW_PLUGIN_DEBUG:FILEPATH=QT_QWEBVIEW_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QWEBVIEW_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqwebview.so //Path to a library. QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-NOTFOUND //Path to a program. QT_RCC_EXECUTABLE:FILEPATH=/usr/bin/rcc //Path to a library. QT_TASKMENUEXTENSION_PLUGIN_DEBUG:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_TASKMENUEXTENSION_PLUGIN_RELEASE:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_RELEASE-NOTFOUND //Delay between invocation of each testing event. QT_TESTING_EVENT_PLAYBACK_DELAY:STRING=100 //Install Qt Testing development files. QT_TESTING_INSTALL_DEVELOPMENT:BOOL=ON //The location of the Qt translations QT_TRANSLATIONS_DIR:PATH=/usr/share/qt4/translations //Path to a program. QT_UIC3_EXECUTABLE:FILEPATH=/usr/bin/uic3 //Path to a program. QT_UIC_EXECUTABLE:FILEPATH=/usr/bin/uic-qt4 //Path to a library. QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-NOTFOUND //xmlpatterns used to generate html from Proxy documentation. QT_XMLPATTERNS_EXECUTABLE:FILEPATH=/usr/bin/xmlpatterns //Dependencies for the target QVTKWidgetPlugin_LIB_DEPENDS:STATIC=optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so;optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so; //Value Computed by CMake QtTesting_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/ThirdParty/QtTesting/vtkqttesting //Dependencies for the target QtTesting_LIB_DEPENDS:STATIC=optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so;optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so; //Value Computed by CMake QtTesting_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/ThirdParty/QtTesting/vtkqttesting //Dependencies for the target QuadView_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Path to scp command, used by CTest for submitting results to // a Dart server SCPCOMMAND:FILEPATH=/usr/bin/scp //Name of the computer/site where compile is being run SITE:STRING=mpi1 //Dependencies for the target SLACTools_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS; //Path to the SLURM sbatch executable SLURM_SBATCH_COMMAND:FILEPATH=SLURM_SBATCH_COMMAND-NOTFOUND //Path to the SLURM srun executable SLURM_SRUN_COMMAND:FILEPATH=SLURM_SRUN_COMMAND-NOTFOUND //Enable CUDA optimizations. SQTK_CUDA:BOOL=OFF //Enable debug output to std err. SQTK_DEBUG:BOOL=OFF //Enable Python bindings. SQTK_PYTHON_BINDINGS:BOOL=OFF //Path to a program. SVNCOMMAND:FILEPATH=/usr/bin/svn //Value Computed by CMake SciberQuestToolKit_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/Plugins/SciberQuestToolKit //Dependencies for the target SciberQuestToolKit_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS;general;vtkFiltersFlowPaths; //Value Computed by CMake SciberQuestToolKit_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/Plugins/SciberQuestToolKit //Dependencies for the target SierraPlotTools_LIB_DEPENDS:STATIC=general;pqComponents; //Dependencies for the target SurfaceLIC_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS;general;vtkRenderingHybridOpenGL; //Value Computed by CMake TestDriver_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/CoProcessing/CoProcessor/Testing/TestDriver //Value Computed by CMake TestDriver_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/CoProcessing/CoProcessor/Testing/TestDriver //Use HIDDEN visibility support if available. USE_COMPILER_HIDDEN_VISIBILITY:BOOL=ON //Dependencies for the target UncertaintyRendering_LIB_DEPENDS:STATIC=general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;general;vtkPVServerManagerApplicationCS;general;vtkRenderingHybridOpenGL; //Value Computed by CMake VPIC_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/VPIC //Dependencies for the target VPIC_LIB_DEPENDS:STATIC=general;vtksys;general;/usr/lib/openmpi/lib/libmpi.so;general;/usr/lib/openmpi/lib/libopen-rte.so;general;/usr/lib/openmpi/lib/libopen-pal.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/x86_64-linux-gnu/libnsl.so;general;/usr/lib/x86_64-linux-gnu/libutil.so;general;/usr/lib/x86_64-linux-gnu/libm.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/openmpi/lib/libmpi_cxx.so;general;/usr/lib/openmpi/lib/libmpi.so;general;/usr/lib/openmpi/lib/libopen-rte.so;general;/usr/lib/openmpi/lib/libopen-pal.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/x86_64-linux-gnu/libnsl.so;general;/usr/lib/x86_64-linux-gnu/libutil.so;general;/usr/lib/x86_64-linux-gnu/libm.so;general;/usr/lib/x86_64-linux-gnu/libdl.so; //Value Computed by CMake VPIC_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/VPIC //Path to a file. VRPN_INCLUDE_DIR:PATH=/mpi3/C2/vrpn/include //Path to a library. VRPN_LIBRARY:FILEPATH=/mpi3/C2/vrpn/lib //Path to a file. VRPN_LIBUSB_INCLUDE_DIR:PATH=/mpi3/C2/vrpn/include //Dependencies for the target VRPlugin_LIB_DEPENDS:STATIC=general;pqComponents;general;/mpi3/C2/vrpn/lib;general;pqApplicationComponents; //Value Computed by CMake VTKEXPAT_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/expat/vtkexpat //Value Computed by CMake VTKEXPAT_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/expat/vtkexpat //Value Computed by CMake VTKFREETYPE_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/freetype/vtkfreetype //Value Computed by CMake VTKFREETYPE_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/freetype/vtkfreetype //Value Computed by CMake VTKFTGL_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/ftgl //Value Computed by CMake VTKFTGL_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/ftgl //Value Computed by CMake VTKGL2PS_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/gl2ps/vtkgl2ps //Value Computed by CMake VTKGL2PS_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/gl2ps/vtkgl2ps //Value Computed by CMake VTKJPEG_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/jpeg/vtkjpeg //Value Computed by CMake VTKJPEG_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/jpeg/vtkjpeg //Value Computed by CMake VTKNETCDF_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/netcdf/vtknetcdf //Value Computed by CMake VTKNETCDF_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf //Value Computed by CMake VTKOGGTHEORA_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/oggtheora/vtkoggtheora //Disable assemby optimizations VTKOGGTHEORA_DISABLE_ASM:BOOL=OFF //Disable the use of floating point code in theora VTKOGGTHEORA_DISABLE_FLOAT:BOOL=OFF //Additional linker flags for vtkoggtheora when building as a shared // library VTKOGGTHEORA_SHARED_LINKER_FLAGS:STRING=-Wl,--version-script="/mpi3/S2/ParaView/VTK/ThirdParty/oggtheora/vtkoggtheora/vtkoggtheora.vscript" //Value Computed by CMake VTKOGGTHEORA_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/oggtheora/vtkoggtheora //Value Computed by CMake VTKPNG_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/png/vtkpng //Value Computed by CMake VTKPNG_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/png/vtkpng //Value Computed by CMake VTKTIFF_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/tiff/vtktiff //Value Computed by CMake VTKTIFF_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/tiff/vtktiff //Value Computed by CMake VTKZLIB_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/zlib/vtkzlib //Value Computed by CMake VTKZLIB_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/zlib/vtkzlib //Build all vtkObject derived classes with object factory new methods. VTK_ALL_NEW_OBJECT_FACTORY:BOOL=OFF //Value Computed by CMake VTK_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK //Request to build all modules VTK_BUILD_ALL_MODULES:BOOL=OFF //Enable modules as needed for testing all the enabled modules VTK_BUILD_ALL_MODULES_FOR_TESTS:BOOL=OFF //Build Cosmo with MPI VTK_COSMO_USE_MPI:BOOL=ON //The repository for data used for testing. To obtain from git: // "git clone git://vtk.org/VTKData.git" [^] VTK_DATA_ROOT:PATH=VTK_DATA_ROOT-NOTFOUND //Build leak checking support into VTK. VTK_DEBUG_LEAKS:BOOL=OFF //Add compiler flags to do stricter checking when building debug. VTK_EXTRA_COMPILER_WARNINGS:BOOL=OFF //Path to a program. VTK_GHOSTSCRIPT_EXECUTABLE:FILEPATH=/usr/bin/gs //Location of the OpenGL extensions header file (glext.h). VTK_GLEXT_FILE:FILEPATH=/mpi3/S2/ParaView/VTK/Utilities/ParseOGLExt/headers/glext.h //Location of the GLX extensions header file (glxext.h). VTK_GLXEXT_FILE:FILEPATH=/mpi3/S2/ParaView/VTK/Utilities/ParseOGLExt/headers/glxext.h //Request building CoProcessing modules VTK_Group_CoProcessing:BOOL=ON //Request building Imaging modules VTK_Group_Imaging:BOOL=OFF //Request building MPI modules VTK_Group_MPI:BOOL=OFF //Request building ParaViewCore modules VTK_Group_ParaViewCore:BOOL=ON //Request building ParaViewPython modules VTK_Group_ParaViewPython:BOOL=OFF //Request building ParaViewQt modules VTK_Group_ParaViewQt:BOOL=ON //Request building ParaViewRendering modules VTK_Group_ParaViewRendering:BOOL=ON //Request building Qt modules VTK_Group_Qt:BOOL=OFF //Request building Rendering modules VTK_Group_Rendering:BOOL=OFF //Request building of all stand alone modules (no external dependencies // required) VTK_Group_StandAlone:BOOL=OFF //Request building Tk modules VTK_Group_Tk:BOOL=OFF //Request building Views modules VTK_Group_Views:BOOL=OFF //The repository for large data used for testing. To obtain from // git: "git clone git://vtk.org/VTKLargeData.git" [^] VTK_LARGE_DATA_ROOT:PATH=VTK_LARGE_DATA_ROOT-NOTFOUND //Remove all legacy code completely. VTK_LEGACY_REMOVE:BOOL=ON //Silence all legacy code messages. VTK_LEGACY_SILENT:BOOL=OFF //Should all modules build instantiators VTK_MAKE_INSTANTIATORS:BOOL=OFF //A ; separated list of directories to search for materials/shaders. VTK_MATERIALS_DIRS:STRING=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/MaterialLibrary/Repository //Max number of threads vktMultiThreader will allocate. VTK_MAX_THREADS:STRING=64 //The full path to mpirun command VTK_MPIRUN_EXE:FILEPATH=/mpi3/C2/mpich-3.0.1/bin/mpiexec //Maximum number of processors available to run parallel applications. // (see /mpi3/S2/ParaView/VTK/Parallel/MPI/CMakeLists.txt for more // info.) VTK_MPI_MAX_NUMPROCS:STRING=2 //Flag used by mpi to specify the number of processes, the next // option will be the number of processes. (see /mpi3/S2/ParaView/VTK/Parallel/MPI/CMakeLists.txt // for more info.) VTK_MPI_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIRun.(see /mpi3/S2/ParaView/VTK/Parallel/MPI/CMakeLists.txt // for more info.) VTK_MPI_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by VTK_MPIRUN_EXE. (see /mpi3/S2/ParaView/VTK/Parallel/MPI/CMakeLists.txt // for more info.) VTK_MPI_PREFLAGS:STRING= //These flags will be directly before the number of processess // flag (see /mpi3/S2/ParaView/VTK/Parallel/MPI/CMakeLists.txt // for more info.) VTK_MPI_PRENUMPROC_FLAGS:STRING= //The OpenGL library being used supports off screen Mesa calls VTK_OPENGL_HAS_OSMESA:BOOL=OFF //Value Computed by CMake VTK_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK //Build VTK with 64 bit ids VTK_USE_64BIT_IDS:BOOL=ON //Use GCC visibility support if available. VTK_USE_GCC_VISIBILITY:BOOL=OFF //Use off screen calls by default VTK_USE_OFFSCREEN:BOOL=OFF //Use system-installed EXPAT VTK_USE_SYSTEM_EXPAT:BOOL=OFF //Use system-installed Freetype VTK_USE_SYSTEM_FREETYPE:BOOL=OFF //Use system-installed GL2PS VTK_USE_SYSTEM_GL2PS:BOOL=OFF //Use system-installed HDF5 VTK_USE_SYSTEM_HDF5:BOOL=OFF //Use system-installed icet VTK_USE_SYSTEM_ICET:BOOL=OFF //Use system-installed JPEG VTK_USE_SYSTEM_JPEG:BOOL=OFF //Use system-installed LibXml2 VTK_USE_SYSTEM_LIBXML2:BOOL=OFF //Use system-installed OGGTHEORA VTK_USE_SYSTEM_OGGTHEORA:BOOL=OFF //Use system-installed PNG VTK_USE_SYSTEM_PNG:BOOL=OFF //Use system-installed protobuf VTK_USE_SYSTEM_PROTOBUF:BOOL=OFF //Use system-installed qttesting VTK_USE_SYSTEM_QTTESTING:BOOL=OFF //Use system-installed TIFF VTK_USE_SYSTEM_TIFF:BOOL=OFF //Use system-installed xdmf2 VTK_USE_SYSTEM_XDMF2:BOOL=OFF //Use system-installed ZLIB VTK_USE_SYSTEM_ZLIB:BOOL=OFF //Use TDx interaction devices VTK_USE_TDX:BOOL=OFF //Build VTK with Tk support VTK_USE_TK:BOOL=OFF //Use X for VTK render windows VTK_USE_X:BOOL=ON //Build VPIC with MPI VTK_VPIC_USE_MPI:BOOL=ON //Location of the WGL extensions header file (wglext.h). VTK_WGLEXT_FILE:FILEPATH=/mpi3/S2/ParaView/VTK/Utilities/ParseOGLExt/headers/wglext.h //Path to a file. VTK_WRAP_HINTS:FILEPATH=/mpi3/S2/ParaView/VTK/Wrapping/Tools/hints //Should VTK Java wrapping be built? VTK_WRAP_JAVA:BOOL=OFF //Should VTK Tcl wrapping be built? VTK_WRAP_TCL:BOOL=OFF //Build Xdmf with MPI VTK_XDMF_USE_MPI:BOOL=OFF //Path to a file. X11_ICE_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_ICE_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libICE.so //Path to a file. X11_SM_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_SM_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libSM.so //Path to a file. X11_X11_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_X11_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libX11.so //Path to a file. X11_XRes_INCLUDE_PATH:PATH=X11_XRes_INCLUDE_PATH-NOTFOUND //Path to a library. X11_XRes_LIB:FILEPATH=X11_XRes_LIB-NOTFOUND //Path to a file. X11_XShm_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_XSync_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_XTest_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_XTest_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXtst.so //Path to a file. X11_Xaccessrules_INCLUDE_PATH:PATH=X11_Xaccessrules_INCLUDE_PATH-NOTFOUND //Path to a file. X11_Xaccessstr_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xau_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xau_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXau.so //Path to a file. X11_Xcomposite_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcomposite_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXcomposite.so //Path to a file. X11_Xcursor_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcursor_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXcursor.so //Path to a file. X11_Xdamage_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdamage_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXdamage.so //Path to a file. X11_Xdmcp_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdmcp_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXdmcp.so //Path to a library. X11_Xext_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXext.so //Path to a file. X11_Xfixes_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xfixes_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXfixes.so //Path to a file. X11_Xft_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xft_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXft.so //Path to a file. X11_Xi_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xi_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXi.so //Path to a file. X11_Xinerama_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinerama_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXinerama.so //Path to a file. X11_Xinput_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinput_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXi.so //Path to a file. X11_Xkb_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xkbfile_INCLUDE_PATH:PATH=X11_Xkbfile_INCLUDE_PATH-NOTFOUND //Path to a library. X11_Xkbfile_LIB:FILEPATH=X11_Xkbfile_LIB-NOTFOUND //Path to a file. X11_Xkblib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xlib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xmu_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xmu_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXmu.so //Path to a file. X11_Xpm_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xpm_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXpm.so //Path to a file. X11_Xrandr_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrandr_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXrandr.so //Path to a file. X11_Xrender_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrender_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXrender.so //Path to a file. X11_Xscreensaver_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xscreensaver_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXss.so //Path to a file. X11_Xshape_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xt_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xt_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXt.so //Path to a file. X11_Xutil_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xv_INCLUDE_PATH:PATH=X11_Xv_INCLUDE_PATH-NOTFOUND //Path to a library. X11_Xv_LIB:FILEPATH=X11_Xv_LIB-NOTFOUND //Path to a library. X11_Xxf86misc_LIB:FILEPATH=X11_Xxf86misc_LIB-NOTFOUND //Path to a library. X11_Xxf86vm_LIB:FILEPATH=X11_Xxf86vm_LIB-NOTFOUND //Path to a file. X11_dpms_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_xf86misc_INCLUDE_PATH:PATH=X11_xf86misc_INCLUDE_PATH-NOTFOUND //Path to a file. X11_xf86vmode_INCLUDE_PATH:PATH=X11_xf86vmode_INCLUDE_PATH-NOTFOUND //XDMF should use MPI XDMF_BUILD_MPI:BOOL=OFF //XDMF has Network Distributed Global Memory (NDGM) XDMF_HAS_NDGM:BOOL=OFF //Path to a file. XDMF_HAVE_FCNTL:PATH=/usr/include //Path to a file. XDMF_HAVE_MMAN:PATH=/usr/include/sys //Path to a file. XDMF_HAVE_NETINET:PATH=/usr/include/netinet //Use bzip2 XDMF_USE_BZIP2:BOOL=OFF //Build GZip Compression XDMF_USE_GZIP:BOOL=OFF //Build Support for MySQL DataItems XDMF_USE_MYSQL:BOOL=OFF //Path to a file. ZLIB_INCLUDE_DIR:PATH=/usr/include //Path to a library. ZLIB_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libz.so //Value Computed by CMake alglib_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/alglib //Value Computed by CMake alglib_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/alglib //Path to a program. file_cmd:FILEPATH=/usr/bin/file //Value Computed by CMake mpi4py_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/Utilities/mpi4py //Value Computed by CMake mpi4py_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/Utilities/mpi4py //Value Computed by CMake netcdf_cxx_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/netcdf/vtknetcdf/cxx //Value Computed by CMake netcdf_cxx_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/cxx //Value Computed by CMake netcdf_libdispatch_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch //Value Computed by CMake netcdf_libdispatch_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch //Value Computed by CMake netcdf_liblib_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/netcdf/vtknetcdf/liblib //Value Computed by CMake netcdf_liblib_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/liblib //Value Computed by CMake netcdf_libsrc4_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4 //Value Computed by CMake netcdf_libsrc4_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4 //Value Computed by CMake netcdf_libsrc_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/netcdf/vtknetcdf/libsrc //Value Computed by CMake netcdf_libsrc_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc //Dependencies for the target pqApplicationComponents_LIB_DEPENDS:STATIC=general;pqComponents;general;vtkGUISupportQt; //Dependencies for the target pqComponents_LIB_DEPENDS:STATIC=general;pqCore; //Dependencies for the target pqCore_LIB_DEPENDS:STATIC=general;pqWidgets;general;vtkGUISupportQt;general;vtkPVServerManagerApplication;general;vtkPVServerManagerDefault;optimized;/usr/lib/x86_64-linux-gnu/libQtUiTools.a;debug;/usr/lib/x86_64-linux-gnu/libQtUiTools.a;optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so;optimized;/usr/lib/x86_64-linux-gnu/libQtXml.so;debug;/usr/lib/x86_64-linux-gnu/libQtXml.so;optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so; //Dependencies for the target pqWidgets_LIB_DEPENDS:STATIC=general;vtkGUISupportQt;general;vtkPVServerManagerCore;general;QtTesting;optimized;/usr/lib/x86_64-linux-gnu/libQtHelp.so;debug;/usr/lib/x86_64-linux-gnu/libQtHelp.so;optimized;/usr/lib/x86_64-linux-gnu/libQtWebKit.so;debug;/usr/lib/x86_64-linux-gnu/libQtWebKit.so;optimized;/usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so;debug;/usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so;optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so;optimized;/usr/lib/x86_64-linux-gnu/libQtXml.so;debug;/usr/lib/x86_64-linux-gnu/libQtXml.so;optimized;/usr/lib/x86_64-linux-gnu/libQtSql.so;debug;/usr/lib/x86_64-linux-gnu/libQtSql.so;optimized;/usr/lib/x86_64-linux-gnu/libQtNetwork.so;debug;/usr/lib/x86_64-linux-gnu/libQtNetwork.so;optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so; //Dependencies for target protobuf-lite_LIB_DEPENDS:STATIC= //Value Computed by CMake protobuf_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/ThirdParty/protobuf/vtkprotobuf //Dependencies for the target protobuf_LIB_DEPENDS:STATIC=general;/usr/lib/x86_64-linux-gnu/libz.so; //Value Computed by CMake protobuf_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/ThirdParty/protobuf/vtkprotobuf //The directory containing a CMake configuration file for qttesting. qttesting_DIR:PATH=qttesting_DIR-NOTFOUND //Path to smooth.flash data file. smooth_flash:FILEPATH=smooth_flash-NOTFOUND //Value Computed by CMake verdict_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/verdict/vtkverdict //Dependencies for target verdict_LIB_DEPENDS:STATIC= //Value Computed by CMake verdict_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/verdict/vtkverdict //Dependencies for the target vtkCPTestDriver_LIB_DEPENDS:STATIC=general;vtkCoProcessorImplementation;general;vtkFiltersCore; //Dependencies for the target vtkChartsCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkChartsCore; //Dependencies for the target vtkChartsCore_LIB_DEPENDS:STATIC=general;vtkCommonColor;general;vtkInfovisCore;general;vtkRenderingContext2D; //Dependencies for the target vtkClientServer_LIB_DEPENDS:STATIC=general;vtkCommonCore; //Dependencies for the target vtkCoProcessorCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCoProcessor; //Dependencies for the target vtkCoProcessorImplementation_LIB_DEPENDS:STATIC=general;vtkCoProcessor;general;vtkPVServerManagerApplication; //Dependencies for the target vtkCoProcessor_LIB_DEPENDS:STATIC=general;vtkPVServerManagerCore; //Dependencies for the target vtkCommonColorCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonColor; //Dependencies for the target vtkCommonColor_LIB_DEPENDS:STATIC=general;vtkCommonDataModel; //Dependencies for the target vtkCommonComputationalGeometryCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonComputationalGeometry; //Dependencies for the target vtkCommonComputationalGeometry_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonMath;general;vtkCommonSystem; //Dependencies for the target vtkCommonCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonCore; //Dependencies for the target vtkCommonCore_LIB_DEPENDS:STATIC=general;vtksys; //Dependencies for the target vtkCommonDataModelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonDataModel; //Dependencies for the target vtkCommonDataModel_LIB_DEPENDS:STATIC=general;vtkCommonMath;general;vtkCommonMisc;general;vtkCommonSystem;general;vtkCommonTransforms; //Dependencies for the target vtkCommonExecutionModelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonExecutionModel; //Dependencies for the target vtkCommonExecutionModel_LIB_DEPENDS:STATIC=general;vtkCommonDataModel; //Dependencies for the target vtkCommonMathCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonMath; //Dependencies for the target vtkCommonMath_LIB_DEPENDS:STATIC=general;vtkCommonCore; //Dependencies for the target vtkCommonMiscCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonMisc; //Dependencies for the target vtkCommonMisc_LIB_DEPENDS:STATIC=general;vtkCommonMath; //Dependencies for the target vtkCommonSystemCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonSystem; //Dependencies for the target vtkCommonSystem_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtksys; //Dependencies for the target vtkCommonTransformsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonTransforms; //Dependencies for the target vtkCommonTransforms_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtkCommonMath; //Dependencies for target vtkDICOMParser_LIB_DEPENDS:STATIC= //Dependencies for the target vtkDomainsChemistryCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkDomainsChemistry; //Dependencies for the target vtkDomainsChemistry_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkIOXML;general;vtkRenderingCore; //Value Computed by CMake vtkExodus2_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/exodusII/vtkexodusII //Value Computed by CMake vtkExodus2_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/exodusII/vtkexodusII //Dependencies for the target vtkEyeDomeLightingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkEyeDomeLighting; //Dependencies for the target vtkEyeDomeLighting_LIB_DEPENDS:STATIC=general;vtkRenderingOpenGL; //Dependencies for the target vtkFiltersAMRCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersAMR; //Dependencies for the target vtkFiltersAMR_LIB_DEPENDS:STATIC=general;vtkFiltersGeneral;general;vtkParallelCore; //Dependencies for the target vtkFiltersCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersCore; //Dependencies for the target vtkFiltersCore_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkCommonMath;general;vtkCommonMisc;general;vtkCommonSystem;general;vtkCommonTransforms; //Dependencies for the target vtkFiltersCosmoCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersCosmo; //Dependencies for the target vtkFiltersCosmo_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;Cosmo;general;vtkParallelCore; //Dependencies for the target vtkFiltersExtractionCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersExtraction; //Dependencies for the target vtkFiltersExtraction_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkFiltersCore;general;vtkFiltersGeneral;general;vtkFiltersStatistics; //Dependencies for the target vtkFiltersFlowPathsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersFlowPaths; //Dependencies for the target vtkFiltersFlowPaths_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkFiltersGeneral;general;vtkFiltersSources;general;vtkIOCore; //Dependencies for the target vtkFiltersGeneralCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersGeneral; //Dependencies for the target vtkFiltersGeneral_LIB_DEPENDS:STATIC=general;vtkCommonComputationalGeometry;general;vtkFiltersCore; //Dependencies for the target vtkFiltersGenericCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersGeneric; //Dependencies for the target vtkFiltersGeneric_LIB_DEPENDS:STATIC=general;vtkFiltersCore;general;vtkFiltersSources; //Dependencies for the target vtkFiltersGeometryCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersGeometry; //Dependencies for the target vtkFiltersGeometry_LIB_DEPENDS:STATIC=general;vtkFiltersCore; //Dependencies for the target vtkFiltersHybridCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersHybrid; //Dependencies for the target vtkFiltersHybrid_LIB_DEPENDS:STATIC=general;vtkFiltersGeneral;general;vtkImagingSources;general;vtkRenderingCore; //Dependencies for the target vtkFiltersHyperTreeCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersHyperTree; //Dependencies for the target vtkFiltersHyperTree_LIB_DEPENDS:STATIC=general;vtkFiltersGeneral; //Dependencies for the target vtkFiltersImagingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersImaging; //Dependencies for the target vtkFiltersImaging_LIB_DEPENDS:STATIC=general;vtkFiltersStatistics;general;vtkImagingGeneral;general;vtkImagingSources; //Dependencies for the target vtkFiltersModelingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersModeling; //Dependencies for the target vtkFiltersModeling_LIB_DEPENDS:STATIC=general;vtkFiltersGeneral;general;vtkFiltersSources; //Dependencies for the target vtkFiltersParallelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersParallel; //Dependencies for the target vtkFiltersParallelFlowPathsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersParallelFlowPaths; //Dependencies for the target vtkFiltersParallelFlowPaths_LIB_DEPENDS:STATIC=general;vtkFiltersAMR;general;vtkFiltersFlowPaths;general;vtkParallelCore;general;vtkParallelMPI; //Dependencies for the target vtkFiltersParallelImagingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersParallelImaging; //Dependencies for the target vtkFiltersParallelImaging_LIB_DEPENDS:STATIC=general;vtkFiltersImaging;general;vtkFiltersParallel;general;vtkIOLegacy;general;vtkImagingCore;general;vtkParallelCore; //Dependencies for the target vtkFiltersParallelMPICS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersParallelMPI; //Dependencies for the target vtkFiltersParallelMPI_LIB_DEPENDS:STATIC=general;vtkFiltersExtraction;general;vtkFiltersGeneral;general;vtkFiltersParallel;general;vtkParallelMPI; //Dependencies for the target vtkFiltersParallelStatisticsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersParallelStatistics; //Dependencies for the target vtkFiltersParallelStatistics_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonMath;general;vtkCommonSystem;general;vtkFiltersStatistics;general;vtkParallelCore;general;vtkalglib; //Dependencies for the target vtkFiltersParallel_LIB_DEPENDS:STATIC=general;vtkFiltersExtraction;general;vtkFiltersModeling;general;vtkParallelCore;general;vtkRenderingCore; //Dependencies for the target vtkFiltersProgrammableCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersProgrammable; //Dependencies for the target vtkFiltersProgrammable_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel; //Dependencies for the target vtkFiltersSourcesCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersSources; //Dependencies for the target vtkFiltersSources_LIB_DEPENDS:STATIC=general;vtkCommonComputationalGeometry;general;vtkFiltersGeneral; //Dependencies for the target vtkFiltersStatisticsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersStatistics; //Dependencies for the target vtkFiltersStatistics_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkCommonMath;general;vtkCommonMisc;general;vtkCommonTransforms;general;vtkImagingFourier;general;vtkalglib; //Dependencies for the target vtkFiltersTextureCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersTexture; //Dependencies for the target vtkFiltersTexture_LIB_DEPENDS:STATIC=general;vtkFiltersGeneral; //Dependencies for the target vtkFiltersVerdictCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkFiltersVerdict; //Dependencies for the target vtkFiltersVerdict_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;verdict; //Dependencies for the target vtkGUISupportQt_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkImagingCore;general;vtkInteractionStyle;general;vtkRenderingOpenGL;optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so;optimized;/usr/lib/x86_64-linux-gnu/libQtNetwork.so;debug;/usr/lib/x86_64-linux-gnu/libQtNetwork.so;optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so;general;/usr/lib/x86_64-linux-gnu/libSM.so;general;/usr/lib/x86_64-linux-gnu/libICE.so;general;/usr/lib/x86_64-linux-gnu/libX11.so;general;/usr/lib/x86_64-linux-gnu/libXext.so; //Dependencies for the target vtkIOAMRCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOAMR; //Dependencies for the target vtkIOAMR_LIB_DEPENDS:STATIC=general;vtkFiltersAMR;general;vtkParallelCore;general;vtkhdf5_hl;general;vtkhdf5; //Dependencies for the target vtkIOCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOCore; //Dependencies for the target vtkIOCore_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonExecutionModel;general;vtkCommonMisc;general;vtksys;general;vtkzlib; //Dependencies for the target vtkIOEnSightCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOEnSight; //Dependencies for the target vtkIOEnSight_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel; //Dependencies for the target vtkIOExodusCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOExodus; //Dependencies for the target vtkIOExodus_LIB_DEPENDS:STATIC=general;vtkFiltersGeneral;general;vtkIOXML;general;vtkexoIIc; //Dependencies for the target vtkIOExportCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOExport; //Dependencies for the target vtkIOExport_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtkIOCore;general;vtkImagingCore;general;vtkRenderingContext2D;general;vtkRenderingCore;general;vtkRenderingFreeType;general;vtkRenderingGL2PS;general;vtkRenderingOpenGL; //Dependencies for the target vtkIOGeometryCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOGeometry; //Dependencies for the target vtkIOGeometry_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonMisc;general;vtkCommonSystem;general;vtkIOCore;general;vtkzlib; //Dependencies for the target vtkIOImageCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOImage; //Dependencies for the target vtkIOImage_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonExecutionModel;general;vtkCommonMath;general;vtkCommonMisc;general;vtkCommonSystem;general;vtkCommonTransforms;general;vtkDICOMParser;general;vtkIOCore;general;vtkmetaio;general;vtkjpeg;general;vtkpng;general;vtktiff; //Dependencies for the target vtkIOImportCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOImport; //Dependencies for the target vtkIOImport_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtkRenderingCore; //Dependencies for the target vtkIOInfovisCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOInfovis; //Dependencies for the target vtkIOInfovis_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonMisc;general;vtkCommonSystem;general;vtkIOCore;general;vtkIOLegacy;general;vtkInfovisCore;general;vtklibxml2; //Dependencies for the target vtkIOLSDynaCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOLSDyna; //Dependencies for the target vtkIOLSDyna_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkIOXML; //Dependencies for the target vtkIOLegacyCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOLegacy; //Dependencies for the target vtkIOLegacy_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonMisc;general;vtkCommonSystem;general;vtkIOCore; //Dependencies for the target vtkIOMPIImageCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOMPIImage; //Dependencies for the target vtkIOMPIImage_LIB_DEPENDS:STATIC=general;vtkIOImage;general;vtkIOImage;general;vtkParallelMPI; //Dependencies for the target vtkIOMovieCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOMovie; //Dependencies for the target vtkIOMovie_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonExecutionModel;general;vtkCommonSystem;general;vtkIOCore;general;vtkoggtheora; //Dependencies for the target vtkIONetCDFCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIONetCDF; //Dependencies for the target vtkIONetCDF_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonSystem;general;vtkIOCore;general;vtkNetCDF_cxx; //Dependencies for the target vtkIOPLYCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOPLY; //Dependencies for the target vtkIOPLY_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkCommonMisc;general;vtkIOGeometry; //Dependencies for the target vtkIOParallelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOParallel; //Dependencies for the target vtkIOParallelExodusCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOParallelExodus; //Dependencies for the target vtkIOParallelExodus_LIB_DEPENDS:STATIC=general;vtkIOExodus;general;vtkIOExodus;general;vtkParallelCore;general;vtkexoIIc; //Dependencies for the target vtkIOParallelLSDynaCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOParallelLSDyna; //Dependencies for the target vtkIOParallelLSDyna_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkIOLSDyna;general;vtkParallelCore; //Dependencies for the target vtkIOParallelNetCDFCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOParallelNetCDF; //Dependencies for the target vtkIOParallelNetCDF_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtkParallelMPI;general;vtkNetCDF_cxx; //Dependencies for the target vtkIOParallel_LIB_DEPENDS:STATIC=general;vtkFiltersParallel;general;vtkIONetCDF;general;vtkIOXML;general;vtkParallelCore;general;vtkexoIIc; //Dependencies for the target vtkIOVPICCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOVPIC; //Dependencies for the target vtkIOVPIC_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkParallelCore;general;VPIC; //Dependencies for the target vtkIOXMLCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOXML; //Dependencies for the target vtkIOXMLParserCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOXMLParser; //Dependencies for the target vtkIOXMLParser_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonMisc;general;vtkCommonSystem;general;vtkIOCore;general;vtkexpat; //Dependencies for the target vtkIOXML_LIB_DEPENDS:STATIC=general;vtkIOGeometry;general;vtkIOXMLParser; //Dependencies for the target vtkIOXdmf2CS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkIOXdmf2; //Dependencies for the target vtkIOXdmf2_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtkCommonDataModel;general;vtkCommonExecutionModel;general;vtkFiltersExtraction;general;vtkIOLegacy;general;vtkIOXML;general;vtkxdmf2; //Dependencies for the target vtkImagingColorCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImagingColor; //Dependencies for the target vtkImagingColor_LIB_DEPENDS:STATIC=general;vtkImagingCore; //Dependencies for the target vtkImagingCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImagingCore; //Dependencies for the target vtkImagingCore_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkCommonMath;general;vtkCommonSystem;general;vtkCommonTransforms; //Dependencies for the target vtkImagingFourierCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImagingFourier; //Dependencies for the target vtkImagingFourier_LIB_DEPENDS:STATIC=general;vtkImagingCore; //Dependencies for the target vtkImagingGeneralCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImagingGeneral; //Dependencies for the target vtkImagingGeneral_LIB_DEPENDS:STATIC=general;vtkImagingSources; //Dependencies for the target vtkImagingHybridCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImagingHybrid; //Dependencies for the target vtkImagingHybrid_LIB_DEPENDS:STATIC=general;vtkIOImage;general;vtkImagingCore; //Dependencies for the target vtkImagingMorphologicalCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImagingMorphological; //Dependencies for the target vtkImagingMorphological_LIB_DEPENDS:STATIC=general;vtkImagingCore;general;vtkImagingGeneral; //Dependencies for the target vtkImagingSourcesCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkImagingSources; //Dependencies for the target vtkImagingSources_LIB_DEPENDS:STATIC=general;vtkImagingCore; //Dependencies for the target vtkInfovisCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkInfovisCore; //Dependencies for the target vtkInfovisCore_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonSystem;general;vtkFiltersExtraction;general;vtkFiltersGeneral; //Dependencies for the target vtkInteractionImageCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkInteractionImage; //Dependencies for the target vtkInteractionImage_LIB_DEPENDS:STATIC=general;vtkImagingColor;general;vtkInteractionStyle;general;vtkInteractionWidgets;general;vtkRenderingCore;general;vtkRenderingFreeType; //Dependencies for the target vtkInteractionStyleCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkInteractionStyle; //Dependencies for the target vtkInteractionStyle_LIB_DEPENDS:STATIC=general;vtkRenderingCore; //Dependencies for the target vtkInteractionWidgetsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkInteractionWidgets; //Dependencies for the target vtkInteractionWidgets_LIB_DEPENDS:STATIC=general;vtkFiltersHybrid;general;vtkFiltersModeling;general;vtkImagingGeneral;general;vtkImagingHybrid;general;vtkInteractionStyle;general;vtkRenderingAnnotation;general;vtkRenderingFreeType;general;vtkRenderingVolume; //Dependencies for the target vtkNetCDF_LIB_DEPENDS:STATIC=general;vtkhdf5_hl;general;vtkhdf5;general;m; //Dependencies for the target vtkNetCDF_cxx_LIB_DEPENDS:STATIC=general;vtkNetCDF; //Dependencies for the target vtkPVClientServerCoreCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVClientServerCoreCore; //Dependencies for the target vtkPVClientServerCoreCore_LIB_DEPENDS:STATIC=general;vtkFiltersExtraction;general;vtkFiltersParallel;general;vtkPVCommon;general;vtkPVCommon;general;vtkPVVTKExtensionsCore;general;vtkParallelMPI; //Dependencies for the target vtkPVClientServerCoreDefaultCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVClientServerCoreDefault; //Dependencies for the target vtkPVClientServerCoreDefault_LIB_DEPENDS:STATIC=general;vtkPVClientServerCoreRendering;general;vtkPVVTKExtensionsDefault; //Dependencies for the target vtkPVClientServerCoreRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVClientServerCoreRendering; //Dependencies for the target vtkPVClientServerCoreRendering_LIB_DEPENDS:STATIC=general;vtkDomainsChemistry;general;vtkFiltersAMR;general;vtkPVClientServerCoreCore;general;vtkPVVTKExtensionsRendering;general;vtkPVVTKExtensionsWebGLExporter;general;vtkRenderingLabel;general;vtkRenderingVolumeAMR;general;vtkRenderingVolumeOpenGL;general;vtkViewsContext2D;general;vtkViewsCore; //Dependencies for the target vtkPVCommonCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVCommon; //Dependencies for the target vtkPVCommon_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkCommonCore;general;vtkIOXMLParser; //Dependencies for the target vtkPVServerImplementationCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerImplementationCore; //Dependencies for the target vtkPVServerImplementationCore_LIB_DEPENDS:STATIC=general;vtkPVClientServerCoreCore;general;protobuf; //Dependencies for the target vtkPVServerImplementationDefaultCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerImplementationDefault; //Dependencies for the target vtkPVServerImplementationDefault_LIB_DEPENDS:STATIC=general;vtkPVClientServerCoreDefault;general;vtkPVServerImplementationRendering; //Dependencies for the target vtkPVServerImplementationRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerImplementationRendering; //Dependencies for the target vtkPVServerImplementationRendering_LIB_DEPENDS:STATIC=general;vtkPVClientServerCoreRendering;general;vtkPVServerImplementationCore; //Dependencies for the target vtkPVServerManagerApplicationCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerManagerApplication; //Dependencies for the target vtkPVServerManagerApplication_LIB_DEPENDS:STATIC=general;vtkPVServerManagerCore;general;vtkCommonCoreCS;general;vtkCommonMathCS;general;vtkCommonMiscCS;general;vtkCommonSystemCS;general;vtkCommonTransformsCS;general;vtkCommonDataModelCS;general;vtkCommonExecutionModelCS;general;vtkImagingCoreCS;general;vtkFiltersCoreCS;general;vtkCommonComputationalGeometryCS;general;vtkFiltersGeneralCS;general;vtkImagingFourierCS;general;vtkFiltersStatisticsCS;general;vtkFiltersExtractionCS;general;vtkFiltersGeometryCS;general;vtkFiltersSourcesCS;general;vtkIOCoreCS;general;vtkIOImageCS;general;vtkIOXMLParserCS;general;vtkRenderingCoreCS;general;vtkInteractionStyleCS;general;vtkImagingHybridCS;general;vtkRenderingOpenGLCS;general;vtkFiltersModelingCS;general;vtkIOLegacyCS;general;vtkParallelCoreCS;general;vtkFiltersParallelCS;general;vtkPVCommonCS;general;vtkPVVTKExtensionsCoreCS;general;vtkParallelMPICS;general;vtkPVClientServerCoreCoreCS;general;vtkPVServerImplementationCoreCS;general;vtkPVServerManagerCoreCS;general;vtkCommonColorCS;general;vtkInfovisCoreCS;general;vtkRenderingFreeTypeCS;general;vtkRenderingContext2DCS;general;vtkChartsCoreCS;general;vtkIOGeometryCS;general;vtkIOXMLCS;general;vtkDomainsChemistryCS;general;vtkFiltersAMRCS;general;vtkFiltersCosmoCS;general;vtkFiltersFlowPathsCS;general;vtkFiltersGenericCS;general;vtkImagingSourcesCS;general;vtkFiltersHybridCS;general;vtkFiltersHyperTreeCS;general;vtkFiltersParallelFlowPathsCS;general;vtkImagingGeneralCS;general;vtkFiltersImagingCS;general;vtkFiltersParallelImagingCS;general;vtkFiltersParallelMPICS;general;vtkFiltersParallelStatisticsCS;general;vtkFiltersProgrammableCS;general;vtkFiltersTextureCS;general;vtkFiltersVerdictCS;general;vtkIOAMRCS;general;vtkIOEnSightCS;general;vtkIOExodusCS;general;vtkRenderingGL2PSCS;general;vtkIOExportCS;general;vtkIOImportCS;general;vtkIOInfovisCS;general;vtkIOMPIImageCS;general;vtkIOMovieCS;general;vtkIONetCDFCS;general;vtkIOPLYCS;general;vtkIOParallelCS;general;vtkIOParallelExodusCS;general;vtkIOLSDynaCS;general;vtkIOParallelLSDynaCS;general;vtkIOParallelNetCDFCS;general;vtkIOVPICCS;general;vtkIOXdmf2CS;general;vtkImagingMorphologicalCS;general;vtkImagingColorCS;general;vtkRenderingAnnotationCS;general;vtkRenderingVolumeCS;general;vtkInteractionWidgetsCS;general;vtkInteractionImageCS;general;vtkRenderingFreeTypeOpenGLCS;general;vtkRenderingParallelCS;general;vtkPVVTKExtensionsRenderingCS;general;vtkPVVTKExtensionsWebGLExporterCS;general;vtkRenderingLabelCS;general;vtkRenderingVolumeAMRCS;general;vtkRenderingVolumeOpenGLCS;general;vtkViewsCoreCS;general;vtkViewsContext2DCS;general;vtkPVClientServerCoreRenderingCS;general;vtkPVVTKExtensionsDefaultCS;general;vtkPVClientServerCoreDefaultCS;general;vtkPVServerImplementationRenderingCS;general;vtkPVServerImplementationDefaultCS;general;vtkPVServerManagerRenderingCS;general;vtkTestingRenderingCS;general;vtkPVServerManagerDefaultCS;general;vtkRenderingHybridOpenGLCS;general;vtkRenderingLODCS;general;vtkCoProcessorCS;general;vtkPVServerManagerCore; //Dependencies for the target vtkPVServerManagerCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerManagerCore; //Dependencies for the target vtkPVServerManagerCore_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtkPVServerImplementationCore; //Dependencies for the target vtkPVServerManagerDefaultCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerManagerDefault; //Dependencies for the target vtkPVServerManagerDefault_LIB_DEPENDS:STATIC=general;vtkIOMovie;general;vtkIOParallelExodus;general;vtkPVServerImplementationDefault;general;vtkPVServerManagerRendering;general;vtkRenderingVolumeOpenGL;general;vtkTestingRendering; //Dependencies for the target vtkPVServerManagerRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVServerManagerRendering; //Dependencies for the target vtkPVServerManagerRendering_LIB_DEPENDS:STATIC=general;vtkPVServerImplementationRendering;general;vtkPVServerManagerCore; //Dependencies for the target vtkPVVTKExtensionsCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVVTKExtensionsCore; //Dependencies for the target vtkPVVTKExtensionsCore_LIB_DEPENDS:STATIC=general;vtkFiltersCore;general;vtkPVCommon;general;vtkParallelCore; //Dependencies for the target vtkPVVTKExtensionsDefaultCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVVTKExtensionsDefault; //Dependencies for the target vtkPVVTKExtensionsDefault_LIB_DEPENDS:STATIC=general;vtkFiltersAMR;general;vtkFiltersParallelStatistics;general;vtkIOEnSight;general;vtkIOImport;general;vtkIOParallel;general;vtkIOParallelExodus;general;vtkImagingFourier;general;vtkImagingSources;general;vtkInteractionWidgets;general;vtkPVClientServerCoreRendering;general;vtkPVVTKExtensionsCore;general;vtkPVVTKExtensionsRendering; //Dependencies for the target vtkPVVTKExtensionsRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVVTKExtensionsRendering; //Dependencies for the target vtkPVVTKExtensionsRendering_LIB_DEPENDS:STATIC=general;vtkChartsCore;general;vtkFiltersExtraction;general;vtkFiltersGeneric;general;vtkFiltersHyperTree;general;vtkFiltersParallel;general;vtkFiltersParallelMPI;general;vtkGUISupportQt;general;vtkIOExport;general;vtkIOXML;general;vtkInteractionStyle;general;vtkInteractionWidgets;general;vtkPVVTKExtensionsCore;general;vtkRenderingAnnotation;general;vtkRenderingFreeTypeOpenGL;general;vtkRenderingOpenGL;general;vtkRenderingParallel;general;IceTCore;general;IceTMPI;general;IceTGL; //Dependencies for the target vtkPVVTKExtensionsWebGLExporterCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPVVTKExtensionsWebGLExporter; //Dependencies for the target vtkPVVTKExtensionsWebGLExporter_LIB_DEPENDS:STATIC=general;vtkIOExport;general;vtkInteractionWidgets;general;vtkRenderingCore; //Dependencies for the target vtkParaViewDocumentation_LIB_DEPENDS:STATIC=optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so;optimized;/usr/lib/x86_64-linux-gnu/libQtNetwork.so;debug;/usr/lib/x86_64-linux-gnu/libQtNetwork.so;optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so; //Dependencies for the target vtkParallelCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkParallelCore; //Dependencies for the target vtkParallelCore_LIB_DEPENDS:STATIC=general;vtkCommonCore;general;vtkIOLegacy; //Dependencies for the target vtkParallelMPICS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkParallelMPI; //Dependencies for the target vtkParallelMPI_LIB_DEPENDS:STATIC=general;vtkParallelCore;general;/usr/lib/openmpi/lib/libmpi.so;general;/usr/lib/openmpi/lib/libopen-rte.so;general;/usr/lib/openmpi/lib/libopen-pal.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/x86_64-linux-gnu/libnsl.so;general;/usr/lib/x86_64-linux-gnu/libutil.so;general;/usr/lib/x86_64-linux-gnu/libm.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/openmpi/lib/libmpi_cxx.so;general;/usr/lib/openmpi/lib/libmpi.so;general;/usr/lib/openmpi/lib/libopen-rte.so;general;/usr/lib/openmpi/lib/libopen-pal.so;general;/usr/lib/x86_64-linux-gnu/libdl.so;general;/usr/lib/x86_64-linux-gnu/libnsl.so;general;/usr/lib/x86_64-linux-gnu/libutil.so;general;/usr/lib/x86_64-linux-gnu/libm.so;general;/usr/lib/x86_64-linux-gnu/libdl.so; //Dependencies for the target vtkPointSpriteGraphicsCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPointSpriteGraphics; //Dependencies for the target vtkPointSpriteGraphics_LIB_DEPENDS:STATIC=general;vtkFiltersCore; //Dependencies for the target vtkPointSpriteRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkPointSpriteRendering; //Dependencies for the target vtkPointSpriteRendering_LIB_DEPENDS:STATIC=general;vtkFiltersHybrid;general;vtkImagingCore;general;vtkInteractionStyle;general;vtkRenderingFreeTypeOpenGL;general;vtkRenderingOpenGL; //Dependencies for the target vtkQvis_LIB_DEPENDS:STATIC=general;vtkCommonCore;optimized;/usr/lib/x86_64-linux-gnu/libQtGui.so;debug;/usr/lib/x86_64-linux-gnu/libQtGui.so;optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so; //Dependencies for the target vtkRenderingAnnotationCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingAnnotation; //Dependencies for the target vtkRenderingAnnotation_LIB_DEPENDS:STATIC=general;vtkImagingColor;general;vtkRenderingFreeType; //Dependencies for the target vtkRenderingContext2DCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingContext2D; //Dependencies for the target vtkRenderingContext2D_LIB_DEPENDS:STATIC=general;vtkCommonDataModel;general;vtkCommonMath;general;vtkCommonTransforms;general;vtkRenderingCore;general;vtkRenderingFreeType;general;vtkRenderingOpenGL; //Dependencies for the target vtkRenderingCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingCore; //Dependencies for the target vtkRenderingCore_LIB_DEPENDS:STATIC=general;vtkCommonExecutionModel;general;vtkCommonTransforms;general;vtkFiltersExtraction;general;vtkFiltersGeneral;general;vtkFiltersGeometry;general;vtkFiltersSources;general;vtkIOImage;general;vtkIOXMLParser; //Dependencies for the target vtkRenderingFreeTypeCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingFreeType; //Dependencies for the target vtkRenderingFreeTypeOpenGLCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingFreeTypeOpenGL; //Dependencies for the target vtkRenderingFreeTypeOpenGL_LIB_DEPENDS:STATIC=general;vtkRenderingCore;general;vtkRenderingFreeType;general;vtkRenderingOpenGL; //Dependencies for the target vtkRenderingFreeType_LIB_DEPENDS:STATIC=general;vtkRenderingCore;general;vtkRenderingCore;general;vtkfreetype;general;vtkftgl; //Dependencies for the target vtkRenderingGL2PSCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingGL2PS; //Dependencies for the target vtkRenderingGL2PS_LIB_DEPENDS:STATIC=general;vtkRenderingContext2D;general;vtkgl2ps; //Dependencies for the target vtkRenderingHybridOpenGLCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingHybridOpenGL; //Dependencies for the target vtkRenderingHybridOpenGL_LIB_DEPENDS:STATIC=general;vtkIOLegacy;general;vtkImagingHybrid;general;vtkImagingSources;general;vtkRenderingOpenGL; //Dependencies for the target vtkRenderingLODCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingLOD; //Dependencies for the target vtkRenderingLOD_LIB_DEPENDS:STATIC=general;vtkFiltersModeling;general;vtkRenderingCore; //Dependencies for the target vtkRenderingLabelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingLabel; //Dependencies for the target vtkRenderingLabel_LIB_DEPENDS:STATIC=general;vtkRenderingFreeType; //Dependencies for the target vtkRenderingOpenGLCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingOpenGL; //Dependencies for the target vtkRenderingOpenGL_LIB_DEPENDS:STATIC=general;vtkImagingHybrid;general;vtkRenderingCore;general;/usr/lib/x86_64-linux-gnu/libGLU.so;general;/usr/lib/libGL.so;general;/usr/lib/x86_64-linux-gnu/libSM.so;general;/usr/lib/x86_64-linux-gnu/libICE.so;general;/usr/lib/x86_64-linux-gnu/libX11.so;general;/usr/lib/x86_64-linux-gnu/libXext.so;general;/usr/lib/libXNVCtrl.a;general;/usr/lib/x86_64-linux-gnu/libSM.so;general;/usr/lib/x86_64-linux-gnu/libICE.so;general;/usr/lib/x86_64-linux-gnu/libX11.so;general;/usr/lib/x86_64-linux-gnu/libXext.so;general;/usr/lib/x86_64-linux-gnu/libXt.so; //Dependencies for the target vtkRenderingParallelCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingParallel; //Dependencies for the target vtkRenderingParallel_LIB_DEPENDS:STATIC=general;vtkFiltersParallel;general;vtkParallelCore;general;vtkRenderingOpenGL; //Dependencies for the target vtkRenderingVolumeAMRCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingVolumeAMR; //Dependencies for the target vtkRenderingVolumeAMR_LIB_DEPENDS:STATIC=general;vtkFiltersAMR;general;vtkParallelCore;general;vtkRenderingVolume; //Dependencies for the target vtkRenderingVolumeCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingVolume; //Dependencies for the target vtkRenderingVolumeOpenGLCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkRenderingVolumeOpenGL; //Dependencies for the target vtkRenderingVolumeOpenGL_LIB_DEPENDS:STATIC=general;vtkRenderingOpenGL;general;vtkRenderingVolume; //Dependencies for the target vtkRenderingVolume_LIB_DEPENDS:STATIC=general;vtkImagingCore;general;vtkRenderingCore; //Dependencies for the target vtkTestingGenericBridge_LIB_DEPENDS:STATIC=general;vtkCommonDataModel; //Dependencies for the target vtkTestingRenderingCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkTestingRendering; //Dependencies for the target vtkTestingRendering_LIB_DEPENDS:STATIC=general;vtkImagingCore;general;vtkRenderingCore; //Dependencies for the target vtkViewsContext2DCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkViewsContext2D; //Dependencies for the target vtkViewsContext2D_LIB_DEPENDS:STATIC=general;vtkRenderingContext2D;general;vtkViewsCore; //Dependencies for the target vtkViewsCoreCS_LIB_DEPENDS:STATIC=general;vtkClientServer;general;vtkViewsCore; //Dependencies for the target vtkViewsCore_LIB_DEPENDS:STATIC=general;vtkInteractionWidgets;general;vtkRenderingCore; //Dependencies for target vtkWrappingTools_LIB_DEPENDS:STATIC= //Dependencies for target vtkalglib_LIB_DEPENDS:STATIC= //Dependencies for the target vtkexoIIc_LIB_DEPENDS:STATIC=general;vtkNetCDF; //Dependencies for target vtkexpat_LIB_DEPENDS:STATIC= //Dependencies for the target vtkfreetype_LIB_DEPENDS:STATIC=general;vtkzlib; //Dependencies for the target vtkftgl_LIB_DEPENDS:STATIC=general;/usr/lib/libGL.so;general;vtkfreetype; //Dependencies for the target vtkgl2ps_LIB_DEPENDS:STATIC=general;/usr/lib/x86_64-linux-gnu/libGLU.so;general;/usr/lib/libGL.so;general;/usr/lib/x86_64-linux-gnu/libSM.so;general;/usr/lib/x86_64-linux-gnu/libICE.so;general;/usr/lib/x86_64-linux-gnu/libX11.so;general;/usr/lib/x86_64-linux-gnu/libXext.so;general;m;general;vtkzlib;general;vtkpng;general;m; //Dependencies for the target vtkhdf5_LIB_DEPENDS:STATIC=general;m;general;vtkzlib; //Dependencies for the target vtkhdf5_hl_LIB_DEPENDS:STATIC=general;vtkhdf5; //Dependencies for target vtkjpeg_LIB_DEPENDS:STATIC= //Value Computed by CMake vtklibxml2_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/libxml2/vtklibxml2 //Dependencies for the target vtklibxml2_LIB_DEPENDS:STATIC=general;dl;general;z;general;dl;general;m; //Value Computed by CMake vtklibxml2_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/libxml2/vtklibxml2 //Value Computed by CMake vtkmetaio_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/MetaIO/vtkmetaio //Dependencies for the target vtkmetaio_LIB_DEPENDS:STATIC=general;vtkzlib; //Value Computed by CMake vtkmetaio_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/Utilities/MetaIO/vtkmetaio //Dependencies for target vtkoggtheora_LIB_DEPENDS:STATIC= //Dependencies for the target vtkpng_LIB_DEPENDS:STATIC=general;vtkzlib;general;-lm; //Value Computed by CMake vtksys_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/KWSys/vtksys //Dependencies for the target vtksys_LIB_DEPENDS:STATIC=general;dl; //Value Computed by CMake vtksys_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/Utilities/KWSys/vtksys //Dependencies for the target vtktiff_LIB_DEPENDS:STATIC=general;vtkzlib;general;vtkjpeg;general;-lm; //Dependencies for the target vtkxdmf2_LIB_DEPENDS:STATIC=general;vtklibxml2;general;vtkhdf5_hl;general;vtkhdf5; //Dependencies for target vtkzlib_LIB_DEPENDS:STATIC= //Value Computed by CMake xdmf2_BINARY_DIR:STATIC=/mpi3/S2/ParaGit-BBUILD2/VTK/ThirdParty/xdmf2/vtkxdmf2 //Value Computed by CMake xdmf2_SOURCE_DIR:STATIC=/mpi3/S2/ParaView/VTK/ThirdParty/xdmf2/vtkxdmf2 ######################## # INTERNAL cache entries ######################## ALGLIB_SHARED_LIB:INTERNAL=ON //Host Arcitecture : Linux IRIXN32 IRIX64 AIX CYGWIN ARCH_TO_BUILD:INTERNAL=Linux //ADVANCED property for variable: BUILD_FORTRAN_COPROCESSING_ADAPTORS BUILD_FORTRAN_COPROCESSING_ADAPTORS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: BUILD_PARTICLE_COPROCESSING_ADAPTORS BUILD_PARTICLE_COPROCESSING_ADAPTORS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: BZRCOMMAND BZRCOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_ANSI_FOR_SCOPE:INTERNAL=TRUE //Have include iostream CMAKE_ANSI_STREAM_HEADERS:INTERNAL=1 //ADVANCED property for variable: CMAKE_AR CMAKE_AR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_BUILD_TOOL CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1 //What is the target build tool cmake is generating for. CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/make //STRINGS property for variable: CMAKE_BUILD_TYPE CMAKE_BUILD_TYPE-STRINGS:INTERNAL=Debug;Release;MinSizeRel;RelWithDebInfo //This is the directory where this CMakeCache.txt was created CMAKE_CACHEFILE_DIR:INTERNAL=/mpi3/S2/ParaGit-BBUILD2 //Major version of cmake used to create the current loaded cache CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2 //Minor version of cmake used to create the current loaded cache CMAKE_CACHE_MINOR_VERSION:INTERNAL=8 //Patch version of cmake used to create the current loaded cache CMAKE_CACHE_PATCH_VERSION:INTERNAL=9 //ADVANCED property for variable: CMAKE_COLOR_MAKEFILE CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1 //Path to CMake executable. CMAKE_COMMAND:INTERNAL=/usr/local/bin/cmake //Path to cpack program executable. CMAKE_CPACK_COMMAND:INTERNAL=/usr/local/bin/cpack //ADVANCED property for variable: CMAKE_CTEST_COMMAND CMAKE_CTEST_COMMAND-ADVANCED:INTERNAL=1 //Path to ctest program executable. CMAKE_CTEST_COMMAND:INTERNAL=/usr/local/bin/ctest //ADVANCED property for variable: CMAKE_CXX_COMPILER CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1 CMAKE_CXX_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_COMPILER CMAKE_C_COMPILER-ADVANCED:INTERNAL=1 CMAKE_C_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS CMAKE_C_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE //Executable file format CMAKE_EXECUTABLE_FORMAT:INTERNAL=ELF //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXPORT_COMPILE_COMMANDS CMAKE_EXPORT_COMPILE_COMMANDS-ADVANCED:INTERNAL=1 //Name of generator. CMAKE_GENERATOR:INTERNAL=Unix Makefiles //Result of TRY_COMPILE CMAKE_HAS_ANSI_STRING_STREAM:INTERNAL=TRUE //Have function connect CMAKE_HAVE_CONNECT:INTERNAL=1 //Have function gethostbyname CMAKE_HAVE_GETHOSTBYNAME:INTERNAL=1 //Have symbol pthread_create CMAKE_HAVE_LIBC_CREATE:INTERNAL=1 //Have include pthread.h CMAKE_HAVE_PTHREAD_H:INTERNAL=1 //Have function remove CMAKE_HAVE_REMOVE:INTERNAL=1 //Have function shmat CMAKE_HAVE_SHMAT:INTERNAL=1 //Start directory with the top level CMakeLists.txt file for this // project CMAKE_HOME_DIRECTORY:INTERNAL=/mpi3/S2/ParaView //Install .so files without execute permission. CMAKE_INSTALL_SO_NO_EXE:INTERNAL=1 //Have library ICE CMAKE_LIB_ICE_HAS_ICECONNECTIONNUMBER:INTERNAL=1 //ADVANCED property for variable: CMAKE_LINKER CMAKE_LINKER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MAKE_PROGRAM CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_NM CMAKE_NM-ADVANCED:INTERNAL=1 //Does the compiler support ansi for scope. CMAKE_NO_ANSI_FOR_SCOPE:INTERNAL=0 //ADVANCED property for variable: CMAKE_NO_ANSI_STREAM_HEADERS CMAKE_NO_ANSI_STREAM_HEADERS-ADVANCED:INTERNAL=1 //Does the compiler support headers like iostream. CMAKE_NO_ANSI_STREAM_HEADERS:INTERNAL=0 //Does the compiler support sstream CMAKE_NO_ANSI_STRING_STREAM:INTERNAL=0 //Does the compiler support std::. CMAKE_NO_STD_NAMESPACE:INTERNAL=0 //number of local generators CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=290 //ADVANCED property for variable: CMAKE_OBJCOPY CMAKE_OBJCOPY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_OBJDUMP CMAKE_OBJDUMP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_RANLIB CMAKE_RANLIB-ADVANCED:INTERNAL=1 //Test Support for 64 bit file systems CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=1 //Path to CMake installation. CMAKE_ROOT:INTERNAL=/usr/local/share/cmake-2.8 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(unsigned short) CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=2 //ADVANCED property for variable: CMAKE_SKIP_INSTALL_RPATH CMAKE_SKIP_INSTALL_RPATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SKIP_RPATH CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_STD_NAMESPACE:INTERNAL=TRUE //ADVANCED property for variable: CMAKE_STRIP CMAKE_STRIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_THREAD_LIBS CMAKE_THREAD_LIBS-ADVANCED:INTERNAL=1 //uname command CMAKE_UNAME:INTERNAL=/bin/uname //ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1 //Result of TEST_BIG_ENDIAN CMAKE_WORDS_BIGENDIAN:INTERNAL=0 //Compiler support for a deprecated attribute COMPILER_HAS_DEPRECATED:INTERNAL=1 //Test COMPILER_HAS_DEPRECATED_ATTR COMPILER_HAS_DEPRECATED_ATTR:INTERNAL=1 //Test COMPILER_HAS_HIDDEN_INLINE_VISIBILITY COMPILER_HAS_HIDDEN_INLINE_VISIBILITY:INTERNAL=1 //Test COMPILER_HAS_HIDDEN_VISIBILITY COMPILER_HAS_HIDDEN_VISIBILITY:INTERNAL=1 //ADVANCED property for variable: COMPRESSIONCOMMAND COMPRESSIONCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COVERAGE_COMMAND COVERAGE_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COVERAGE_EXTRA_FLAGS COVERAGE_EXTRA_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_DEB CPACK_BINARY_DEB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_NSIS CPACK_BINARY_NSIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_RPM CPACK_BINARY_RPM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_STGZ CPACK_BINARY_STGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TBZ2 CPACK_BINARY_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TGZ CPACK_BINARY_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TZ CPACK_BINARY_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TBZ2 CPACK_SOURCE_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TGZ CPACK_SOURCE_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TZ CPACK_SOURCE_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_ZIP CPACK_SOURCE_ZIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CTEST_SUBMIT_RETRY_COUNT CTEST_SUBMIT_RETRY_COUNT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CTEST_SUBMIT_RETRY_DELAY CTEST_SUBMIT_RETRY_DELAY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVSCOMMAND CVSCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVS_UPDATE_OPTIONS CVS_UPDATE_OPTIONS-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CXX_HAVE_OFFSETOF:INTERNAL=TRUE //ADVANCED property for variable: DART_BUILD_ERROR_REPORT_LIMIT DART_BUILD_ERROR_REPORT_LIMIT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_BUILD_WARNING_REPORT_LIMIT DART_BUILD_WARNING_REPORT_LIMIT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_ROOT DART_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_TESTING_TIMEOUT DART_TESTING_TIMEOUT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_VERBOSE_BUILD DART_VERBOSE_BUILD-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DELIVER_CONTINUOUS_EMAIL DELIVER_CONTINUOUS_EMAIL-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE DEV_T_IS_SCALAR:INTERNAL=FALSE //ADVANCED property for variable: EXECUTABLE_OUTPUT_PATH EXECUTABLE_OUTPUT_PATH-ADVANCED:INTERNAL=1 EXECUTABLE_OUTPUT_PATH:INTERNAL=/mpi3/S2/ParaGit-BBUILD2/ThirdParty/protobuf/vtkprotobuf/bin //ADVANCED property for variable: EXODUSII_DISABLE_COMPILER_WARNINGS EXODUSII_DISABLE_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //Have include malloc.h EX_HAVE_MALLOC_H:INTERNAL=1 //ADVANCED property for variable: Eigen_DIR Eigen_DIR-ADVANCED:INTERNAL=1 //Details about finding Git FIND_PACKAGE_MESSAGE_DETAILS_Git:INTERNAL=[/usr/bin/git][v1.7.9.5()] //Details about finding MPI_C FIND_PACKAGE_MESSAGE_DETAILS_MPI_C:INTERNAL=[/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so][/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi][v()] //Details about finding MPI_CXX FIND_PACKAGE_MESSAGE_DETAILS_MPI_CXX:INTERNAL=[/usr/lib/openmpi/lib/libmpi_cxx.so;/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so][/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi][v()] //Details about finding OpenGL FIND_PACKAGE_MESSAGE_DETAILS_OpenGL:INTERNAL=[/usr/lib/libGL.so][v()] //Details about finding Qt4 FIND_PACKAGE_MESSAGE_DETAILS_Qt4:INTERNAL=[/usr/bin/qmake][/usr/bin/moc-qt4][/usr/bin/rcc][/usr/bin/uic-qt4][/usr/include/qt4][/usr/lib/x86_64-linux-gnu][optimized;/usr/lib/x86_64-linux-gnu/libQtCore.so;debug;/usr/lib/x86_64-linux-gnu/libQtCore.so][v4.8.1(4.7.0)] //Details about finding Threads FIND_PACKAGE_MESSAGE_DETAILS_Threads:INTERNAL=[TRUE][v()] //Details about finding X11 FIND_PACKAGE_MESSAGE_DETAILS_X11:INTERNAL=[/usr/lib/x86_64-linux-gnu/libX11.so][/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include] //Details about finding ZLIB FIND_PACKAGE_MESSAGE_DETAILS_ZLIB:INTERNAL=[/usr/lib/x86_64-linux-gnu/libz.so][/usr/include][v1.2.3.4()] //Result of TRY_COMPILE GETTIMEOFDAY_GIVES_TZ:INTERNAL=FALSE //ADVANCED property for variable: GITCOMMAND GITCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GIT_EXECUTABLE GIT_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_INCLUDE_DIR GLUT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_Xi_LIBRARY GLUT_Xi_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_Xmu_LIBRARY GLUT_Xmu_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_glut_LIBRARY GLUT_glut_LIBRARY-ADVANCED:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddress GLX_DECLARES_FUNCTION_glXGetProcAddress:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddressARB GLX_DECLARES_FUNCTION_glXGetProcAddressARB:INTERNAL=1 //Test GLX_DECLARES_FUNCTION_glXGetProcAddressARB_AS_EMPTY GLX_DECLARES_FUNCTION_glXGetProcAddressARB_AS_EMPTY:INTERNAL= //Test GLX_DECLARES_FUNCTION_glXGetProcAddress_AS_EMPTY GLX_DECLARES_FUNCTION_glXGetProcAddress_AS_EMPTY:INTERNAL= //Test GLX_DEFINES_MACRO_GLX_ARB_get_proc_address GLX_DEFINES_MACRO_GLX_ARB_get_proc_address:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_1 GLX_DEFINES_MACRO_GLX_VERSION_1_1:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_2 GLX_DEFINES_MACRO_GLX_VERSION_1_2:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_3 GLX_DEFINES_MACRO_GLX_VERSION_1_3:INTERNAL=1 //Test GLX_DEFINES_MACRO_GLX_VERSION_1_4 GLX_DEFINES_MACRO_GLX_VERSION_1_4:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXFBConfig GLX_DEFINES_TYPE_GLXFBConfig:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXextFuncPtr GLX_DEFINES_TYPE_GLXextFuncPtr:INTERNAL=1 //Test GLX_DEFINES_TYPE_GLXextFuncPtr_AS_EMPTY GLX_DEFINES_TYPE_GLXextFuncPtr_AS_EMPTY:INTERNAL= //Test GLX_INCLUDES_GLXEXT GLX_INCLUDES_GLXEXT:INTERNAL=1 GLX_USES_MACRO_GLX_GLXEXT_LEGACY:INTERNAL=TRUE //ADVANCED property for variable: GUNZIPCOMMAND GUNZIPCOMMAND-ADVANCED:INTERNAL=1 //Other test H5_CXX_HAVE_OFFSETOF:INTERNAL=1 //Other test H5_DEV_T_IS_SCALAR:INTERNAL= //Checking IF overflows normally converting floating-point to integer // values H5_FP_TO_INTEGER_OVERFLOW_WORKS:INTERNAL=1 //Result of TRY_COMPILE H5_FP_TO_INTEGER_OVERFLOW_WORKS_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_FP_TO_INTEGER_OVERFLOW_WORKS_RUN:INTERNAL=0 //Checking IF accurately roundup converting floating-point to unsigned // long long values H5_FP_TO_ULLONG_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_FP_TO_ULLONG_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_FP_TO_ULLONG_ACCURATE_RUN:INTERNAL=0 //Checking IF right maximum converting floating-point to unsigned // long long values H5_FP_TO_ULLONG_RIGHT_MAXIMUM:INTERNAL=1 //Result of TRY_COMPILE H5_FP_TO_ULLONG_RIGHT_MAXIMUM_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_FP_TO_ULLONG_RIGHT_MAXIMUM_RUN:INTERNAL=0 //Other test H5_GETTIMEOFDAY_GIVES_TZ:INTERNAL= //Have function alarm H5_HAVE_ALARM:INTERNAL=1 //Other test H5_HAVE_ATTRIBUTE:INTERNAL=1 //Other test H5_HAVE_C99_DESIGNATED_INITIALIZER:INTERNAL=1 //Other test H5_HAVE_C99_FUNC:INTERNAL=1 //Have symbol tzname H5_HAVE_DECL_TZNAME:INTERNAL=1 //Have function difftime H5_HAVE_DIFFTIME:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h;stdlib.h;memory.h;dlfcn.h H5_HAVE_DLFCN_H:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h;stdlib.h;memory.h;dlfcn.h;features.h H5_HAVE_FEATURES_H:INTERNAL=1 //Have function fork H5_HAVE_FORK:INTERNAL=1 //Have function frexpf H5_HAVE_FREXPF:INTERNAL=1 //Have function frexpl H5_HAVE_FREXPL:INTERNAL=1 //Have function fseeko H5_HAVE_FSEEKO:INTERNAL=1 //Have function fstat64 H5_HAVE_FSTAT64:INTERNAL=1 //Have function ftello H5_HAVE_FTELLO:INTERNAL=1 //Other test H5_HAVE_FUNCTION:INTERNAL=1 //Have function gethostname H5_HAVE_GETHOSTNAME:INTERNAL=1 //Have function getpwuid H5_HAVE_GETPWUID:INTERNAL=1 //Have function getrusage H5_HAVE_GETRUSAGE:INTERNAL=1 //Have includes ;globus/common.h H5_HAVE_GLOBUS_COMMON_H:INTERNAL= //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h;stdlib.h;memory.h;dlfcn.h;features.h;inttypes.h H5_HAVE_INTTYPES_H:INTERNAL=1 //Have function ioctl H5_HAVE_IOCTL:INTERNAL=1 //Have includes ;io.h H5_HAVE_IO_H:INTERNAL= //Have library m; H5_HAVE_LIBM:INTERNAL=1 //Have library socket;m H5_HAVE_LIBSOCKET:INTERNAL= //Have library ucb;m H5_HAVE_LIBUCB:INTERNAL= //Have library ws2_32;m H5_HAVE_LIBWS2_32:INTERNAL= //Have library wsock32;m H5_HAVE_LIBWSOCK32:INTERNAL= //Have function longjmp H5_HAVE_LONGJMP:INTERNAL=1 //Have function lstat H5_HAVE_LSTAT:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h;stdlib.h;memory.h H5_HAVE_MEMORY_H:INTERNAL=1 //Have includes ;mfhdf.h H5_HAVE_MFHDF_H:INTERNAL= //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h;stdlib.h;memory.h;dlfcn.h;features.h;inttypes.h;netinet/in.h H5_HAVE_NETINET_IN_H:INTERNAL=1 //Other test H5_HAVE_OFF64_T:INTERNAL= //Have includes ;pdb.h H5_HAVE_PDB_H:INTERNAL= //Have include ;pthread.h H5_HAVE_PTHREAD_H:INTERNAL=1 //Have function random H5_HAVE_RANDOM:INTERNAL=1 //Have function rand_r H5_HAVE_RAND_R:INTERNAL=1 //Have function setjmp H5_HAVE_SETJMP:INTERNAL=1 //Have include pthread.h;setjmp.h H5_HAVE_SETJMP_H:INTERNAL=1 //Have function setsysinfo H5_HAVE_SETSYSINFO:INTERNAL= //Have function sigaction H5_HAVE_SIGACTION:INTERNAL=1 //Have function siglongjmp H5_HAVE_SIGLONGJMP:INTERNAL=1 //Have function signal H5_HAVE_SIGNAL:INTERNAL=1 //Have function sigprocmask H5_HAVE_SIGPROCMASK:INTERNAL=1 //Have function sigsetjmp H5_HAVE_SIGSETJMP:INTERNAL= //Have function snprintf H5_HAVE_SNPRINTF:INTERNAL=1 //Other test H5_HAVE_SOCKLEN_T:INTERNAL= //Have function srandom H5_HAVE_SRANDOM:INTERNAL=1 //Have includes pthread.h;setjmp.h;srbclient.h H5_HAVE_SRBCLIENT_H:INTERNAL= //Have function stat64 H5_HAVE_STAT64:INTERNAL=1 //Other test H5_HAVE_STAT_ST_BLOCKS:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h H5_HAVE_STDDEF_H:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h H5_HAVE_STDINT_H:INTERNAL=1 //Have include stdint.h H5_HAVE_STDINT_H_CXX:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h;stdlib.h H5_HAVE_STDLIB_H:INTERNAL=1 //Have function strdup H5_HAVE_STRDUP:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h H5_HAVE_STRINGS_H:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h H5_HAVE_STRING_H:INTERNAL=1 //Other test H5_HAVE_STRUCT_TIMEZONE:INTERNAL= //Other test H5_HAVE_STRUCT_TM_TM_ZONE:INTERNAL=1 //Have function symlink H5_HAVE_SYMLINK:INTERNAL=1 //Have function system H5_HAVE_SYSTEM:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h H5_HAVE_SYS_IOCTL_H:INTERNAL=1 //Have includes pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/proc.h H5_HAVE_SYS_PROC_H:INTERNAL= //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h H5_HAVE_SYS_RESOURCE_H:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h H5_HAVE_SYS_SOCKET_H:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h H5_HAVE_SYS_STAT_H:INTERNAL=1 H5_HAVE_SYS_SYSINFO_H:INTERNAL= //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h H5_HAVE_SYS_TIMEB_H:INTERNAL=1 //H5_HAVE_SYS_TIME_GETTIMEOFDAY H5_HAVE_SYS_TIME_GETTIMEOFDAY:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h H5_HAVE_SYS_TIME_H:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h H5_HAVE_SYS_TYPES_H:INTERNAL=1 //Other test H5_HAVE_TIMEZONE:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h H5_HAVE_TIME_H:INTERNAL=1 //Have symbol TIOCGETD H5_HAVE_TIOCGETD:INTERNAL=1 //Have symbol TIOCGWINSZ H5_HAVE_TIOCGWINSZ:INTERNAL=1 //Other test H5_HAVE_TM_GMTOFF:INTERNAL=1 //Other test H5_HAVE_TM_ZONE:INTERNAL=1 //Have include pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h H5_HAVE_UNISTD_H:INTERNAL=1 //Have function vasprintf H5_HAVE_VASPRINTF:INTERNAL=1 //Have function vsnprintf H5_HAVE_VSNPRINTF:INTERNAL=1 //Have function waitpid H5_HAVE_WAITPID:INTERNAL=1 //Have includes pthread.h;setjmp.h;stddef.h;stdint.h;string.h;strings.h;sys/ioctl.h;sys/resource.h;sys/socket.h;sys/stat.h;sys/time.h;time.h;sys/timeb.h;sys/types.h;unistd.h;stdlib.h;memory.h;dlfcn.h;features.h;inttypes.h;winsock.h H5_HAVE_WINSOCK_H:INTERNAL= //Other test H5_INLINE_TEST___inline:INTERNAL=1 //Other test H5_INLINE_TEST___inline__:INTERNAL=1 //Other test H5_INLINE_TEST_inline:INTERNAL=1 //checking IF accurately converting from integers to long double H5_INTEGER_TO_LDOUBLE_ACCURATE:INTERNAL=1 //checking IF converting from long double to integers is accurate H5_LDOUBLE_TO_INTEGER_ACCURATE:INTERNAL=1 //Checking IF converting from long double to integers works H5_LDOUBLE_TO_INTEGER_WORKS:INTERNAL=1 //Result of TRY_COMPILE H5_LDOUBLE_TO_INTEGER_WORKS_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LDOUBLE_TO_INTEGER_WORKS_RUN:INTERNAL=0 //Checking IF correctly converting long double to (unsigned) long // long values H5_LDOUBLE_TO_LLONG_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_LDOUBLE_TO_LLONG_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LDOUBLE_TO_LLONG_ACCURATE_RUN:INTERNAL=0 //Checking IF correctly converting long double to unsigned int // values H5_LDOUBLE_TO_UINT_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_LDOUBLE_TO_UINT_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LDOUBLE_TO_UINT_ACCURATE_RUN:INTERNAL=0 //Use Legacy Names for Libraries and Programs H5_LEGACY_NAMING:INTERNAL=ON //Checking IF compiling long long to floating-point typecasts work H5_LLONG_TO_FP_CAST_WORKS:INTERNAL=1 //Checking IF correctly converting (unsigned) long long to long // double values H5_LLONG_TO_LDOUBLE_CORRECT:INTERNAL=1 //Result of TRY_COMPILE H5_LLONG_TO_LDOUBLE_CORRECT_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_LLONG_TO_LDOUBLE_CORRECT_RUN:INTERNAL=0 //Checking IF alignment restrictions are strictly enforced H5_NO_ALIGNMENT_RESTRICTIONS:INTERNAL=1 //Result of TRY_COMPILE H5_NO_ALIGNMENT_RESTRICTIONS_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_NO_ALIGNMENT_RESTRICTIONS_RUN:INTERNAL=0 //Width for printf for type `long long' or `__int64', us. `ll H5_PRINTF_LL_WIDTH:INTERNAL="ll" //CHECK_TYPE_SIZE: sizeof(char) H5_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) H5_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) H5_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) H5_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int16_t) H5_SIZEOF_INT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(int32_t) H5_SIZEOF_INT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int64_t) H5_SIZEOF_INT64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int8_t) H5_SIZEOF_INT8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int_fast16_t) H5_SIZEOF_INT_FAST16_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast32_t) H5_SIZEOF_INT_FAST32_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast64_t) H5_SIZEOF_INT_FAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_fast8_t) H5_SIZEOF_INT_FAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int_least16_t) H5_SIZEOF_INT_LEAST16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(int_least32_t) H5_SIZEOF_INT_LEAST32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int_least64_t) H5_SIZEOF_INT_LEAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(int_least8_t) H5_SIZEOF_INT_LEAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(long) H5_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long double) H5_SIZEOF_LONG_DOUBLE:INTERNAL=16 //CHECK_TYPE_SIZE: sizeof(long long) H5_SIZEOF_LONG_LONG:INTERNAL=8 //SizeOf for off64_t H5_SIZEOF_OFF64_T:INTERNAL=0 //CHECK_TYPE_SIZE: sizeof(off_t) H5_SIZEOF_OFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) H5_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(size_t) H5_SIZEOF_SIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ssize_t) H5_SIZEOF_SSIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint16_t) H5_SIZEOF_UINT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint32_t) H5_SIZEOF_UINT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(uint64_t) H5_SIZEOF_UINT64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint8_t) H5_SIZEOF_UINT8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(uint_fast16_t) H5_SIZEOF_UINT_FAST16_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast32_t) H5_SIZEOF_UINT_FAST32_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast64_t) H5_SIZEOF_UINT_FAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_fast8_t) H5_SIZEOF_UINT_FAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(uint_least16_t) H5_SIZEOF_UINT_LEAST16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint_least32_t) H5_SIZEOF_UINT_LEAST32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(uint_least64_t) H5_SIZEOF_UINT_LEAST64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(uint_least8_t) H5_SIZEOF_UINT_LEAST8_T:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(unsigned) H5_SIZEOF_UNSIGNED:INTERNAL=4 //SizeOf for __int64 H5_SIZEOF___INT64:INTERNAL=0 //Other test H5_STDC_HEADERS:INTERNAL=1 //Other test H5_SYSTEM_SCOPE_THREADS:INTERNAL=1 //Other test H5_TIME_WITH_SYS_TIME:INTERNAL=1 //Checking IF compiling unsigned long long to floating-point typecasts // work H5_ULLONG_TO_FP_CAST_WORKS:INTERNAL=1 //Checking IF converting unsigned long long to long double with // precision H5_ULLONG_TO_LDOUBLE_PRECISION:INTERNAL=1 //Result of TRY_COMPILE H5_ULLONG_TO_LDOUBLE_PRECISION_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_ULLONG_TO_LDOUBLE_PRECISION_RUN:INTERNAL=0 //Checking IF accurately converting unsigned long to float values H5_ULONG_TO_FLOAT_ACCURATE:INTERNAL=1 //Result of TRY_COMPILE H5_ULONG_TO_FLOAT_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_ULONG_TO_FLOAT_ACCURATE_RUN:INTERNAL=0 //Checking IF accurately converting unsigned long long to floating-point // values H5_ULONG_TO_FP_BOTTOM_BIT_ACCURATE:INTERNAL= //Result of TRY_COMPILE H5_ULONG_TO_FP_BOTTOM_BIT_ACCURATE_COMPILE:INTERNAL=TRUE //Result of TRY_RUN H5_ULONG_TO_FP_BOTTOM_BIT_ACCURATE_RUN:INTERNAL=1 //Other test H5_VSNPRINTF_WORKS:INTERNAL=1 //Have symbol alloca HAVE_ALLOCA:INTERNAL=1 //Have include ;alloca.h HAVE_ALLOCA_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h HAVE_ANSIDECL_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h HAVE_ARPA_INET_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h HAVE_ARPA_NAMESER_H:INTERNAL=1 //Have include assert.h HAVE_ASSERT_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_ATTRIBUTE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_C99_DESIGNATED_INITIALIZER:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_C99_FUNC:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_REQUIRE_LARGE_FILE_SUPPORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_SIZEOF_UNSIGNED_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_CMAKE_WORDS_BIGENDIAN:INTERNAL=TRUE //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h HAVE_CTYPE_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h HAVE_DIRENT_H:INTERNAL=1 //Have include dlfcn.h HAVE_DLFCN_H:INTERNAL=1 //Have library dl;z;dl;m HAVE_DLOPEN:INTERNAL=1 //Have includes stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;dl.h HAVE_DL_H:INTERNAL= //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h HAVE_ERRNO_H:INTERNAL=1 //Have include fcntl.h HAVE_FCNTL_H:INTERNAL=1 //Have include fenv.h HAVE_FENV_H:INTERNAL=1 //Have symbol finite HAVE_FINITE:INTERNAL=1 //Have include float.h HAVE_FLOAT_H:INTERNAL=1 //Have function floor HAVE_FLOOR:INTERNAL=1 //Have symbol fpclass HAVE_FPCLASS:INTERNAL= //Have symbol fprintf HAVE_FPRINTF:INTERNAL=1 //Have symbol fp_class HAVE_FP_CLASS:INTERNAL= //Have includes stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;fp_class.h HAVE_FP_CLASS_H:INTERNAL= //Have symbol ftime HAVE_FTIME:INTERNAL=1 //NetCDF test HAVE_FTRUNCATE:INTERNAL=1 //Result of TRY_COMPILE HAVE_FUNCTION:INTERNAL=TRUE //Test HAVE_GCC_ERROR_RETURN_TYPE HAVE_GCC_ERROR_RETURN_TYPE:INTERNAL=1 //Test HAVE_GCC_VISIBILITY HAVE_GCC_VISIBILITY:INTERNAL=1 //Result of TRY_COMPILE HAVE_GETADDRINFO_COMPILED:INTERNAL=TRUE //Have function getopt HAVE_GETOPT:INTERNAL=1 //Have symbol gettimeofday HAVE_GETTIMEOFDAY:INTERNAL=1 //Result of TRY_COMPILE HAVE_H5_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_INT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_LONG_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_OFF64_T:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_H5_SIZEOF_OFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_SIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_SSIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_FAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UINT_LEAST8_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF_UNSIGNED:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_H5_SIZEOF___INT64:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF_VOID_P:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_ICET_SIZEOF___INT64:INTERNAL=FALSE //Have includes ieeefp.h HAVE_IEEEFP_H:INTERNAL= //Test HAVE_INLINE_FUNCTIONS HAVE_INLINE_FUNCTIONS:INTERNAL=1 //Have include inttypes.h HAVE_INTTYPES_H:INTERNAL=1 //Have function isascii HAVE_ISASCII:INTERNAL=1 //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_KWSYS_SIZEOF___INT64:INTERNAL=FALSE //Have library dl; HAVE_LIBDL:INTERNAL=1 //Have library z;dl HAVE_LIBZ:INTERNAL=1 //Have include limits.h HAVE_LIMITS_H:INTERNAL=1 //Have symbol localtime HAVE_LOCALTIME:INTERNAL=1 //Have include malloc.h HAVE_MALLOC_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h HAVE_MATH_H:INTERNAL=1 //Have function memmove HAVE_MEMMOVE:INTERNAL=1 //Have include memory.h HAVE_MEMORY_H:INTERNAL=1 //Have function memset HAVE_MEMSET:INTERNAL=1 //Have function mmap HAVE_MMAP:INTERNAL=1 //Have includes stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;nan.h HAVE_NAN_H:INTERNAL= //Have includes stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;ndir.h HAVE_NDIR_H:INTERNAL= //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h HAVE_NETDB_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h HAVE_NETINET_IN_H:INTERNAL=1 //Test HAVE_NO_COMMON HAVE_NO_COMMON:INTERNAL=1 //Result of TRY_COMPILE HAVE_OFF64_T:INTERNAL=FALSE //Test HAVE_OMIT_FRAME_POINTER HAVE_OMIT_FRAME_POINTER:INTERNAL=1 //Have function pow HAVE_POW:INTERNAL=1 //Have symbol printf HAVE_PRINTF:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;pthread.h HAVE_PTHREAD_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;pthread.h;resolv.h HAVE_RESOLV_H:INTERNAL=1 //Have library dld;dl HAVE_SHLLOAD:INTERNAL= //Have symbol signal HAVE_SIGNAL:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h HAVE_SIGNAL_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_OFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_PTRDIFF_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_SSIZE_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_SIZEOF_UCHAR:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SIZEOF__BOOL:INTERNAL=TRUE //Have symbol snprintf HAVE_SNPRINTF:INTERNAL=1 //Result of TRY_COMPILE HAVE_SOCKLEN_T:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_SOCKLEN_T_COMPILED:INTERNAL=TRUE //Have symbol sprintf HAVE_SPRINTF:INTERNAL=1 //Have function sqrt HAVE_SQRT:INTERNAL=1 //Have symbol sscanf HAVE_SSCANF:INTERNAL=1 //Have symbol stat HAVE_STAT:INTERNAL=1 //Result of TRY_COMPILE HAVE_STAT_ST_BLOCKS:INTERNAL=TRUE //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;pthread.h;resolv.h;stdarg.h HAVE_STDARG_H:INTERNAL=1 //Have include alloca.h;stdlib.h;sys/types.h;sys/stat.h;unistd.h;fcntl.h;stdio.h;string.h;stddef.h;stdint.h;inttypes.h;stdbool.h HAVE_STDBOOL_H:INTERNAL=1 //Have include stddef.h HAVE_STDDEF_H:INTERNAL=1 //Have include stdint.h HAVE_STDINT_H:INTERNAL=1 //Have include alloca.h;stdlib.h;sys/types.h;sys/stat.h;unistd.h;fcntl.h;stdio.h HAVE_STDIO_H:INTERNAL=1 //Have include stdlib.h HAVE_STDLIB_H:INTERNAL=1 //Test HAVE_STD_C99 HAVE_STD_C99:INTERNAL=1 //Have function strcasecmp HAVE_STRCASECMP:INTERNAL=1 //Have function strchr HAVE_STRCHR:INTERNAL=1 //Have symbol strdup HAVE_STRDUP:INTERNAL=1 //Have symbol strerror HAVE_STRERROR:INTERNAL=1 //Have symbol strftime HAVE_STRFTIME:INTERNAL=1 //Have include strings.h HAVE_STRINGS_H:INTERNAL=1 //Have include string.h HAVE_STRING_H:INTERNAL=1 //Have symbol strndup HAVE_STRNDUP:INTERNAL=1 //Have function strrchr HAVE_STRRCHR:INTERNAL=1 //Have function strstr HAVE_STRSTR:INTERNAL=1 //Have function strtol HAVE_STRTOL:INTERNAL=1 //Have function strtoll HAVE_STRTOLL:INTERNAL=1 //Have function areroul HAVE_STRTOUL:INTERNAL= //Result of TRY_COMPILE HAVE_STRUCT_TIMEZONE:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_STRUCT_TM_TM_ZONE:INTERNAL=TRUE //NetCDF test HAVE_ST_BLKSIZE:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_DIR_H_COMPILED:INTERNAL=TRUE //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;pthread.h;resolv.h;stdarg.h;sys/mman.h HAVE_SYS_MMAN_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_NDIR_H_COMPILED:INTERNAL=FALSE //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h HAVE_SYS_SELECT_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h HAVE_SYS_SOCKET_H:INTERNAL=1 //Have include sys/stat.h HAVE_SYS_STAT_H:INTERNAL=1 //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;pthread.h;resolv.h;stdarg.h;sys/mman.h;sys/timeb.h HAVE_SYS_TIMEB_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_SYS_TIME_GETTIMEOFDAY:INTERNAL=TRUE //Have include sys/time.h HAVE_SYS_TIME_H:INTERNAL=1 //Have include sys/types.h HAVE_SYS_TYPES_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_TIMEZONE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_TIME_GETTIMEOFDAY:INTERNAL=FALSE //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h HAVE_TIME_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_TM_GMTOFF:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_TM_ZONE:INTERNAL=TRUE //Have include unistd.h HAVE_UNISTD_H:INTERNAL=1 //Result of TRY_COMPILE HAVE_VA_COPY_COMPILED:INTERNAL=TRUE //Have symbol vfprintf HAVE_VFPRINTF:INTERNAL=1 //Have symbol vsnprintf HAVE_VSNPRINTF:INTERNAL=1 //Have symbol vsprintf HAVE_VSPRINTF:INTERNAL=1 //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_INT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_INT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_INT64_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_UINT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_UINT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_U_INT16_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTKOGGTHEORA_U_INT32_T:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF_CHAR:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF_DOUBLE:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF_FLOAT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF_INT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF_LONG_LONG:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF_SHORT:INTERNAL=TRUE //Result of TRY_COMPILE HAVE_VTK_SIZEOF___INT64:INTERNAL=FALSE //Result of TRY_COMPILE HAVE_VTK_UINTPTR_T:INTERNAL=TRUE //Have includes windows.h HAVE_WINDOWS_H:INTERNAL= //Have include stdio.h;stddef.h;sys/types.h;inttypes.h;dlfcn.h;fcntl.h;malloc.h;memory.h;netdb.h;limits.h;sys/socket.h;netinet/in.h;sys/select.h;stdint.h;stdlib.h;string.h;strings.h;sys/stat.h;sys/time.h;time.h;unistd.h;signal.h;errno.h;ansidecl.h;arpa/inet.h;arpa/nameser.h;ctype.h;dirent.h;float.h;math.h;pthread.h;resolv.h;stdarg.h;sys/mman.h;sys/timeb.h;zlib.h HAVE_ZLIB_H:INTERNAL=1 //Have symbol _stat HAVE__STAT:INTERNAL= //Result of TRY_COMPILE HAVE___VA_COPY_COMPILED:INTERNAL=TRUE //Allow External Library Building HDF5_ALLOW_EXTERNAL_SUPPORT:INTERNAL=OFF //Build HDF5 C++ Library HDF5_BUILD_CPP_LIB:INTERNAL=OFF //Build HIGH Level HDF5 Library HDF5_BUILD_HL_LIB:INTERNAL=ON //Disable compiler warnings HDF5_DISABLE_COMPILER_WARNINGS:INTERNAL=ON //Enable the function stack tracing (for developer debugging). HDF5_ENABLE_CODESTACK:INTERNAL=OFF //Enable code coverage for Libraries and Programs HDF5_ENABLE_COVERAGE:INTERNAL=OFF //Enable deprecated public API symbols HDF5_ENABLE_DEPRECATED_SYMBOLS:INTERNAL=ON //Enable GPFS hints for the MPI/POSIX file driver HDF5_ENABLE_GPFS:INTERNAL=OFF //Enable datasets larger than memory HDF5_ENABLE_HSIZET:INTERNAL=ON //Enable support for large (64-bit) files on Linux. HDF5_ENABLE_LARGE_FILE:INTERNAL=ON //Enable parallel build (requires MPI) HDF5_ENABLE_PARALLEL:INTERNAL=OFF //Use SZip Filter HDF5_ENABLE_SZIP_SUPPORT:INTERNAL=OFF //Enable Threadsafety HDF5_ENABLE_THREADSAFE:INTERNAL=OFF //Enable API tracing capability HDF5_ENABLE_TRACE:INTERNAL=OFF //Indicate that a memory checker is used HDF5_ENABLE_USING_MEMCHECKER:INTERNAL=OFF //Enable Zlib Filters HDF5_ENABLE_Z_LIB_SUPPORT:INTERNAL=ON //Securely clear file buffers before writing to file HDF5_Enable_Clear_File_Buffers:INTERNAL=ON //Instrument The library HDF5_Enable_Instrument:INTERNAL=OFF //Used to pass variables between directories HDF5_LIBRARIES_TO_EXPORT:INTERNAL=vtkhdf5;vtkhdf5_hl //Enable metadata trace file collection HDF5_METADATA_TRACE_FILE:INTERNAL=OFF //CPACK - include external libraries HDF5_PACKAGE_EXTLIBS:INTERNAL=OFF //Result of TRY_COMPILE HDF5_PRINTF_LL_TEST_COMPILE:INTERNAL=TRUE //Result of TRY_RUN HDF5_PRINTF_LL_TEST_RUN:INTERNAL=0 //Whether to perform strict file format checks HDF5_STRICT_FORMAT_CHECKS:INTERNAL=OFF //Use the HDF5 1.6.x API by default HDF5_USE_16_API_DEFAULT:INTERNAL=OFF //Use the FLETCHER32 Filter HDF5_USE_FILTER_FLETCHER32:INTERNAL=ON //Use the NBIT Filter HDF5_USE_FILTER_NBIT:INTERNAL=ON //Use the SCALEOFFSET Filter HDF5_USE_FILTER_SCALEOFFSET:INTERNAL=ON //Use the SHUFFLE Filter HDF5_USE_FILTER_SHUFFLE:INTERNAL=ON //Use the PACKED BITS feature in h5dump HDF5_USE_H5DUMP_PACKED_BITS:INTERNAL=ON //IF data accuracy is guaranteed during data conversions HDF5_WANT_DATA_ACCURACY:INTERNAL=ON //exception handling functions is checked during data conversions HDF5_WANT_DCONV_EXCEPTION:INTERNAL=ON //ADVANCED property for variable: HGCOMMAND HGCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICET_BUILD_TESTING ICET_BUILD_TESTING-ADVANCED:INTERNAL=1 ICET_INSTALL_TARGETS:INTERNAL=IceTCore;IceTMPI;IceTGL //ADVANCED property for variable: ICET_MAGIC_K ICET_MAGIC_K-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICET_MAX_IMAGE_SPLIT ICET_MAX_IMAGE_SPLIT-ADVANCED:INTERNAL=1 //This is set from VTK_MPIRUN_EXE. ICET_MPIRUN_EXE:INTERNAL=/mpi3/C2/mpich-3.0.1/bin/mpiexec //ADVANCED property for variable: ICET_MPI_MAX_NUMPROCS ICET_MPI_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //This is set from VTK_MPI_MAX_NUMPROCS. ICET_MPI_MAX_NUMPROCS:INTERNAL=2 //This is set from a combination of VTK_MPI_PRENUMPROC_FLAGS and // VTK_MPI_NUMPROC_FLAG ICET_MPI_NUMPROC_FLAG:INTERNAL=;-np //This is set from VTK_MPI_POSTFLAGS. ICET_MPI_POSTFLAGS:INTERNAL= //This is set from VTK_MPI_PREFLAGS. ICET_MPI_PREFLAGS:INTERNAL= //CHECK_TYPE_SIZE: sizeof(char) ICET_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) ICET_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) ICET_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) ICET_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) ICET_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) ICET_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) ICET_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(void*) ICET_SIZEOF_VOID_P:INTERNAL=8 //CHECK_TYPE_SIZE: __int64 unknown ICET_SIZEOF___INT64:INTERNAL= //ADVANCED property for variable: ICET_TEST_FLAGS ICET_TEST_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICET_USE_MPE ICET_USE_MPE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICET_USE_MPI ICET_USE_MPI-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ICET_USE_OPENGL ICET_USE_OPENGL-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE INLINE_TEST___inline:INTERNAL=TRUE //Result of TRY_COMPILE INLINE_TEST___inline__:INTERNAL=TRUE //Result of TRY_COMPILE INLINE_TEST_inline:INTERNAL=TRUE //ADVANCED property for variable: JAVACOMMAND JAVACOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_RUN KWSYS_CHAR_IS_SIGNED:INTERNAL=0 //Result of TRY_COMPILE KWSYS_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_ARGUMENT_DEPENDENT_LOOKUP_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_ATOLL_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_ATOL_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDDEF_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_CSTDIO_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_ENVIRON_IN_STDLIB_H_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_CXX_HAS_FULL_SPECIALIZATION_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_LONG_LONG_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_MEMBER_TEMPLATES_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_NULL_TEMPLATE_ARGS_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_CXX_HAS_RLIMIT64_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_SETENV_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS_UNSETENV_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_CXX_HAS__ATOI64_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_CXX_HAS___INT64_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_C_HAS_PTRDIFF_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_C_HAS_SSIZE_T_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_HAVE_BINARY_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_ANSI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_IOS_USE_SSTREAM_COMPILED:INTERNAL=TRUE //Result of TRY_RUN KWSYS_LFS_WORKS:INTERNAL=0 //Result of TRY_COMPILE KWSYS_LFS_WORKS_COMPILED:INTERNAL=TRUE //CHECK_TYPE_SIZE: sizeof(char) KWSYS_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int) KWSYS_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) KWSYS_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) KWSYS_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) KWSYS_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: __int64 unknown KWSYS_SIZEOF___INT64:INTERNAL= //Result of TRY_COMPILE KWSYS_STAT_HAS_ST_MTIM_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_MAX_SIZE_ARGUMENT_COMPILED:INTERNAL=FALSE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_OBJECTS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_REBIND_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ALLOCATOR_TEMPLATE_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAS_ITERATOR_TRAITS_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_HAVE_STD_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE KWSYS_STL_STRING_HAVE_NEQ_CHAR_COMPILED:INTERNAL=TRUE //Have include sys/types.h;ifaddrs.h KWSYS_SYS_HAS_IFADDRS_H:INTERNAL=1 //ADVANCED property for variable: LIBRARY_OUTPUT_PATH LIBRARY_OUTPUT_PATH-ADVANCED:INTERNAL=1 LIBRARY_OUTPUT_PATH:INTERNAL=/mpi3/S2/ParaGit-BBUILD2/ThirdParty/protobuf/vtkprotobuf/bin //ADVANCED property for variable: MAKECOMMAND MAKECOMMAND-ADVANCED:INTERNAL=1 //Path to vtkMaterialLibraryMacro.h MATERIAL_LIBRARY_MATERIAL_MACRO_HEADER:INTERNAL=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/MaterialLibrary/vtkMaterialLibraryMacro.h //Path to vtkShaderCodeLibraryMacro.h MATERIAL_LIBRARY_SHADER_MACRO_HEADER:INTERNAL=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/MaterialLibrary/vtkShaderCodeLibraryMacro.h //ADVANCED property for variable: MEMORYCHECK_COMMAND MEMORYCHECK_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MEMORYCHECK_SUPPRESSIONS_FILE MEMORYCHECK_SUPPRESSIONS_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC MPIEXEC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_MAX_NUMPROCS MPIEXEC_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_NUMPROC_FLAG MPIEXEC_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_POSTFLAGS MPIEXEC_POSTFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_PREFLAGS MPIEXEC_PREFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_COMPILER MPI_CXX_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_COMPILE_FLAGS MPI_CXX_COMPILE_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_INCLUDE_PATH MPI_CXX_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_LIBRARIES MPI_CXX_LIBRARIES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_LINK_FLAGS MPI_CXX_LINK_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_COMPILER MPI_C_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_COMPILE_FLAGS MPI_C_COMPILE_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_INCLUDE_PATH MPI_C_INCLUDE_PATH-ADVANCED:INTERNAL=0 //ADVANCED property for variable: MPI_C_LIBRARIES MPI_C_LIBRARIES-ADVANCED:INTERNAL=0 //ADVANCED property for variable: MPI_C_LINK_FLAGS MPI_C_LINK_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_EXTRA_LIBRARY MPI_EXTRA_LIBRARY-ADVANCED:INTERNAL=1 //Scratch variable for MPI header detection MPI_HEADER_PATH:INTERNAL=MPI_HEADER_PATH-NOTFOUND //Scratch variable for MPI lib detection MPI_LIB:INTERNAL=MPI_LIB-NOTFOUND //ADVANCED property for variable: MPI_LIBRARY MPI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_AutobahnPython Module_AutobahnPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_Twisted Module_Twisted-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_VisItLib Module_VisItLib-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_ZopeInterface Module_ZopeInterface-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_pqApplicationComponents Module_pqApplicationComponents-ADVANCED:INTERNAL=1 //Request building pqApplicationComponents Module_pqApplicationComponents:INTERNAL=OFF //ADVANCED property for variable: Module_pqComponents Module_pqComponents-ADVANCED:INTERNAL=1 //Request building pqComponents Module_pqComponents:INTERNAL=OFF //ADVANCED property for variable: Module_pqCore Module_pqCore-ADVANCED:INTERNAL=1 //Request building pqCore Module_pqCore:INTERNAL=OFF //ADVANCED property for variable: Module_pqPython Module_pqPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_pqWidgets Module_pqWidgets-ADVANCED:INTERNAL=1 //Request building pqWidgets Module_pqWidgets:INTERNAL=OFF //ADVANCED property for variable: Module_smTestDriver Module_smTestDriver-ADVANCED:INTERNAL=1 //Request building smTestDriver Module_smTestDriver:INTERNAL=OFF //ADVANCED property for variable: Module_vtkAcceleratorsPiston Module_vtkAcceleratorsPiston-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkChartsCore Module_vtkChartsCore-ADVANCED:INTERNAL=1 //Request building vtkChartsCore Module_vtkChartsCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkClientServer Module_vtkClientServer-ADVANCED:INTERNAL=1 //Request building vtkClientServer Module_vtkClientServer:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCoProcessor Module_vtkCoProcessor-ADVANCED:INTERNAL=1 //Request building vtkCoProcessor Module_vtkCoProcessor:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCoProcessorImplementation Module_vtkCoProcessorImplementation-ADVANCED:INTERNAL=1 //Request building vtkCoProcessorImplementation Module_vtkCoProcessorImplementation:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonColor Module_vtkCommonColor-ADVANCED:INTERNAL=1 //Request building vtkCommonColor Module_vtkCommonColor:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonComputationalGeometry Module_vtkCommonComputationalGeometry-ADVANCED:INTERNAL=1 //Request building vtkCommonComputationalGeometry Module_vtkCommonComputationalGeometry:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonCore Module_vtkCommonCore-ADVANCED:INTERNAL=1 //Request building vtkCommonCore Module_vtkCommonCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonDataModel Module_vtkCommonDataModel-ADVANCED:INTERNAL=1 //Request building vtkCommonDataModel Module_vtkCommonDataModel:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonExecutionModel Module_vtkCommonExecutionModel-ADVANCED:INTERNAL=1 //Request building vtkCommonExecutionModel Module_vtkCommonExecutionModel:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonMath Module_vtkCommonMath-ADVANCED:INTERNAL=1 //Request building vtkCommonMath Module_vtkCommonMath:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonMisc Module_vtkCommonMisc-ADVANCED:INTERNAL=1 //Request building vtkCommonMisc Module_vtkCommonMisc:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonSystem Module_vtkCommonSystem-ADVANCED:INTERNAL=1 //Request building vtkCommonSystem Module_vtkCommonSystem:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCommonTransforms Module_vtkCommonTransforms-ADVANCED:INTERNAL=1 //Request building vtkCommonTransforms Module_vtkCommonTransforms:INTERNAL=OFF //ADVANCED property for variable: Module_vtkCosmo Module_vtkCosmo-ADVANCED:INTERNAL=1 //Request building vtkCosmo Module_vtkCosmo:INTERNAL=OFF //ADVANCED property for variable: Module_vtkDICOMParser Module_vtkDICOMParser-ADVANCED:INTERNAL=1 //Request building vtkDICOMParser Module_vtkDICOMParser:INTERNAL=OFF //ADVANCED property for variable: Module_vtkDomainsChemistry Module_vtkDomainsChemistry-ADVANCED:INTERNAL=1 //Request building vtkDomainsChemistry Module_vtkDomainsChemistry:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersAMR Module_vtkFiltersAMR-ADVANCED:INTERNAL=1 //Request building vtkFiltersAMR Module_vtkFiltersAMR:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersCore Module_vtkFiltersCore-ADVANCED:INTERNAL=1 //Request building vtkFiltersCore Module_vtkFiltersCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersCosmo Module_vtkFiltersCosmo-ADVANCED:INTERNAL=1 //Request building vtkFiltersCosmo Module_vtkFiltersCosmo:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersExtraction Module_vtkFiltersExtraction-ADVANCED:INTERNAL=1 //Request building vtkFiltersExtraction Module_vtkFiltersExtraction:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersFlowPaths Module_vtkFiltersFlowPaths-ADVANCED:INTERNAL=1 //Request building vtkFiltersFlowPaths Module_vtkFiltersFlowPaths:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersGeneral Module_vtkFiltersGeneral-ADVANCED:INTERNAL=1 //Request building vtkFiltersGeneral Module_vtkFiltersGeneral:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersGeneric Module_vtkFiltersGeneric-ADVANCED:INTERNAL=1 //Request building vtkFiltersGeneric Module_vtkFiltersGeneric:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersGeometry Module_vtkFiltersGeometry-ADVANCED:INTERNAL=1 //Request building vtkFiltersGeometry Module_vtkFiltersGeometry:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersHybrid Module_vtkFiltersHybrid-ADVANCED:INTERNAL=1 //Request building vtkFiltersHybrid Module_vtkFiltersHybrid:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersHyperTree Module_vtkFiltersHyperTree-ADVANCED:INTERNAL=1 //Request building vtkFiltersHyperTree Module_vtkFiltersHyperTree:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersImaging Module_vtkFiltersImaging-ADVANCED:INTERNAL=1 //Request building vtkFiltersImaging Module_vtkFiltersImaging:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersModeling Module_vtkFiltersModeling-ADVANCED:INTERNAL=1 //Request building vtkFiltersModeling Module_vtkFiltersModeling:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersParallel Module_vtkFiltersParallel-ADVANCED:INTERNAL=1 //Request building vtkFiltersParallel Module_vtkFiltersParallel:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersParallelFlowPaths Module_vtkFiltersParallelFlowPaths-ADVANCED:INTERNAL=1 //Request building vtkFiltersParallelFlowPaths Module_vtkFiltersParallelFlowPaths:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersParallelGeometry Module_vtkFiltersParallelGeometry-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkFiltersParallelImaging Module_vtkFiltersParallelImaging-ADVANCED:INTERNAL=1 //Request building vtkFiltersParallelImaging Module_vtkFiltersParallelImaging:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersParallelMPI Module_vtkFiltersParallelMPI-ADVANCED:INTERNAL=1 //Request building vtkFiltersParallelMPI Module_vtkFiltersParallelMPI:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersParallelStatistics Module_vtkFiltersParallelStatistics-ADVANCED:INTERNAL=1 //Request building vtkFiltersParallelStatistics Module_vtkFiltersParallelStatistics:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersProgrammable Module_vtkFiltersProgrammable-ADVANCED:INTERNAL=1 //Request building vtkFiltersProgrammable Module_vtkFiltersProgrammable:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersReebGraph Module_vtkFiltersReebGraph-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkFiltersSelection Module_vtkFiltersSelection-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkFiltersSources Module_vtkFiltersSources-ADVANCED:INTERNAL=1 //Request building vtkFiltersSources Module_vtkFiltersSources:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersStatistics Module_vtkFiltersStatistics-ADVANCED:INTERNAL=1 //Request building vtkFiltersStatistics Module_vtkFiltersStatistics:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersStatisticsGnuR Module_vtkFiltersStatisticsGnuR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkFiltersTexture Module_vtkFiltersTexture-ADVANCED:INTERNAL=1 //Request building vtkFiltersTexture Module_vtkFiltersTexture:INTERNAL=OFF //ADVANCED property for variable: Module_vtkFiltersVerdict Module_vtkFiltersVerdict-ADVANCED:INTERNAL=1 //Request building vtkFiltersVerdict Module_vtkFiltersVerdict:INTERNAL=OFF //ADVANCED property for variable: Module_vtkGUISupportQt Module_vtkGUISupportQt-ADVANCED:INTERNAL=1 //Request building vtkGUISupportQt Module_vtkGUISupportQt:INTERNAL=OFF //ADVANCED property for variable: Module_vtkGUISupportQtOpenGL Module_vtkGUISupportQtOpenGL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkGUISupportQtSQL Module_vtkGUISupportQtSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkGUISupportQtWebkit Module_vtkGUISupportQtWebkit-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkGeovisCore Module_vtkGeovisCore-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOAMR Module_vtkIOAMR-ADVANCED:INTERNAL=1 //Request building vtkIOAMR Module_vtkIOAMR:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOCore Module_vtkIOCore-ADVANCED:INTERNAL=1 //Request building vtkIOCore Module_vtkIOCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOEnSight Module_vtkIOEnSight-ADVANCED:INTERNAL=1 //Request building vtkIOEnSight Module_vtkIOEnSight:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOExodus Module_vtkIOExodus-ADVANCED:INTERNAL=1 //Request building vtkIOExodus Module_vtkIOExodus:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOExport Module_vtkIOExport-ADVANCED:INTERNAL=1 //Request building vtkIOExport Module_vtkIOExport:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOFFMPEG Module_vtkIOFFMPEG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOGDAL Module_vtkIOGDAL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOGeometry Module_vtkIOGeometry-ADVANCED:INTERNAL=1 //Request building vtkIOGeometry Module_vtkIOGeometry:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOImage Module_vtkIOImage-ADVANCED:INTERNAL=1 //Request building vtkIOImage Module_vtkIOImage:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOImport Module_vtkIOImport-ADVANCED:INTERNAL=1 //Request building vtkIOImport Module_vtkIOImport:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOInfovis Module_vtkIOInfovis-ADVANCED:INTERNAL=1 //Request building vtkIOInfovis Module_vtkIOInfovis:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOLSDyna Module_vtkIOLSDyna-ADVANCED:INTERNAL=1 //Request building vtkIOLSDyna Module_vtkIOLSDyna:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOLegacy Module_vtkIOLegacy-ADVANCED:INTERNAL=1 //Request building vtkIOLegacy Module_vtkIOLegacy:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOMINC Module_vtkIOMINC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOMPIImage Module_vtkIOMPIImage-ADVANCED:INTERNAL=1 //Request building vtkIOMPIImage Module_vtkIOMPIImage:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOMPIParallel Module_vtkIOMPIParallel-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOMovie Module_vtkIOMovie-ADVANCED:INTERNAL=1 //Request building vtkIOMovie Module_vtkIOMovie:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOMySQL Module_vtkIOMySQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIONetCDF Module_vtkIONetCDF-ADVANCED:INTERNAL=1 //Request building vtkIONetCDF Module_vtkIONetCDF:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOODBC Module_vtkIOODBC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOPLY Module_vtkIOPLY-ADVANCED:INTERNAL=1 //Request building vtkIOPLY Module_vtkIOPLY:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOParallel Module_vtkIOParallel-ADVANCED:INTERNAL=1 //Request building vtkIOParallel Module_vtkIOParallel:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOParallelExodus Module_vtkIOParallelExodus-ADVANCED:INTERNAL=1 //Request building vtkIOParallelExodus Module_vtkIOParallelExodus:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOParallelLSDyna Module_vtkIOParallelLSDyna-ADVANCED:INTERNAL=1 //Request building vtkIOParallelLSDyna Module_vtkIOParallelLSDyna:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOParallelNetCDF Module_vtkIOParallelNetCDF-ADVANCED:INTERNAL=1 //Request building vtkIOParallelNetCDF Module_vtkIOParallelNetCDF:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOPostgreSQL Module_vtkIOPostgreSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOSQL Module_vtkIOSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOVPIC Module_vtkIOVPIC-ADVANCED:INTERNAL=1 //Request building vtkIOVPIC Module_vtkIOVPIC:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOVideo Module_vtkIOVideo-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOVisItBridge Module_vtkIOVisItBridge-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkIOXML Module_vtkIOXML-ADVANCED:INTERNAL=1 //Request building vtkIOXML Module_vtkIOXML:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOXMLParser Module_vtkIOXMLParser-ADVANCED:INTERNAL=1 //Request building vtkIOXMLParser Module_vtkIOXMLParser:INTERNAL=OFF //ADVANCED property for variable: Module_vtkIOXdmf2 Module_vtkIOXdmf2-ADVANCED:INTERNAL=1 //Request building vtkIOXdmf2 Module_vtkIOXdmf2:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingColor Module_vtkImagingColor-ADVANCED:INTERNAL=1 //Request building vtkImagingColor Module_vtkImagingColor:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingCore Module_vtkImagingCore-ADVANCED:INTERNAL=1 //Request building vtkImagingCore Module_vtkImagingCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingFourier Module_vtkImagingFourier-ADVANCED:INTERNAL=1 //Request building vtkImagingFourier Module_vtkImagingFourier:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingGeneral Module_vtkImagingGeneral-ADVANCED:INTERNAL=1 //Request building vtkImagingGeneral Module_vtkImagingGeneral:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingHybrid Module_vtkImagingHybrid-ADVANCED:INTERNAL=1 //Request building vtkImagingHybrid Module_vtkImagingHybrid:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingMath Module_vtkImagingMath-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkImagingMorphological Module_vtkImagingMorphological-ADVANCED:INTERNAL=1 //Request building vtkImagingMorphological Module_vtkImagingMorphological:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingSources Module_vtkImagingSources-ADVANCED:INTERNAL=1 //Request building vtkImagingSources Module_vtkImagingSources:INTERNAL=OFF //ADVANCED property for variable: Module_vtkImagingStatistics Module_vtkImagingStatistics-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkImagingStencil Module_vtkImagingStencil-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkInfovisBoost Module_vtkInfovisBoost-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkInfovisBoostGraphAlgorithms Module_vtkInfovisBoostGraphAlgorithms-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkInfovisCore Module_vtkInfovisCore-ADVANCED:INTERNAL=1 //Request building vtkInfovisCore Module_vtkInfovisCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkInfovisLayout Module_vtkInfovisLayout-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkInfovisParallel Module_vtkInfovisParallel-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkInteractionImage Module_vtkInteractionImage-ADVANCED:INTERNAL=1 //Request building vtkInteractionImage Module_vtkInteractionImage:INTERNAL=OFF //ADVANCED property for variable: Module_vtkInteractionStyle Module_vtkInteractionStyle-ADVANCED:INTERNAL=1 //Request building vtkInteractionStyle Module_vtkInteractionStyle:INTERNAL=OFF //ADVANCED property for variable: Module_vtkInteractionWidgets Module_vtkInteractionWidgets-ADVANCED:INTERNAL=1 //Request building vtkInteractionWidgets Module_vtkInteractionWidgets:INTERNAL=OFF //ADVANCED property for variable: Module_vtkMetaIO Module_vtkMetaIO-ADVANCED:INTERNAL=1 //Request building vtkMetaIO Module_vtkMetaIO:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVClientServerCoreCore Module_vtkPVClientServerCoreCore-ADVANCED:INTERNAL=1 //Request building vtkPVClientServerCoreCore Module_vtkPVClientServerCoreCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVClientServerCoreDefault Module_vtkPVClientServerCoreDefault-ADVANCED:INTERNAL=1 //Request building vtkPVClientServerCoreDefault Module_vtkPVClientServerCoreDefault:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVClientServerCoreRendering Module_vtkPVClientServerCoreRendering-ADVANCED:INTERNAL=1 //Request building vtkPVClientServerCoreRendering Module_vtkPVClientServerCoreRendering:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVCommon Module_vtkPVCommon-ADVANCED:INTERNAL=1 //Request building vtkPVCommon Module_vtkPVCommon:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVPythonSupport Module_vtkPVPythonSupport-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkPVServerImplementationCore Module_vtkPVServerImplementationCore-ADVANCED:INTERNAL=1 //Request building vtkPVServerImplementationCore Module_vtkPVServerImplementationCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVServerImplementationDefault Module_vtkPVServerImplementationDefault-ADVANCED:INTERNAL=1 //Request building vtkPVServerImplementationDefault Module_vtkPVServerImplementationDefault:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVServerImplementationRendering Module_vtkPVServerImplementationRendering-ADVANCED:INTERNAL=1 //Request building vtkPVServerImplementationRendering Module_vtkPVServerImplementationRendering:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVServerManagerApplication Module_vtkPVServerManagerApplication-ADVANCED:INTERNAL=1 //Request building vtkPVServerManagerApplication Module_vtkPVServerManagerApplication:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVServerManagerCore Module_vtkPVServerManagerCore-ADVANCED:INTERNAL=1 //Request building vtkPVServerManagerCore Module_vtkPVServerManagerCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVServerManagerDefault Module_vtkPVServerManagerDefault-ADVANCED:INTERNAL=1 //Request building vtkPVServerManagerDefault Module_vtkPVServerManagerDefault:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVServerManagerRendering Module_vtkPVServerManagerRendering-ADVANCED:INTERNAL=1 //Request building vtkPVServerManagerRendering Module_vtkPVServerManagerRendering:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVVTKExtensionsCore Module_vtkPVVTKExtensionsCore-ADVANCED:INTERNAL=1 //Request building vtkPVVTKExtensionsCore Module_vtkPVVTKExtensionsCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVVTKExtensionsDefault Module_vtkPVVTKExtensionsDefault-ADVANCED:INTERNAL=1 //Request building vtkPVVTKExtensionsDefault Module_vtkPVVTKExtensionsDefault:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVVTKExtensionsRendering Module_vtkPVVTKExtensionsRendering-ADVANCED:INTERNAL=1 //Request building vtkPVVTKExtensionsRendering Module_vtkPVVTKExtensionsRendering:INTERNAL=OFF //ADVANCED property for variable: Module_vtkPVVTKExtensionsWebGLExporter Module_vtkPVVTKExtensionsWebGLExporter-ADVANCED:INTERNAL=1 //Request building vtkPVVTKExtensionsWebGLExporter Module_vtkPVVTKExtensionsWebGLExporter:INTERNAL=OFF //ADVANCED property for variable: Module_vtkParaViewWeb Module_vtkParaViewWeb-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkParaViewWebDocumentation Module_vtkParaViewWebDocumentation-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkParallelCore Module_vtkParallelCore-ADVANCED:INTERNAL=1 //Request building vtkParallelCore Module_vtkParallelCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkParallelMPI Module_vtkParallelMPI-ADVANCED:INTERNAL=1 //Request building vtkParallelMPI Module_vtkParallelMPI:INTERNAL=OFF //ADVANCED property for variable: Module_vtkParseOGLExt Module_vtkParseOGLExt-ADVANCED:INTERNAL=1 //Request building vtkParseOGLExt Module_vtkParseOGLExt:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingAnnotation Module_vtkRenderingAnnotation-ADVANCED:INTERNAL=1 //Request building vtkRenderingAnnotation Module_vtkRenderingAnnotation:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingContext2D Module_vtkRenderingContext2D-ADVANCED:INTERNAL=1 //Request building vtkRenderingContext2D Module_vtkRenderingContext2D:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingCore Module_vtkRenderingCore-ADVANCED:INTERNAL=1 //Request building vtkRenderingCore Module_vtkRenderingCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingFreeType Module_vtkRenderingFreeType-ADVANCED:INTERNAL=1 //Request building vtkRenderingFreeType Module_vtkRenderingFreeType:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingFreeTypeFontConfig Module_vtkRenderingFreeTypeFontConfig-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkRenderingFreeTypeOpenGL Module_vtkRenderingFreeTypeOpenGL-ADVANCED:INTERNAL=1 //Request building vtkRenderingFreeTypeOpenGL Module_vtkRenderingFreeTypeOpenGL:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingGL2PS Module_vtkRenderingGL2PS-ADVANCED:INTERNAL=1 //Request building vtkRenderingGL2PS Module_vtkRenderingGL2PS:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingHybridOpenGL Module_vtkRenderingHybridOpenGL-ADVANCED:INTERNAL=1 //Request building vtkRenderingHybridOpenGL Module_vtkRenderingHybridOpenGL:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingImage Module_vtkRenderingImage-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkRenderingLOD Module_vtkRenderingLOD-ADVANCED:INTERNAL=1 //Request building vtkRenderingLOD Module_vtkRenderingLOD:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingLabel Module_vtkRenderingLabel-ADVANCED:INTERNAL=1 //Request building vtkRenderingLabel Module_vtkRenderingLabel:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingMatplotlib Module_vtkRenderingMatplotlib-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkRenderingOpenGL Module_vtkRenderingOpenGL-ADVANCED:INTERNAL=1 //Request building vtkRenderingOpenGL Module_vtkRenderingOpenGL:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingParallel Module_vtkRenderingParallel-ADVANCED:INTERNAL=1 //Request building vtkRenderingParallel Module_vtkRenderingParallel:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingQt Module_vtkRenderingQt-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkRenderingTk Module_vtkRenderingTk-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkRenderingVolume Module_vtkRenderingVolume-ADVANCED:INTERNAL=1 //Request building vtkRenderingVolume Module_vtkRenderingVolume:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingVolumeAMR Module_vtkRenderingVolumeAMR-ADVANCED:INTERNAL=1 //Request building vtkRenderingVolumeAMR Module_vtkRenderingVolumeAMR:INTERNAL=OFF //ADVANCED property for variable: Module_vtkRenderingVolumeOpenGL Module_vtkRenderingVolumeOpenGL-ADVANCED:INTERNAL=1 //Request building vtkRenderingVolumeOpenGL Module_vtkRenderingVolumeOpenGL:INTERNAL=OFF //ADVANCED property for variable: Module_vtkTclTk Module_vtkTclTk-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkTestingCore Module_vtkTestingCore-ADVANCED:INTERNAL=1 //Request building vtkTestingCore Module_vtkTestingCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkTestingGenericBridge Module_vtkTestingGenericBridge-ADVANCED:INTERNAL=1 //Request building vtkTestingGenericBridge Module_vtkTestingGenericBridge:INTERNAL=OFF //ADVANCED property for variable: Module_vtkTestingIOSQL Module_vtkTestingIOSQL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkTestingRendering Module_vtkTestingRendering-ADVANCED:INTERNAL=1 //Request building vtkTestingRendering Module_vtkTestingRendering:INTERNAL=OFF //ADVANCED property for variable: Module_vtkUtilitiesColorSeriesToXML Module_vtkUtilitiesColorSeriesToXML-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkUtilitiesEncodeString Module_vtkUtilitiesEncodeString-ADVANCED:INTERNAL=1 //Request building vtkUtilitiesEncodeString Module_vtkUtilitiesEncodeString:INTERNAL=OFF //ADVANCED property for variable: Module_vtkUtilitiesHashSource Module_vtkUtilitiesHashSource-ADVANCED:INTERNAL=1 //Request building vtkUtilitiesHashSource Module_vtkUtilitiesHashSource:INTERNAL=OFF //ADVANCED property for variable: Module_vtkUtilitiesMaterialLibrary Module_vtkUtilitiesMaterialLibrary-ADVANCED:INTERNAL=1 //Request building vtkUtilitiesMaterialLibrary Module_vtkUtilitiesMaterialLibrary:INTERNAL=OFF //ADVANCED property for variable: Module_vtkUtilitiesProcessXML Module_vtkUtilitiesProcessXML-ADVANCED:INTERNAL=1 //Request building vtkUtilitiesProcessXML Module_vtkUtilitiesProcessXML:INTERNAL=OFF //ADVANCED property for variable: Module_vtkUtilitiesWrapClientServer Module_vtkUtilitiesWrapClientServer-ADVANCED:INTERNAL=1 //Request building vtkUtilitiesWrapClientServer Module_vtkUtilitiesWrapClientServer:INTERNAL=OFF //ADVANCED property for variable: Module_vtkVPIC Module_vtkVPIC-ADVANCED:INTERNAL=1 //Request building vtkVPIC Module_vtkVPIC:INTERNAL=OFF //ADVANCED property for variable: Module_vtkViewsContext2D Module_vtkViewsContext2D-ADVANCED:INTERNAL=1 //Request building vtkViewsContext2D Module_vtkViewsContext2D:INTERNAL=OFF //ADVANCED property for variable: Module_vtkViewsCore Module_vtkViewsCore-ADVANCED:INTERNAL=1 //Request building vtkViewsCore Module_vtkViewsCore:INTERNAL=OFF //ADVANCED property for variable: Module_vtkViewsGeovis Module_vtkViewsGeovis-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkViewsInfovis Module_vtkViewsInfovis-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkViewsQt Module_vtkViewsQt-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkWrappingJava Module_vtkWrappingJava-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkWrappingPython Module_vtkWrappingPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkWrappingTcl Module_vtkWrappingTcl-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtkWrappingTools Module_vtkWrappingTools-ADVANCED:INTERNAL=1 //Request building vtkWrappingTools Module_vtkWrappingTools:INTERNAL=OFF //ADVANCED property for variable: Module_vtkalglib Module_vtkalglib-ADVANCED:INTERNAL=1 //Request building vtkalglib Module_vtkalglib:INTERNAL=OFF //ADVANCED property for variable: Module_vtkexodusII Module_vtkexodusII-ADVANCED:INTERNAL=1 //Request building vtkexodusII Module_vtkexodusII:INTERNAL=OFF //ADVANCED property for variable: Module_vtkexpat Module_vtkexpat-ADVANCED:INTERNAL=1 //Request building vtkexpat Module_vtkexpat:INTERNAL=OFF //ADVANCED property for variable: Module_vtkfreetype Module_vtkfreetype-ADVANCED:INTERNAL=1 //Request building vtkfreetype Module_vtkfreetype:INTERNAL=OFF //ADVANCED property for variable: Module_vtkftgl Module_vtkftgl-ADVANCED:INTERNAL=1 //Request building vtkftgl Module_vtkftgl:INTERNAL=OFF //ADVANCED property for variable: Module_vtkgl2ps Module_vtkgl2ps-ADVANCED:INTERNAL=1 //Request building vtkgl2ps Module_vtkgl2ps:INTERNAL=OFF //ADVANCED property for variable: Module_vtkhdf5 Module_vtkhdf5-ADVANCED:INTERNAL=1 //Request building vtkhdf5 Module_vtkhdf5:INTERNAL=OFF //ADVANCED property for variable: Module_vtkicet Module_vtkicet-ADVANCED:INTERNAL=1 //Request building vtkicet Module_vtkicet:INTERNAL=OFF //ADVANCED property for variable: Module_vtkjpeg Module_vtkjpeg-ADVANCED:INTERNAL=1 //Request building vtkjpeg Module_vtkjpeg:INTERNAL=OFF //ADVANCED property for variable: Module_vtklibproj4 Module_vtklibproj4-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtklibxml2 Module_vtklibxml2-ADVANCED:INTERNAL=1 //Request building vtklibxml2 Module_vtklibxml2:INTERNAL=OFF //ADVANCED property for variable: Module_vtkmrmpi Module_vtkmrmpi-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtknetcdf Module_vtknetcdf-ADVANCED:INTERNAL=1 //Request building vtknetcdf Module_vtknetcdf:INTERNAL=OFF //ADVANCED property for variable: Module_vtkoggtheora Module_vtkoggtheora-ADVANCED:INTERNAL=1 //Request building vtkoggtheora Module_vtkoggtheora:INTERNAL=OFF //ADVANCED property for variable: Module_vtkpng Module_vtkpng-ADVANCED:INTERNAL=1 //Request building vtkpng Module_vtkpng:INTERNAL=OFF //ADVANCED property for variable: Module_vtkprotobuf Module_vtkprotobuf-ADVANCED:INTERNAL=1 //Request building vtkprotobuf Module_vtkprotobuf:INTERNAL=OFF //ADVANCED property for variable: Module_vtkqttesting Module_vtkqttesting-ADVANCED:INTERNAL=1 //Request building vtkqttesting Module_vtkqttesting:INTERNAL=OFF //ADVANCED property for variable: Module_vtksqlite Module_vtksqlite-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Module_vtksys Module_vtksys-ADVANCED:INTERNAL=1 //Request building vtksys Module_vtksys:INTERNAL=OFF //ADVANCED property for variable: Module_vtktiff Module_vtktiff-ADVANCED:INTERNAL=1 //Request building vtktiff Module_vtktiff:INTERNAL=OFF //ADVANCED property for variable: Module_vtkverdict Module_vtkverdict-ADVANCED:INTERNAL=1 //Request building vtkverdict Module_vtkverdict:INTERNAL=OFF //ADVANCED property for variable: Module_vtkxdmf2 Module_vtkxdmf2-ADVANCED:INTERNAL=1 //Request building vtkxdmf2 Module_vtkxdmf2:INTERNAL=OFF //ADVANCED property for variable: Module_vtkzlib Module_vtkzlib-ADVANCED:INTERNAL=1 //Request building vtkzlib Module_vtkzlib:INTERNAL=OFF //ADVANCED property for variable: NETCDF4_CHUNK_CACHE_NELEMS NETCDF4_CHUNK_CACHE_NELEMS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF4_CHUNK_CACHE_PREEMPTION NETCDF4_CHUNK_CACHE_PREEMPTION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF4_CHUNK_CACHE_SIZE NETCDF4_CHUNK_CACHE_SIZE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF4_DEFAULT_CHUNKS_IN_CACHE NETCDF4_DEFAULT_CHUNKS_IN_CACHE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF4_DEFAULT_CHUNK_SIZE NETCDF4_DEFAULT_CHUNK_SIZE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF4_MAX_DEFAULT_CACHE_SIZE NETCDF4_MAX_DEFAULT_CACHE_SIZE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF_DISABLE_COMPILER_WARNINGS NETCDF_DISABLE_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NETCDF_ENABLE_CXX NETCDF_ENABLE_CXX-ADVANCED:INTERNAL=1 //Have library c NOT_NEED_LIBNSL:INTERNAL=1 //ADVANCED property for variable: NVCtrlLib_INCLUDE_DIR NVCtrlLib_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NVCtrlLib_LIBRARY NVCtrlLib_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_INCLUDE_DIR OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_gl_LIBRARY OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_glu_LIBRARY OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_xmesa_INCLUDE_DIR OPENGL_xmesa_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_AdiosReader PARAVIEW_BUILD_PLUGIN_AdiosReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIIO PARAVIEW_BUILD_PLUGIN_AnalyzeNIfTIIO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_ArrowGlyph PARAVIEW_BUILD_PLUGIN_ArrowGlyph-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_EyeDomeLighting PARAVIEW_BUILD_PLUGIN_EyeDomeLighting-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_ForceTime PARAVIEW_BUILD_PLUGIN_ForceTime-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_GMVReader PARAVIEW_BUILD_PLUGIN_GMVReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_H5PartReader PARAVIEW_BUILD_PLUGIN_H5PartReader-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_MantaView PARAVIEW_BUILD_PLUGIN_MantaView-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_MobileRemoteControl PARAVIEW_BUILD_PLUGIN_MobileRemoteControl-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Moments PARAVIEW_BUILD_PLUGIN_Moments-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_Nektar PARAVIEW_BUILD_PLUGIN_Nektar-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_NonOrthogonalSource PARAVIEW_BUILD_PLUGIN_NonOrthogonalSource-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_PacMan PARAVIEW_BUILD_PLUGIN_PacMan-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_PointSprite PARAVIEW_BUILD_PLUGIN_PointSprite-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_PrismPlugin PARAVIEW_BUILD_PLUGIN_PrismPlugin-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_QuadView PARAVIEW_BUILD_PLUGIN_QuadView-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SLACTools PARAVIEW_BUILD_PLUGIN_SLACTools-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SciberQuestToolKit PARAVIEW_BUILD_PLUGIN_SciberQuestToolKit-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SierraPlotTools PARAVIEW_BUILD_PLUGIN_SierraPlotTools-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_SurfaceLIC PARAVIEW_BUILD_PLUGIN_SurfaceLIC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_UncertaintyRendering PARAVIEW_BUILD_PLUGIN_UncertaintyRendering-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_VRPlugin PARAVIEW_BUILD_PLUGIN_VRPlugin-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_BUILD_PLUGIN_VaporPlugin PARAVIEW_BUILD_PLUGIN_VaporPlugin-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_CLIENT_RENDER_SERVER_TESTS PARAVIEW_CLIENT_RENDER_SERVER_TESTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_COLLABORATION_TESTING PARAVIEW_COLLABORATION_TESTING-ADVANCED:INTERNAL=1 //List of modules to CS wrap PARAVIEW_CURRENT_CS_MODULES:INTERNAL=vtkCommonCore;vtkCommonMath;vtkCommonMisc;vtkCommonSystem;vtkCommonTransforms;vtkCommonDataModel;vtkCommonExecutionModel;vtkImagingCore;vtkFiltersCore;vtkCommonComputationalGeometry;vtkFiltersGeneral;vtkImagingFourier;vtkFiltersStatistics;vtkFiltersExtraction;vtkFiltersGeometry;vtkFiltersSources;vtkIOCore;vtkIOImage;vtkIOXMLParser;vtkRenderingCore;vtkInteractionStyle;vtkImagingHybrid;vtkRenderingOpenGL;vtkFiltersModeling;vtkIOLegacy;vtkParallelCore;vtkFiltersParallel;vtkPVCommon;vtkPVVTKExtensionsCore;vtkParallelMPI;vtkPVClientServerCoreCore;vtkPVServerImplementationCore;vtkPVServerManagerCore;vtkCommonColor;vtkInfovisCore;vtkRenderingFreeType;vtkRenderingContext2D;vtkChartsCore;vtkIOGeometry;vtkIOXML;vtkDomainsChemistry;vtkFiltersAMR;vtkFiltersCosmo;vtkFiltersFlowPaths;vtkFiltersGeneric;vtkImagingSources;vtkFiltersHybrid;vtkFiltersHyperTree;vtkFiltersParallelFlowPaths;vtkImagingGeneral;vtkFiltersImaging;vtkFiltersParallelImaging;vtkFiltersParallelMPI;vtkFiltersParallelStatistics;vtkFiltersProgrammable;vtkFiltersTexture;vtkFiltersVerdict;vtkIOAMR;vtkIOEnSight;vtkIOExodus;vtkRenderingGL2PS;vtkIOExport;vtkIOImport;vtkIOInfovis;vtkIOMPIImage;vtkIOMovie;vtkIONetCDF;vtkIOPLY;vtkIOParallel;vtkIOParallelExodus;vtkIOLSDyna;vtkIOParallelLSDyna;vtkIOParallelNetCDF;vtkIOVPIC;vtkIOXdmf2;vtkImagingMorphological;vtkImagingColor;vtkRenderingAnnotation;vtkRenderingVolume;vtkInteractionWidgets;vtkInteractionImage;vtkRenderingFreeTypeOpenGL;vtkRenderingParallel;vtkPVVTKExtensionsRendering;vtkPVVTKExtensionsWebGLExporter;vtkRenderingLabel;vtkRenderingVolumeAMR;vtkRenderingVolumeOpenGL;vtkViewsCore;vtkViewsContext2D;vtkPVClientServerCoreRendering;vtkPVVTKExtensionsDefault;vtkPVClientServerCoreDefault;vtkPVServerImplementationRendering;vtkPVServerImplementationDefault;vtkPVServerManagerRendering;vtkTestingRendering;vtkPVServerManagerDefault;vtkRenderingHybridOpenGL;vtkRenderingLOD;vtkPVServerManagerApplication;vtkCoProcessor //ADVANCED property for variable: PARAVIEW_ENABLE_SPYPLOT_MARKERS PARAVIEW_ENABLE_SPYPLOT_MARKERS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_ENABLE_VTK_MODULES_AS_NEEDED PARAVIEW_ENABLE_VTK_MODULES_AS_NEEDED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_EXTERNAL_PLUGIN_DIRS PARAVIEW_EXTERNAL_PLUGIN_DIRS-ADVANCED:INTERNAL=1 //Server Manager XMLs PARAVIEW_SERVERMANAGER_XMLS:INTERNAL=/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/filters.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/sources.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/readers.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/utilities.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/rendering.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/views_and_representations.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/3d_widgets.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/internal_writers.xml;/mpi3/S2/ParaView/ParaViewCore/ServerManager/SMApplication/Resources/writers.xml //ADVANCED property for variable: PARAVIEW_USE_ICE_T PARAVIEW_USE_ICE_T-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PARAVIEW_USE_MPI_SSEND PARAVIEW_USE_MPI_SSEND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PROTOBUF_DISABLE_COMPILER_WARNINGS PROTOBUF_DISABLE_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_CLEAN_COMMAND PV_TEST_CLEAN_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_CLIENT PV_TEST_CLIENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_INIT_COMMAND PV_TEST_INIT_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PV_TEST_USE_RANDOM_PORTS PV_TEST_USE_RANDOM_PORTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_EXECUTABLE PYTHON_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_DEBUG QT_ARTHURPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_RELEASE QT_ARTHURPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 QT_BINARY_DIR:INTERNAL=/usr/bin //ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_DEBUG QT_CONTAINEREXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_RELEASE QT_CONTAINEREXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DBUSCPP2XML_EXECUTABLE QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DBUSXML2CPP_EXECUTABLE QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DESIGNER_EXECUTABLE QT_DESIGNER_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DOC_DIR QT_DOC_DIR-ADVANCED:INTERNAL=1 QT_HEADERS_DIR:INTERNAL=/usr/include/qt4 //ADVANCED property for variable: QT_HELP_GENERATOR QT_HELP_GENERATOR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_IMPORTS_DIR QT_IMPORTS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LIBRARY_DIR QT_LIBRARY_DIR-ADVANCED:INTERNAL=1 //Qt library dir QT_LIBRARY_DIR:INTERNAL=/usr/lib/x86_64-linux-gnu //ADVANCED property for variable: QT_LINGUIST_EXECUTABLE QT_LINGUIST_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LRELEASE_EXECUTABLE QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LUPDATE_EXECUTABLE QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_MKSPECS_DIR QT_MKSPECS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_MOC_EXECUTABLE QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_DEBUG QT_PHONONWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_RELEASE QT_PHONONWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_INCLUDE_DIR QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY_DEBUG QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY_RELEASE QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PLUGINS_DIR QT_PLUGINS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCNCODECS_PLUGIN_DEBUG QT_QCNCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCNCODECS_PLUGIN_RELEASE QT_QCNCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCOLLECTIONGENERATOR_EXECUTABLE QT_QCOLLECTIONGENERATOR_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_DEBUG QT_QCOREWLANBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_RELEASE QT_QCOREWLANBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_DEBUG QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_RELEASE QT_QDECLARATIVEVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_DEBUG QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_RELEASE QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_DEBUG QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_RELEASE QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_DEBUG QT_QGENERICBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_RELEASE QT_QGENERICBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGIF_PLUGIN_DEBUG QT_QGIF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGIF_PLUGIN_RELEASE QT_QGIF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QICO_PLUGIN_DEBUG QT_QICO_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QICO_PLUGIN_RELEASE QT_QICO_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_DEBUG QT_QIMSW_MULTI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_RELEASE QT_QIMSW_MULTI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPCODECS_PLUGIN_DEBUG QT_QJPCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPCODECS_PLUGIN_RELEASE QT_QJPCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPEG_PLUGIN_DEBUG QT_QJPEG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPEG_PLUGIN_RELEASE QT_QJPEG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QKRCODECS_PLUGIN_DEBUG QT_QKRCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QKRCODECS_PLUGIN_RELEASE QT_QKRCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QMAKE_EXECUTABLE QT_QMAKE_EXECUTABLE-ADVANCED:INTERNAL=1 QT_QMAKE_EXECUTABLE_LAST:INTERNAL=/usr/bin/qmake //ADVANCED property for variable: QT_QMNG_PLUGIN_DEBUG QT_QMNG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QMNG_PLUGIN_RELEASE QT_QMNG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLDB2_PLUGIN_DEBUG QT_QSQLDB2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLDB2_PLUGIN_RELEASE QT_QSQLDB2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_DEBUG QT_QSQLIBASE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_RELEASE QT_QSQLIBASE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE2_PLUGIN_DEBUG QT_QSQLITE2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE2_PLUGIN_RELEASE QT_QSQLITE2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE_PLUGIN_DEBUG QT_QSQLITE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE_PLUGIN_RELEASE QT_QSQLITE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_DEBUG QT_QSQLMYSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_RELEASE QT_QSQLMYSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLOCI_PLUGIN_DEBUG QT_QSQLOCI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLOCI_PLUGIN_RELEASE QT_QSQLOCI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLODBC_PLUGIN_DEBUG QT_QSQLODBC_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLODBC_PLUGIN_RELEASE QT_QSQLODBC_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_DEBUG QT_QSQLPSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_RELEASE QT_QSQLPSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLTDS_PLUGIN_DEBUG QT_QSQLTDS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLTDS_PLUGIN_RELEASE QT_QSQLTDS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVGICON_PLUGIN_DEBUG QT_QSVGICON_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVGICON_PLUGIN_RELEASE QT_QSVGICON_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVG_PLUGIN_DEBUG QT_QSVG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVG_PLUGIN_RELEASE QT_QSVG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_INCLUDE_DIR QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_DEBUG QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_RELEASE QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_INCLUDE_DIR QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_DEBUG QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_RELEASE QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_DEBUG QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_RELEASE QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_INCLUDE_DIR QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY_DEBUG QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY_RELEASE QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_INCLUDE_DIR QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY QT_QTDBUS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY_DEBUG QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY_RELEASE QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_INCLUDE_DIR QT_QTDECLARATIVE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY QT_QTDECLARATIVE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_DEBUG QT_QTDECLARATIVE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_RELEASE QT_QTDECLARATIVE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_DEBUG QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_RELEASE QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_INCLUDE_DIR QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY_DEBUG QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY_RELEASE QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_INCLUDE_DIR QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY_DEBUG QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY_RELEASE QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTIFF_PLUGIN_DEBUG QT_QTIFF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTIFF_PLUGIN_RELEASE QT_QTIFF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_INCLUDE_DIR QT_QTMOTIF_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY QT_QTMOTIF_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY_DEBUG QT_QTMOTIF_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY_RELEASE QT_QTMOTIF_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_INCLUDE_DIR QT_QTMULTIMEDIA_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY QT_QTMULTIMEDIA_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_DEBUG QT_QTMULTIMEDIA_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_RELEASE QT_QTMULTIMEDIA_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_INCLUDE_DIR QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY_DEBUG QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY_RELEASE QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_INCLUDE_DIR QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY QT_QTNSPLUGIN_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_INCLUDE_DIR QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY_DEBUG QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY_RELEASE QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_DEBUG QT_QTSCRIPTDBUS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_RELEASE QT_QTSCRIPTDBUS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_INCLUDE_DIR QT_QTSCRIPTTOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY QT_QTSCRIPTTOOLS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_DEBUG QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_RELEASE QT_QTSCRIPTTOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_INCLUDE_DIR QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_DEBUG QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_RELEASE QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_INCLUDE_DIR QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY_DEBUG QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY_RELEASE QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_INCLUDE_DIR QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY_DEBUG QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY_RELEASE QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_INCLUDE_DIR QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY_DEBUG QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY_RELEASE QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_INCLUDE_DIR QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_DEBUG QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_RELEASE QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWCODECS_PLUGIN_DEBUG QT_QTWCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWCODECS_PLUGIN_RELEASE QT_QTWCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_INCLUDE_DIR QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_DEBUG QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_RELEASE QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_INCLUDE_DIR QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_INCLUDE_DIR QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY_DEBUG QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY_RELEASE QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_DEBUG QT_QWEBVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_RELEASE QT_QWEBVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_RCC_EXECUTABLE QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_DEBUG QT_TASKMENUEXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_RELEASE QT_TASKMENUEXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TESTING_EVENT_PLAYBACK_DELAY QT_TESTING_EVENT_PLAYBACK_DELAY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TESTING_INSTALL_DEVELOPMENT QT_TESTING_INSTALL_DEVELOPMENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TRANSLATIONS_DIR QT_TRANSLATIONS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_UIC3_EXECUTABLE QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_UIC_EXECUTABLE QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_XMLPATTERNS_EXECUTABLE QT_XMLPATTERNS_EXECUTABLE-ADVANCED:INTERNAL=1 //Have symbol Q_WS_MAC Q_WS_MAC:INTERNAL= //Have symbol Q_WS_QWS Q_WS_QWS:INTERNAL= //Have symbol Q_WS_WIN Q_WS_WIN:INTERNAL= //Have symbol Q_WS_X11 Q_WS_X11:INTERNAL=1 //ADVANCED property for variable: SCPCOMMAND SCPCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SITE SITE-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(off_t) SIZEOF_OFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ptrdiff_t) SIZEOF_PTRDIFF_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(size_t) SIZEOF_SIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(ssize_t) SIZEOF_SSIZE_T:INTERNAL=8 //CHECK_TYPE_SIZE: uchar unknown SIZEOF_UCHAR:INTERNAL= //CHECK_TYPE_SIZE: sizeof(_Bool) SIZEOF__BOOL:INTERNAL=1 //ADVANCED property for variable: SLURM_SBATCH_COMMAND SLURM_SBATCH_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SLURM_SRUN_COMMAND SLURM_SRUN_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SQTK_CUDA SQTK_CUDA-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SQTK_DEBUG SQTK_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SQTK_PYTHON_BINDINGS SQTK_PYTHON_BINDINGS-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE STDC_HEADERS:INTERNAL=TRUE //Result of TRY_COMPILE SUCCEED:INTERNAL=TRUE //Result of TRY_COMPILE SUCCEED_MAP:INTERNAL=TRUE //Result of TRY_COMPILE SUCCEED_SET:INTERNAL=TRUE //Result of TRY_COMPILE SUPPORT_IP6_COMPILED:INTERNAL=TRUE //ADVANCED property for variable: SVNCOMMAND SVNCOMMAND-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE SYSTEM_SCOPE_THREADS:INTERNAL=TRUE //Result of TRY_COMPILE TIME_WITH_SYS_TIME:INTERNAL=TRUE //ADVANCED property for variable: USE_COMPILER_HIDDEN_VISIBILITY USE_COMPILER_HIDDEN_VISIBILITY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VERDICT_BUILD_DOC VERDICT_BUILD_DOC-ADVANCED:INTERNAL=1 //Build the 2007 Verdict User Manual VERDICT_BUILD_DOC:INTERNAL=OFF //ADVANCED property for variable: VERDICT_ENABLE_TESTING VERDICT_ENABLE_TESTING-ADVANCED:INTERNAL=1 //Should tests of the VERDICT library be built? VERDICT_ENABLE_TESTING:INTERNAL=OFF //ADVANCED property for variable: VERDICT_MANGLE VERDICT_MANGLE-ADVANCED:INTERNAL=1 //Mangle verdict names for inclusion in a larger library? VERDICT_MANGLE:INTERNAL=OFF //A string to prepend to all verdict function names and classes. VERDICT_MANGLE_PREFIX:INTERNAL= //ADVANCED property for variable: VRPN_INCLUDE_DIR VRPN_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VRPN_LIBRARY VRPN_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VRPN_LIBUSB_INCLUDE_DIR VRPN_LIBUSB_INCLUDE_DIR-ADVANCED:INTERNAL=0 //Result of TRY_COMPILE VSNPRINTF_WORKS:INTERNAL=TRUE //ADVANCED property for variable: VTKOGGTHEORA_DISABLE_ASM VTKOGGTHEORA_DISABLE_ASM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTKOGGTHEORA_DISABLE_FLOAT VTKOGGTHEORA_DISABLE_FLOAT-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(int) VTKOGGTHEORA_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int16_t) VTKOGGTHEORA_INT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(int32_t) VTKOGGTHEORA_INT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int64_t) VTKOGGTHEORA_INT64_T:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long) VTKOGGTHEORA_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) VTKOGGTHEORA_LONG_LONG:INTERNAL=8 //ADVANCED property for variable: VTKOGGTHEORA_SHARED_LINKER_FLAGS VTKOGGTHEORA_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(short) VTKOGGTHEORA_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint16_t) VTKOGGTHEORA_UINT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(uint32_t) VTKOGGTHEORA_UINT32_T:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(u_int16_t) VTKOGGTHEORA_U_INT16_T:INTERNAL=2 //CHECK_TYPE_SIZE: sizeof(u_int32_t) VTKOGGTHEORA_U_INT32_T:INTERNAL=4 //ADVANCED property for variable: VTK_ALL_NEW_OBJECT_FACTORY VTK_ALL_NEW_OBJECT_FACTORY-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VTK_ANSI_STREAM_EOF_COMPILED:INTERNAL=TRUE //Result of TRY_RUN VTK_ANSI_STREAM_EOF_RESULT:INTERNAL=1 //ADVANCED property for variable: VTK_BUILD_ALL_MODULES VTK_BUILD_ALL_MODULES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_BUILD_ALL_MODULES_FOR_TESTS VTK_BUILD_ALL_MODULES_FOR_TESTS-ADVANCED:INTERNAL=1 //Support for C++ type bool VTK_COMPILER_HAS_BOOL:INTERNAL=1 //Support for full template specialization syntax VTK_COMPILER_HAS_FULL_SPECIALIZATION:INTERNAL=1 //Test VTK_CONST_REVERSE_ITERATOR_COMPARISON VTK_CONST_REVERSE_ITERATOR_COMPARISON:INTERNAL=1 //ADVANCED property for variable: VTK_COSMO_USE_MPI VTK_COSMO_USE_MPI-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_DATA_ROOT VTK_DATA_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_DEBUG_LEAKS VTK_DEBUG_LEAKS-ADVANCED:INTERNAL=1 //The directory that code for shaders is stored in. VTK_DEFAULT_SHADERS_DIR:INTERNAL=/mpi3/S2/ParaGit-BBUILD2/VTK/Utilities/MaterialLibrary/Repository //Support for C++ explict templates VTK_EXPLICIT_TEMPLATES:INTERNAL=1 //ADVANCED property for variable: VTK_EXTRA_COMPILER_WARNINGS VTK_EXTRA_COMPILER_WARNINGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_GHOSTSCRIPT_EXECUTABLE VTK_GHOSTSCRIPT_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_GLEXT_FILE VTK_GLEXT_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_GLXEXT_FILE VTK_GLXEXT_FILE-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS:INTERNAL=TRUE //OpenGL includes used to test glXGetProcAddressARB prototype. VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS_INCLUDES:INTERNAL=/usr/include //Already set VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS VTK_GLX_GET_PROC_ADDRESS_ARB_PROTOTYPE_EXISTS_TESTED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_CoProcessing VTK_Group_CoProcessing-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_Imaging VTK_Group_Imaging-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_MPI VTK_Group_MPI-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_ParaViewCore VTK_Group_ParaViewCore-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_ParaViewPython VTK_Group_ParaViewPython-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_ParaViewQt VTK_Group_ParaViewQt-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_ParaViewRendering VTK_Group_ParaViewRendering-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_Qt VTK_Group_Qt-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_Rendering VTK_Group_Rendering-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_StandAlone VTK_Group_StandAlone-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_Group_Views VTK_Group_Views-ADVANCED:INTERNAL=1 //Have symbol feenableexcept VTK_HAS_FEENABLEEXCEPT:INTERNAL=1 //Have symbol isinf VTK_HAS_ISINF:INTERNAL= //Have symbol isnan VTK_HAS_ISNAN:INTERNAL= //Have symbol _isnan VTK_HAS__ISNAN:INTERNAL= //Support for getsockname with socklen_t VTK_HAVE_GETSOCKNAME_WITH_SOCKLEN_T:INTERNAL=1 //Have library socket VTK_HAVE_LIBSOCKET:INTERNAL= //Have symbol SO_REUSEADDR VTK_HAVE_SO_REUSEADDR:INTERNAL=1 //For __sync atomic builtins. VTK_HAVE_SYNC_BUILTINS:INTERNAL=1 //VTK modular always ignores BTX VTK_IGNORE_BTX:INTERNAL=ON //Whether istream supports long long VTK_ISTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //ADVANCED property for variable: VTK_LARGE_DATA_ROOT VTK_LARGE_DATA_ROOT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_LEGACY_REMOVE VTK_LEGACY_REMOVE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_LEGACY_SILENT VTK_LEGACY_SILENT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MAKE_INSTANTIATORS VTK_MAKE_INSTANTIATORS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MATERIALS_DIRS VTK_MATERIALS_DIRS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MAX_THREADS VTK_MAX_THREADS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPIRUN_EXE VTK_MPIRUN_EXE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_MAX_NUMPROCS VTK_MPI_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_NUMPROC_FLAG VTK_MPI_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_POSTFLAGS VTK_MPI_POSTFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_PREFLAGS VTK_MPI_PREFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_MPI_PRENUMPROC_FLAGS VTK_MPI_PRENUMPROC_FLAGS-ADVANCED:INTERNAL=1 //Disable Python Threads support VTK_NO_PYTHON_THREADS:INTERNAL=1 //ADVANCED property for variable: VTK_OPENGL_HAS_OSMESA VTK_OPENGL_HAS_OSMESA-ADVANCED:INTERNAL=1 //Whether ostream supports long long VTK_OSTREAM_SUPPORTS_LONG_LONG:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(char) VTK_SIZEOF_CHAR:INTERNAL=1 //CHECK_TYPE_SIZE: sizeof(double) VTK_SIZEOF_DOUBLE:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(float) VTK_SIZEOF_FLOAT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(int) VTK_SIZEOF_INT:INTERNAL=4 //CHECK_TYPE_SIZE: sizeof(long) VTK_SIZEOF_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(long long) VTK_SIZEOF_LONG_LONG:INTERNAL=8 //CHECK_TYPE_SIZE: sizeof(short) VTK_SIZEOF_SHORT:INTERNAL=2 //CHECK_TYPE_SIZE: __int64 unknown VTK_SIZEOF___INT64:INTERNAL= //Result of TRY_COMPILE VTK_TEST_SYNC_BUILTINS_COMPILED:INTERNAL=TRUE //Whether char is signed. VTK_TYPE_CHAR_IS_SIGNED:INTERNAL=1 //Result of TRY_COMPILE VTK_TYPE_CHAR_IS_SIGNED_COMPILED:INTERNAL=TRUE //CHECK_TYPE_SIZE: sizeof(uintptr_t) VTK_UINTPTR_T:INTERNAL=8 //ADVANCED property for variable: VTK_USE_64BIT_IDS VTK_USE_64BIT_IDS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_GCC_VISIBILITY VTK_USE_GCC_VISIBILITY-ADVANCED:INTERNAL=1 //Have function glXGetProcAddressARB VTK_USE_GLX_GET_PROC_ADDRESS_ARB:INTERNAL=1 //ADVANCED property for variable: VTK_USE_OFFSCREEN VTK_USE_OFFSCREEN-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_EXPAT VTK_USE_SYSTEM_EXPAT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_FREETYPE VTK_USE_SYSTEM_FREETYPE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_GL2PS VTK_USE_SYSTEM_GL2PS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_HDF5 VTK_USE_SYSTEM_HDF5-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_ICET VTK_USE_SYSTEM_ICET-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_JPEG VTK_USE_SYSTEM_JPEG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_LIBXML2 VTK_USE_SYSTEM_LIBXML2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_OGGTHEORA VTK_USE_SYSTEM_OGGTHEORA-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_PNG VTK_USE_SYSTEM_PNG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_PROTOBUF VTK_USE_SYSTEM_PROTOBUF-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_QTTESTING VTK_USE_SYSTEM_QTTESTING-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_TIFF VTK_USE_SYSTEM_TIFF-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_XDMF2 VTK_USE_SYSTEM_XDMF2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_SYSTEM_ZLIB VTK_USE_SYSTEM_ZLIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TDX VTK_USE_TDX-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_TK VTK_USE_TK-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_USE_X VTK_USE_X-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_VPIC_USE_MPI VTK_VPIC_USE_MPI-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WGLEXT_FILE VTK_WGLEXT_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WRAP_HINTS VTK_WRAP_HINTS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_WRAP_JAVA VTK_WRAP_JAVA-ADVANCED:INTERNAL=1 //Should VTK Python wrapping be built? VTK_WRAP_PYTHON:INTERNAL=OFF //ADVANCED property for variable: VTK_WRAP_TCL VTK_WRAP_TCL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VTK_XDMF_USE_MPI VTK_XDMF_USE_MPI-ADVANCED:INTERNAL=1 //Test Wno-unused-result Wno-unused-result:INTERNAL=1 //ADVANCED property for variable: X11_ICE_INCLUDE_PATH X11_ICE_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_ICE_LIB X11_ICE_LIB-ADVANCED:INTERNAL=1 //Have library /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so X11_LIB_X11_SOLO:INTERNAL=1 //ADVANCED property for variable: X11_SM_INCLUDE_PATH X11_SM_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_SM_LIB X11_SM_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_INCLUDE_PATH X11_X11_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_LIB X11_X11_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XRes_INCLUDE_PATH X11_XRes_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XRes_LIB X11_XRes_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XShm_INCLUDE_PATH X11_XShm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XSync_INCLUDE_PATH X11_XSync_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_INCLUDE_PATH X11_XTest_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_LIB X11_XTest_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessrules_INCLUDE_PATH X11_Xaccessrules_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessstr_INCLUDE_PATH X11_Xaccessstr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_INCLUDE_PATH X11_Xau_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_LIB X11_Xau_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_INCLUDE_PATH X11_Xcomposite_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_LIB X11_Xcomposite_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_INCLUDE_PATH X11_Xcursor_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_LIB X11_Xcursor_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_INCLUDE_PATH X11_Xdamage_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_LIB X11_Xdamage_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_INCLUDE_PATH X11_Xdmcp_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_LIB X11_Xdmcp_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xext_LIB X11_Xext_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_INCLUDE_PATH X11_Xfixes_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_LIB X11_Xfixes_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_INCLUDE_PATH X11_Xft_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_LIB X11_Xft_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_INCLUDE_PATH X11_Xi_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_LIB X11_Xi_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_INCLUDE_PATH X11_Xinerama_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_LIB X11_Xinerama_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_INCLUDE_PATH X11_Xinput_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_LIB X11_Xinput_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkb_INCLUDE_PATH X11_Xkb_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkbfile_INCLUDE_PATH X11_Xkbfile_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkbfile_LIB X11_Xkbfile_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkblib_INCLUDE_PATH X11_Xkblib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xlib_INCLUDE_PATH X11_Xlib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xmu_INCLUDE_PATH X11_Xmu_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xmu_LIB X11_Xmu_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_INCLUDE_PATH X11_Xpm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_LIB X11_Xpm_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_INCLUDE_PATH X11_Xrandr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_LIB X11_Xrandr_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_INCLUDE_PATH X11_Xrender_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_LIB X11_Xrender_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_INCLUDE_PATH X11_Xscreensaver_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_LIB X11_Xscreensaver_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xshape_INCLUDE_PATH X11_Xshape_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_INCLUDE_PATH X11_Xt_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_LIB X11_Xt_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xutil_INCLUDE_PATH X11_Xutil_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_INCLUDE_PATH X11_Xv_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_LIB X11_Xv_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xxf86misc_LIB X11_Xxf86misc_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xxf86vm_LIB X11_Xxf86vm_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_dpms_INCLUDE_PATH X11_dpms_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86misc_INCLUDE_PATH X11_xf86misc_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86vmode_INCLUDE_PATH X11_xf86vmode_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_BUILD_MPI XDMF_BUILD_MPI-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAS_NDGM XDMF_HAS_NDGM-ADVANCED:INTERNAL=1 //Whether streams support 64-bit types XDMF_HAVE_64BIT_STREAMS:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_FCNTL XDMF_HAVE_FCNTL-ADVANCED:INTERNAL=1 //Have include malloc.h XDMF_HAVE_MALLOC_H:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_MMAN XDMF_HAVE_MMAN-ADVANCED:INTERNAL=1 //ADVANCED property for variable: XDMF_HAVE_NETINET XDMF_HAVE_NETINET-ADVANCED:INTERNAL=1 XDMF_REGENERATE_WRAPPERS:INTERNAL=OFF XDMF_REGENERATE_YACCLEX:INTERNAL=OFF //ADVANCED property for variable: XDMF_USE_MYSQL XDMF_USE_MYSQL-ADVANCED:INTERNAL=1 XDMF_WRAP_CSHARP:INTERNAL=OFF XDMF_WRAP_PYTHON:INTERNAL=OFF XDMF_WRAP_TCL:INTERNAL=OFF //ADVANCED property for variable: ZLIB_INCLUDE_DIR ZLIB_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: ZLIB_LIBRARY ZLIB_LIBRARY-ADVANCED:INTERNAL=1 //ParaView has been configured __paraview_configured:INTERNAL=TRUE //Have function _isinf float.h:INTERNAL= netcdf_cxx_SOURCES:INTERNAL=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/cxx/netcdf.cpp;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/cxx/ncvalues.cpp netcdf_dispatch_SOURCES:INTERNAL=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/parallel.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/copy.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/file.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/dim.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/att.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/error.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/var.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/dispatch.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/nc_url.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/nclist.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/ncbytes.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/ncbytes.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libdispatch/nc4.c netcdf_liblib_SOURCES:INTERNAL=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/liblib/stub.c netcdf_src4_SOURCES:INTERNAL=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4internal.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/error4.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4dispatch.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4dispatch.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4attr.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4dim.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4file.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4grp.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4type.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4var.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/ncfunc.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4internal.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc4/nc4hdf.c netcdf_src_SOURCES:INTERNAL=/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/string.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/v1hpg.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/onstack.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/rnd.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/utf8proc.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/utf8proc_data.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/nclistmgr.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/putget.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/attr.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/nc3dispatch.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/nc.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/var.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/dim.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/ncx.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/ncx.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/lookup3.c;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/pstdint.h;/mpi3/S2/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/libsrc/posixio.c //ADVANCED property for variable: smooth_flash smooth_flash-ADVANCED:INTERNAL=1 ===vrpn # This is the CMakeCache file. # For build in directory: /mpi3/S2/vrpn-BUILD # It was generated by CMake: /usr/local/bin/cmake # You can edit this file to change values found and used by cmake. # If you do not want to change any of the values, simply exit the editor. # If you do want to change a value, simply edit, save, and exit the editor. # The syntax for the file is as follows: # KEY:TYPE=VALUE # KEY is the name of a variable in the cache. # TYPE is a hint to GUI's for the type of VALUE, DO NOT EDIT TYPE!. # VALUE is the current value for the KEY. ######################## # EXTERNAL cache entries ######################## //Path to a program. BIBTEX_COMPILER:FILEPATH=/usr/bin/bibtex //Human-readable build ID info BUILDNAME:STRING=Linux-3.2.0-38-generic-x86_64-gcc4.6 //Build the testing tree. BUILD_TESTING:BOOL=ON //Path to a program. BZRCOMMAND:FILEPATH=/usr/bin/bzr //Path to a program. CMAKE_AR:FILEPATH=/usr/bin/ar CMAKE_BUILD_TYPE:STRING=RelWithDebInfo //Enable/Disable color output during build. CMAKE_COLOR_MAKEFILE:BOOL=ON //CXX compiler. CMAKE_CXX_COMPILER:FILEPATH=/usr/bin/c++ //Flags used by the compiler during all build types. CMAKE_CXX_FLAGS:STRING=-fPIC -DAdd_ -m64 -pthread -O3 -fopenmp -lgomp -march=barcelona -ftree-vectorize -funroll-loops -ffast-math //Flags used by the compiler during debug builds. CMAKE_CXX_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_CXX_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_CXX_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_CXX_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //C compiler. CMAKE_C_COMPILER:FILEPATH=/usr/bin/gcc //Flags used by the compiler during all build types. CMAKE_C_FLAGS:STRING=-fPIC -DAdd_ -m64 -pthread -O3 -fopenmp -lgomp -march=barcelona -ftree-vectorize -funroll-loops -ffast-math //Flags used by the compiler during debug builds. CMAKE_C_FLAGS_DEBUG:STRING=-g //Flags used by the compiler during release minsize builds. CMAKE_C_FLAGS_MINSIZEREL:STRING=-Os -DNDEBUG //Flags used by the compiler during release builds (/MD /Ob1 /Oi // /Ot /Oy /Gs will produce slightly less optimized but smaller // files). CMAKE_C_FLAGS_RELEASE:STRING=-O3 -DNDEBUG //Flags used by the compiler during Release with Debug Info builds. CMAKE_C_FLAGS_RELWITHDEBINFO:STRING=-O2 -g //Flags used by the linker. CMAKE_EXE_LINKER_FLAGS:STRING=' ' //Flags used by the linker during debug builds. CMAKE_EXE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_EXE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_EXE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Enable/Disable output of compile commands during generation. CMAKE_EXPORT_COMPILE_COMMANDS:BOOL=OFF //Install path prefix, prepended onto install directories. CMAKE_INSTALL_PREFIX:PATH=/mpi3/C2/vrpn //Path to a program. CMAKE_LINKER:FILEPATH=/usr/bin/ld //Path to a program. CMAKE_MAKE_PROGRAM:FILEPATH=/usr/bin/make //Flags used by the linker during the creation of modules. CMAKE_MODULE_LINKER_FLAGS:STRING=' ' //Flags used by the linker during debug builds. CMAKE_MODULE_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_MODULE_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO:STRING= //Path to a program. CMAKE_NM:FILEPATH=/usr/bin/nm //Path to a program. CMAKE_OBJCOPY:FILEPATH=/usr/bin/objcopy //Path to a program. CMAKE_OBJDUMP:FILEPATH=/usr/bin/objdump //Value Computed by CMake CMAKE_PROJECT_NAME:STATIC=VRPN //Path to a program. CMAKE_RANLIB:FILEPATH=/usr/bin/ranlib //Flags used by the linker during the creation of dll's. CMAKE_SHARED_LINKER_FLAGS:STRING=' ' //Flags used by the linker during debug builds. CMAKE_SHARED_LINKER_FLAGS_DEBUG:STRING= //Flags used by the linker during release minsize builds. CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL:STRING= //Flags used by the linker during release builds. CMAKE_SHARED_LINKER_FLAGS_RELEASE:STRING= //Flags used by the linker during Release with Debug Info builds. CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO:STRING= //If set, runtime paths are not added when installing shared libraries, // but are added when building. CMAKE_SKIP_INSTALL_RPATH:BOOL=NO //If set, runtime paths are not added when using shared libraries. CMAKE_SKIP_RPATH:BOOL=NO //Path to a program. CMAKE_STRIP:FILEPATH=/usr/bin/strip //If true, cmake will use relative paths in makefiles and projects. CMAKE_USE_RELATIVE_PATHS:BOOL=OFF //If this value is on, makefiles will be generated without the // .SILENT directive, and all commands will be echoed to the console // during the make. This is useful for debugging only. With Visual // Studio IDE projects all commands are done without /nologo. CMAKE_VERBOSE_MAKEFILE:BOOL=FALSE //Path to the coverage program that CTest uses for performing coverage // inspection COVERAGE_COMMAND:FILEPATH=/usr/bin/gcov //Extra command line flags to pass to the coverage tool COVERAGE_EXTRA_FLAGS:STRING=-l //Enable to build Debian packages CPACK_BINARY_DEB:BOOL=OFF //Enable to build NSIS packages CPACK_BINARY_NSIS:BOOL=OFF //Enable to build RPM packages CPACK_BINARY_RPM:BOOL=OFF //Enable to build STGZ packages CPACK_BINARY_STGZ:BOOL=ON //Enable to build TBZ2 packages CPACK_BINARY_TBZ2:BOOL=OFF //Enable to build TGZ packages CPACK_BINARY_TGZ:BOOL=ON //Enable to build TZ packages CPACK_BINARY_TZ:BOOL=ON //Enable to build TBZ2 source packages CPACK_SOURCE_TBZ2:BOOL=ON //Enable to build TGZ source packages CPACK_SOURCE_TGZ:BOOL=ON //Enable to build TZ source packages CPACK_SOURCE_TZ:BOOL=ON //Enable to build ZIP source packages CPACK_SOURCE_ZIP:BOOL=OFF //Path to a program. CPPCHECK_EXECUTABLE:FILEPATH=CPPCHECK_EXECUTABLE-NOTFOUND //Path to search for cppcheck CPPCHECK_ROOT_DIR:PATH= //How many times to retry timed-out CTest submissions. CTEST_SUBMIT_RETRY_COUNT:STRING=3 //How long to wait between timed-out CTest submissions. CTEST_SUBMIT_RETRY_DELAY:STRING=5 //Path to a program. CVSCOMMAND:FILEPATH=CVSCOMMAND-NOTFOUND //Options passed to the cvs update command. CVS_UPDATE_OPTIONS:STRING=-d -A -P //Maximum time allowed before CTest will kill the test. DART_TESTING_TIMEOUT:STRING=1500 //Directory to use as the root of all dashboard work DASHBOARDSCRIPT_BASE_DIRECTORY:PATH=/mpi3/S2/vrpn-BUILD/Dashboards-mpi1-joni //Build configuration to use for dashboard builds by default DASHBOARDSCRIPT_BUILD_CONFIGURATION:STRING=RelWithDebInfo //The cmake binary to use when configuring a dashboard build DASHBOARDSCRIPT_CMAKE_COMMAND:FILEPATH=/usr/local/bin/cmake //Path to a program. DASHBOARDSCRIPT_CTEST_EXECUTABLE:FILEPATH=/usr/local/bin/ctest //Graphviz Dot tool for using Doxygen DOXYGEN_DOT_EXECUTABLE:FILEPATH=/usr/bin/dot DOXYGEN_DOT_PATH:FILEPATH=/usr/bin //Doxygen documentation generation tool (http://www.doxygen.org [^]) DOXYGEN_EXECUTABLE:FILEPATH=/usr/bin/doxygen //Path to a program. DVIPDF_CONVERTER:FILEPATH=/usr/bin/dvipdfm //Path to a program. DVIPS_CONVERTER:FILEPATH=/usr/bin/dvips //Path to a file. GHOST_INCLUDE_DIR:PATH=GHOST_INCLUDE_DIR-NOTFOUND //Path to a library. GHOST_LIBRARY:FILEPATH=GHOST_LIBRARY-NOTFOUND //Path to search for GHOST GHOST_ROOT_DIR:PATH= //Path to a program. GITCOMMAND:FILEPATH=/usr/bin/git //git command line client GIT_EXECUTABLE:FILEPATH=/usr/bin/git //Path to a file. GLUT_INCLUDE_DIR:PATH=GLUT_INCLUDE_DIR-NOTFOUND //Path to a library. GLUT_Xi_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libXi.so //Path to a library. GLUT_Xmu_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libXmu.so //Path to a library. GLUT_glut_LIBRARY:FILEPATH=GLUT_glut_LIBRARY-NOTFOUND //Path to a file. GPM_INCLUDE_DIR:PATH=GPM_INCLUDE_DIR-NOTFOUND //Path to a library. GPM_LIBRARY:FILEPATH=GPM_LIBRARY-NOTFOUND //Path to a file. HDAPI_HDU_INCLUDE_DIR:PATH=HDAPI_HDU_INCLUDE_DIR-NOTFOUND //The HDAPI_HDU library HDAPI_HDU_LIBRARY:FILEPATH= //Path to a library. HDAPI_HDU_LIBRARY_DEBUG:FILEPATH=HDAPI_HDU_LIBRARY_DEBUG-NOTFOUND //Path to a library. HDAPI_HDU_LIBRARY_RELEASE:FILEPATH=HDAPI_HDU_LIBRARY_RELEASE-NOTFOUND //Path to a file. HDAPI_HDU_SOURCE_DIR:PATH=HDAPI_HDU_SOURCE_DIR-NOTFOUND //Path to a file. HDAPI_INCLUDE_DIR:PATH=HDAPI_INCLUDE_DIR-NOTFOUND //The HDAPI library HDAPI_LIBRARY:FILEPATH= //Path to a library. HDAPI_LIBRARY_DEBUG:FILEPATH=HDAPI_LIBRARY_DEBUG-NOTFOUND //Path to a library. HDAPI_LIBRARY_RELEASE:FILEPATH=HDAPI_LIBRARY_RELEASE-NOTFOUND //Path to a library. HDAPI_PHANToMIO_LIBRARY:FILEPATH=HDAPI_PHANToMIO_LIBRARY-NOTFOUND //Path to a program. HGCOMMAND:FILEPATH=/usr/bin/hg //Path to a file. HIDAPI_HIDRAW_INCLUDE_DIR:PATH=/mpi3/C2/include/hidapi //Path to a file. HIDAPI_INCLUDE_DIR:PATH=/mpi3/C2/hidapi/include/hidapi //Path to a library. HIDAPI_LIBRARY:FILEPATH=/mpi3/C2/hidapi/lib/libhidapi-libusb.so //Path to a library. HIDAPI_LIBUDEV:FILEPATH=/usr/lib/x86_64-linux-gnu/libudev.so //Path to a file. HIDAPI_LIBUDEV_INCLUDE_DIR:PATH=/mpi3/C2/hidapi/lib //Path to a file. HLAPI_HLU_INCLUDE_DIR:PATH=HLAPI_HLU_INCLUDE_DIR-NOTFOUND //The HLAPI_HLU library HLAPI_HLU_LIBRARY:FILEPATH= //Path to a library. HLAPI_HLU_LIBRARY_DEBUG:FILEPATH=HLAPI_HLU_LIBRARY_DEBUG-NOTFOUND //Path to a library. HLAPI_HLU_LIBRARY_RELEASE:FILEPATH=HLAPI_HLU_LIBRARY_RELEASE-NOTFOUND //Path to a file. HLAPI_HLU_SOURCE_DIR:PATH=HLAPI_HLU_SOURCE_DIR-NOTFOUND //Path to a file. HLAPI_INCLUDE_DIR:PATH=HLAPI_INCLUDE_DIR-NOTFOUND //The HLAPI library HLAPI_LIBRARY:FILEPATH= //Path to a library. HLAPI_LIBRARY_DEBUG:FILEPATH=HLAPI_LIBRARY_DEBUG-NOTFOUND //Path to a library. HLAPI_LIBRARY_RELEASE:FILEPATH=HLAPI_LIBRARY_RELEASE-NOTFOUND //Path to a program. JAVAH_EXECUTABLE:FILEPATH=JAVAH_EXECUTABLE-NOTFOUND //Path to a file. JAVA_AWT_INCLUDE_PATH:PATH=JAVA_AWT_INCLUDE_PATH-NOTFOUND //Path to a library. JAVA_AWT_LIBRARY:FILEPATH=JAVA_AWT_LIBRARY-NOTFOUND //Path to a file. JAVA_INCLUDE_PATH:PATH=JAVA_INCLUDE_PATH-NOTFOUND //Path to a file. JAVA_INCLUDE_PATH2:PATH=JAVA_INCLUDE_PATH2-NOTFOUND //Path to a library. JAVA_JVM_LIBRARY:FILEPATH=JAVA_JVM_LIBRARY-NOTFOUND //Path to a file. JSONCPP_INCLUDE_DIR:PATH=JSONCPP_INCLUDE_DIR-NOTFOUND //Path to a library. JSONCPP_LIBRARY:FILEPATH=JSONCPP_LIBRARY-NOTFOUND //Directory to search for JSONCPP JSONCPP_ROOT_DIR:PATH= //Path to a program. Java_JAR_EXECUTABLE:FILEPATH=Java_JAR_EXECUTABLE-NOTFOUND //Path to a program. Java_JAVAC_EXECUTABLE:FILEPATH=Java_JAVAC_EXECUTABLE-NOTFOUND //Path to a program. Java_JAVADOC_EXECUTABLE:FILEPATH=Java_JAVADOC_EXECUTABLE-NOTFOUND //Path to a program. Java_JAVAH_EXECUTABLE:FILEPATH=Java_JAVAH_EXECUTABLE-NOTFOUND //Path to a program. Java_JAVA_EXECUTABLE:FILEPATH=/usr/bin/java //Path to a program. LATEX2HTML_CONVERTER:FILEPATH=LATEX2HTML_CONVERTER-NOTFOUND //Path to a program. LATEX_COMPILER:FILEPATH=/usr/bin/latex //Path to a file. LIBNIFALCON_INCLUDE_DIR:PATH=LIBNIFALCON_INCLUDE_DIR-NOTFOUND //Path to a library. LIBNIFALCON_LIBRARY:FILEPATH=LIBNIFALCON_LIBRARY-NOTFOUND //Path to a file. LIBNIFALCON_LIBUSB1_INCLUDE_DIR:PATH=/usr/include //Path to a library. LIBNIFALCON_LIBUSB1_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libusb-1.0.so //Where to start searching LIBNIFALCON_ROOT_DIR:PATH= //Path to a library. LIBNIFALCON_rt_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/librt.so //Path to a file. LIBUSB1_INCLUDE_DIR:PATH=/usr/include/libusb-1.0 //Path to a library. LIBUSB1_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libusb-1.0.so //Root directory to search for libusb-1 LIBUSB1_ROOT_DIR:PATH= //Command to build the project MAKECOMMAND:STRING=/usr/bin/make -i //Path to a program. MAKEINDEX_COMPILER:FILEPATH=/usr/bin/makeindex //Path to the memory checking command, used for memory error detection. MEMORYCHECK_COMMAND:FILEPATH=/usr/bin/valgrind //File that contains suppressions for the memory checker MEMORYCHECK_SUPPRESSIONS_FILE:FILEPATH= //Executable for running MPI programs. MPIEXEC:FILEPATH=/mpi3/C2/mpich-3.0.1/bin/mpiexec //Maximum number of processors available to run MPI applications. MPIEXEC_MAX_NUMPROCS:STRING=2 //Flag used by MPI to specify the number of processes for MPIEXEC; // the next option will be the number of processes. MPIEXEC_NUMPROC_FLAG:STRING=-np //These flags will come after all flags given to MPIEXEC. MPIEXEC_POSTFLAGS:STRING= //These flags will be directly before the executable that is being // run by MPIEXEC. MPIEXEC_PREFLAGS:STRING= //Cleared MPI_CXX_COMPILER:FILEPATH=/usr/bin/mpicxx //MPI CXX compilation flags MPI_CXX_COMPILE_FLAGS:STRING= //MPI CXX include path MPI_CXX_INCLUDE_PATH:STRING=/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi //MPI CXX libraries to link against MPI_CXX_LIBRARIES:STRING=/usr/lib/openmpi/lib/libmpi_cxx.so;/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so //MPI CXX linking flags MPI_CXX_LINK_FLAGS:STRING= -Wl,--export-dynamic //Cleared MPI_C_COMPILER:FILEPATH=/usr/bin/mpicc //MPI C compilation flags MPI_C_COMPILE_FLAGS:STRING= //MPI C include path MPI_C_INCLUDE_PATH:STRING=/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi //MPI C libraries to link against MPI_C_LIBRARIES:STRING=/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so //MPI C linking flags MPI_C_LINK_FLAGS:STRING= -Wl,--export-dynamic //Extra MPI libraries to link against MPI_EXTRA_LIBRARY:STRING=/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so //MPI library to link against MPI_LIBRARY:FILEPATH=/usr/lib/openmpi/lib/libmpi_cxx.so //Path to a file. NIDAQMX_INCLUDE_DIR:PATH=NIDAQMX_INCLUDE_DIR-NOTFOUND //Path to a library. NIDAQMX_LIBRARY:FILEPATH=NIDAQMX_LIBRARY-NOTFOUND //Path to a file. OPENGL_INCLUDE_DIR:PATH=/usr/include //Path to a library. OPENGL_gl_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libGL.so //Path to a library. OPENGL_glu_LIBRARY:FILEPATH=/usr/lib/x86_64-linux-gnu/libGLU.so //Path to a file. OPENGL_xmesa_INCLUDE_DIR:PATH=OPENGL_xmesa_INCLUDE_DIR-NOTFOUND //Whether we should compile HDU and HLU, if needed, as a part of // the solution OPENHAPTICS_NESTED_TARGETS:BOOL=ON //Path to search for OpenHaptics OPENHAPTICS_ROOT_DIR:PATH= //Path to a program. PDFLATEX_COMPILER:FILEPATH=/usr/bin/pdflatex //Location found for module Parse::RecDescent PERLMODULES_PARSE_RECDESCENT_MODULE:FILEPATH=/usr/share/perl5/Parse/RecDescent.pm //Path to a program. PERL_EXECUTABLE:FILEPATH=/usr/bin/perl //pkg-config executable PKG_CONFIG_EXECUTABLE:FILEPATH=/usr/bin/pkg-config //Path to a program. PS2PDF_CONVERTER:FILEPATH=/usr/bin/ps2pdf14 //Add module vrpn-python PYTHON_ENABLE_MODULE_vrpn-python:BOOL=ON //Path to a file. PYTHON_INCLUDE_DIR:PATH=/usr/include/python3.2mu //Path to a library. PYTHON_LIBRARY:FILEPATH=/usr/lib/libpython3.2mu.so //Add module vrpn-python shared PYTHON_MODULE_vrpn-python_BUILD_SHARED:BOOL=ON //Path to a library. QT_ARTHURPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_ARTHURPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_ARTHURPLUGIN_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_CONTAINEREXTENSION_PLUGIN_DEBUG:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_CONTAINEREXTENSION_PLUGIN_RELEASE:FILEPATH=QT_CONTAINEREXTENSION_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-NOTFOUND //Path to a program. QT_DBUSCPP2XML_EXECUTABLE:FILEPATH=/usr/bin/qdbuscpp2xml //Path to a program. QT_DBUSXML2CPP_EXECUTABLE:FILEPATH=/usr/bin/qdbusxml2cpp //Path to a program. QT_DESIGNER_EXECUTABLE:FILEPATH=/usr/bin/designer-qt4 //The location of the Qt docs QT_DOC_DIR:PATH=/usr/share/qt4/doc //The location of the Qt imports QT_IMPORTS_DIR:PATH=QT_IMPORTS_DIR-NOTFOUND //Path to a program. QT_LINGUIST_EXECUTABLE:FILEPATH=/usr/bin/linguist-qt4 //Path to a program. QT_LRELEASE_EXECUTABLE:FILEPATH=/usr/bin/lrelease-qt4 //Path to a program. QT_LUPDATE_EXECUTABLE:FILEPATH=/usr/bin/lupdate-qt4 //The location of the Qt mkspecs containing qconfig.pri QT_MKSPECS_DIR:PATH=/usr/share/qt4/mkspecs //Path to a program. QT_MOC_EXECUTABLE:FILEPATH=/usr/bin/moc-qt4 //Path to a library. QT_PHONONWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_PHONONWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_PHONONWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libphononwidgets.so //Path to a file. QT_PHONON_INCLUDE_DIR:PATH=/usr/include/qt4/phonon //The Qt PHONON library QT_PHONON_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libphonon.so //Path to a library. QT_PHONON_LIBRARY_DEBUG:FILEPATH=QT_PHONON_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_PHONON_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libphonon.so //The location of the Qt plugins QT_PLUGINS_DIR:PATH=/usr/lib/x86_64-linux-gnu/qt4/plugins //Path to a library. QT_QCNCODECS_PLUGIN_DEBUG:FILEPATH=QT_QCNCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QCNCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqcncodecs.so //Path to a program. QT_QCOLLECTIONGENERATOR_EXECUTABLE:FILEPATH=/usr/bin/qcollectiongenerator //Path to a library. QT_QCOREWLANBEARER_PLUGIN_DEBUG:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QCOREWLANBEARER_PLUGIN_RELEASE:FILEPATH=QT_QCOREWLANBEARER_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QDECLARATIVEVIEW_PLUGIN_DEBUG:FILEPATH=QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QDECLARATIVEVIEW_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqdeclarativeview.so //Path to a library. QT_QDECORATIONDEFAULT_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QDECORATIONDEFAULT_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QDECORATIONWINDOWS_PLUGIN_DEBUG:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QDECORATIONWINDOWS_PLUGIN_RELEASE:FILEPATH=QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QGENERICBEARER_PLUGIN_DEBUG:FILEPATH=QT_QGENERICBEARER_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QGENERICBEARER_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/bearer/libqgenericbearer.so //Path to a library. QT_QGIF_PLUGIN_DEBUG:FILEPATH=QT_QGIF_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QGIF_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqgif.so //Path to a library. QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/graphicssystems/libqglgraphicssystem.so //Path to a library. QT_QICO_PLUGIN_DEBUG:FILEPATH=QT_QICO_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QICO_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqico.so //Path to a library. QT_QIMSW_MULTI_PLUGIN_DEBUG:FILEPATH=QT_QIMSW_MULTI_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QIMSW_MULTI_PLUGIN_RELEASE:FILEPATH=QT_QIMSW_MULTI_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QJPCODECS_PLUGIN_DEBUG:FILEPATH=QT_QJPCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QJPCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqjpcodecs.so //Path to a library. QT_QJPEG_PLUGIN_DEBUG:FILEPATH=QT_QJPEG_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QJPEG_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqjpeg.so //Path to a library. QT_QKRCODECS_PLUGIN_DEBUG:FILEPATH=QT_QKRCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QKRCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqkrcodecs.so //The qmake executable for the Qt installation to use QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin/qmake //Path to a library. QT_QMNG_PLUGIN_DEBUG:FILEPATH=QT_QMNG_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QMNG_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqmng.so //Path to a library. QT_QSQLDB2_PLUGIN_DEBUG:FILEPATH=QT_QSQLDB2_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLDB2_PLUGIN_RELEASE:FILEPATH=QT_QSQLDB2_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLIBASE_PLUGIN_DEBUG:FILEPATH=QT_QSQLIBASE_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLIBASE_PLUGIN_RELEASE:FILEPATH=QT_QSQLIBASE_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLITE2_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE2_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLITE2_PLUGIN_RELEASE:FILEPATH=QT_QSQLITE2_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLITE_PLUGIN_DEBUG:FILEPATH=QT_QSQLITE_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLITE_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/sqldrivers/libqsqlite.so //Path to a library. QT_QSQLMYSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLMYSQL_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLMYSQL_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/sqldrivers/libqsqlmysql.so //Path to a library. QT_QSQLOCI_PLUGIN_DEBUG:FILEPATH=QT_QSQLOCI_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLOCI_PLUGIN_RELEASE:FILEPATH=QT_QSQLOCI_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLODBC_PLUGIN_DEBUG:FILEPATH=QT_QSQLODBC_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLODBC_PLUGIN_RELEASE:FILEPATH=QT_QSQLODBC_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLPSQL_PLUGIN_DEBUG:FILEPATH=QT_QSQLPSQL_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLPSQL_PLUGIN_RELEASE:FILEPATH=QT_QSQLPSQL_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSQLTDS_PLUGIN_DEBUG:FILEPATH=QT_QSQLTDS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSQLTDS_PLUGIN_RELEASE:FILEPATH=QT_QSQLTDS_PLUGIN_RELEASE-NOTFOUND //Path to a library. QT_QSVGICON_PLUGIN_DEBUG:FILEPATH=QT_QSVGICON_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSVGICON_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/iconengines/libqsvgicon.so //Path to a library. QT_QSVG_PLUGIN_DEBUG:FILEPATH=QT_QSVG_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QSVG_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqsvg.so //Path to a library. QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqt3supportwidgets.so //Path to a file. QT_QT3SUPPORT_INCLUDE_DIR:PATH=/usr/include/qt4/Qt3Support //The Qt QT3SUPPORT library QT_QT3SUPPORT_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQt3Support.so //Path to a library. QT_QT3SUPPORT_LIBRARY_DEBUG:FILEPATH=QT_QT3SUPPORT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QT3SUPPORT_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQt3Support.so //Path to a library. QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblecompatwidgets.so //Path to a library. QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG:FILEPATH=QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/accessible/libqtaccessiblewidgets.so //Path to a file. QT_QTASSISTANTCLIENT_INCLUDE_DIR:PATH=QT_QTASSISTANTCLIENT_INCLUDE_DIR-NOTFOUND //The Qt QTASSISTANTCLIENT library QT_QTASSISTANTCLIENT_LIBRARY:STRING= //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANTCLIENT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTASSISTANT_INCLUDE_DIR:PATH=QT_QTASSISTANT_INCLUDE_DIR-NOTFOUND //The Qt QTASSISTANT library QT_QTASSISTANT_LIBRARY:STRING= //Path to a library. QT_QTASSISTANT_LIBRARY_DEBUG:FILEPATH=QT_QTASSISTANT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTASSISTANT_LIBRARY_RELEASE:FILEPATH=QT_QTASSISTANT_LIBRARY_RELEASE-NOTFOUND //The Qt QTCLUCENE library QT_QTCLUCENE_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtCLucene.so //Path to a library. QT_QTCLUCENE_LIBRARY_DEBUG:FILEPATH=QT_QTCLUCENE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCLUCENE_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtCLucene.so //Path to a file. QT_QTCORE_INCLUDE_DIR:PATH=/usr/include/qt4/QtCore //The Qt QTCORE library QT_QTCORE_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtCore.so //Path to a library. QT_QTCORE_LIBRARY_DEBUG:FILEPATH=QT_QTCORE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTCORE_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtCore.so //Path to a file. QT_QTDBUS_INCLUDE_DIR:PATH=/usr/include/qt4/QtDBus //The Qt QTDBUS library QT_QTDBUS_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtDBus.so //Path to a library. QT_QTDBUS_LIBRARY_DEBUG:FILEPATH=QT_QTDBUS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDBUS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDBus.so //Path to a file. QT_QTDECLARATIVE_INCLUDE_DIR:PATH=/usr/include/qt4/QtDeclarative //The Qt QTDECLARATIVE library QT_QTDECLARATIVE_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtDeclarative.so //Path to a library. QT_QTDECLARATIVE_LIBRARY_DEBUG:FILEPATH=QT_QTDECLARATIVE_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDECLARATIVE_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDeclarative.so //Path to a file. QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR:PATH=/usr/include/qt4/QtDesigner //The Qt QTDESIGNERCOMPONENTS library QT_QTDESIGNERCOMPONENTS_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtDesignerComponents.so //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDesignerComponents.so //Path to a file. QT_QTDESIGNER_INCLUDE_DIR:PATH=/usr/include/qt4/QtDesigner //The Qt QTDESIGNER library QT_QTDESIGNER_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtDesigner.so //Path to a library. QT_QTDESIGNER_LIBRARY_DEBUG:FILEPATH=QT_QTDESIGNER_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTDESIGNER_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtDesigner.so //Path to a file. QT_QTGUI_INCLUDE_DIR:PATH=/usr/include/qt4/QtGui //The Qt QTGUI library QT_QTGUI_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtGui.so //Path to a library. QT_QTGUI_LIBRARY_DEBUG:FILEPATH=QT_QTGUI_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTGUI_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtGui.so //Path to a file. QT_QTHELP_INCLUDE_DIR:PATH=/usr/include/qt4/QtHelp //The Qt QTHELP library QT_QTHELP_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtHelp.so //Path to a library. QT_QTHELP_LIBRARY_DEBUG:FILEPATH=QT_QTHELP_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTHELP_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtHelp.so //Path to a library. QT_QTIFF_PLUGIN_DEBUG:FILEPATH=QT_QTIFF_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTIFF_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so //Path to a file. QT_QTMOTIF_INCLUDE_DIR:PATH=QT_QTMOTIF_INCLUDE_DIR-NOTFOUND //The Qt QTMOTIF library QT_QTMOTIF_LIBRARY:STRING= //Path to a library. QT_QTMOTIF_LIBRARY_DEBUG:FILEPATH=QT_QTMOTIF_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTMOTIF_LIBRARY_RELEASE:FILEPATH=QT_QTMOTIF_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTMULTIMEDIA_INCLUDE_DIR:PATH=QT_QTMULTIMEDIA_INCLUDE_DIR-NOTFOUND //The Qt QTMULTIMEDIA library QT_QTMULTIMEDIA_LIBRARY:STRING= //Path to a library. QT_QTMULTIMEDIA_LIBRARY_DEBUG:FILEPATH=QT_QTMULTIMEDIA_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTMULTIMEDIA_LIBRARY_RELEASE:FILEPATH=QT_QTMULTIMEDIA_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTNETWORK_INCLUDE_DIR:PATH=/usr/include/qt4/QtNetwork //The Qt QTNETWORK library QT_QTNETWORK_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtNetwork.so //Path to a library. QT_QTNETWORK_LIBRARY_DEBUG:FILEPATH=QT_QTNETWORK_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNETWORK_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtNetwork.so //Path to a file. QT_QTNSPLUGIN_INCLUDE_DIR:PATH=QT_QTNSPLUGIN_INCLUDE_DIR-NOTFOUND //The Qt QTNSPLUGIN library QT_QTNSPLUGIN_LIBRARY:STRING= //Path to a library. QT_QTNSPLUGIN_LIBRARY_DEBUG:FILEPATH=QT_QTNSPLUGIN_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTNSPLUGIN_LIBRARY_RELEASE:FILEPATH=QT_QTNSPLUGIN_LIBRARY_RELEASE-NOTFOUND //Path to a file. QT_QTOPENGL_INCLUDE_DIR:PATH=/usr/include/qt4/QtOpenGL //The Qt QTOPENGL library QT_QTOPENGL_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtOpenGL.so //Path to a library. QT_QTOPENGL_LIBRARY_DEBUG:FILEPATH=QT_QTOPENGL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTOPENGL_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtOpenGL.so //Path to a library. QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG:FILEPATH=QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/graphicssystems/libqtracegraphicssystem.so //Path to a library. QT_QTSCRIPTDBUS_PLUGIN_DEBUG:FILEPATH=QT_QTSCRIPTDBUS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPTDBUS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/script/libqtscriptdbus.so //Path to a file. QT_QTSCRIPTTOOLS_INCLUDE_DIR:PATH=/usr/include/qt4/QtScriptTools //The Qt QTSCRIPTTOOLS library QT_QTSCRIPTTOOLS_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtScriptTools.so //Path to a library. QT_QTSCRIPTTOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPTTOOLS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtScriptTools.so //Path to a file. QT_QTSCRIPT_INCLUDE_DIR:PATH=/usr/include/qt4/QtScript //The Qt QTSCRIPT library QT_QTSCRIPT_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtScript.so //Path to a library. QT_QTSCRIPT_LIBRARY_DEBUG:FILEPATH=QT_QTSCRIPT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSCRIPT_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtScript.so //Path to a file. QT_QTSQL_INCLUDE_DIR:PATH=/usr/include/qt4/QtSql //The Qt QTSQL library QT_QTSQL_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtSql.so //Path to a library. QT_QTSQL_LIBRARY_DEBUG:FILEPATH=QT_QTSQL_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSQL_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtSql.so //Path to a file. QT_QTSVG_INCLUDE_DIR:PATH=/usr/include/qt4/QtSvg //The Qt QTSVG library QT_QTSVG_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtSvg.so //Path to a library. QT_QTSVG_LIBRARY_DEBUG:FILEPATH=QT_QTSVG_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTSVG_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtSvg.so //Path to a file. QT_QTTEST_INCLUDE_DIR:PATH=/usr/include/qt4/QtTest //The Qt QTTEST library QT_QTTEST_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtTest.so //Path to a library. QT_QTTEST_LIBRARY_DEBUG:FILEPATH=QT_QTTEST_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTTEST_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtTest.so //Path to a file. QT_QTUITOOLS_INCLUDE_DIR:PATH=/usr/include/qt4/QtUiTools //The Qt QTUITOOLS library QT_QTUITOOLS_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtUiTools.a //Path to a library. QT_QTUITOOLS_LIBRARY_DEBUG:FILEPATH=QT_QTUITOOLS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTUITOOLS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtUiTools.a //Path to a library. QT_QTWCODECS_PLUGIN_DEBUG:FILEPATH=QT_QTWCODECS_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QTWCODECS_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/codecs/libqtwcodecs.so //Path to a file. QT_QTWEBKIT_INCLUDE_DIR:PATH=/usr/include/qt4/QtWebKit //The Qt QTWEBKIT library QT_QTWEBKIT_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtWebKit.so //Path to a library. QT_QTWEBKIT_LIBRARY_DEBUG:FILEPATH=QT_QTWEBKIT_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTWEBKIT_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtWebKit.so //Path to a file. QT_QTXMLPATTERNS_INCLUDE_DIR:PATH=/usr/include/qt4/QtXmlPatterns //The Qt QTXMLPATTERNS library QT_QTXMLPATTERNS_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so //Path to a library. QT_QTXMLPATTERNS_LIBRARY_DEBUG:FILEPATH=QT_QTXMLPATTERNS_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXMLPATTERNS_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtXmlPatterns.so //Path to a file. QT_QTXML_INCLUDE_DIR:PATH=/usr/include/qt4/QtXml //The Qt QTXML library QT_QTXML_LIBRARY:STRING=/usr/lib/x86_64-linux-gnu/libQtXml.so //Path to a library. QT_QTXML_LIBRARY_DEBUG:FILEPATH=QT_QTXML_LIBRARY_DEBUG-NOTFOUND //Path to a library. QT_QTXML_LIBRARY_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/libQtXml.so //Path to a library. QT_QWEBVIEW_PLUGIN_DEBUG:FILEPATH=QT_QWEBVIEW_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QWEBVIEW_PLUGIN_RELEASE:FILEPATH=/usr/lib/x86_64-linux-gnu/qt4/plugins/designer/libqwebview.so //Path to a library. QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE:FILEPATH=QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-NOTFOUND //Path to a program. QT_RCC_EXECUTABLE:FILEPATH=/usr/bin/rcc //Path to a library. QT_TASKMENUEXTENSION_PLUGIN_DEBUG:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_TASKMENUEXTENSION_PLUGIN_RELEASE:FILEPATH=QT_TASKMENUEXTENSION_PLUGIN_RELEASE-NOTFOUND //The location of the Qt translations QT_TRANSLATIONS_DIR:PATH=/usr/share/qt4/translations //Path to a program. QT_UIC3_EXECUTABLE:FILEPATH=/usr/bin/uic3 //Path to a program. QT_UIC_EXECUTABLE:FILEPATH=/usr/bin/uic-qt4 //Path to a library. QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-NOTFOUND //Path to a library. QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE:FILEPATH=QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-NOTFOUND //Enable to build quatlib examples QUATLIB_BUILD_EXAMPLES:BOOL=OFF //Path to scp command, used by CTest for submitting results to // a Dart server SCPCOMMAND:FILEPATH=/usr/bin/scp //Human-readable site name SITE:STRING=joni@mpi1 //Path to the SLURM sbatch executable SLURM_SBATCH_COMMAND:FILEPATH=SLURM_SBATCH_COMMAND-NOTFOUND //Path to the SLURM srun executable SLURM_SRUN_COMMAND:FILEPATH=SLURM_SRUN_COMMAND-NOTFOUND //Path to a program. SVNCOMMAND:FILEPATH=/usr/bin/svn //Path to a file. SWIG_DIR:PATH=/usr/share/swig2.0 //Path to a program. SWIG_EXECUTABLE:FILEPATH=/usr/bin/swig2.0 //Swig version SWIG_VERSION:STRING=2.0.4 //Path to a file. VIEWPOINT_INCLUDE_DIR:PATH=VIEWPOINT_INCLUDE_DIR-NOTFOUND //Path to a library. VIEWPOINT_LIBRARY:FILEPATH=VIEWPOINT_LIBRARY-NOTFOUND //Directory to search for Arrington Research ViewPoint EyeTracker // SDK VIEWPOINT_ROOT_DIR:PATH= //Value Computed by CMake VRPN_BINARY_DIR:STATIC=/mpi3/S2/vrpn-BUILD //Build VRPN client apps and tests VRPN_BUILD_CLIENTS:BOOL=ON //Build the vrpn library including only client code VRPN_BUILD_CLIENT_LIBRARY:BOOL=ON //Build with flags to enable extra warnings. VRPN_BUILD_EXTRA_COMPILER_WARNINGS:BOOL=OFF //Should we build a GUI for analyzing live HID streams? VRPN_BUILD_HID_GUI:BOOL=ON //Build VRPN Java bindings VRPN_BUILD_JAVA:BOOL=OFF //Build with flags to enable profiling. VRPN_BUILD_PROFILING_SUPPORT:BOOL=OFF //Build VRPN Python 2.x SWIG-based bindings VRPN_BUILD_PYTHON:BOOL=OFF //Build VRPN Python handcoded bindings for Python 2.x VRPN_BUILD_PYTHON_HANDCODED_2X:BOOL=OFF //Build VRPN Python handcoded bindings for Python 3.x VRPN_BUILD_PYTHON_HANDCODED_3X:BOOL=ON //Build VRPN servers VRPN_BUILD_SERVERS:BOOL=ON //Build the vrpnserver library including client and server code VRPN_BUILD_SERVER_LIBRARY:BOOL=ON //Build VRPN RPC generation VRPN_BUILD_TEST_RPC_GENERATION:BOOL=ON //Should verbose debugging messages be displayed during HID interactions? VRPN_HID_DEBUGGING:BOOL=OFF //Build with InterSense native library support VRPN_INCLUDE_INTERSENSE:BOOL=OFF //Build with PhaseSpace library support VRPN_INCLUDE_PHASESPACE:BOOL=OFF //Value Computed by CMake VRPN_SOURCE_DIR:STATIC=/mpi3/S2/vrpn //Build with flags to enable the use of DevInput. (Uses kernel // header - may make servers GPL) VRPN_USE_DEV_INPUT:BOOL=ON //Build with Hillcrest Labs' Freespace devices support VRPN_USE_FREESPACE:BOOL=OFF //Allow SensAble Phantom support through GHOST - VRPN_USE_PHANTOM_SERVER // must still be set VRPN_USE_GHOST:BOOL=OFF //Build with GPM Linux mouse interface support (makes servers GPL) VRPN_USE_GPM_MOUSE:BOOL=OFF //Allow SensAble Phantom support through HDAPI/HLAPI - VRPN_USE_PHANTOM_SERVER // must still be set VRPN_USE_HDAPI:BOOL=OFF //Build with support for HID devices using HIDAPI VRPN_USE_HID:BOOL=ON //Build with support for Linux kernel joystick interface (Uses // kernel header - may make servers GPL) VRPN_USE_JOYLIN:BOOL=ON //Build with support JSON over UDP (for Android widgets) VRPN_USE_JSONNET:BOOL=OFF //Build with libnifalcon support to access Novint Falcon devices VRPN_USE_LIBNIFALCON:BOOL=OFF //Attempt to use LibUSB-1.0 to talk directly to USB devices. VRPN_USE_LIBUSB_1_0:BOOL=OFF //Build with HIDAPI code from within VRPN source directory VRPN_USE_LOCAL_HIDAPI:BOOL=OFF //Build with MicroScribe3D library support VRPN_USE_MICROSCRIBE:BOOL=OFF //Build with GLI Interactive LLC MotionNode library support VRPN_USE_MOTIONNODE:BOOL=OFF //Build with MPI support VRPN_USE_MPI:BOOL=OFF //Build with National Instruments (old library) support VRPN_USE_NATIONAL_INSTRUMENTS:BOOL=OFF //Build with National Instruments NIDAQMX support VRPN_USE_NATIONAL_INSTRUMENTS_MX:BOOL=OFF //Build with NIDAQ support ca. 1999 VRPN_USE_NIDAQ:BOOL=OFF //Build with flags to enable the use of Polhemus DVI library. VRPN_USE_PDI:BOOL=OFF //Build with SensAble Phantom support VRPN_USE_PHANTOM_SERVER:BOOL=OFF //Build with support for TrivisioColibri tracker VRPN_USE_TRIVISIOCOLIBRI:BOOL=OFF //Build with US Digital SEI/A2 library support VRPN_USE_USDIGITAL:BOOL=OFF //Build with support for ViewPoint EyeTracker VRPN_USE_VIEWPOINT:BOOL=OFF //Build with WiiUse library support (makes servers GPL) VRPN_USE_WIIUSE:BOOL=OFF //Path to a file. WIIUSE_INCLUDE_DIR:PATH=WIIUSE_INCLUDE_DIR-NOTFOUND //Path to a library. WIIUSE_LIBRARY:FILEPATH=WIIUSE_LIBRARY-NOTFOUND //Directory to search for WiiUse WIIUSE_ROOT_DIR:PATH= //Path to a file. X11_ICE_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_ICE_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libICE.so //Path to a file. X11_SM_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_SM_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libSM.so //Path to a file. X11_X11_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_X11_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libX11.so //Path to a file. X11_XRes_INCLUDE_PATH:PATH=X11_XRes_INCLUDE_PATH-NOTFOUND //Path to a library. X11_XRes_LIB:FILEPATH=X11_XRes_LIB-NOTFOUND //Path to a file. X11_XShm_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_XSync_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_XTest_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_XTest_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXtst.so //Path to a file. X11_Xaccessrules_INCLUDE_PATH:PATH=X11_Xaccessrules_INCLUDE_PATH-NOTFOUND //Path to a file. X11_Xaccessstr_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xau_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xau_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXau.so //Path to a file. X11_Xcomposite_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcomposite_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXcomposite.so //Path to a file. X11_Xcursor_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xcursor_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXcursor.so //Path to a file. X11_Xdamage_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdamage_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXdamage.so //Path to a file. X11_Xdmcp_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xdmcp_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXdmcp.so //Path to a library. X11_Xext_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXext.so //Path to a file. X11_Xfixes_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xfixes_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXfixes.so //Path to a file. X11_Xft_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xft_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXft.so //Path to a file. X11_Xi_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xi_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXi.so //Path to a file. X11_Xinerama_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinerama_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXinerama.so //Path to a file. X11_Xinput_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xinput_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXi.so //Path to a file. X11_Xkb_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xkbfile_INCLUDE_PATH:PATH=X11_Xkbfile_INCLUDE_PATH-NOTFOUND //Path to a library. X11_Xkbfile_LIB:FILEPATH=X11_Xkbfile_LIB-NOTFOUND //Path to a file. X11_Xkblib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xlib_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xmu_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xmu_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXmu.so //Path to a file. X11_Xpm_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xpm_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXpm.so //Path to a file. X11_Xrandr_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrandr_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXrandr.so //Path to a file. X11_Xrender_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xrender_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXrender.so //Path to a file. X11_Xscreensaver_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xscreensaver_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXss.so //Path to a file. X11_Xshape_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xt_INCLUDE_PATH:PATH=/usr/include //Path to a library. X11_Xt_LIB:FILEPATH=/usr/lib/x86_64-linux-gnu/libXt.so //Path to a file. X11_Xutil_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_Xv_INCLUDE_PATH:PATH=X11_Xv_INCLUDE_PATH-NOTFOUND //Path to a library. X11_Xv_LIB:FILEPATH=X11_Xv_LIB-NOTFOUND //Path to a library. X11_Xxf86misc_LIB:FILEPATH=X11_Xxf86misc_LIB-NOTFOUND //Path to a library. X11_Xxf86vm_LIB:FILEPATH=X11_Xxf86vm_LIB-NOTFOUND //Path to a file. X11_dpms_INCLUDE_PATH:PATH=/usr/include //Path to a file. X11_xf86misc_INCLUDE_PATH:PATH=X11_xf86misc_INCLUDE_PATH-NOTFOUND //Path to a file. X11_xf86vmode_INCLUDE_PATH:PATH=X11_xf86vmode_INCLUDE_PATH-NOTFOUND //Path to a program. file_cmd:FILEPATH=/usr/bin/file //Dependencies for target gpsnmea_LIB_DEPENDS:STATIC= //Dependencies for target quat_LIB_DEPENDS:STATIC= //Value Computed by CMake quatlib_BINARY_DIR:STATIC=/mpi3/S2/vrpn-BUILD/quat //Value Computed by CMake quatlib_SOURCE_DIR:STATIC=/mpi3/S2/vrpn/quat //Dependencies for the target vrpn-python_LIB_DEPENDS:STATIC=general;/usr/lib/libpython3.2mu.so;general;vrpnserver; //Dependencies for the target vrpn_LIB_DEPENDS:STATIC=general;quat;general;-lpthread; //Dependencies for target vrpn_atmel_LIB_DEPENDS:STATIC= //Dependencies for target vrpn_timecode_generator_LIB_DEPENDS:STATIC= //Dependencies for the target vrpnserver_LIB_DEPENDS:STATIC=general;quat;general;-lpthread;general;/mpi3/C2/hidapi/lib/libhidapi-libusb.so;general;vrpn_atmel;general;gpsnmea; ######################## # INTERNAL cache entries ######################## //ADVANCED property for variable: BIBTEX_COMPILER BIBTEX_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: BZRCOMMAND BZRCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_AR CMAKE_AR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_BUILD_TOOL CMAKE_BUILD_TOOL-ADVANCED:INTERNAL=1 //What is the target build tool cmake is generating for. CMAKE_BUILD_TOOL:INTERNAL=/usr/bin/make //This is the directory where this CMakeCache.txt was created CMAKE_CACHEFILE_DIR:INTERNAL=/mpi3/S2/vrpn-BUILD //Major version of cmake used to create the current loaded cache CMAKE_CACHE_MAJOR_VERSION:INTERNAL=2 //Minor version of cmake used to create the current loaded cache CMAKE_CACHE_MINOR_VERSION:INTERNAL=8 //Patch version of cmake used to create the current loaded cache CMAKE_CACHE_PATCH_VERSION:INTERNAL=9 //ADVANCED property for variable: CMAKE_COLOR_MAKEFILE CMAKE_COLOR_MAKEFILE-ADVANCED:INTERNAL=1 //Path to CMake executable. CMAKE_COMMAND:INTERNAL=/usr/local/bin/cmake //Path to cpack program executable. CMAKE_CPACK_COMMAND:INTERNAL=/usr/local/bin/cpack //ADVANCED property for variable: CMAKE_CTEST_COMMAND CMAKE_CTEST_COMMAND-ADVANCED:INTERNAL=1 //Path to ctest program executable. CMAKE_CTEST_COMMAND:INTERNAL=/usr/local/bin/ctest //ADVANCED property for variable: CMAKE_CXX_COMPILER CMAKE_CXX_COMPILER-ADVANCED:INTERNAL=1 CMAKE_CXX_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS CMAKE_CXX_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_DEBUG CMAKE_CXX_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_MINSIZEREL CMAKE_CXX_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELEASE CMAKE_CXX_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_CXX_FLAGS_RELWITHDEBINFO CMAKE_CXX_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_COMPILER CMAKE_C_COMPILER-ADVANCED:INTERNAL=1 CMAKE_C_COMPILER_WORKS:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS CMAKE_C_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_DEBUG CMAKE_C_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_MINSIZEREL CMAKE_C_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELEASE CMAKE_C_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_C_FLAGS_RELWITHDEBINFO CMAKE_C_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //Result of TRY_COMPILE CMAKE_DETERMINE_CXX_ABI_COMPILED:INTERNAL=TRUE //Result of TRY_COMPILE CMAKE_DETERMINE_C_ABI_COMPILED:INTERNAL=TRUE //Executable file format CMAKE_EXECUTABLE_FORMAT:INTERNAL=ELF //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS CMAKE_EXE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_DEBUG CMAKE_EXE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_MINSIZEREL CMAKE_EXE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELEASE CMAKE_EXE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_EXE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_EXPORT_COMPILE_COMMANDS CMAKE_EXPORT_COMPILE_COMMANDS-ADVANCED:INTERNAL=1 //Name of generator. CMAKE_GENERATOR:INTERNAL=Unix Makefiles //Have function connect CMAKE_HAVE_CONNECT:INTERNAL=1 //Have function gethostbyname CMAKE_HAVE_GETHOSTBYNAME:INTERNAL=1 //Have symbol pthread_create CMAKE_HAVE_LIBC_CREATE:INTERNAL= //Have library pthreads CMAKE_HAVE_PTHREADS_CREATE:INTERNAL= //Have library pthread CMAKE_HAVE_PTHREAD_CREATE:INTERNAL=1 //Have include pthread.h CMAKE_HAVE_PTHREAD_H:INTERNAL=1 //Have function remove CMAKE_HAVE_REMOVE:INTERNAL=1 //Have function shmat CMAKE_HAVE_SHMAT:INTERNAL=1 //Start directory with the top level CMakeLists.txt file for this // project CMAKE_HOME_DIRECTORY:INTERNAL=/mpi3/S2/vrpn //Install .so files without execute permission. CMAKE_INSTALL_SO_NO_EXE:INTERNAL=1 //Have library ICE CMAKE_LIB_ICE_HAS_ICECONNECTIONNUMBER:INTERNAL=1 //ADVANCED property for variable: CMAKE_LINKER CMAKE_LINKER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MAKE_PROGRAM CMAKE_MAKE_PROGRAM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS CMAKE_MODULE_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_DEBUG CMAKE_MODULE_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL CMAKE_MODULE_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELEASE CMAKE_MODULE_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO CMAKE_MODULE_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_NM CMAKE_NM-ADVANCED:INTERNAL=1 //number of local generators CMAKE_NUMBER_OF_LOCAL_GENERATORS:INTERNAL=15 //ADVANCED property for variable: CMAKE_OBJCOPY CMAKE_OBJCOPY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_OBJDUMP CMAKE_OBJDUMP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_RANLIB CMAKE_RANLIB-ADVANCED:INTERNAL=1 //Path to CMake installation. CMAKE_ROOT:INTERNAL=/usr/local/share/cmake-2.8 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS CMAKE_SHARED_LINKER_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_DEBUG CMAKE_SHARED_LINKER_FLAGS_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL CMAKE_SHARED_LINKER_FLAGS_MINSIZEREL-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELEASE CMAKE_SHARED_LINKER_FLAGS_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO CMAKE_SHARED_LINKER_FLAGS_RELWITHDEBINFO-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SKIP_INSTALL_RPATH CMAKE_SKIP_INSTALL_RPATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_SKIP_RPATH CMAKE_SKIP_RPATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_STRIP CMAKE_STRIP-ADVANCED:INTERNAL=1 //uname command CMAKE_UNAME:INTERNAL=/bin/uname //ADVANCED property for variable: CMAKE_USE_RELATIVE_PATHS CMAKE_USE_RELATIVE_PATHS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CMAKE_VERBOSE_MAKEFILE CMAKE_VERBOSE_MAKEFILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COVERAGE_COMMAND COVERAGE_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: COVERAGE_EXTRA_FLAGS COVERAGE_EXTRA_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_DEB CPACK_BINARY_DEB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_NSIS CPACK_BINARY_NSIS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_RPM CPACK_BINARY_RPM-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_STGZ CPACK_BINARY_STGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TBZ2 CPACK_BINARY_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TGZ CPACK_BINARY_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_BINARY_TZ CPACK_BINARY_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TBZ2 CPACK_SOURCE_TBZ2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TGZ CPACK_SOURCE_TGZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_TZ CPACK_SOURCE_TZ-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPACK_SOURCE_ZIP CPACK_SOURCE_ZIP-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CPPCHECK_EXECUTABLE CPPCHECK_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CTEST_SUBMIT_RETRY_COUNT CTEST_SUBMIT_RETRY_COUNT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CTEST_SUBMIT_RETRY_DELAY CTEST_SUBMIT_RETRY_DELAY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVSCOMMAND CVSCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: CVS_UPDATE_OPTIONS CVS_UPDATE_OPTIONS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DART_TESTING_TIMEOUT DART_TESTING_TIMEOUT-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DASHBOARDSCRIPT_BASE_DIRECTORY DASHBOARDSCRIPT_BASE_DIRECTORY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DASHBOARDSCRIPT_BUILD_CONFIGURATION DASHBOARDSCRIPT_BUILD_CONFIGURATION-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DASHBOARDSCRIPT_CMAKE_COMMAND DASHBOARDSCRIPT_CMAKE_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DASHBOARDSCRIPT_CTEST_EXECUTABLE DASHBOARDSCRIPT_CTEST_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DOXYGEN_DOT_EXECUTABLE DOXYGEN_DOT_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DOXYGEN_DOT_PATH DOXYGEN_DOT_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DOXYGEN_EXECUTABLE DOXYGEN_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DVIPDF_CONVERTER DVIPDF_CONVERTER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: DVIPS_CONVERTER DVIPS_CONVERTER-ADVANCED:INTERNAL=1 //Details about finding HIDAPI FIND_PACKAGE_MESSAGE_DETAILS_HIDAPI:INTERNAL=[/mpi3/C2/hidapi/lib/libhidapi-libusb.so][/mpi3/C2/hidapi/include/hidapi][v()] //Details about finding Libusb1 FIND_PACKAGE_MESSAGE_DETAILS_Libusb1:INTERNAL=[/usr/lib/x86_64-linux-gnu/libusb-1.0.so][/usr/include/libusb-1.0][v()] //Details about finding MPI_C FIND_PACKAGE_MESSAGE_DETAILS_MPI_C:INTERNAL=[/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so][/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi][v()] //Details about finding MPI_CXX FIND_PACKAGE_MESSAGE_DETAILS_MPI_CXX:INTERNAL=[/usr/lib/openmpi/lib/libmpi_cxx.so;/usr/lib/openmpi/lib/libmpi.so;/usr/lib/openmpi/lib/libopen-rte.so;/usr/lib/openmpi/lib/libopen-pal.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libnsl.so;/usr/lib/x86_64-linux-gnu/libutil.so;/usr/lib/x86_64-linux-gnu/libm.so;/usr/lib/x86_64-linux-gnu/libdl.so][/usr/lib/openmpi/include;/usr/lib/openmpi/include/openmpi][v()] //Details about finding OpenGL FIND_PACKAGE_MESSAGE_DETAILS_OpenGL:INTERNAL=[/usr/lib/x86_64-linux-gnu/libGL.so][v()] //Details about finding Perl FIND_PACKAGE_MESSAGE_DETAILS_Perl:INTERNAL=[/usr/bin/perl][v5.14.2()] //Details about finding PerlModules FIND_PACKAGE_MESSAGE_DETAILS_PerlModules:INTERNAL=[TRUE][/usr/share/perl5/Parse/RecDescent.pm][v()] //Details about finding PythonLibs FIND_PACKAGE_MESSAGE_DETAILS_PythonLibs:INTERNAL=[/usr/lib/libpython3.2mu.so][/usr/include/python3.2mu][v3.2.3(3)] //Details about finding Qt4 FIND_PACKAGE_MESSAGE_DETAILS_Qt4:INTERNAL=[/usr/bin/qmake][/usr/bin/moc-qt4][/usr/bin/rcc][/usr/bin/uic-qt4][/usr/include/qt4][/usr/lib/x86_64-linux-gnu][/usr/lib/x86_64-linux-gnu/libQtCore.so][v4.8.1(4.7)] //Details about finding SWIG FIND_PACKAGE_MESSAGE_DETAILS_SWIG:INTERNAL=[/usr/bin/swig2.0][/usr/share/swig2.0][v2.0.4()] //Details about finding Threads FIND_PACKAGE_MESSAGE_DETAILS_Threads:INTERNAL=[TRUE][v()] //Details about finding X11 FIND_PACKAGE_MESSAGE_DETAILS_X11:INTERNAL=[/usr/lib/x86_64-linux-gnu/libX11.so][/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include;/usr/include] //ADVANCED property for variable: GHOST_INCLUDE_DIR GHOST_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GHOST_LIBRARY GHOST_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GITCOMMAND GITCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GIT_EXECUTABLE GIT_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_INCLUDE_DIR GLUT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_Xi_LIBRARY GLUT_Xi_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_Xmu_LIBRARY GLUT_Xmu_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GLUT_glut_LIBRARY GLUT_glut_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GPM_INCLUDE_DIR GPM_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: GPM_LIBRARY GPM_LIBRARY-ADVANCED:INTERNAL=1 //Have include linux/input.h HAVE_LINUX_INPUT_H:INTERNAL=1 //Have include linux/joystick.h HAVE_LINUX_JOYSTICK_H:INTERNAL=1 //ADVANCED property for variable: HDAPI_HDU_INCLUDE_DIR HDAPI_HDU_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_HDU_LIBRARY HDAPI_HDU_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_HDU_LIBRARY_DEBUG HDAPI_HDU_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_HDU_LIBRARY_RELEASE HDAPI_HDU_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_INCLUDE_DIR HDAPI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_LIBRARY HDAPI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_LIBRARY_DEBUG HDAPI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_LIBRARY_RELEASE HDAPI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HDAPI_PHANToMIO_LIBRARY HDAPI_PHANToMIO_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HGCOMMAND HGCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HIDAPI_HIDRAW_INCLUDE_DIR HIDAPI_HIDRAW_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HIDAPI_INCLUDE_DIR HIDAPI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HIDAPI_LIBRARY HIDAPI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HIDAPI_LIBUDEV HIDAPI_LIBUDEV-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HIDAPI_LIBUDEV_INCLUDE_DIR HIDAPI_LIBUDEV_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_HLU_INCLUDE_DIR HLAPI_HLU_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_HLU_LIBRARY HLAPI_HLU_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_HLU_LIBRARY_DEBUG HLAPI_HLU_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_HLU_LIBRARY_RELEASE HLAPI_HLU_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_INCLUDE_DIR HLAPI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_LIBRARY HLAPI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_LIBRARY_DEBUG HLAPI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: HLAPI_LIBRARY_RELEASE HLAPI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JAVAH_EXECUTABLE JAVAH_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JAVA_AWT_INCLUDE_PATH JAVA_AWT_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JAVA_AWT_LIBRARY JAVA_AWT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JAVA_INCLUDE_PATH JAVA_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JAVA_INCLUDE_PATH2 JAVA_INCLUDE_PATH2-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JAVA_JVM_LIBRARY JAVA_JVM_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JSONCPP_INCLUDE_DIR JSONCPP_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: JSONCPP_LIBRARY JSONCPP_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Java_JAR_EXECUTABLE Java_JAR_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Java_JAVAC_EXECUTABLE Java_JAVAC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Java_JAVADOC_EXECUTABLE Java_JAVADOC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Java_JAVAH_EXECUTABLE Java_JAVAH_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: Java_JAVA_EXECUTABLE Java_JAVA_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LATEX2HTML_CONVERTER LATEX2HTML_CONVERTER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LATEX_COMPILER LATEX_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBNIFALCON_INCLUDE_DIR LIBNIFALCON_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBNIFALCON_LIBRARY LIBNIFALCON_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBNIFALCON_LIBUSB1_INCLUDE_DIR LIBNIFALCON_LIBUSB1_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBNIFALCON_LIBUSB1_LIBRARY LIBNIFALCON_LIBUSB1_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBNIFALCON_rt_LIBRARY LIBNIFALCON_rt_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBUSB1_INCLUDE_DIR LIBUSB1_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBUSB1_LIBRARY LIBUSB1_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: LIBUSB1_ROOT_DIR LIBUSB1_ROOT_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MAKECOMMAND MAKECOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MAKEINDEX_COMPILER MAKEINDEX_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MEMORYCHECK_COMMAND MEMORYCHECK_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MEMORYCHECK_SUPPRESSIONS_FILE MEMORYCHECK_SUPPRESSIONS_FILE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC MPIEXEC-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_MAX_NUMPROCS MPIEXEC_MAX_NUMPROCS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_NUMPROC_FLAG MPIEXEC_NUMPROC_FLAG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_POSTFLAGS MPIEXEC_POSTFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPIEXEC_PREFLAGS MPIEXEC_PREFLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_COMPILER MPI_CXX_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_COMPILE_FLAGS MPI_CXX_COMPILE_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_INCLUDE_PATH MPI_CXX_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_LIBRARIES MPI_CXX_LIBRARIES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_CXX_LINK_FLAGS MPI_CXX_LINK_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_COMPILER MPI_C_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_COMPILE_FLAGS MPI_C_COMPILE_FLAGS-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_INCLUDE_PATH MPI_C_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_LIBRARIES MPI_C_LIBRARIES-ADVANCED:INTERNAL=1 //ADVANCED property for variable: MPI_C_LINK_FLAGS MPI_C_LINK_FLAGS-ADVANCED:INTERNAL=1 //Scratch variable for MPI header detection MPI_HEADER_PATH:INTERNAL=MPI_HEADER_PATH-NOTFOUND //Scratch variable for MPI lib detection MPI_LIB:INTERNAL=MPI_LIB-NOTFOUND //ADVANCED property for variable: NIDAQMX_INCLUDE_DIR NIDAQMX_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: NIDAQMX_LIBRARY NIDAQMX_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_INCLUDE_DIR OPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_gl_LIBRARY OPENGL_gl_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_glu_LIBRARY OPENGL_glu_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENGL_xmesa_INCLUDE_DIR OPENGL_xmesa_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: OPENHAPTICS_NESTED_TARGETS OPENHAPTICS_NESTED_TARGETS-ADVANCED:INTERNAL=1 PC_LIBUSB1_CFLAGS:INTERNAL=-I/usr/include/libusb-1.0 PC_LIBUSB1_CFLAGS_I:INTERNAL= PC_LIBUSB1_CFLAGS_OTHER:INTERNAL= PC_LIBUSB1_FOUND:INTERNAL=1 PC_LIBUSB1_INCLUDEDIR:INTERNAL=/usr/include PC_LIBUSB1_INCLUDE_DIRS:INTERNAL=/usr/include/libusb-1.0 PC_LIBUSB1_LDFLAGS:INTERNAL=-lusb-1.0 PC_LIBUSB1_LDFLAGS_OTHER:INTERNAL= PC_LIBUSB1_LIBDIR:INTERNAL=/usr/lib/x86_64-linux-gnu PC_LIBUSB1_LIBRARIES:INTERNAL=usb-1.0 PC_LIBUSB1_LIBRARY_DIRS:INTERNAL= PC_LIBUSB1_LIBS:INTERNAL= PC_LIBUSB1_LIBS_L:INTERNAL= PC_LIBUSB1_LIBS_OTHER:INTERNAL= PC_LIBUSB1_LIBS_PATHS:INTERNAL= PC_LIBUSB1_PREFIX:INTERNAL=/usr PC_LIBUSB1_STATIC_CFLAGS:INTERNAL=-I/usr/include/libusb-1.0 PC_LIBUSB1_STATIC_CFLAGS_I:INTERNAL= PC_LIBUSB1_STATIC_CFLAGS_OTHER:INTERNAL= PC_LIBUSB1_STATIC_INCLUDE_DIRS:INTERNAL=/usr/include/libusb-1.0 PC_LIBUSB1_STATIC_LDFLAGS:INTERNAL=-pthread;-lusb-1.0;-lrt PC_LIBUSB1_STATIC_LDFLAGS_OTHER:INTERNAL=-pthread PC_LIBUSB1_STATIC_LIBDIR:INTERNAL= PC_LIBUSB1_STATIC_LIBRARIES:INTERNAL=usb-1.0;rt PC_LIBUSB1_STATIC_LIBRARY_DIRS:INTERNAL= PC_LIBUSB1_STATIC_LIBS:INTERNAL= PC_LIBUSB1_STATIC_LIBS_L:INTERNAL= PC_LIBUSB1_STATIC_LIBS_OTHER:INTERNAL= PC_LIBUSB1_STATIC_LIBS_PATHS:INTERNAL= PC_LIBUSB1_VERSION:INTERNAL=1.0.9-rc3 PC_LIBUSB1_libusb-1.0_INCLUDEDIR:INTERNAL= PC_LIBUSB1_libusb-1.0_LIBDIR:INTERNAL= PC_LIBUSB1_libusb-1.0_PREFIX:INTERNAL= PC_LIBUSB1_libusb-1.0_VERSION:INTERNAL= //ADVANCED property for variable: PDFLATEX_COMPILER PDFLATEX_COMPILER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PERLMODULES_PARSE_RECDESCENT_MODULE PERLMODULES_PARSE_RECDESCENT_MODULE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PERL_EXECUTABLE PERL_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PKG_CONFIG_EXECUTABLE PKG_CONFIG_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PS2PDF_CONVERTER PS2PDF_CONVERTER-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_ENABLE_MODULE_vrpn-python PYTHON_ENABLE_MODULE_vrpn-python-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_INCLUDE_DIR PYTHON_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_LIBRARY PYTHON_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: PYTHON_MODULE_vrpn-python_BUILD_SHARED PYTHON_MODULE_vrpn-python_BUILD_SHARED-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_DEBUG QT_ARTHURPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_ARTHURPLUGIN_PLUGIN_RELEASE QT_ARTHURPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 QT_BINARY_DIR:INTERNAL=/usr/bin //ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_DEBUG QT_CONTAINEREXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_CONTAINEREXTENSION_PLUGIN_RELEASE QT_CONTAINEREXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG QT_CUSTOMWIDGETPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE QT_CUSTOMWIDGETPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DBUSCPP2XML_EXECUTABLE QT_DBUSCPP2XML_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DBUSXML2CPP_EXECUTABLE QT_DBUSXML2CPP_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DESIGNER_EXECUTABLE QT_DESIGNER_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_DOC_DIR QT_DOC_DIR-ADVANCED:INTERNAL=1 QT_HEADERS_DIR:INTERNAL=/usr/include/qt4 //ADVANCED property for variable: QT_IMPORTS_DIR QT_IMPORTS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LIBRARY_DIR QT_LIBRARY_DIR-ADVANCED:INTERNAL=1 //Qt library dir QT_LIBRARY_DIR:INTERNAL=/usr/lib/x86_64-linux-gnu //ADVANCED property for variable: QT_LINGUIST_EXECUTABLE QT_LINGUIST_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LRELEASE_EXECUTABLE QT_LRELEASE_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_LUPDATE_EXECUTABLE QT_LUPDATE_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_MKSPECS_DIR QT_MKSPECS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_MOC_EXECUTABLE QT_MOC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_DEBUG QT_PHONONWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONONWIDGETS_PLUGIN_RELEASE QT_PHONONWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_INCLUDE_DIR QT_PHONON_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY QT_PHONON_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY_DEBUG QT_PHONON_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PHONON_LIBRARY_RELEASE QT_PHONON_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_PLUGINS_DIR QT_PLUGINS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCNCODECS_PLUGIN_DEBUG QT_QCNCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCNCODECS_PLUGIN_RELEASE QT_QCNCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCOLLECTIONGENERATOR_EXECUTABLE QT_QCOLLECTIONGENERATOR_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_DEBUG QT_QCOREWLANBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QCOREWLANBEARER_PLUGIN_RELEASE QT_QCOREWLANBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_DEBUG QT_QDECLARATIVEVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECLARATIVEVIEW_PLUGIN_RELEASE QT_QDECLARATIVEVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_DEBUG QT_QDECORATIONDEFAULT_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONDEFAULT_PLUGIN_RELEASE QT_QDECORATIONDEFAULT_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_DEBUG QT_QDECORATIONWINDOWS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QDECORATIONWINDOWS_PLUGIN_RELEASE QT_QDECORATIONWINDOWS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_DEBUG QT_QGENERICBEARER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGENERICBEARER_PLUGIN_RELEASE QT_QGENERICBEARER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGIF_PLUGIN_DEBUG QT_QGIF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGIF_PLUGIN_RELEASE QT_QGIF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG QT_QGLGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE QT_QGLGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QICO_PLUGIN_DEBUG QT_QICO_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QICO_PLUGIN_RELEASE QT_QICO_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_DEBUG QT_QIMSW_MULTI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QIMSW_MULTI_PLUGIN_RELEASE QT_QIMSW_MULTI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPCODECS_PLUGIN_DEBUG QT_QJPCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPCODECS_PLUGIN_RELEASE QT_QJPCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPEG_PLUGIN_DEBUG QT_QJPEG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QJPEG_PLUGIN_RELEASE QT_QJPEG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QKRCODECS_PLUGIN_DEBUG QT_QKRCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QKRCODECS_PLUGIN_RELEASE QT_QKRCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 QT_QMAKE_EXECUTABLE_LAST:INTERNAL=/usr/bin/qmake //ADVANCED property for variable: QT_QMNG_PLUGIN_DEBUG QT_QMNG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QMNG_PLUGIN_RELEASE QT_QMNG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLDB2_PLUGIN_DEBUG QT_QSQLDB2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLDB2_PLUGIN_RELEASE QT_QSQLDB2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_DEBUG QT_QSQLIBASE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLIBASE_PLUGIN_RELEASE QT_QSQLIBASE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE2_PLUGIN_DEBUG QT_QSQLITE2_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE2_PLUGIN_RELEASE QT_QSQLITE2_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE_PLUGIN_DEBUG QT_QSQLITE_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLITE_PLUGIN_RELEASE QT_QSQLITE_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_DEBUG QT_QSQLMYSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLMYSQL_PLUGIN_RELEASE QT_QSQLMYSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLOCI_PLUGIN_DEBUG QT_QSQLOCI_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLOCI_PLUGIN_RELEASE QT_QSQLOCI_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLODBC_PLUGIN_DEBUG QT_QSQLODBC_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLODBC_PLUGIN_RELEASE QT_QSQLODBC_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_DEBUG QT_QSQLPSQL_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLPSQL_PLUGIN_RELEASE QT_QSQLPSQL_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLTDS_PLUGIN_DEBUG QT_QSQLTDS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSQLTDS_PLUGIN_RELEASE QT_QSQLTDS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVGICON_PLUGIN_DEBUG QT_QSVGICON_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVGICON_PLUGIN_RELEASE QT_QSVGICON_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVG_PLUGIN_DEBUG QT_QSVG_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QSVG_PLUGIN_RELEASE QT_QSVG_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG QT_QT3SUPPORTWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE QT_QT3SUPPORTWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_INCLUDE_DIR QT_QT3SUPPORT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY QT_QT3SUPPORT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_DEBUG QT_QT3SUPPORT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QT3SUPPORT_LIBRARY_RELEASE QT_QT3SUPPORT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE QT_QTACCESSIBLECOMPATWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG QT_QTACCESSIBLEWIDGETS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE QT_QTACCESSIBLEWIDGETS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_INCLUDE_DIR QT_QTASSISTANTCLIENT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY QT_QTASSISTANTCLIENT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_DEBUG QT_QTASSISTANTCLIENT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANTCLIENT_LIBRARY_RELEASE QT_QTASSISTANTCLIENT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_INCLUDE_DIR QT_QTASSISTANT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY QT_QTASSISTANT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_DEBUG QT_QTASSISTANT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTASSISTANT_LIBRARY_RELEASE QT_QTASSISTANT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY QT_QTCLUCENE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_DEBUG QT_QTCLUCENE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCLUCENE_LIBRARY_RELEASE QT_QTCLUCENE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_INCLUDE_DIR QT_QTCORE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY QT_QTCORE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY_DEBUG QT_QTCORE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTCORE_LIBRARY_RELEASE QT_QTCORE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_INCLUDE_DIR QT_QTDBUS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY QT_QTDBUS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY_DEBUG QT_QTDBUS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDBUS_LIBRARY_RELEASE QT_QTDBUS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_INCLUDE_DIR QT_QTDECLARATIVE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY QT_QTDECLARATIVE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_DEBUG QT_QTDECLARATIVE_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDECLARATIVE_LIBRARY_RELEASE QT_QTDECLARATIVE_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR QT_QTDESIGNERCOMPONENTS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY QT_QTDESIGNERCOMPONENTS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG QT_QTDESIGNERCOMPONENTS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE QT_QTDESIGNERCOMPONENTS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_INCLUDE_DIR QT_QTDESIGNER_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY QT_QTDESIGNER_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_DEBUG QT_QTDESIGNER_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTDESIGNER_LIBRARY_RELEASE QT_QTDESIGNER_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_INCLUDE_DIR QT_QTGUI_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY QT_QTGUI_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY_DEBUG QT_QTGUI_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTGUI_LIBRARY_RELEASE QT_QTGUI_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_INCLUDE_DIR QT_QTHELP_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY QT_QTHELP_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY_DEBUG QT_QTHELP_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTHELP_LIBRARY_RELEASE QT_QTHELP_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTIFF_PLUGIN_DEBUG QT_QTIFF_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTIFF_PLUGIN_RELEASE QT_QTIFF_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_INCLUDE_DIR QT_QTMOTIF_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY QT_QTMOTIF_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY_DEBUG QT_QTMOTIF_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMOTIF_LIBRARY_RELEASE QT_QTMOTIF_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_INCLUDE_DIR QT_QTMULTIMEDIA_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY QT_QTMULTIMEDIA_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_DEBUG QT_QTMULTIMEDIA_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTMULTIMEDIA_LIBRARY_RELEASE QT_QTMULTIMEDIA_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_INCLUDE_DIR QT_QTNETWORK_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY QT_QTNETWORK_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY_DEBUG QT_QTNETWORK_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNETWORK_LIBRARY_RELEASE QT_QTNETWORK_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_INCLUDE_DIR QT_QTNSPLUGIN_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY QT_QTNSPLUGIN_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_DEBUG QT_QTNSPLUGIN_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTNSPLUGIN_LIBRARY_RELEASE QT_QTNSPLUGIN_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_INCLUDE_DIR QT_QTOPENGL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY QT_QTOPENGL_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY_DEBUG QT_QTOPENGL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTOPENGL_LIBRARY_RELEASE QT_QTOPENGL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG QT_QTRACEGRAPHICSSYSTEM_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE QT_QTRACEGRAPHICSSYSTEM_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_DEBUG QT_QTSCRIPTDBUS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTDBUS_PLUGIN_RELEASE QT_QTSCRIPTDBUS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_INCLUDE_DIR QT_QTSCRIPTTOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY QT_QTSCRIPTTOOLS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_DEBUG QT_QTSCRIPTTOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPTTOOLS_LIBRARY_RELEASE QT_QTSCRIPTTOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_INCLUDE_DIR QT_QTSCRIPT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY QT_QTSCRIPT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_DEBUG QT_QTSCRIPT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSCRIPT_LIBRARY_RELEASE QT_QTSCRIPT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_INCLUDE_DIR QT_QTSQL_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY QT_QTSQL_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY_DEBUG QT_QTSQL_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSQL_LIBRARY_RELEASE QT_QTSQL_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_INCLUDE_DIR QT_QTSVG_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY QT_QTSVG_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY_DEBUG QT_QTSVG_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTSVG_LIBRARY_RELEASE QT_QTSVG_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_INCLUDE_DIR QT_QTTEST_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY QT_QTTEST_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY_DEBUG QT_QTTEST_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTTEST_LIBRARY_RELEASE QT_QTTEST_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_INCLUDE_DIR QT_QTUITOOLS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY QT_QTUITOOLS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_DEBUG QT_QTUITOOLS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTUITOOLS_LIBRARY_RELEASE QT_QTUITOOLS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWCODECS_PLUGIN_DEBUG QT_QTWCODECS_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWCODECS_PLUGIN_RELEASE QT_QTWCODECS_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_INCLUDE_DIR QT_QTWEBKIT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY QT_QTWEBKIT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_DEBUG QT_QTWEBKIT_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTWEBKIT_LIBRARY_RELEASE QT_QTWEBKIT_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_INCLUDE_DIR QT_QTXMLPATTERNS_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY QT_QTXMLPATTERNS_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_DEBUG QT_QTXMLPATTERNS_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXMLPATTERNS_LIBRARY_RELEASE QT_QTXMLPATTERNS_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_INCLUDE_DIR QT_QTXML_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY QT_QTXML_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY_DEBUG QT_QTXML_LIBRARY_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QTXML_LIBRARY_RELEASE QT_QTXML_LIBRARY_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_DEBUG QT_QWEBVIEW_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWEBVIEW_PLUGIN_RELEASE QT_QWEBVIEW_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG QT_QWSTSLIBMOUSEHANDLER_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE QT_QWSTSLIBMOUSEHANDLER_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_RCC_EXECUTABLE QT_RCC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_DEBUG QT_TASKMENUEXTENSION_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TASKMENUEXTENSION_PLUGIN_RELEASE QT_TASKMENUEXTENSION_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_TRANSLATIONS_DIR QT_TRANSLATIONS_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_UIC3_EXECUTABLE QT_UIC3_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_UIC_EXECUTABLE QT_UIC_EXECUTABLE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG QT_WORLDTIMECLOCKPLUGIN_PLUGIN_DEBUG-ADVANCED:INTERNAL=1 //ADVANCED property for variable: QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE QT_WORLDTIMECLOCKPLUGIN_PLUGIN_RELEASE-ADVANCED:INTERNAL=1 //Have symbol Q_WS_MAC Q_WS_MAC:INTERNAL= //Have symbol Q_WS_QWS Q_WS_QWS:INTERNAL= //Have symbol Q_WS_WIN Q_WS_WIN:INTERNAL= //Have symbol Q_WS_X11 Q_WS_X11:INTERNAL=1 //ADVANCED property for variable: SCPCOMMAND SCPCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SITE SITE-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SLURM_SBATCH_COMMAND SLURM_SBATCH_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SLURM_SRUN_COMMAND SLURM_SRUN_COMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: SVNCOMMAND SVNCOMMAND-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VIEWPOINT_INCLUDE_DIR VIEWPOINT_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: VIEWPOINT_LIBRARY VIEWPOINT_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: WIIUSE_INCLUDE_DIR WIIUSE_INCLUDE_DIR-ADVANCED:INTERNAL=1 //ADVANCED property for variable: WIIUSE_LIBRARY WIIUSE_LIBRARY-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_ICE_INCLUDE_PATH X11_ICE_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_ICE_LIB X11_ICE_LIB-ADVANCED:INTERNAL=1 //Have library /usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so X11_LIB_X11_SOLO:INTERNAL=1 //ADVANCED property for variable: X11_SM_INCLUDE_PATH X11_SM_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_SM_LIB X11_SM_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_INCLUDE_PATH X11_X11_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_X11_LIB X11_X11_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XRes_INCLUDE_PATH X11_XRes_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XRes_LIB X11_XRes_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XShm_INCLUDE_PATH X11_XShm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XSync_INCLUDE_PATH X11_XSync_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_INCLUDE_PATH X11_XTest_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_XTest_LIB X11_XTest_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessrules_INCLUDE_PATH X11_Xaccessrules_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xaccessstr_INCLUDE_PATH X11_Xaccessstr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_INCLUDE_PATH X11_Xau_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xau_LIB X11_Xau_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_INCLUDE_PATH X11_Xcomposite_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcomposite_LIB X11_Xcomposite_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_INCLUDE_PATH X11_Xcursor_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xcursor_LIB X11_Xcursor_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_INCLUDE_PATH X11_Xdamage_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdamage_LIB X11_Xdamage_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_INCLUDE_PATH X11_Xdmcp_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xdmcp_LIB X11_Xdmcp_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xext_LIB X11_Xext_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_INCLUDE_PATH X11_Xfixes_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xfixes_LIB X11_Xfixes_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_INCLUDE_PATH X11_Xft_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xft_LIB X11_Xft_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_INCLUDE_PATH X11_Xi_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xi_LIB X11_Xi_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_INCLUDE_PATH X11_Xinerama_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinerama_LIB X11_Xinerama_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_INCLUDE_PATH X11_Xinput_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xinput_LIB X11_Xinput_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkb_INCLUDE_PATH X11_Xkb_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkbfile_INCLUDE_PATH X11_Xkbfile_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkbfile_LIB X11_Xkbfile_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xkblib_INCLUDE_PATH X11_Xkblib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xlib_INCLUDE_PATH X11_Xlib_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xmu_INCLUDE_PATH X11_Xmu_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xmu_LIB X11_Xmu_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_INCLUDE_PATH X11_Xpm_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xpm_LIB X11_Xpm_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_INCLUDE_PATH X11_Xrandr_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrandr_LIB X11_Xrandr_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_INCLUDE_PATH X11_Xrender_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xrender_LIB X11_Xrender_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_INCLUDE_PATH X11_Xscreensaver_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xscreensaver_LIB X11_Xscreensaver_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xshape_INCLUDE_PATH X11_Xshape_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_INCLUDE_PATH X11_Xt_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xt_LIB X11_Xt_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xutil_INCLUDE_PATH X11_Xutil_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_INCLUDE_PATH X11_Xv_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xv_LIB X11_Xv_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xxf86misc_LIB X11_Xxf86misc_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_Xxf86vm_LIB X11_Xxf86vm_LIB-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_dpms_INCLUDE_PATH X11_dpms_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86misc_INCLUDE_PATH X11_xf86misc_INCLUDE_PATH-ADVANCED:INTERNAL=1 //ADVANCED property for variable: X11_xf86vmode_INCLUDE_PATH X11_xf86vmode_INCLUDE_PATH-ADVANCED:INTERNAL=1 _VRPN_PYTHON_SETTINGS:INTERNAL=OFFOFFON _VRPN_PYTHON_VERSIONSEARCH:INTERNAL=3 __DEFAULT_BUILD_TYPE_SET:INTERNAL=YES __pkg_config_checked_PC_LIBUSB1:INTERNAL=1 _dashboardscript_machine:INTERNAL=mpi1 | ||||||||
Project | ParaViewVR | ||||||||
(0038365) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-03-15 04:47 | Joni-Pekka Kurronen | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038365 | |
