| 0013968 | ParaView | (No Category) | public | 2013-03-25 10:57 | 2013-05-18 20:00 | ||||
| Assigned To | Sebastien Jourdain | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | git-master | ||||||||
| Target Version | Fixed in Version | 4.0 | |||||||
| Summary | 0013968: ParaView crashes creating vtkMPIImageReader when reading raw data files on serial builds | ||||||||
| Description | There is a bug in ParView, local client, MPI turned off, where ParaView is trying to read raw data with the MPI based vtkMPIImageReader. This is a bug. Should replicate with any raw data, but I replicated it with volums_ex.out (knox). I am replicating this bug on a local build of ParaView, Master or 3.98.1, PARAVIEW_USE_MPI set to off, Linux, local server. Here is a thread between Utkarsh and me: Yup, that;s bug. I am guessing in that happened somewhere during the movement of classes for modularization in one way or the other. Can you report a bug please? I'll have it fixed. Utkarsh > So, assuming that we shouldn't have a reader called vtkMPIImageReader in a non MPI build, why do I find the following in readers.xml? Is this setting up for remote server, or is it a bug? I don't find another ImageReader in this file. > > <SourceProxy class="vtkMPIImageReader" > label="Image Reader" > name="ImageReader"> > ... > <!-- End ImageReader --> > </SourceProxy> > > Thanks, > > Alan > > > > On Fri, Mar 22, 2013 at 8:24 PM, Scott, W Alan <wascott@sandia.gov> wrote: >> I have a build of ParaView (both 3.98.1 and master) that is failing >> when trying to read raw data files. The Kitware binaries >> successfully read this raw data. The error message is as follows: >> >> ERROR: In >> ..../src/ParaView3/ParaViewCore/ServerImplementation/Core/vtkSIProxy. >> c >> xx >> , line >> 307 >> vtkSISourceProxy (0x17bc94a0): Failed to create vtkMPIImageReader. >> Aborting for debugging purposes. >> >> Anyone have any ideas? >> >> Thanks all! >> >> Alan >> >> | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 13968-disable-invalid-proxy-when-mpi-off | ||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0030472) Alan Scott (manager) 2013-03-25 10:58 |
The sooner this one gets fixed the better. I will then test. Thanks |
(0030558) Utkarsh Ayachit (administrator) 2013-04-12 12:08 |
reopening to fix documentation generation related issues. |
(0030675) Utkarsh Ayachit (administrator) 2013-05-02 09:55 |
SUMMARY --------------------------------------------- Topics merged into master: 0013923-Move-DataAnalysis-Toolbar 12412_enable_pass_data_MaterialInterfaceFilter 13343_fix_time_serie_visit_readers 13968-disable-invalid-proxy-when-mpi-off (VTK) 13984_64bit_headers_for_xml_writers clean_coprocessing_python fix_collaboration_import (VTK) nudge-vtk panel_cleanups perlin-noise scalarbar_from_vtk --------------------------------------------- |
(0030721) Alan Scott (manager) 2013-05-07 21:09 |
I am pretty sure this is fixed. I am having issues testing. If I need, I will reopen. Tested master, Linux, local server. |
| Notes |
| Issue History | |||
| 2013-03-25 10:57 | Alan Scott | New Issue | |
| 2013-03-25 10:58 | Alan Scott | Note Added: 0030472 | |
| 2013-03-25 10:58 | Alan Scott | Status | backlog => todo |
| 2013-04-10 08:30 | Utkarsh Ayachit | Assigned To | => Sebastien Jourdain |
| 2013-04-10 09:09 | Sebastien Jourdain | Status | todo => active development |
| 2013-04-10 14:19 | Sebastien Jourdain | Topic Name | => 13968-disable-invalid-proxy-when-mpi-off |
| 2013-04-10 14:19 | Sebastien Jourdain | Status | active development => gatekeeper review |
| 2013-04-10 14:19 | Sebastien Jourdain | Resolution | open => fixed |
| 2013-04-12 12:08 | Utkarsh Ayachit | Note Added: 0030558 | |
| 2013-04-12 12:08 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
| 2013-04-12 12:08 | Utkarsh Ayachit | Resolution | fixed => reopened |
| 2013-04-30 09:55 | Sebastien Jourdain | Assigned To | Sebastien Jourdain => Utkarsh Ayachit |
| 2013-04-30 09:58 | Sebastien Jourdain | Assigned To | Utkarsh Ayachit => Sebastien Jourdain |
| 2013-04-30 11:18 | Sebastien Jourdain | Status | backlog => gatekeeper review |
| 2013-04-30 11:18 | Sebastien Jourdain | Resolution | reopened => fixed |
| 2013-05-02 09:55 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2013-05-02 09:55 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
| 2013-05-02 09:55 | Utkarsh Ayachit | Note Added: 0030675 | |
| 2013-05-02 11:22 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2013-05-02 11:22 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-05-07 21:09 | Alan Scott | Note Added: 0030721 | |
| 2013-05-07 21:09 | Alan Scott | Status | customer review => closed |
| 2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
| Issue History |
