0013999 | ParaView | (No Category) | public | 2013-04-10 08:56 | 2015-01-11 08:26 | ||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013999: pvpython: OpenDataFile(): AttributeError: Attribute FileName does not exist. | ||||||||
Description | I'm trying to read in a binary *.raw file: >>> reader = OpenDataFile("z.raw") Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/usr/local/lib/paraview-3.10/site-packages/paraview/simple.py", line 132, in OpenDataFile reader = globals()[xml_name](FileName=filename, **extraArgs) File "/usr/local/lib/paraview-3.10/site-packages/paraview/simple.py", line 583, in CreateObject setattr(px, param, params[param]) File "/usr/local/lib/paraview-3.10/site-packages/paraview/servermanager.py", line 207, in __setattr__ "to add this attribute.") AttributeError: Attribute FileName does not exist. This class does not allow addition of new attributes to avoid mistakes due to typos. Use add_attribute() if you really want to add this attribute. >>> | ||||||||
Project | TBD | ||||||||
Topic Name | 13999_fix_open_datafile | ||||||||
(0030550) Utkarsh Ayachit (administrator) 2013-04-10 08:59 |
commit b94a4040c9463326b362112dccf0da94a592b9ae Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Apr 10 08:57:06 2013 -0400 BUG 0013999. Fix OpenDataFile(). Adding new vtkSMCoreUtilities class that can consolidate miscellaneous utility methods. Added a method to vtkSMCoreUtilities to locate the "file-name" property. Making the UI and Python use the same method to locate the file-name property. This addresses the issue when ImageReader was created to open a *.raw file. Change-Id: I700ea9aad2b6e393231a9c6f3e81ebce7b22e36a |
(0030566) Utkarsh Ayachit (administrator) 2013-04-12 12:17 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 0014001-plot3d-improvements 13997_disable_phasta_adaptor 13999_fix_open_datafile (VTK) 14000-multi-block-table-cut 14003_fix_view_updates 14006-add-filters-to-paraview-vtk-python fix_cthadaptor_compile_warnings fix-warnings multiblock-chart-array-as-axis pvw-mobile-interaction-integration pvw-web-viz-improvement renable_catalyst_tests 13989_fix_segfault |
(0032061) Alan Scott (manager) 2013-12-24 19:36 |
Old bug, closing. |
2013-04-10 08:56 | Utkarsh Ayachit | New Issue | |
2013-04-10 08:59 | Utkarsh Ayachit | Topic Name | => 13999_fix_open_datafile |
2013-04-10 08:59 | Utkarsh Ayachit | Note Added: 0030550 | |
2013-04-10 08:59 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-04-10 08:59 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-04-10 08:59 | Utkarsh Ayachit | Resolution | open => fixed |
2013-04-10 08:59 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-04-12 12:17 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-04-12 12:17 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-04-12 12:17 | Utkarsh Ayachit | Note Added: 0030566 | |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2013-12-24 19:36 | Alan Scott | Note Added: 0032061 | |
2013-12-24 19:36 | Alan Scott | Status | customer review => closed |
2015-01-11 08:26 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 7588dab1 |
2015-01-11 08:26 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b94a4040 |
