0014016 | ParaView | (No Category) | public | 2013-04-16 18:40 | 2016-08-12 09:59 | ||||
Reporter | Matthew Woehlke | ||||||||
Summary | 0014016: paraview does not build against external VTK | ||||||||
Description | The fix for issue 0013894 is either inadequate or has bitrotted. I have run into (at least) the following problems trying to build paraview against external VTK: - CMake/ParaViewModuleTop.cmake attempts to build non-existing VTK modules. As these have no ${_module}_SOURCE_DIR, this results in CMake errors about trying to add the top-level source directory multiple times. I was able to fix this by skipping modules for which ${_module}_SOURCE_DIR is empty, although this isn't very elegant. - Plugins can't find VTK because the build-dir ParaviewConfig.cmake refers to Paraview_BINARY_DIR/VTK/VTKConfig.cmake which of course does not exist. This can be fixed by setting the name of the VTKConfig.cmake outside of configuring ParaViewConfig.cmake.in, to a different value depending on whether VTK is external. | ||||||||
Project | TBD | ||||||||
(0030607) Matthew Woehlke (reporter) 2013-04-24 19:59 |
Additional problems I have found: - Python wrapping does not work (patch below). - Finding paraview does not work because there is no VTK module pqApplicationComponents. I'm not sure how to handle the second. Not shoving paraview modules in VTK_FIND_COMPONENTS is a start, but then something needs to actually check for requested paraview modules. This could be done with an additional call to vtk_module_config for the paraview models, except that a: I am not sure that this function can be used for modules outside of VTK proper, and b: something needs to set the list of paraview modules that are available. Patch for first issue: diff --git a/Wrapping/Python/CMakeLists.txt b/Wrapping/Python/CMakeLists.txt index 5c3ad60..7bbd3da 100644 --- a/Wrapping/Python/CMakeLists.txt +++ b/Wrapping/Python/CMakeLists.txt @@ -88,6 +88,26 @@ ADD_CUSTOM_COMMAND( ADD_CUSTOM_TARGET(paraview_pyc ALL DEPENDS "${PV_PYTHON_MODULE_BINARY_DIR}/pv_compile_complete") +if (PARAVIEW_USING_EXTERNAL_VTK) + include(vtkPythonWrapping) + + get_property(VTK_PYTHON_MODULES GLOBAL PROPERTY VTK_PYTHON_WRAPPED) + + # Get the include directories for the module and all its dependencies. + macro(vtk_include_recurse module) + _vtk_module_config_recurse("${module}_PYTHON" ${module}) + include_directories(${${module}_PYTHON_INCLUDE_DIRS}) + endmacro() + + # Loop through all modules that should be wrapped, and wrap them. + foreach(module ${VTK_PYTHON_MODULES}) + vtk_module_load(${module}) + vtk_module_headers_load(${module}) + vtk_include_recurse(${module}) + vtk_add_python_wrapping(${module}) + endforeach() +endif () + # Install the paraview module files. INSTALL(DIRECTORY ${PV_PYTHON_MODULE_BINARY_DIR} DESTINATION ${VTK_INSTALL_LIBRARY_DIR}/site-packages |
(0038381) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-04-16 18:40 | Matthew Woehlke | New Issue | |
2013-04-24 19:59 | Matthew Woehlke | Note Added: 0030607 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038381 | |
