0014048 | ParaView | (No Category) | public | 2013-05-03 13:22 | 2015-01-11 08:26 | ||||
Target Version | 4.0 | Fixed in Version | 4.0 | ||||||
Summary | 0014048: Spreadsheet View doesn't show selected cells correctly. | ||||||||
Description | - Create Sphere, Apply - Split View and create SpreadSheet View - Swicth to show "Cells" in the spreadsheet view - select cell around the center -- Works - Now select a cell closer to the periphery ( we need to select a cell not currentl visible in the spreadsheet view). -- The previously highlighted cells aren't cleared -- that's a BUG. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14045_fix_selection_speadsheet_view_bug | ||||||||
(0030689) Utkarsh Ayachit (administrator) 2013-05-03 13:24 |
commit d0063360322e25cc582909e7a2f40373d0f94c59 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri May 3 13:22:53 2013 -0400 BUG 0014048. Selected rows weren't cleared when selection changed. Selected rows weren't cleared when selection changed, rather the notification that the rows were cleared wasn't sent. Fixed that. Also fixed the random header highliting issue (the header for the spreadsheet view would occassionaly go *bold* as the selection changed. Change-Id: Id49a79f01c54101fbbbbc0e376747a084e3932c9 |
(0030746) Utkarsh Ayachit (administrator) 2013-05-10 08:23 |
SUMMARY --------------------------------------------- Topics merged into master: 13853_catalyst_immediate_mode_rendering2 13981_fix_install_rules 13991_fix_window_sizes 14040_add_save_animation_time_range_v2 14046_fix_selection_issues 14058_fix_camera_animation_in_parallel_scale 14059-vtkPVGeometryFilter-unnecessary-array fix-custom-view-button-leak fix-multi-block-issues fix_pointsprite_plugin gmv-test-cleanup pvw-add-exit-button |
(0030759) Alan Scott (manager) 2013-05-13 17:13 |
Tested Linux, master, remote server. |
2013-05-03 13:22 | Utkarsh Ayachit | New Issue | |
2013-05-03 13:24 | Utkarsh Ayachit | Topic Name | => 14045_fix_selection_speadsheet_view_bug |
2013-05-03 13:24 | Utkarsh Ayachit | Note Added: 0030689 | |
2013-05-03 13:24 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-05-03 13:24 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-05-03 13:24 | Utkarsh Ayachit | Resolution | open => fixed |
2013-05-03 13:24 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-05-03 13:24 | Utkarsh Ayachit | Target Version | => 4.0 |
2013-05-10 08:23 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-05-10 08:23 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-10 08:23 | Utkarsh Ayachit | Note Added: 0030746 | |
2013-05-13 17:13 | Alan Scott | Note Added: 0030759 | |
2013-05-13 17:13 | Alan Scott | Status | customer review => closed |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2015-01-11 08:26 | Sebastiennn Jourdain | Source_changeset_attached | => ParaView master 936f4ed5 |
2015-01-11 08:26 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master d0063360 |
