0014051 | ParaView | (No Category) | public | 2013-05-06 13:06 | 2013-05-22 19:13 | ||||
Reporter | Burlen | ||||||||
Assigned To | David Thompson | ||||||||
Summary | 0014051: segfault opening the color scale editor / vtkPVProminentValuesInformation | ||||||||
Description | with git master from this afternoon, I'm experiencing segfaults when I try to open the color scale editor. seems to be related to vtkPVProminentValuesInformation see stack trace below. I experience the crash after making a slice that doesn't cut through all ranks and attempt to open the color scale editor. Steps to reproduce: Start pvserver running parallel 2 ranks Open the attached dataset, load b array Slice the dataset such that the slice contains no data from at least one rank. Color slice by b array magnitude Open the color scale editor -> crash Program received signal SIGSEGV, Segmentation fault. 0x00007fde3f6dbee1 in vtkInformationVector::GetInformationObject (this=0x0, index=0) at /work/ext/ParaView/sqtk-pv/ParaView/VTK/Common/Core/vtkInformationVector.cxx:157 157 if(index >= 0 && index < this->NumberOfInformationObjects) (gdb) where #0 0x00007fde3f6dbee1 in vtkInformationVector::GetInformationObject (this=0x0, index=0) at /work/ext/ParaView/sqtk-pv/ParaView/VTK/Common/Core/vtkInformationVector.cxx:157 #1 0x00007fde3f5c5950 in vtkAbstractArray::UpdateDiscreteValueSet (this=0x3ce0130, uncertainty=0, minimumProminence=0) at /work/ext/ParaView/sqtk-pv/ParaView/VTK/Common/Core/vtkAbstractArray.c #2 0x00007fde3f5c4d81 in vtkAbstractArray::GetProminentComponentValues (this=0x3ce0130, comp=-1, values=0x3cd2f30, uncertainty=0, minimumProminence=0) at /work/ext/ParaView/sqtk-pv/ParaView/VTK/Common/Core/vtkAbstractArray.cxx:548 #3 0x00007fde383df72d in vtkPVProminentValuesInformation::CopyDistinctValuesFromObject (this=0x3ccfeb0, array=0x3ce0130) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVProminentValuesInformation.cxx:391 #4 0x00007fde383df5b7 in vtkPVProminentValuesInformation::CopyFromLeafDataObject (this=0x3ccfeb0, dobj=0x4084620) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVProminentValuesInformation.cxx:360 #5 0x00007fde383df2ad in vtkPVProminentValuesInformation::CopyFromCompositeDataSet (this=0x3ccbd80, cds=0x40bb800) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVProminentValuesInformation.cxx:309 #6 0x00007fde383def5f in vtkPVProminentValuesInformation::CopyFromObject (this=0x3ccbd80, obj=0x405dd90) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ClientServerCore/Rendering/vtkPVProminentValuesInformation.cxx:263 #7 0x00007fde401554f0 in vtkPVSessionCore::GatherInformationInternal (this=0x23a3b90, information=0x3ccbd80, globalid=4483) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:838 #8 0x00007fde401555cb in vtkPVSessionCore::GatherInformation (this=0x23a3b90, location=17, information=0x3ccbd80, globalid=4483) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionCore.cxx:858 0000009 0x00007fde401512c0 in vtkPVSessionBase::GatherInformation (this=0x23a9ad0, location=17, information=0x3ccbd80, globalid=4483) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionBase.cxx:258 #10 0x00007fde40160b7e in vtkPVSessionServer::GatherInformationInternal (this=0x23a9ad0, location=17, classname=0x3cbb9f8 "vtkPVProminentValuesInformation", globalid=4483, stream=...) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionServer.cxx:567 0000011 0x00007fde401608f0 in vtkPVSessionServer::OnClientServerMessageRMI (this=0x23a9ad0, message=0x408dec0, message_length=135) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionServer.cxx:527 #12 0x00007fde4015ee0c in (anonymous namespace)::RMICallback (localArg=0x23a9ad0, remoteArg=0x408dec0, remoteArgLength=135) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ServerImplementation/Core/vtkPVSessionServer.cxx:56 #13 0x00007fde3fb0c4bf in vtkMultiProcessController::ProcessRMI (this=0x2cdfe60, remoteProcessId=1, arg=0x408dec0, argLength=135, rmiTag=55625) at /work/ext/ParaView/sqtk-pv/ParaView/VTK/Parallel/Core/vtkMultiProcessController.cxx:650 #14 0x00007fde3fb0c06e in vtkMultiProcessController::ProcessRMIs (this=0x2cdfe60, reportErrors=0, dont_loop=1) at /work/ext/ParaView/sqtk-pv/ParaView/VTK/Parallel/Core/vtkMultiProcessController.cxx:597 #15 0x00007fde3fe64291 in vtkTCPNetworkAccessManager::ProcessEventsInternal (this=0x2394e90, timeout_msecs=0, do_processing=true) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ClientServerCore/Core/vtkTCPNetworkAccessManager.cxx:268 #16 0x00007fde3fe63e50 in vtkTCPNetworkAccessManager::ProcessEvents (this=0x2394e90, timeout_msecs=0) at /work/ext/ParaView/sqtk-pv/ParaView/ParaViewCore/ClientServerCore/Core/vtkTCPNetworkAccessManager.cxx:165 #17 0x0000000000401713 in RealMain (argc=1, argv=0x7fff7f9ea6a8, type=vtkProcessModule::PROCESS_SERVER) at /work/ext/ParaView/sqtk-pv/ParaView/CommandLineExecutables/pvserver_common.h:90 #18 0x00000000004017c5 in main (argc=1, argv=0x7fff7f9ea6a8) at /work/ext/ParaView/sqtk-pv/ParaView/CommandLineExecutables/pvserver.cxx:21 | ||||||||
Project | TBD | ||||||||
Topic Name | 14051_prominent_value_crash | ||||||||
Attached Files | ![]() | ||||||||
(0030701) David Thompson (developer) 2013-05-07 15:22 |
Both PV-VTK and PV have a branch named 14051_prominent_value_crash that should be merged to master. The test data and steps to reproduce no longer produce a crash. |
(0030722) Sebastien Jourdain (manager) 2013-05-08 09:18 |
Merged into master |
(0030826) Alan Scott (manager) 2013-05-22 19:13 |
Tested Linux, master, remote server, 2 pvservers. |
2013-05-06 13:06 | Burlen | New Issue | |
2013-05-06 13:06 | Burlen | File Added: crash-test-pvti.tgz | |
2013-05-06 13:08 | Sebastien Jourdain | Assigned To | => David Thompson |
2013-05-06 13:13 | Burlen | Description Updated | |
2013-05-07 15:22 | David Thompson | Topic Name | => 14051_prominent_value_crash |
2013-05-07 15:22 | David Thompson | Note Added: 0030701 | |
2013-05-07 15:22 | David Thompson | Status | backlog => gatekeeper review |
2013-05-07 15:22 | David Thompson | Resolution | open => fixed |
2013-05-08 09:18 | Sebastien Jourdain | Status | gatekeeper review => customer review |
2013-05-08 09:18 | Sebastien Jourdain | Note Added: 0030722 | |
2013-05-22 19:13 | Alan Scott | Note Added: 0030826 | |
2013-05-22 19:13 | Alan Scott | Status | customer review => closed |
