0014061 | ParaView | (No Category) | public | 2013-05-10 13:20 | 2016-08-12 09:59 | ||||
Reporter | Burlen | ||||||||
Summary | 0014061: missing geometry after d3 | ||||||||
Description | after running d3 some geometry in the rendered surface is missing. Not sure if it's d3 or pv's internal extract surface filter. attached screen shot show before and after d3 and missing surface geometry. steps to reproduce: start pv client server with 4 mpi ranks open the attached vts dataset apply d3 dataset can be found here: http://hpcvis.com/downloads/shuttle_6_0.vts [^] | ||||||||
Project | TBD | ||||||||
Attached Files | missing-geometry-after-d3.png [^] (150,261 bytes) 2013-05-10 13:20
(0038391) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-05-10 13:20 | Burlen | New Issue | |
2013-05-10 13:20 | Burlen | File Added: missing-geometry-after-d3.png | |
2013-05-10 13:23 | Burlen | Description Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038391 | |
