0014078 | ParaView | (No Category) | public | 2013-05-22 09:05 | 2013-05-30 13:19 | ||||
Assigned To | Nikhil Shetty | ||||||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0014078: Fix names for tar-balls for extra plugins built by ParaViewSuperbuild | ||||||||
Description | Plugins build by ParaViewSuperbuid e.g. VisTrails, AcuSolveReader generate tar/zip balls incosistently e.g. some place the dll/so in a dir, other don't. None use the ParaView version as a suffix for the directory or tar ball. Here's what needs to happen: - all plugins must place the necessary shared libraries and other files in an archive named as <PluginName>-<ParaView Version>-<Platform>.<ext> e.g. AcuSolveReader-4.0.0-RC1-Linux-64bit.tgz. - the archive must contain a directory named using the same naming convention as the archive itself and the files must be in that directory. | ||||||||
Project | Kitware | ||||||||
Topic Name | 0014078-fix-tarball-plugin-names | ||||||||
(0030871) Utkarsh Ayachit (administrator) 2013-05-30 11:48 |
SUMMARY --------------------------------------------- Topics merged into master: 14095_scalar_bar_slowdown 14101_fix_coprocessing_py nektar_reader_plugin remove-multi-block-opacity-test save-animation-dialog --------------------------------------------- Topics reverted from next: 13024-python-debug-leaks-view ogg-support python-refactoring |
2013-05-22 09:05 | Utkarsh Ayachit | New Issue | |
2013-05-22 09:05 | Utkarsh Ayachit | Assigned To | => Nikhil Shetty |
2013-05-23 10:54 | Nikhil Shetty | Status | backlog => todo |
2013-05-23 10:57 | Nikhil Shetty | Status | todo => active development |
2013-05-24 16:26 | Nikhil Shetty | Topic Name | => 0014078-fix-tarball-plugin-names |
2013-05-24 16:26 | Nikhil Shetty | Status | active development => gatekeeper review |
2013-05-30 11:48 | Utkarsh Ayachit | Fixed in Version | => 4.0 |
2013-05-30 11:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-30 11:48 | Utkarsh Ayachit | Note Added: 0030871 | |
2013-05-30 13:19 | Utkarsh Ayachit | Status | customer review => closed |
2013-05-30 13:19 | Utkarsh Ayachit | Resolution | open => fixed |
