0014091 | ParaView | (No Category) | public | 2013-05-28 15:52 | 2013-11-01 13:18 | ||||
Reporter | Burlen | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014091: color scale editor -- Ignores Render View immediately | ||||||||
Description | selecting a new lut causes remote render even when "Render View Immediately" is unchecked. If Render View Immediately is unchecked then render should not occur until apply is hit. | ||||||||
Tags | ColorMap | ||||||||
Project | TBD | ||||||||
Topic Name | 13082_fix_log_lut | ||||||||
(0031346) Utkarsh Ayachit (administrator) 2013-07-26 16:45 |
This is fixed by the Color Map Editor refactor. Unless, the "auto-update" button on the Color Map Editor panel (button right next to the "Update" button) is pressed/checked, changing color preset will not cause a render. User will have to press the "Update" button to trigger the render (or cause a render on the view by other means such as interacting). |
(0031368) Utkarsh Ayachit (administrator) 2013-07-30 10:55 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 13082_fix_log_lut 14190_pythonprogrammablefilter_pass_request 14191_particle_streaming --------------------------------------------- |
(0031416) Alan Scott (manager) 2013-08-09 19:22 |
Tested master, remote server, Linux. |
2013-05-28 15:52 | Burlen | New Issue | |
2013-05-28 16:07 | Burlen | Description Updated | |
2013-07-26 12:38 | Utkarsh Ayachit | Tag Attached: ColorMap | |
2013-07-26 16:45 | Utkarsh Ayachit | Topic Name | => 13082_fix_log_lut |
2013-07-26 16:45 | Utkarsh Ayachit | Note Added: 0031346 | |
2013-07-26 16:45 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-07-26 16:45 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-07-26 16:45 | Utkarsh Ayachit | Resolution | open => fixed |
2013-07-26 16:45 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-07-30 10:54 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-07-30 10:55 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-07-30 10:55 | Utkarsh Ayachit | Note Added: 0031368 | |
2013-08-09 19:22 | Alan Scott | Note Added: 0031416 | |
2013-08-09 19:22 | Alan Scott | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
