0014118 | ParaView | (No Category) | public | 2013-06-05 16:40 | 2016-08-12 09:59 | ||||
Reporter | Cory Quammen | ||||||||
Summary | 0014118: VisItBridge compilation error | ||||||||
Description | I have enabled PARAVIEW_USE_VISITBRIDGE using ParaView commit 3f4918784cb8aa2662d27ccdcad9b49eff2e8490 on Mac OS X. Compilation fails with [ 94%] Building CXX object Utilities/VisItBridge/databases/CMakeFiles/vtkIOVisItBridge.dir/vtkVisItVsReader.cxx.o /Users/quammen/dev/build/MADAIWorkbench-Installer/bin/ParaView-build/Utilities/VisItBridge/databases/vtkVisItVsReader.cxx: In member function ‘virtual bool vtkVisItVsReader::InitializeAVTReader(const int&)’: /Users/quammen/dev/build/MADAIWorkbench-Installer/bin/ParaView-build/Utilities/VisItBridge/databases/vtkVisItVsReader.cxx:102: error: cannot allocate an object of abstract type ‘avtVsFileFormat’ /Users/quammen/dev/build/MADAIWorkbench-Installer/src/ParaView/Utilities/VisItBridge/databases/Vs/avtVsFileFormat.h:41: note: because the following virtual functions are pure within ‘avtVsFileFormat’: /Users/quammen/dev/build/MADAIWorkbench-Installer/src/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats/avtFileFormat.h:150: note: virtual const char* avtFileFormat::GetType() /Users/quammen/dev/build/MADAIWorkbench-Installer/src/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats/avtSTMDFileFormat.h:129: note: virtual vtkDataSet* avtSTMDFileFormat::GetMesh(int, const char*) /Users/quammen/dev/build/MADAIWorkbench-Installer/src/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats/avtSTMDFileFormat.h:130: note: virtual vtkDataArray* avtSTMDFileFormat::GetVar(int, const char*) /Users/quammen/dev/build/MADAIWorkbench-Installer/src/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats/avtSTMDFileFormat.h:140: note: virtual void avtSTMDFileFormat::PopulateDatabaseMetaData(avtDatabaseMetaData*) make[3]: *** [Utilities/VisItBridge/databases/CMakeFiles/vtkIOVisItBridge.dir/vtkVisItVsReader.cxx.o] Error 1 make[2]: *** [Utilities/VisItBridge/databases/CMakeFiles/vtkIOVisItBridge.dir/all] Error 2 make[1]: *** [Utilities/VisItBridge/databases/CMakeFiles/vtkIOVisItBridge.dir/rule] Error 2 make: *** [vtkIOVisItBridge] Error 2 | ||||||||
Project | TBD | ||||||||
Attached Files | ![]() | ||||||||
(0030977) Utkarsh Ayachit (administrator) 2013-06-07 12:03 |
Can you attach your CMakeCache.txt? Are you using system HDF5? |
(0030982) Cory Quammen (developer) 2013-06-11 15:08 |
CMakeCache.txt attached. I am not using system HDF5. |
(0030985) Cory Quammen (developer) 2013-06-11 16:03 |
I do have an HDF5 installation in /opt/local. Boost is also installed there, so Boost_INCLUDE_DIR is set to /opt/local/include. This is added to the VISITBRIDGE_INCLUDE_DIRS, so there is a danger that the wrong HDF5 header files are being located. |
(0030987) Cory Quammen (developer) 2013-06-11 17:44 |
I just confirmed it's a problem with my installation of HDF5 using mac ports. The installed version was 1.6.9. The header for this version was getting included, so the majority of the content for avtVsFileFormat.h and avtVsFileFormat.C was skipped by the preprocessor because of the check #if HDF5_VERSION_GE(1, 8, 1) at avtVsFileFormat.h:64 A solution migt be to include the VTK HDF5 include directories before any system include directories. |
(0038404) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-06-05 16:40 | Cory Quammen | New Issue | |
2013-06-07 12:03 | Utkarsh Ayachit | Note Added: 0030977 | |
2013-06-07 12:03 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-06-11 15:08 | Cory Quammen | File Added: CMakeCache.txt | |
2013-06-11 15:08 | Cory Quammen | Note Added: 0030982 | |
2013-06-11 16:03 | Cory Quammen | Note Added: 0030985 | |
2013-06-11 17:44 | Cory Quammen | Note Added: 0030987 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038404 | |
