0014137ParaView(No Category)public2013-06-20 10:582016-08-12 09:59
Reportergrenon
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0014137: Request feature of a "Select blocks through" selection mode
DescriptionThe problem arises when you want to select blocks on a complex geometry with many blocks and when it is not possible to have a point of view showing all searched blocks: the "Select blocks" mode gives only VISIBLE blocks that are inside or intersect the rubberband frame drawn when dragging the mouse.
It would be nice to have a "Select blocks through" that gives ALL blocks inside a Frustum that works like for the cells in the "Select cells through" mode.
TagsNo tags attached.
ProjectTBD
Topic Name
Typefeature
 Relationships
  Notes
(0038409)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2013-06-20 10:58 grenon New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038409
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
