0014141 | ParaView | (No Category) | public | 2013-06-23 18:38 | 2016-08-12 09:59 | ||||
Reporter | jin_cn | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014141: Python script does not work | ||||||||
Description | The attached python script, a very simple one, does not run on PV 4.0. It works in previous versions. Please add this kind of test into your regression suite. | ||||||||
Project | Release | ||||||||
Attached Files | test_box.py [^] (730 bytes) 2013-06-23 18:38 | ||||||||
(0031027) Sebastien Jourdain (manager) 2013-06-24 08:13 |
Could you explain what is not working ? Just tried it and didn't noticed any issue. Thanks, Seb |
(0031028) jin_cn (reporter) 2013-06-24 09:21 |
OS: Fedora 14 64 bit Add new macro..., click "test_box", here is the error: Traceback (most recent call last): File "<string>", line 5, in <module> NameError: name 'Box' is not defined Same error when running from python shell Trace works fine. test_box.py was recorded from trace. |
(0031140) jin_cn (reporter) 2013-07-15 03:50 |
It does not work on windows (7 64bit) either, similar error msg |
(0038411) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-06-23 18:38 | jin_cn | New Issue | |
2013-06-23 18:38 | jin_cn | File Added: test_box.py | |
2013-06-24 08:13 | Sebastien Jourdain | Note Added: 0031027 | |
2013-06-24 09:21 | jin_cn | Note Added: 0031028 | |
2013-07-15 03:50 | jin_cn | Note Added: 0031140 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038411 | |
