0014170 | VTK | (No Category) | public | 2013-07-15 06:47 | 2013-09-25 02:39 | ||||
Reporter | John Biddiscombe | ||||||||
Assigned To | John Biddiscombe | ||||||||
Product Version | 6.0.0 | ||||||||
Summary | 0014170: Segfault in vtkSmartVolumeMapper | ||||||||
Description | Bad code causes segfault. Patch attached | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | 0001-Fix-a-segfault-in-setting-of-GPU-resampler-input.patch [^] (1,052 bytes) 2013-07-15 06:47 [Show Content] | ||||||||
(0031618) David Cole (developer) 2013-09-24 18:24 |
I ran into this one today, too. Thanks for posting the patch. It appears to be fixed in 'master' already, but like this, instead of using the attached patch: // make sure we not create a shallow copy each time to avoid // performance penalty. input2=vtkImageData::New(); f->SetInputDataObject(input2); input2->Delete(); needShallowCopy=true; Perhaps this bug should be marked as "resolved" in VTK 'master'...? |
(0031622) John Biddiscombe (developer) 2013-09-25 02:39 |
Original patch was reviewed and a better fix using the more up to date pipeline set/get mechanism was used. Issue is now closed |
2013-07-15 06:47 | John Biddiscombe | New Issue | |
2013-07-15 06:47 | John Biddiscombe | File Added: 0001-Fix-a-segfault-in-setting-of-GPU-resampler-input.patch | |
2013-09-24 18:24 | David Cole | Note Added: 0031618 | |
2013-09-25 02:39 | John Biddiscombe | Note Added: 0031622 | |
2013-09-25 02:39 | John Biddiscombe | Status | backlog => closed |
2013-09-25 02:39 | John Biddiscombe | Assigned To | => John Biddiscombe |
2013-09-25 02:39 | John Biddiscombe | Resolution | open => fixed |
