0014187 | ParaView | (No Category) | public | 2013-07-25 13:32 | 2015-01-11 08:24 | ||||
Reporter | Alejandro Ribes | ||||||||
Product Version | 4.0 | ||||||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014187: Information on data arrays not update when changing time steps | ||||||||
Description | Load a file with time steps for instance can1.ex or FileSeries/blow* from ParaviewData. Apply. In "Information" panel, we focus on data arrays values. Click many times on icon "Next frame" in order to go next time steps. => Values are well updated for "DISPL". Click many times on icon "Previous frame" in order to go previous time steps. => Values are not updated. Click again on "Next frame". => Values are not updated anymore. | ||||||||
Project | ParaViS | ||||||||
Topic Name | 14187_fix_animation_cache_default | ||||||||
Attached Files | ![]() | ||||||||
(0031381) Utkarsh Ayachit (administrator) 2013-08-01 12:19 |
commit 31232529b044bb529a6160fbb139c45c18969378 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Aug 1 12:09:52 2013 -0400 BUG 0014187. Fix default to not cache animations. ParaView by default caches animation geometry. With cached geomtry the data-ranges cannot be shown correctly. Since geometry-caching happens under the covers it difficult for users to understand what's going on with data-ranges. Hence, we change the default to not cache. Thus when users do turn on geometry-caching, they can be made away that that will affect data ranges. Change-Id: I4445fb0f9c71f6701edd1db3bbcb779c75419adf |
(0031382) Utkarsh Ayachit (administrator) 2013-08-01 12:20 |
Alejandro, The problem arises due to geometry caching which is ON by default. I've pushed a change to disable caching by default and add a note to the settings dialog to warn users about the potentially incorrectly data-ranges when changing timesteps. |
(0031386) Utkarsh Ayachit (administrator) 2013-08-05 12:21 |
SUMMARY --------------------------------------------- Topics merged into master: 14187_fix_animation_cache_default 14198_easy_add_annotations 14198_easy_add_contour_values fix_manta_benchmark pqContourWidget_better_widget_checking |
(0031602) Alan Scott (manager) 2013-09-18 14:53 |
Tested master, Linux, local server. Yep, Cache Geometry is now off by default. |
2013-07-25 13:32 | Alejandro Ribes | New Issue | |
2013-07-25 13:32 | Alejandro Ribes | Assigned To | => Utkarsh Ayachit |
2013-07-29 10:30 | Utkarsh Ayachit | File Added: bug.14187.m4v | |
2013-07-29 10:30 | Utkarsh Ayachit | Note Added: 0031357 | |
2013-08-01 12:02 | Utkarsh Ayachit | Note Deleted: 0031357 | |
2013-08-01 12:19 | Utkarsh Ayachit | Topic Name | => 14187_fix_animation_cache_default |
2013-08-01 12:19 | Utkarsh Ayachit | Note Added: 0031381 | |
2013-08-01 12:19 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-08-01 12:20 | Utkarsh Ayachit | Note Added: 0031382 | |
2013-08-05 12:20 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-08-05 12:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-05 12:21 | Utkarsh Ayachit | Note Added: 0031386 | |
2013-09-18 14:53 | Alan Scott | Note Added: 0031602 | |
2013-09-18 14:53 | Alan Scott | Status | customer review => closed |
2013-09-18 14:53 | Alan Scott | Resolution | open => fixed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 4dd9f34c |
2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 31232529 |
