0014215 | ParaView | (No Category) | public | 2013-08-07 03:02 | 2016-08-12 09:59 | ||||
Reporter | hamidnt | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014215: Paraview 4.0.1 does not compile with FFMPEG 2.0 | ||||||||
Description | FFMPEG 2.0 has changed CodecID to AVCodecID. This makes paraview compile to fail when ffmpeg is enabled. Making the mentioned change in the file VTK/IO/FFMPEG/vtkFFMPEGWriter.cxx will remove the issue. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0031487) Marcus D. Hanwell (developer) 2013-08-19 16:25 |
I hit this last week, and hope to find some time to get to it. It is an API change in ffmpeg, but we would like like to retain support for the old and new API. |
(0031493) hamidnt (reporter) 2013-08-23 15:48 edited on: 2013-08-23 15:49 |
As far as I encountered, since this API change effect is very local (only one place in the file vtkFFMPEGWiter.cxx uses CodecID), both new and old ffmpeg can be easily supported via a c++ macro definition and the necessary test condition in the CMakeLists.txt file. However, coding standards of the Paraview project may require more elaborate solutions, which I am not aware of. |
(0038434) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-08-07 03:02 | hamidnt | New Issue | |
2013-08-19 16:25 | Marcus D. Hanwell | Note Added: 0031487 | |
2013-08-23 15:48 | hamidnt | Note Added: 0031493 | |
2013-08-23 15:49 | hamidnt | Note Edited: 0031493 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038434 | |
