| 0014231 | ParaView | (No Category) | public | 2013-08-14 13:13 | 2013-11-01 13:18 | ||||
| Reporter | David C. Lonie | ||||||||
| Assigned To | David C. Lonie | ||||||||
| Product Version | git-master | ||||||||
| Target Version | Fixed in Version | 4.1 | |||||||
| Summary | 0014231: Fix vtkDataLabelRepresentation + vtkGL2PSExporter compatibility | ||||||||
| Description | The current implementation ultimately uses a vtkTextMapper + vtkActor, which should be replaced by a vtkTextActor. Alternatively, a special case can be added vtkPVGL2PSExporter to recognize vtkLabeledDataMapper as a special case for exporting text, though this will not add MathText support as vtkTextActor will. | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0031623) David C. Lonie (developer) 2013-09-25 14:57 |
Fixed in master. To test: 1) Make a selection of points/cells. 2) Add labels in the Find Data dialog. 3) File >> Export Scene >> "somefile.ps". Use default options. Labels should appear in the exported file. |
| Notes |
| Issue History | |||
| 2013-08-14 13:13 | David C. Lonie | New Issue | |
| 2013-08-14 13:13 | David C. Lonie | Assigned To | => David C. Lonie |
| 2013-09-25 14:57 | David C. Lonie | Note Added: 0031623 | |
| 2013-09-25 14:57 | David C. Lonie | Status | backlog => closed |
| 2013-09-25 14:57 | David C. Lonie | Resolution | open => fixed |
| 2013-09-25 14:57 | David C. Lonie | Fixed in Version | => git-master |
| 2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
| Issue History |
