| 0014238 | ParaView | (No Category) | public | 2013-08-20 15:14 | 2015-01-11 08:23 | ||||
| Assigned To | Kyle Lutz | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | git-master | ||||||||
| Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
| Summary | 0014238: Crash opening EnSight .case files with FILE block | ||||||||
| Description | I have a dataset that crashes. It is an EnSight .case file. The issue occurs in the FILE block of the .case file. ParaView is reading three lines for the following, where it should be reading two: file set: # number of steps: # This works if there is only one file set, but if you have more than one, it is wrong. Issue was found in parallel (with crash), but should also have happened in serial (which surprisingly didn't crash). Linux, master, remote server. Open attached .case file. Dies. I have attached two .diff files that patch and correct this bug. >> pwd /projects/viz/ParaView-Distribution/ParaView/4.1.0-alan/ParaView4/ParaViewCore/VTKExtensions/Default git diff vtkPEnSightReader.cxx > ~/vtkPEnSightReader.cxx.diff >> pwd /projects/viz/ParaView-Distribution/ParaView/4.1.0-alan/ParaView4/VTK/IO/EnSight redsky-login3:EnSight$ git diff vtkEnSightReader.cxx > ~/vtkEnSightReader.cxx.diff Bug and dataset provided by Georg Hammerl (Thanks!) | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14238-fix-ensight-crash | ||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0031490) Alan Scott (manager) 2013-08-20 15:20 |
Please review patch, and apply. |
(0031537) Kyle Lutz (viewer) 2013-09-04 11:12 |
Merge topic '14238-fix-ensight-crash' into next 6ea35af Fix crash in EnSight reader Gerrit topic: http://review.source.kitware.com/#/t/3208/ [^] |
(0031538) Kyle Lutz (viewer) 2013-09-04 11:13 |
Patch applied. Verified ParaView successfully opens the attached data set. |
(0031548) Utkarsh Ayachit (administrator) 2013-09-09 12:08 |
14238-fix-ensight-crash (VTK) add_cosmo_reader find-data (VTK) fix-python-cmake-rules fix-warnings (VTK) forward-to-vtk-master (VTK) vtkweb-integration |
(0031597) Alan Scott (manager) 2013-09-18 13:23 |
Tested local server, master, Linux. |
| Notes |
| Issue History | |||
| 2013-08-20 15:14 | Alan Scott | New Issue | |
| 2013-08-20 15:18 | Alan Scott | File Added: bug-14238-test-dataset.tar.gz | |
| 2013-08-20 15:19 | Alan Scott | File Added: vtkEnSightReader.cxx.diff | |
| 2013-08-20 15:19 | Alan Scott | File Added: vtkPEnSightReader.cxx.diff | |
| 2013-08-20 15:20 | Alan Scott | Description Updated | |
| 2013-08-20 15:20 | Alan Scott | Note Added: 0031490 | |
| 2013-08-20 15:20 | Alan Scott | Assigned To | => Utkarsh Ayachit |
| 2013-08-20 15:20 | Alan Scott | Status | backlog => todo |
| 2013-08-23 15:54 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Kyle Lutz |
| 2013-08-23 17:09 | Utkarsh Ayachit | Target Version | => 4.1 |
| 2013-09-04 11:12 | Kyle Lutz | Topic Name | => 14238-fix-ensight-crash |
| 2013-09-04 11:12 | Kyle Lutz | Note Added: 0031537 | |
| 2013-09-04 11:12 | Kyle Lutz | Status | todo => gatekeeper review |
| 2013-09-04 11:12 | Kyle Lutz | Resolution | open => fixed |
| 2013-09-04 11:13 | Kyle Lutz | Note Added: 0031538 | |
| 2013-09-09 12:07 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2013-09-09 12:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-09-09 12:08 | Utkarsh Ayachit | Note Added: 0031548 | |
| 2013-09-18 13:23 | Alan Scott | Note Added: 0031597 | |
| 2013-09-18 13:23 | Alan Scott | Status | customer review => closed |
| 2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
| 2015-01-09 13:46 | Kyle Lutz | Source_changeset_attached | => VTK master cac24ae3 |
| 2015-01-11 08:23 | Kyle Lutz | Source_changeset_attached | => ParaView master 6ea35afd |
| Issue History |
