0014279 | ParaView | (No Category) | public | 2013-09-16 13:07 | 2015-01-11 08:16 | ||||
Product Version | 4.0 | ||||||||
Summary | 0014279: Glyph filter producing different results on OsX and Windows. | ||||||||
Description | Check the attached images produces on OsX and Windows using data in Archive.zip (check with Utkarsh for the dataset). | ||||||||
Project | Kitware | ||||||||
Topic Name | 14279_fix_rand_on_windows_attempt_2 | ||||||||
Attached Files | ![]() ![]() ![]() ![]() | ||||||||
Relationships | ||||||
(0033177) Utkarsh Ayachit (administrator) 2014-08-02 17:51 |
commit 340d1bae94100b8f459680ca8d0c15fbab0e8e1d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Aug 2 17:48:37 2014 -0400 BUG 0014279. Fix random glyphs on Windows. BUG 0014279 was encountered because the code that used rand() didn't not take into consideration that the int value returned by rand() may be less than the number of point ids in the dataset. On Windows, is was indeed limited to 32767 (on unixes, it wasn't that low). Thus resulted in the rand point ids selected being limited to that range. Fixed that. Change-Id: Ifd0e13cdba8404776a2388e2c5c3f68c6889a8ca |
(0033178) Utkarsh Ayachit (administrator) 2014-08-02 17:54 |
Alan, you can test this out without the actual data by simply creating a large dataset with more than 32767 points e.g. Wavelet with extents 0, 64, 0, 64, 0, 64. |
(0033180) Utkarsh Ayachit (administrator) 2014-08-04 10:12 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 14279_glyph_filter (VTK) fix_invalid_socket_check |
(0033181) Utkarsh Ayachit (administrator) 2014-08-04 10:13 |
Alan, This Glyph filter was entirely revamped. However this old version of the filter is still available as "Legacy Glyph". To test this fix, you should use that filter instead of the "Glyph". |
(0033253) Utkarsh Ayachit (administrator) 2014-08-19 11:00 |
commit 069f1024a6807380b43ead6cf0e9e97bdf92cf01 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Aug 19 10:58:31 2014 -0400 BUG 0014279. Fix random glyphs on Windows. BUG 0014279 was encountered because the code that used rand() didn't not take into consideration that the int value returned by rand() may be less than the number of point ids in the dataset. On Windows, is was indeed limited to 32767 (on unixes, it wasn't that low). Thus resulted in the rand point ids selected being limited to that range. Fixed that. Change-Id: Ifd0e13cdba8404776a2388e2c5c3f68c6889a8ca |
(0033274) Utkarsh Ayachit (administrator) 2014-08-20 08:45 |
SUMMARY --------------------------------------------- Topics merged into master: 14279_fix_rand_on_windows_attempt_2 14813_fix_mode_shapes_range catalyst-updates --------------------------------------------- Topics reverted from next: catalyst-script-plugin-client |
(0033779) Alan Scott (manager) 2014-11-06 20:35 |
Tested as per Utkarsh's directions below. Tested Linux, master, local server. |
2013-09-16 13:07 | Utkarsh Ayachit | New Issue | |
2013-09-16 13:07 | Utkarsh Ayachit | File Added: Windows_401.png | |
2013-09-16 13:08 | Utkarsh Ayachit | File Added: OSX_401.png | |
2013-09-16 13:08 | Utkarsh Ayachit | Target Version | => 4.1 |
2014-02-07 21:47 | Utkarsh Ayachit | Target Version | 4.1 => 4.2 |
2014-06-08 17:33 | Utkarsh Ayachit | Assigned To | => George Zagaris |
2014-06-08 17:33 | Utkarsh Ayachit | Note Added: 0032779 | |
2014-07-05 21:25 | Utkarsh Ayachit | Assigned To | George Zagaris => Cory Quammen |
2014-07-22 22:24 | Utkarsh Ayachit | Assigned To | Cory Quammen => Utkarsh Ayachit |
2014-07-31 13:08 | Utkarsh Ayachit | Status | backlog => todo |
2014-08-01 20:22 | Utkarsh Ayachit | Note Deleted: 0032779 | |
2014-08-02 17:51 | Utkarsh Ayachit | Topic Name | => 14279_fix_rand_on_windows |
2014-08-02 17:51 | Utkarsh Ayachit | Note Added: 0033177 | |
2014-08-02 17:51 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2014-08-02 17:51 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-08-02 17:51 | Utkarsh Ayachit | Resolution | open => fixed |
2014-08-02 17:54 | Utkarsh Ayachit | Note Added: 0033178 | |
2014-08-04 10:12 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-08-04 10:12 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-08-04 10:12 | Utkarsh Ayachit | Note Added: 0033180 | |
2014-08-04 10:13 | Utkarsh Ayachit | Note Added: 0033181 | |
2014-08-13 11:17 | Utkarsh Ayachit | Relationship added | has duplicate 0014923 |
2014-08-19 11:00 | Utkarsh Ayachit | Status | customer review => todo |
2014-08-19 11:00 | Utkarsh Ayachit | Topic Name | 14279_fix_rand_on_windows => 14279_fix_rand_on_windows_attempt_2 |
2014-08-19 11:00 | Utkarsh Ayachit | Note Added: 0033253 | |
2014-08-19 11:00 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2014-08-20 08:45 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-08-20 08:45 | Utkarsh Ayachit | Note Added: 0033274 | |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2014-11-06 20:35 | Alan Scott | Note Added: 0033779 | |
2014-11-06 20:35 | Alan Scott | Status | customer review => closed |
2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 19b0565f |
2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 069f1024 |
