0014311 | ParaView | (No Category) | public | 2013-09-27 12:28 | 2016-02-11 22:18 | ||||
Assigned To | Alan Scott | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0014311: Text edit boxes in property inspector sometimes stop working | ||||||||
Description | I have found that on some occasions the text edit boxes in the property inspector stop working in that you cannot type anything in them. I can replicate this problem by manipulating the view. These operations seem to replicate the problem: 1. Create a sphere source. 2. Delete the view (x box in the upper right corner). The view area should be blank with the set of create view buttons. 3. Click the eye next to the sphere in the Pipeline Browser. A default 3D view will be created and the sphere shown. 4. Attempt to change the radius of the sphere. You will not be able to. Note that I have only tried this on Mac OS. I don't know if you get the same problem on other systems. | ||||||||
Project | Sandia | ||||||||
(0031880) Utkarsh Ayachit (administrator) 2013-11-26 13:57 |
Verified that this works on Linux. Need to try on Mac. People have been reporting similar issues on mailing list with Mac. Need to track it down. |
(0031956) Utkarsh Ayachit (administrator) 2013-12-16 15:59 |
Could definitely reproduce this on OsX 10.9. Looking into it. |
(0035723) Alan Scott (manager) 2016-02-11 22:18 |
Tested on my Mac. Used 5.0.0, local server. This now works correctly. Closing bug. |
2013-09-27 12:28 | Ken Moreland | New Issue | |
2013-11-26 13:57 | Utkarsh Ayachit | Note Added: 0031880 | |
2013-11-26 13:57 | Utkarsh Ayachit | Project | TBD => Sandia |
2013-11-26 13:57 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-11-26 13:57 | Utkarsh Ayachit | Priority | normal => high |
2013-11-26 13:57 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-12-16 15:59 | Utkarsh Ayachit | Note Added: 0031956 | |
2014-02-07 21:47 | Utkarsh Ayachit | Target Version | 4.1 => 4.2 |
2014-11-14 22:52 | Utkarsh Ayachit | Target Version | 4.2 => 4.4 |
2015-07-08 16:36 | Utkarsh Ayachit | Status | backlog => todo |
2015-07-09 16:34 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => |
2015-09-11 16:43 | Utkarsh Ayachit | Target Version | 4.4 => 5.1 |
2016-02-11 22:18 | Alan Scott | Note Added: 0035723 | |
2016-02-11 22:18 | Alan Scott | Status | todo => closed |
2016-02-11 22:18 | Alan Scott | Assigned To | => Alan Scott |
2016-02-11 22:18 | Alan Scott | Resolution | open => fixed |
