0014352 | ParaView | (No Category) | public | 2013-10-23 07:59 | 2014-04-08 20:49 | ||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014352: Find Data dialog not showing selection label properties correctly | ||||||||
Description | To reproduce try this: + Restart ParaView + Create Sphere, Apply + Do a surface selection to select a few cells + Edit | Find Data + Click on the "gear" button under the "Selection Display Properties" label. You'll see the properties for the selection as expected. Now do the following: + Restart ParaView + Edit | Find Data *<-- this is essential + Create Sphere, Apply + Do a surface selection to select a few cells + Click on the "gear" button under the "Selection Display Properties" label. You'll no longer see the properties for font etc.! | ||||||||
Project | Sandia | ||||||||
Topic Name | fix_find_data_dialog | ||||||||
(0031767) Utkarsh Ayachit (administrator) 2013-10-29 11:48 |
commit a1bf4a7e9e25748cbe865ee4fb47baa9051ba874 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 23 10:29:47 2013 -0400 Refactor find-data dialog. This commit refactors find data dialog to resolve several bugs as well as similify the code. Now pqFindDataDialog relies on using separate classes for each of the different components in the dialog making is easier to manage responsibilities between the various components. Also resolves BUG 0014317 and BUG 0014285. This removes obsolete classes like pqSelectionInspectorPanel, pqQueryDialog and their UI files as well. Additionally, this commit fixes pqProxyWidgetDialog to use a container to avoid proxy widgets not being spaced correctly. Change-Id: Id51c9f9eceed314f2e9d9823e0523cc1d6037c06 |
(0031768) Utkarsh Ayachit (administrator) 2013-10-29 11:49 |
Note the dialog has changed slightly. Earlier, the gear would "unfold" to show more properties, now it pops up a modal dialog. |
(0031777) Utkarsh Ayachit (administrator) 2013-10-30 09:57 |
SUMMARY --------------------------------------------- Topics merged into master: fix_find_data_dialog fix_visitbridge_dependency (VTK) pvweb-update-file-loader-app pvw-ipython-module (VTK) update_vtk_master |
(0032564) Alan Scott (manager) 2014-04-08 20:49 |
Tested master, Linux, local server. |
2013-10-23 07:59 | Utkarsh Ayachit | New Issue | |
2013-10-23 07:59 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-10-29 11:48 | Utkarsh Ayachit | Topic Name | => fix_find_data_dialog |
2013-10-29 11:48 | Utkarsh Ayachit | Note Added: 0031767 | |
2013-10-29 11:48 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-10-29 11:48 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-10-29 11:48 | Utkarsh Ayachit | Resolution | open => fixed |
2013-10-29 11:48 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-10-29 11:49 | Utkarsh Ayachit | Note Added: 0031768 | |
2013-10-30 09:56 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-10-30 09:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-10-30 09:57 | Utkarsh Ayachit | Note Added: 0031777 | |
2013-11-01 13:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2014-04-08 20:49 | Alan Scott | Note Added: 0032564 | |
2014-04-08 20:49 | Alan Scott | Status | customer review => closed |
