0014353 | ParaView | (No Category) | public | 2013-10-23 09:57 | 2016-08-12 09:59 | ||||
Reporter | Dominik Szczerba | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014353: Problems reading 2nd order mixed meshes in xdmf format | ||||||||
Description | <?xml version="1.0" ?> <Xdmf> <Domain Name="Unnamed"> <Grid Name="Mesh"> <Geometry GeometryType="XYZ"> <DataItem Format="XML" Dimensions="10 3"> 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.0 0.0 0.0 1.0 0.5 0.0 0.0 0.5 0.5 0.0 0.0 0.5 0.0 0.0 0.0 0.5 0.5 0.0 0.5 0.0 0.5 0.5 </DataItem> </Geometry> The following valid XDMF file causes an error when imported into ParaView 4.0.1: <Topology TopologyType="Mixed" NumberOfElements="1" > <DataItem Format="XML" DataType="Int" Dimensions="11"> 26 0 1 2 3 4 5 6 7 8 9 </DataItem> </Topology> </Grid> </Domain> </Xdmf> | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0031741) Dominik Szczerba (reporter) 2013-10-25 08:13 |
I wonder if this has something to do with the fact, that VTK does not offer support for 2nd order prisms and pyramids...? |
(0038452) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-10-23 09:57 | Dominik Szczerba | New Issue | |
2013-10-25 08:13 | Dominik Szczerba | Note Added: 0031741 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038452 | |
