0014422 | ParaView | (No Category) | public | 2013-11-25 11:58 | 2016-08-12 09:59 | ||||
Reporter | Ben Spencer | ||||||||
Summary | 0014422: Add option to label points by coordinates | ||||||||
Description | Points and cells can be labeled by the values of variables. The variable to use for labeling is selected in the Selection Inspector (or Selection Display Inspector in 4.1). It would also be very helpful to have an option to label points by their x, y, z coordinates. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0038471) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-11-25 11:58 | Ben Spencer | New Issue | |
2013-11-26 13:37 | Utkarsh Ayachit | Assigned To | => Dan Lipsa |
2013-12-19 10:30 | Dan Lipsa | Status | backlog => active development |
2014-09-10 08:12 | Dan Lipsa | Status | active development => todo |
2014-12-02 16:14 | Dan Lipsa | Status | todo => backlog |
2015-01-30 16:11 | Dan Lipsa | Assigned To | Dan Lipsa => |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038471 | |
