0014430 | ParaView | (No Category) | public | 2013-11-27 13:59 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Assigned To | Andy Bauer | ||||||||
Summary | 0014430: time steps not right for reading a series of vtm files | ||||||||
Description | The time steps for reading a series of vtm files with each vtm file being time independent is wrong. The steps to reproduce are: 1) Create a multiblock data set (I created a wavelet and a line source and then combined them with the group datasets filter) 2) Write this multiblock to several files like (tmp1.vtk, tmp2.vtm, tmp3.vtm,...) 3) Load these files in as a file series 4) Select a point and then do a plot selection over time -- the time in the plot will show only time 0. Note that the information tab shows the expected time steps. Note that steps 1 and 2 can be skipped by using the data sets that I attached. | ||||||||
Project | TBD | ||||||||
Attached Files | mulitblock.tgz [^] (36,651 bytes) 2013-11-27 13:59 | ||||||||
(0038475) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-11-27 13:59 | Andy Bauer | New Issue | |
2013-11-27 13:59 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2013-11-27 13:59 | Andy Bauer | File Added: mulitblock.tgz | |
2013-11-27 16:27 | Andy Bauer | Assigned To | Utkarsh Ayachit => Andy Bauer |
2013-11-27 16:27 | Andy Bauer | Status | backlog => todo |
2013-11-27 16:45 | Andy Bauer | Status | todo => active development |
2014-01-29 10:51 | Andy Bauer | Status | active development => todo |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038475 | |
2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
