| 0014450 | ParaView | (No Category) | public | 2013-12-09 10:38 | 2016-08-12 09:59 | ||||
| Assigned To | Kitware Robot | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Summary | 0014450: Preserve Topology on ExtractSelection removes data arrays | ||||||||
| Description | + Open attached file + apply + Select 1 cell + Apply "Extract Selection" filter. + Now check "Preserve Topology" on the properties panel -- you'll get the following warning: Warning: In /home/utkarsh/Kitware/ParaView3/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMPVRepresentationProxy.cxx, line 279 vtkSMPVRepresentationProxy (0x5b2e660): Could not determine array range. Bugs: + ParaView should not produce this warning. If it needs to, it must be more user friendly. It's complaining since the "color" array that it was coloring with was removed by the filter. + ExtractSelection should not remove data array when Preserve Topology is checked. | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0038480) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2013-12-09 10:38 | Utkarsh Ayachit | New Issue | |
| 2013-12-09 10:38 | Utkarsh Ayachit | File Added: foo.vtk | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038480 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
