| 0014581 | ParaView | (No Category) | public | 2014-02-17 15:50 | 2015-01-11 08:18 | ||||
| Assigned To | David C. Lonie | ||||||||
| Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 4.1 | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014581: Volume rendering is bad remote rendering | ||||||||
| Description | 4.1.0, Linux, remote server (8 servers). Edit/ Settings/ RenderView /Server/ Remote Render Threshold set to 0. Open disk_out_ref.exo. All vars on. Apply. Paint by Pres. Volume render. Bug is very, very obvious. Only 8 cells will appear. To see what it should look like, try local server, or run ParaView 4.0.1. In the Output Messages, we get the following: ERROR: In ..../VTK/Rendering/VolumeOpenGL/vtkOpenGLProjectedTetrahedraMapper.cxx, line 183 vtkOpenGLProjectedTetrahedraMapper (0x128982c0): The required extensions are not supported. ERROR: In ..../VTK/Rendering/VolumeOpenGL/vtkOpenGLProjectedTetrahedraMapper.cxx, line 268 vtkOpenGLProjectedTetrahedraMapper (0x128982c0): failed at glRenderBufferStorage color 1 OpenGL errors detected 0 : (1280) Invalid enum i Warning: In ..../VTK/Rendering/VolumeOpenGL/vtkOpenGLProjectedTetrahedraMapper.cxx, line 309 vtkOpenGLProjectedTetrahedraMapper (0x128982c0): Missing FBO support. The algorithm may produce visual artifacts. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14581-volume-render-bug | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032343) Alan Scott (manager) 2014-02-17 15:52 |
After writing up this bug, everything crashed. Not sure how replicable the crash is. |
(0032413) David C. Lonie (developer) 2014-02-26 09:32 |
There was a bug in the box clip filter I introduced with the insitu changes. It was causing the first unclipped cell to be copied into the filter's output repeatedly. VTK fix pushed here: http://review.source.kitware.com/#/t/4012 [^] |
(0032420) Utkarsh Ayachit (administrator) 2014-02-27 11:28 |
351af40 (stage/14581-volume-render-bug) Update VTK to fix 0014581. |
(0032422) Utkarsh Ayachit (administrator) 2014-02-27 11:29 |
Topics merged into master: 14557-color-legend-update (VTK) 14581-volume-render-bug 14584-frequency-live-view 14600-restore-numpy 14602_fix_text_representation fix_mili |
(0032516) Alan Scott (manager) 2014-03-20 21:49 |
I am pretty sure this is fixed. Close when bug 14615 is closed. |
(0032568) Alan Scott (manager) 2014-04-08 21:34 |
Tested master, remote server, Linux. |
(0034057) David C. Lonie (developer) 2015-01-11 08:18 |
Fix committed to master branch. |
| Notes |
| Issue History | |||
| 2014-02-17 15:50 | Alan Scott | New Issue | |
| 2014-02-17 15:52 | Alan Scott | Note Added: 0032343 | |
| 2014-02-19 14:13 | Utkarsh Ayachit | Assigned To | => David C. Lonie |
| 2014-02-19 14:13 | Utkarsh Ayachit | Status | backlog => todo |
| 2014-02-26 09:32 | David C. Lonie | Note Added: 0032413 | |
| 2014-02-27 10:23 | Utkarsh Ayachit | Status | todo => active development |
| 2014-02-27 11:28 | Utkarsh Ayachit | Topic Name | => 14581-volume-render-bug |
| 2014-02-27 11:28 | Utkarsh Ayachit | Note Added: 0032420 | |
| 2014-02-27 11:28 | Utkarsh Ayachit | Status | active development => gatekeeper review |
| 2014-02-27 11:28 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2014-02-27 11:28 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-02-27 11:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-02-27 11:29 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-02-27 11:29 | Utkarsh Ayachit | Note Added: 0032422 | |
| 2014-03-20 21:49 | Alan Scott | Relationship added | related to 0014615 |
| 2014-03-20 21:49 | Alan Scott | Note Added: 0032516 | |
| 2014-04-08 21:34 | Alan Scott | Note Added: 0032568 | |
| 2014-04-08 21:34 | Alan Scott | Status | customer review => closed |
| 2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| 2015-01-11 08:18 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master c31f9ddf |
| 2015-01-11 08:18 | David C. Lonie | Source_changeset_attached | => ParaView master 351af405 |
| 2015-01-11 08:18 | David C. Lonie | Note Added: 0034057 | |
| Issue History |
