| 0014602 | ParaView | (No Category) | public | 2014-02-26 04:38 | 2015-01-11 08:18 | ||||
| Reporter | grenon | ||||||||
| Product Version | 4.1 | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014602: Text position is not saved in state file | ||||||||
| Description | Text appears at lower left corner when loading state file. Duplicate of issues 8789 and 10521 that should be fixed in version 3.12. | ||||||||
| Project | TBD | ||||||||
| Topic Name | 14602_fix_text_representation | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032414) Utkarsh Ayachit (administrator) 2014-02-26 10:53 |
commit 07694987a93a0a5e1630f5db3987f33d2b1bca69 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Feb 26 10:49:46 2014 -0500 BUG 0014602. Fixed text position not being saved in state files. The bug was stemming from the fact the the property links set up in vtkSMNewWidgetRepresentationProxy between the in/out properties was getting destroyed prematurely due to incorrect logic to track reference counting. The reference count tracking logic is indeed fragile. Instead, changed vtkSMPropertyLink to not use vtkSmartPointer, instead use vtkWeakPointer. Then vtkSMNewWidgetRepresentationProxy no longer needs to do anything special to avoid leaks. With the link working again, state file correctly saves the values for Position1 and Position2, thus overcoming the bug. Change-Id: Icdeb9dbacd13d9c4f8fc48663624533b7f624b67 |
(0032425) Utkarsh Ayachit (administrator) 2014-02-27 11:29 |
Topics merged into master: 14557-color-legend-update (VTK) 14581-volume-render-bug 14584-frequency-live-view 14600-restore-numpy 14602_fix_text_representation fix_mili |
(0032515) Alan Scott (manager) 2014-03-20 21:47 |
Perfect. Tested with mouse, and "Use Window Location". Tested Linux, master, remote server. |
| Notes |
| Issue History | |||
| 2014-02-26 04:38 | grenon | New Issue | |
| 2014-02-26 10:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2014-02-26 10:43 | Utkarsh Ayachit | Status | backlog => active development |
| 2014-02-26 10:53 | Utkarsh Ayachit | Topic Name | => 14602_fix_text_representation |
| 2014-02-26 10:53 | Utkarsh Ayachit | Note Added: 0032414 | |
| 2014-02-26 10:53 | Utkarsh Ayachit | Status | active development => gatekeeper review |
| 2014-02-26 10:53 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2014-02-26 10:53 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-02-27 11:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-02-27 11:29 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-02-27 11:29 | Utkarsh Ayachit | Note Added: 0032425 | |
| 2014-03-09 16:28 | Utkarsh Ayachit | Relationship added | has duplicate 0014623 |
| 2014-03-20 21:47 | Alan Scott | Note Added: 0032515 | |
| 2014-03-20 21:47 | Alan Scott | Status | customer review => closed |
| 2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| 2015-01-11 08:18 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 12119d1e |
| 2015-01-11 08:18 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master f946c5a0 |
| Issue History |
