0014653 | ParaView | (No Category) | public | 2014-03-27 19:13 | 2015-06-04 17:29 | ||||
Target Version | 4.4 | Fixed in Version | |||||||
Summary | 0014653: Cube axis numbers overwrite themselves | ||||||||
Description | For an object that is a somewhat strange shape, it is easy to have the numbers on the cube axis overwrite themselves. This needs to be fixed. One way to replicate is: ParaView Linux, local server, master. Sources/ Cube. Apply. Advanced properties tab. Transforming. Scale. 0.01, 0.1, 0.02 Cube Axis. Edit. For each axis, Original Bounds as Range. OK. +Y. Now the bottom axis (the X axis) is on top of itself. I know that zooming in fixes the issue, but my user's example doesn't. | ||||||||
Project | Sandia | ||||||||
(0032536) Alan Scott (manager) 2014-03-27 19:27 |
Marking as todo, since I have a user that is being impacted by this bug. |
(0034353) Utkarsh Ayachit (administrator) 2015-04-09 21:22 edited on: 2015-04-30 09:01 |
The new Axes Grid (http://www.kitware.com/blog/home/post/871 [^]) handles label placement better than the Cube Axes. The Axes Grid is designed as a replacement for the Cube Axes. Hence, marking this resolved. To use the Axes Grid, use the "Show Axes Grid" button on the Properties panel, under the "View" section. It shows up on for Render Views. |
(0034480) Alan Scott (manager) 2015-06-04 17:29 |
Agreed. This bug has been deprecated by the new Axes Grid. |
2014-03-27 19:13 | Alan Scott | New Issue | |
2014-03-27 19:27 | Alan Scott | Note Added: 0032536 | |
2014-03-27 19:27 | Alan Scott | Assigned To | => Alan Scott |
2014-03-27 19:27 | Alan Scott | Status | backlog => todo |
2014-03-28 15:56 | Alan Scott | Assigned To | Alan Scott => |
2014-12-08 22:16 | Alan Scott | Target Version | => 4.4 |
2015-04-09 21:22 | Utkarsh Ayachit | Note Added: 0034353 | |
2015-04-09 21:22 | Utkarsh Ayachit | Status | todo => customer review |
2015-04-09 21:22 | Utkarsh Ayachit | Resolution | open => fixed |
2015-04-09 21:22 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-04-30 09:00 | Utkarsh Ayachit | Note Edited: 0034353 | |
2015-04-30 09:01 | Utkarsh Ayachit | Note Edited: 0034353 | |
2015-06-04 17:29 | Alan Scott | Note Added: 0034480 | |
2015-06-04 17:29 | Alan Scott | Status | customer review => closed |
