| 0014682 | ParaView | (No Category) | public | 2014-04-10 08:37 | 2016-08-12 09:59 | ||||
| Reporter | Alexey Gurin | ||||||||
| Assigned To | Kitware Robot | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 4.1 | ||||||||
| Summary | 0014682: Incorrect fetching of rectilinear grid object | ||||||||
| Description | Error occurs when I try to get point coordinates with function GetPoint() from vtkRectilinearGrid object. vtkRectilinearGrid object obtained by servermanager.Fetch() function contains incorrect coordinate data - X, X, X instead of X, Y, Z. Uploaded test case. Open file "data.vtk" provided, make "data.vtk" source active and execute script "script.py". Expected output: (0.0,2.0,4.0) Output received: (0.0,0.0,0.0) Error is in the vtkAppendRectilinearGrid::RequestData function in vtkAppendRectilinearGrid.cxx file. Line 188: input->GetXCoordinates(), inputExtent); Should be: input->GetYCoordinates(), inputExtent); Line 190: input->GetXCoordinates(), inputExtent); Should be: input->GetZCoordinates(), inputExtent); | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0038559) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2014-04-10 08:37 | Alexey Gurin | New Issue | |
| 2014-04-10 08:37 | Alexey Gurin | File Added: TestCase.zip | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038559 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
