0014718 | ParaView | (No Category) | public | 2014-05-05 15:47 | 2016-08-12 09:59 | ||||
Summary | 0014718: Pause in animation track | ||||||||
Description | I have a user that would like to use create an animation track, interpolate between camera locations. He would like to have a pause function. Otherwise, if you have two views that are the same, don't move the camera as the animation inspector moves between the two, same views. For instance, if he wants to look at the front of a car, then look at the back of the car, he would start looking at the front of the car, pause for numerous seconds, fly around the car to the back, then pause for numerous seconds. Currently, the only way to do this is to create numerous views in the track that are the same point - and the camera moves as the track runs from a view to the same view. | ||||||||
Tags | Animation | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0038570) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-05-05 15:47 | Alan Scott | New Issue | |
2014-06-09 07:20 | Utkarsh Ayachit | Tag Attached: Animation | |
2016-03-09 13:29 | Alan Scott | Relationship added | related to 0016022 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038570 | |
