0014734 | ParaView | (No Category) | public | 2014-05-16 08:39 | 2014-08-29 11:00 | ||||
Assigned To | johan andruejol | ||||||||
Summary | 0014734: Automatically pick a good default size of pqProxyWidgetDialog | ||||||||
Description | pqProxyWidgetDialog is used to automatically create dialogs for pqProxyWidget -- which is a autogenerated widget for a vtkSMProxy. We use pqProxyWidgetDialog in several locations e.g 1. "Edit Color Legend Properties" dialog + Start ParaView + Create "Wavelet" from "Sources" menu, hit "Apply" + Click "Edit Color Map" from the toolbar and then click the "Edit color legend properties" button (http://www.kitware.com/blog/home/post/578 [^]) + This dialog will popup 2. "Configure Writer" dialog + Start ParaView + Create "Wavelet" from "Sources" menu, hit "Apply" + File | Save Data --- save as foo.vtk + Configure Writer dialog will popup. Dialog (1) is too short. We could easily make it longer, to avoid scroll bars, which would make it easier to use. However, doing that makes dialog (2) unnecessarily longer. The goal of this task is to fix pqProxyWidgetDialog to try to show the dialog with "optimal" length between a fixed minimum and maximum size based on the contents of the dialog. "Optimal" length is the minimum length needed to now show the vertical scroll bar. Of course, if optimal length is too small or too big, we will clamp it to a predermined min/max value. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14734-GoodDefaultSizeForpqProxyWidgetDialog | ||||||||
(0032660) Cory Quammen (developer) 2014-05-23 16:16 |
Looks good. Now merge into the next branch with git stage-push git stage-merge |
(0032672) Utkarsh Ayachit (administrator) 2014-05-28 09:43 |
Johan, mind updating the "Topic Name" to refer to the branch name used when pushing to stage? I typically also point to the gerrit topic or the commit log in the "note" field to make it easier to track the commit from the bug. |
(0032673) johan andruejol (developer) 2014-05-28 09:47 |
Gerrit topic for reference: http://review.source.kitware.com/#/c/15499/ [^] |
(0032678) johan andruejol (developer) 2014-05-29 11:21 |
See commit: c0aa71f454c49751b11171aa339af7da20cb8cf7 |
(0032694) Utkarsh Ayachit (administrator) 2014-05-30 08:14 |
SUMMARY --------------------------------------------- Topics merged into master: 14679_color_legend_bugs 14734-GoodDefaultSizeForpqProxyWidgetDialog cleanup-cmake fix_assembly_render_view fix_fragment_large_scale fix_plugin_loading_order fix_qt_modules remove-unused-directory --------------------------------------------- Topics reverted from next: 14673_fix_follow_data |
(0032722) Alan Scott (manager) 2014-06-03 20:24 |
Tested master, Linux, remote server. |
2014-05-16 08:39 | Utkarsh Ayachit | New Issue | |
2014-05-16 10:10 | Utkarsh Ayachit | Assigned To | => johan andruejol |
2014-05-20 10:33 | johan andruejol | Status | backlog => active development |
2014-05-23 16:16 | Cory Quammen | Note Added: 0032660 | |
2014-05-28 09:41 | johan andruejol | Status | active development => gatekeeper review |
2014-05-28 09:41 | johan andruejol | Resolution | open => fixed |
2014-05-28 09:43 | Utkarsh Ayachit | Note Added: 0032672 | |
2014-05-28 09:44 | johan andruejol | Status | gatekeeper review => active development |
2014-05-28 09:47 | johan andruejol | Topic Name | => 14734-GoodDefaultSizeForpqProxyWidgetDialog |
2014-05-28 09:47 | johan andruejol | Note Added: 0032673 | |
2014-05-28 09:47 | johan andruejol | Status | active development => gatekeeper review |
2014-05-28 09:47 | johan andruejol | Fixed in Version | => git-next |
2014-05-29 11:20 | johan andruejol | Status | gatekeeper review => active development |
2014-05-29 11:21 | johan andruejol | Note Added: 0032678 | |
2014-05-29 11:21 | johan andruejol | Status | active development => gatekeeper review |
2014-05-30 08:13 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-05-30 08:14 | Utkarsh Ayachit | Note Added: 0032694 | |
2014-05-30 08:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-03 20:24 | Alan Scott | Note Added: 0032722 | |
2014-06-03 20:24 | Alan Scott | Status | customer review => closed |
2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
