0014749 | ParaView | (No Category) | public | 2014-05-21 15:24 | 2016-08-12 09:59 | ||||
Summary | 0014749: Suggestions for improvement of point/cell display labels | ||||||||
Description | We need to add a "are you sure?" warning when users try to select a large number of cells and/or points, and the display labels is turned on. This causes crashes. We also need to give the user the option to depopulate the cells and points that have display labels turned on - with say 100 as a maximum. Maximum to be user selectable. Use same random method as used by the glyph filter for huge numbers of points or vectors. Marking high, since this leads to crashes. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0038574) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-05-21 15:24 | Alan Scott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038574 | |
