0014766 | ParaView | (No Category) | public | 2014-05-30 22:00 | 2014-06-03 19:55 | ||||
Assigned To | Nathan Fabian | ||||||||
Summary | 0014766: CTH Tracer cleanup | ||||||||
Description | CTH tracers still have some cleanup. * An error message appears in parallel, remote server. Tracers need to work in parallel, and the error message needs to be removed. * Only open up one 3d window, tracers on? If a user uses tracers, and wants tracers, she will know they exist. Otherwise, if only tracers are found, open a second window, 3d. Currently, a 2d window is opened for markers, and yet another for tracers. | ||||||||
Project | Sandia | ||||||||
(0032716) Nathan Fabian (developer) 2014-06-03 17:48 |
So far in testing tracers in parallel I can find neither the multiple windows (only uses the one 3d window I have open) and can't reproduce error messages. Tracers look to be the same as single process. I may need a different test file. |
(0032717) Alan Scott (manager) 2014-06-03 19:55 |
This was caused by a bad .config/ParaView/*.ini file. Deleted it, and now things are fine. Closing. |
2014-05-30 22:00 | Alan Scott | New Issue | |
2014-05-30 22:00 | Alan Scott | Assigned To | => Nathan Fabian |
2014-06-03 17:48 | Nathan Fabian | Note Added: 0032716 | |
2014-06-03 19:55 | Alan Scott | Note Added: 0032717 | |
2014-06-03 19:55 | Alan Scott | Status | backlog => closed |
2014-06-03 19:55 | Alan Scott | Resolution | open => fixed |
