0014792 | ParaView | (No Category) | public | 2014-06-09 16:20 | 2014-08-29 10:59 | ||||
Summary | 0014792: In client-server mode, image volume rendering using incorrect size when determining whether to use remote rendering. | ||||||||
Description | + Start ParaView in client-server mode (single process pvserver is fine). + Set the remote rendering threshold to 2 MB + Create a wavelet with whole extent (-10, 100, -10, 100, -10, 100). This has size > 2 MB. + Now, switch representation type to "Volume". ==> One would expect to see the volume with "Remote Rendering" kicking in. It doesn't. Switch the threshold to 0 MB, and remote rendering works as expected. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14792_fix_remote_volume_rendering | ||||||||
Relationships | ||||||
(0032809) Utkarsh Ayachit (administrator) 2014-06-09 16:22 |
Problem is stemming from the fact that vtkImageVolumeRepresentation hands over a data outline to vtkPVDataDeliveryManager for delivery. vtkPVDataDeliveryManager is simply using the size of that geometry to make remote-rendering decisions. That's incorrect. It should use the original data size. |
(0032821) Utkarsh Ayachit (administrator) 2014-06-10 14:32 |
commit 4a1d88c54ea42849fde114c6d899f2699990539d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Jun 9 16:24:50 2014 -0400 BUG 0014729: Fix remote rendering when rendering image volumes. vtkPVDataDeliveryManager was using incorrect geometry size for vtkImageVolumeRepresentation. vtkImageVolumeRepresentation needed to report the true data size to vtkPVDataDeliveryManager for it make the correct decision. This commit fixes that by adding an API to vtkPVDataDeliveryManager to pass in a "true-data-size" when passing dataset to deliver. Change-Id: Iff1bc45e18f35b1bf1c57739b23daa7441c5ecd8 |
(0032823) Utkarsh Ayachit (administrator) 2014-06-10 14:34 |
Note you can't test this fix until BUG 0014794 is fixed. |
(0032852) Utkarsh Ayachit (administrator) 2014-06-12 08:59 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 14244_fix_stereo_image_captures 14696_min_max_labels 14760_fix_settings_saving 14792_fix_remote_volume_rendering fix_some_warnings static-plugins-in-servers |
(0032975) Alan Scott (manager) 2014-07-07 17:51 |
Tested master, remote server, Linux. |
2014-06-09 16:20 | Utkarsh Ayachit | New Issue | |
2014-06-09 16:21 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-06-09 16:21 | Utkarsh Ayachit | Status | backlog => active development |
2014-06-09 16:22 | Utkarsh Ayachit | Note Added: 0032809 | |
2014-06-09 16:28 | Utkarsh Ayachit | Note Added: 0032810 | |
2014-06-09 16:29 | Utkarsh Ayachit | Topic Name | => 14792_fix_remote_volume_rendering |
2014-06-09 16:30 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-06-10 14:32 | Utkarsh Ayachit | Note Deleted: 0032810 | |
2014-06-10 14:32 | Utkarsh Ayachit | Note Added: 0032821 | |
2014-06-10 14:32 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2014-06-10 14:32 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-06-10 14:32 | Utkarsh Ayachit | Resolution | open => fixed |
2014-06-10 14:33 | Utkarsh Ayachit | Relationship added | child of 0014794 |
2014-06-10 14:34 | Utkarsh Ayachit | Note Added: 0032823 | |
2014-06-12 08:59 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-06-12 08:59 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-06-12 08:59 | Utkarsh Ayachit | Note Added: 0032852 | |
2014-07-07 17:51 | Alan Scott | Note Added: 0032975 | |
2014-07-07 17:51 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
