0014795 | ParaView | (No Category) | public | 2014-06-11 16:12 | 2014-08-29 11:00 | ||||
Reporter | johan andruejol | ||||||||
Summary | 0014795: Compilation issue in vtkXMLPDataWriterClientServer.cxx | ||||||||
Description | The compilation errors: >.\vtkXMLPDataWriterClientServer.cxx(180) : error C2065: 'vtkMultiProcessController' : undeclared identifier 2>.\vtkXMLPDataWriterClientServer.cxx(180) : error C2065: 'temp0' : undeclared identifier 2>.\vtkXMLPDataWriterClientServer.cxx(181) : error C2065: 'temp0' : undeclared identifier 2>.\vtkXMLPDataWriterClientServer.cxx(183) : error C2039: 'SetController' : is not a member of 'vtkXMLPDataWriter' 2> W:\Paraview\ParaView\VTK\IO\XML\vtkXMLPDataWriter.h(30) : see declaration of 'vtkXMLPDataWriter' 2>.\vtkXMLPDataWriterClientServer.cxx(183) : error C2065: 'temp0' : undeclared identifier 2>.\vtkXMLPDataWriterClientServer.cxx(189) : error C2065: 'vtkMultiProcessController' : undeclared identifier 2>.\vtkXMLPDataWriterClientServer.cxx(189) : error C2065: 'temp20' : undeclared identifier 2>.\vtkXMLPDataWriterClientServer.cxx(191) : error C2065: 'temp20' : undeclared identifier 2>.\vtkXMLPDataWriterClientServer.cxx(191) : error C2039: 'GetController' : is not a member of 'vtkXMLPDataWriter' 2> W:\Paraview\ParaView\VTK\IO\XML\vtkXMLPDataWriter.h(30) : see declaration of 'vtkXMLPDataWriter' 2>.\vtkXMLPDataWriterClientServer.cxx(193) : error C2065: 'temp20' : undeclared identifier I use a workaround for now by commenting the lines 178 to 196. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0032855) Utkarsh Ayachit (administrator) 2014-06-12 10:59 |
this may have been a user/system error. It works as expected now. |
2014-06-11 16:12 | johan andruejol | New Issue | |
2014-06-12 10:59 | Utkarsh Ayachit | Note Added: 0032855 | |
2014-06-12 10:59 | Utkarsh Ayachit | Status | backlog => closed |
2014-06-12 10:59 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-06-12 10:59 | Utkarsh Ayachit | Resolution | open => no change required |
2014-06-12 10:59 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
