0014807 | ParaView | (No Category) | public | 2014-06-17 18:00 | 2014-06-26 18:42 | ||||
Reporter | Scott Wittenburg | ||||||||
Assigned To | Scott Wittenburg | ||||||||
Summary | 0014807: ParaViewWeb should use server manager color abstractions | ||||||||
Description | ParaViewWeb has been using a stop-gap approach to color management with the LookupTableManager defined in helper.py. Recent changes to ParaView move color management functionality out of the Qt layer and into server manager, where it is now accessible from the Python layer. ParaViewWeb protocols need to be updated and refactored to take advantage of these changes and remove the need for the helper LookupTableManager. | ||||||||
Project | TBD | ||||||||
Topic Name | pvweb-fix-lookup-table-usage | ||||||||
(0032910) Sebastien Jourdain (manager) 2014-06-24 17:50 |
SUMMARY --------------------------------------------- Topics merged into master: 13575_default_for_offscreen_rendering 14705_hide_time_marker 14806_fix_protobuf add_pythonalgorithm_dependency fix-msvc-iterator-warning fix_install_rules_visitbridge fix_lic_on_structured_grids fixing_markers_crashes (VTK) pvweb-fix-lookup-table-usage (VTK) pvweb-replace-missing-server-import pvweb-update-install-guides remove-dead-smsettings-code safer-catalyze pvweb-update-WAMPv2 --------------------------------------------- Topics reverted from next: 14788-pqTextEdit 14790_save_restore_settings_buttons pvweb-update-to-WAMP-v2 stage-push-data |
(0032923) Alan Scott (manager) 2014-06-26 18:42 |
Developer tag in git. Closing. |
2014-06-17 18:00 | Scott Wittenburg | New Issue | |
2014-06-17 18:00 | Scott Wittenburg | Assigned To | => Scott Wittenburg |
2014-06-18 17:03 | Scott Wittenburg | Topic Name | => pvweb-fix-lookup-table-usage |
2014-06-18 17:03 | Scott Wittenburg | Status | backlog => gatekeeper review |
2014-06-18 17:03 | Scott Wittenburg | Resolution | open => fixed |
2014-06-24 17:50 | Sebastien Jourdain | Status | gatekeeper review => customer review |
2014-06-24 17:50 | Sebastien Jourdain | Note Added: 0032910 | |
2014-06-26 18:42 | Alan Scott | Note Added: 0032923 | |
2014-06-26 18:42 | Alan Scott | Status | customer review => closed |
