0014812 | ParaView | (No Category) | public | 2014-06-19 15:36 | 2016-08-12 09:59 | ||||
Summary | 0014812: Find data doesn't update variables | ||||||||
Description | Find data doeesn't update the point variables drop down list automatically when new variables are added. Here is how to replicate: * Master, Linux, local server. * Open can.exo. All vars on. Turn off VEL. Apply. * Find Data. Find Points. Open the menu that says Global ID. As expected, VEL is missing. Close Find Data. * In the Properties tab, select and load VEL. Apply. * Find data. (Find points will remain selected.) Click on Global ID, and scroll down. VEL is missing. * Workaround. Change Find to Find Cells. Change back to Find Points. Now, VEL is present. | ||||||||
Project | Sandia | ||||||||
(0038584) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-06-19 15:36 | Alan Scott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038584 | |
