0014834 | ParaView | (No Category) | public | 2014-06-30 16:39 | 2015-01-11 08:16 | ||||
Reporter | Burlen | ||||||||
Product Version | 4.2 | ||||||||
Target Version | Fixed in Version | 4.2 | |||||||
Summary | 0014834: info not updated after visibility change | ||||||||
Description | after loading state where a filter is invisible, making the filter visible causes the filter to render itself correctly however client side info (information panel) is not updated. This can cause some filters to be disabled incorrectly. Probably other weirdness as well. see also mail list thread http://public.kitware.com/pipermail/paraview/2014-June/031527.html [^] steps to reproduce: 1. start client 2. create plane and sphere w/ defaults 3. make sphere invisible 4. save state 5. delete all 6. load state 7. make sphere visible 8. look at information panel. | ||||||||
Project | TBD | ||||||||
Topic Name | 14834_fix_representation_update | ||||||||
Relationships | ||||||
(0033047) Utkarsh Ayachit (administrator) 2014-07-21 15:09 |
commit 94fdffe40fd1024fd9415bfee5896444f0a70252 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Jul 21 15:04:11 2014 -0400 BUG 0014834: Fix representation update logic. vtkSMRepresentationProxy tried to take extra precations when calling vtkSMProxy::PostUpdateData() to ensure that the method wasn't called unless the VTK-side representation truly updated. If the VTKRepresentation didn't update, the upstream pipeline may not be updated and hence telling the input proxies that they have been updated would be incorrect. However it missed a case when loading state files. When loading state files, the this->MarkedModified is false by default. Thus the first time PostUpdateData() was called, it always assumed the VTKRepresentation had updated since we used the same flag. Fixed that by adding a new flag VTKRepresentationUpdated to indicate that the VTK representation has updated. This address the bug. Change-Id: I8a74d1734e0cec6a0f17690551e9a01761791fa4 |
(0033060) Utkarsh Ayachit (administrator) 2014-07-22 08:32 |
--------------------------------------------- Topics merged into master: 0014874_fix_scalar_opacity_unit_distance 14834_fix_representation_update dashboard-warnings-20140721 refactor_python_tracing_2 |
(0033083) Alan Scott (manager) 2014-07-24 21:11 |
Although the bug itself is fixed, there is now an error message put out by this test. Please fix the error before we close this bug. Linux, master, local server. Do steps above. When you turn visibility on for the sphere, you get the following error prints: ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 0 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 324 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 336 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 ERROR: In /projects/viz/paraview/src/ParaView/4.2.0-alan2/ParaView4/ParaViewCore/ServerManager/Core/vtkSMArrayListDomain.cxx, line 312 vtkSMRepresentedArrayListDomain (0x3472220): Index out of range: 1 |
(0033094) Alan Scott (manager) 2014-07-25 15:51 |
This bug is fixed. Tested Linux, local server, master. Moved the error listed in the notes to another bug. Closing this one. |
2014-06-30 16:39 | Burlen | New Issue | |
2014-06-30 16:40 | Burlen | Description Updated | |
2014-06-30 16:41 | Burlen | Description Updated | |
2014-06-30 16:44 | Burlen | Product Version | => 4.1 |
2014-06-30 16:44 | Burlen | Description Updated | |
2014-07-09 16:21 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-07-09 16:21 | Utkarsh Ayachit | Product Version | 4.1 => 4.2 |
2014-07-21 15:09 | Utkarsh Ayachit | Topic Name | => 14834_fix_representation_update |
2014-07-21 15:09 | Utkarsh Ayachit | Note Added: 0033047 | |
2014-07-21 15:09 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-21 15:09 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-07-21 15:09 | Utkarsh Ayachit | Resolution | open => fixed |
2014-07-22 08:32 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-07-22 08:32 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-22 08:32 | Utkarsh Ayachit | Note Added: 0033060 | |
2014-07-24 21:11 | Alan Scott | Note Added: 0033083 | |
2014-07-25 15:50 | Alan Scott | Relationship added | related to 0014888 |
2014-07-25 15:51 | Alan Scott | Note Added: 0033094 | |
2014-07-25 15:51 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 8cb28017 |
2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 94fdffe4 |
