0014836 | ParaView | (No Category) | public | 2014-07-01 06:36 | 2016-08-12 09:59 | ||||
Reporter | h0dges | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014836: Paraview Error when Resampling Dataset | ||||||||
Description | In order to get an even distribution of glyphs with a density smaller than the model mesh I followed the instructions here: http://www.cfd-online.com/Forums/openfoam/77056-evenly-distributed-arrows-using-glyph-paraview.html#post262607 [^] However when I try to follow this procedure with the VTK file (attached), I run into this error message described here: http://www.cfd-online.com/Forums/openfoam/77056-evenly-distributed-arrows-using-glyph-paraview.html#post499341 [^] | ||||||||
Project | TBD | ||||||||
Attached Files | mag01.vts [^] (875,201 bytes) 2014-07-01 06:36 | ||||||||
(0033050) h0dges (reporter) 2014-07-22 07:02 |
I have resolved this issue. I got confused by the non-intuitive interface. The radio selector should be replaced with two list boxes: One for 'Inputs' and one for 'Sources'. Or: Select Input: [list] > Next Select Source [list] > Back | OK |
(0038588) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-01 06:36 | h0dges | New Issue | |
2014-07-01 06:36 | h0dges | File Added: mag01.vts | |
2014-07-22 07:02 | h0dges | Note Added: 0033050 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038588 | |
