0014848 | ParaView | (No Category) | public | 2014-07-08 20:00 | 2015-01-11 08:16 | ||||
Summary | 0014848: Properties, blocks select, ctrl and shift doesn't work | ||||||||
Description | We have lost the functionality of <ctrl> and <shift> when selecting blocks. This needs to be fixed for 4.2, since it makes dealing with large numbers of blocks impossible. * Linux, master, local server. * Open bake.e. All vars on. Apply. (You can replicate with can.exo, it shows the problem but not the necessity.) * Now, unselect blocks numbers 10 through 50, and odd blocks from 53 through 70. What should happen is that you can <ctrl> click on the numerous blocks, highlighting them, and then toggle all of them. Much more important, you should be able to click on a block highlighting it (10 above), <shift> click on 50 - highlighting them all, and then toggle all of them. This was working a few years ago, but hasn't worked in the last year or so. A user asked why it had gone away... Ask Utkarsh or me for bake.e. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14848_fix_mutlselection | ||||||||
(0033127) Utkarsh Ayachit (administrator) 2014-07-29 10:50 |
Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Jul 29 10:48:52 2014 -0400 BUG $14848: Fix multi-selection in "Blocks" widget. You can now select multiple rows and the right click to check/uncheck the selection. Change-Id: Id302f586bd2c2815fd6f961af2e8e275ef1cc220 |
(0033170) Utkarsh Ayachit (administrator) 2014-07-31 09:00 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 14599_fix_double_range_issues 14789_fix_border 14831_log_scaling_crash 14848_fix_mutlselection appdata-file catalyst-dependencies catalyst-kits compilation_issue_processxml excess-moc-wrapping fix-cache-doc fix-catalyst-python kit-libraries (VTK) newest-xdmf pass_connectid_to_autompi remove-mpi4py (VTK) update-vtk-20140729 --------------------------------------------- Topics reverted from next: 14813_fix_mode_shapes_range fix_proxy_widget_dialog_apply pvweb-fixes |
(0033260) Alan Scott (manager) 2014-08-19 18:12 |
Tested local server, Linux, master. |
2014-07-08 20:00 | Alan Scott | New Issue | |
2014-07-08 20:01 | Alan Scott | Target Version | => 4.2 |
2014-07-29 10:50 | Utkarsh Ayachit | Topic Name | => 14848_fix_mutlselection |
2014-07-29 10:50 | Utkarsh Ayachit | Note Added: 0033127 | |
2014-07-29 10:50 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-07-29 10:50 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-07-29 10:50 | Utkarsh Ayachit | Resolution | open => fixed |
2014-07-29 10:50 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-07-31 08:59 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-07-31 09:00 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-07-31 09:00 | Utkarsh Ayachit | Note Added: 0033170 | |
2014-08-19 18:12 | Alan Scott | Note Added: 0033260 | |
2014-08-19 18:12 | Alan Scott | Status | customer review => closed |
2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b3ba47ce |
2015-01-11 08:16 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master e4516efd |
