0014869 | ParaView | (No Category) | public | 2014-07-16 15:55 | 2016-08-12 09:59 | ||||
Reporter | Matthew Woehlke | ||||||||
Summary | 0014869: paraview cannot load plugin | ||||||||
Description | Well designed build systems use -fvisibility=hidden to build (where that is appropriate, e.g. gcc, clang). Unfortunately, vtkPVPlugin.h does not correctly define its ABI export symbol (C_EXPORT), which causes ParaView to be unable to load any plugins build by a well-behaved build system, unless the build adds -fvisibility=default to the COMPILE_FLAGS of ${PLUGIN_BINARY_DIR}/${PLUGINNAME}_Plugin.cxx. C_EXPORT should be defined to include '__attribute__ ((visibility("default")))' (see e.g. generate_export_header). Since add_paraview_plugin is already calling this, perhaps the easiest fix is to remove (or at least make condition on not being already defined) the definition of C_EXPORT from vtkPVPlugin.h and instead add to the generated ${PLUGINNAME}_Plugin.h to define this to the plugin's ABI export symbol prior to including vtkPVPlugin.h. | ||||||||
Project | TBD | ||||||||
(0038601) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-07-16 15:55 | Matthew Woehlke | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038601 | |
