0014943 | ParaView | (No Category) | public | 2014-08-15 15:32 | 2015-01-02 10:43 | ||||
Assigned To | Dan Lipsa | ||||||||
Target Version | 4.3 | Fixed in Version | 4.3 | ||||||
Summary | 0014943: Allow uints, floats and doubles to be used by un - Map Scalars | ||||||||
Description | Please allow the "Map Scalars" functionality, when unselected, to use uint32's, floats and doubles. Some formats, such as Exodus, don't even allow non floating point variables. Furthermore, the only output that the calculator puts out is doubles! You should be able to test this using disk_out_ref.exo, variable V. Be sure to use the calculator to scale it to 0.0 to 1.0. | ||||||||
Additional Information | VTK commits =========== commit 2d61deaa1bcf9f9fd6806b1c40d2f23bdad8dfbd Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Dec 1 13:50:40 2014 -0500 Add a test for VTK_COLOR_MODE_DIRECT_SCALARS Change-Id: I9ddbc050bd4cdb0c9dafaed55dd427b84f8a551c commit 00de9a942ff74e797fbe4cd8c67307c8065cdade Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Thu Nov 20 13:35:35 2014 -0500 Add VTK_COLOR_MODE_DIRECT_SCALARS. See vtkScalarsToColors::MapScalars. Change-Id: I0fa7d8dde623b19204397d259e0c63f7d5bc4b66 ParaView commits ================ commit 534490e6642fb4764bd35bfdea53178fd750c855 Author: Dan Lipsa <dan.lipsa@kitware.com> Date: Mon Nov 24 14:05:03 2014 -0500 vtkGeometryRepresentation::SetMapScalars(0) maps all scalar types. Change-Id: Ie1e6e1b16c00377aecce7b931785382e8cf4bd9b | ||||||||
Project | Sandia | ||||||||
Topic Name | map-scalars-14943 | ||||||||
(0033810) Utkarsh Ayachit (administrator) 2014-11-14 11:24 |
+ Add a new VTK_COLOR_MODE_DIRECT_SCALARS in addition to VTK_COLOR_MODE_DEFAULT, VTK_COLOR_MODE_MAP_SCALARS. + vtkScalarsToColors::MapScalars() (and maybe other places too) should respect this new mode to directly color using data arrays. + Update ParaView to pick this new mode instead of VTK_COLOR_MODE_DEFAULT when MapScalars checkbox is unchecked. |
(0033907) Utkarsh Ayachit (administrator) 2014-12-08 08:04 |
Topics merged into master (v4.2.0-231-g445a425): 0015171_camera_front_of_plane_widget 0015172_automatic_annotations (VTK) exodus-15127 fix-log-mark-labels fix-osx-fileinfo fix_pvscalarabar_warning genericio_reader_optimization include-missing-header linking-with-kits-enabled (VTK) map-scalars-14943 pvweb-fix-extract-block-bug pvweb-fix-incorrect-filter-name qt5-find-components |
(0033928) Alan Scott (manager) 2014-12-10 15:56 |
Excellent. Tested with disk_out_ref.exo. Calculator. Clip. In the calculator, used formula (Temp-290)*(1/650)*iHat+(Temp-290)*(1/650)*jHat+(Temp-290)*(1/650)*kHat. I then messed around changing (Temp-290)*(1/650) to 1. Tested remote server, Linux, master. |
2014-08-15 15:32 | Alan Scott | New Issue | |
2014-08-15 15:37 | Alan Scott | Target Version | => 4.3 |
2014-11-04 10:03 | Utkarsh Ayachit | Target Version | 4.3 => bug_fix |
2014-11-14 11:15 | Utkarsh Ayachit | Assigned To | => Dan Lipsa |
2014-11-14 11:24 | Utkarsh Ayachit | Note Added: 0033810 | |
2014-11-14 22:56 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2014-11-18 14:07 | Dan Lipsa | Status | backlog => active development |
2014-12-02 16:40 | Dan Lipsa | Topic Name | => map-scalars-14943 |
2014-12-02 16:40 | Dan Lipsa | Additional Information Updated | |
2014-12-03 11:27 | Dan Lipsa | Additional Information Updated | |
2014-12-05 10:13 | Dan Lipsa | Status | active development => gatekeeper review |
2014-12-08 08:03 | Utkarsh Ayachit | Fixed in Version | => git-master |
2014-12-08 08:04 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-12-08 08:04 | Utkarsh Ayachit | Note Added: 0033907 | |
2014-12-10 15:56 | Alan Scott | Note Added: 0033928 | |
2014-12-10 15:56 | Alan Scott | Status | customer review => closed |
2014-12-10 15:56 | Alan Scott | Resolution | open => fixed |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
