0014945 | ParaView | (No Category) | public | 2014-08-15 16:19 | 2015-09-06 12:18 | ||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0014945: Plot selection over time should produce quartile area plots | ||||||||
Description | When you do a plot selection over time, the resulting series are actually descriptive statistics over each field (min, max, average, quartiles, stddev, etc.). This is because a query often returns multiple values, so the descriptive statistics summarize everything to a single value. That makes sense, but the result of running the filter is this plot that blindly charts all these independent statistical values for all these independent fields, which usually results in an unreadable mess (such as reported in bug 0014940). We need a better way to present this data. I propose presenting this data in a quartile area plot. I think I made this name up (I don't know if they have a name), but the idea is that the average value is shown as a deeply colored line, the 2nd/3rd quartile is drawn under that as a muted area, and the min/max range is drawn under that as a more muted area. I have attached an example image of such a plot for one series. This is a much cleaner and more natural representation of the statistical data. It also has the great advantage where if the selection is returning one item per time step, the areas collapse to show that single deep line. That is, you are getting the exact line you were expecting in the first place. | ||||||||
Project | Sandia | ||||||||
Attached Files | QuartileAreaPlot.png [^] (30,987 bytes) 2014-08-15 16:19
Relationships | |||||||||||
(0033825) Alan Scott (manager) 2014-11-20 19:26 |
Set for 4.4, at Ken's request. |
(0034413) Utkarsh Ayachit (administrator) 2015-05-14 19:51 |
Merged in master. Here's the merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/87 [^] |
(0034473) Alan Scott (manager) 2015-06-04 15:55 |
Very nice. Notice I created a separate clean up bug, linked above. Tested master, Linux, local server. (Numpy is failing on my remote build). |
2014-08-15 16:19 | Ken Moreland | New Issue | |
2014-08-15 16:19 | Ken Moreland | File Added: QuartileAreaPlot.png | |
2014-08-15 16:20 | Ken Moreland | Relationship added | related to 0014940 |
2014-11-20 19:26 | Alan Scott | Project | TBD => Sandia |
2014-11-20 19:26 | Alan Scott | Note Added: 0033825 | |
2014-11-20 19:26 | Alan Scott | Target Version | => 4.4 |
2015-04-21 15:36 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-04-21 15:36 | Utkarsh Ayachit | Status | backlog => active development |
2015-05-14 19:51 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2015-05-14 19:51 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-05-14 19:51 | Utkarsh Ayachit | Resolution | open => fixed |
2015-05-14 19:51 | Utkarsh Ayachit | Note Added: 0034413 | |
2015-05-14 19:51 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-06-04 15:54 | Alan Scott | Relationship added | related to 0015512 |
2015-06-04 15:55 | Alan Scott | Note Added: 0034473 | |
2015-06-04 15:55 | Alan Scott | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
