0014980 | ParaView | (No Category) | public | 2014-09-01 07:22 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Product Version | 4.1 | ||||||||
Summary | 0014980: Scalar bar legend labels have not reliable behaviour for display | ||||||||
Description | In the "Color map editor", there is a dialog box "Edit color legend parameters". It allows to choose the number of labels that you want to show along the scalar bar legend by filling the field "Number Of Labels". But the number of the labels asked for the displaying doesn't correspond to the real number of the displayed labels. The behaviour is similar to the following: Number Of Labels = 1 --> 0 label is displayed Number Of Labels = 2 --> 1 label is displayed Number Of Labels = 3 to 5 --> 2 labels are displayed Number Of Labels = 6 to 14 --> 5 labels are displayed Number Of Labels = 15 to 23 --> 14 labels are displayed Number Of Labels = 24 to 29 --> 23 labels are displayed Number Of Labels = 30 to 59 --> 29 labels are displayed Number Of Labels => 60 OR = 0 --> 59 labels are displayed Could it be possible that the number of labels asked is exactly the number of labels displayed ? | ||||||||
Project | ParaViS | ||||||||
(0033308) Tristan Coulange (developer) 2014-09-04 11:25 edited on: 2014-09-04 11:26 |
Hello, Actually this number is the "Maximum number of labels", so it was renamed in ParaView 4.2. ParaView computes the real number of labels using this maximum, and in most cases it is not the same. For now, the only way to set an exact number of labels is the "Annotation" functionality: - Open the "Color Map Editor" panel - Click on the "Advanced properties" button - At the bottom of the panel there is a table in which you can add Annotations - Then you can show/hide them in the "Edit Color Legend Parameters" panel This is not user-friendly but it works. If you want we can develop an improvement of this functionality to create automatically these Annotations from a number of Annotations and a range defined by the user. The development is estimated at about 3 days. What do you think about this? Tristan |
(0034222) Tristan Coulange (developer) 2015-02-17 07:48 |
The improvement is done and merged into master: http://review.source.kitware.com/#/c/18227/ [^] Add a PV scalar bar option to automatically generate annotations. The option allows to automatically create annotations at the boundary of two dicreet colors. This allows to see the bounds each color represents when working with a small amount of colors. Change-Id: I73096651406f21d01d58ae8ce57fea69557f1256 |
(0038648) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-09-01 07:22 | Vadim SANDLER | New Issue | |
2014-09-01 07:22 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2014-09-04 11:25 | Tristan Coulange | Note Added: 0033308 | |
2014-09-04 11:26 | Tristan Coulange | Note Edited: 0033308 | |
2015-02-17 07:48 | Tristan Coulange | Note Added: 0034222 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038648 | |
