0014992ParaView(No Category)public2014-09-11 10:282016-08-12 09:59
ReporterCory Quammen
Assigned ToCory Quammen
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version4.2
Summary0014992: vtkSMDomain::SetDefaultValues() overrides custom setting defaults in some cases
DescriptionIn particular, this makes it impossible to set the default representation type for GeometryRepresentation with the following JSON:
   "representations" : {
      "GeometryRepresentation" : {
         "Representation" : "Surface With Edges"
The reason is that custom default values are set prior to domains being reset. Some domains, such as vtkSMBooleanDomain, do nothing in SetDefaultValues(). Others, such as vtkSMRepresentationTypeDomain, change property values.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0038654)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2014-09-11 10:28 Cory Quammen New Issue
2014-09-11 10:28 Cory Quammen Assigned To => Cory Quammen
2016-08-12 09:59 Kitware Robot Note Added: 0038654
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
